[geos-commits] [SCM] GEOS branch 3.8 updated. 17110ec835b9f1f61d45fce37c00f574e640e195
git at osgeo.org
git at osgeo.org
Mon Mar 9 18:25:56 PDT 2020
the project "GEOS".
The branch, 3.8 has been updated
via 17110ec835b9f1f61d45fce37c00f574e640e195 (commit)
via 7af76085fcfa21f88d6508eb9b2ef523850f0dd0 (commit)
via f3fd71cf00f0407aa24710458c9677f7637caa61 (commit)
from 07ad79c5ad48095aa2822668a2bc15085875eb52 (commit)
revisions in full, below.
commit 17110ec835b9f1f61d45fce37c00f574e640e195
Author: Dan Baston <dbaston at gmail.com>
Date: Mon Mar 2 13:27:07 2020 -0500
NEWS update
diff --git a/NEWS b/NEWS
index b634f11..f5aa0b0 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
Changes in 3.8.1
-2019-xx-xx
+2020-xx-xx
- Bug fixes / improvements
- Stack allocate line segments in OverlapUnion (Paul Ramsey)
@@ -10,6 +10,8 @@ Changes in 3.8.1
- Improve performance of GEOSisValid (#1008, Dan Baston)
- Avoid changing MultiLineString component order in GEOSReverse
(#1013, Dan Baston)
+ - Fix missing vtable for LineString and CoordinateArraySequenceFactory
+ (#299 and #1016, Evgen Bodunov)
Changes in 3.8.0
2019-10-10
commit 7af76085fcfa21f88d6508eb9b2ef523850f0dd0
Date: Mon Mar 2 13:20:28 2020 -0500
Add test showing LineString vtable creation
References https://github.com/libgeos/geos/issues/285
References #1016
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index 2adffdb..6873371 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -512,5 +512,20 @@ void object::test<28>
ensure(geo->isDimensionStrict(geos::geom::Dimension::L));
ensure(!geo->isDimensionStrict(geos::geom::Dimension::A));
+// test dynamic_cast for LineString (shows that vtable is created)
+// https://github.com/libgeos/geos/issues/285
+template<>
+template<>
+void object::test<29>
+ std::unique_ptr<geos::geom::LineString> a = geos::geom::GeometryFactory::getDefaultInstance()->createLineString();
+ geos::geom::Geometry *b = a.get(); // ok
+ geos::geom::LineString *c = dynamic_cast<geos::geom::LineString *>(b);
+ ensure(c != nullptr);
} // namespace tut
commit f3fd71cf00f0407aa24710458c9677f7637caa61
Author: Evgen Bodunov <evgen at getyourmap.com>
Date: Thu Feb 27 17:59:40 2020 +0300
Fixed https://trac.osgeo.org/geos/ticket/894 and https://github.com/libgeos/geos/issues/285
To have a vtable we should have explicit definition of key function. Details: https://lld.llvm.org/missingkeyfunction.html#missing-key-function
diff --git a/include/geos/geom/CoordinateArraySequenceFactory.inl b/include/geos/geom/CoordinateArraySequenceFactory.inl
index 761fdc6..e36a313 100644
--- a/include/geos/geom/CoordinateArraySequenceFactory.inl
+++ b/include/geos/geom/CoordinateArraySequenceFactory.inl
@@ -23,14 +23,6 @@ namespace geos {
namespace geom { // geos::geom
INLINE std::unique_ptr<CoordinateSequence>
-CoordinateArraySequenceFactory::create() const
- return std::unique_ptr<CoordinateSequence>(
- new CoordinateArraySequence(
- reinterpret_cast<std::vector<Coordinate>*>(0), 0));
-INLINE std::unique_ptr<CoordinateSequence>
CoordinateArraySequenceFactory::create(std::vector<Coordinate>* coords,
size_t dimension) const
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index 6ed0348..0316d62 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
@@ -74,7 +74,7 @@ public:
/// A vector of const LineString pointers
typedef std::vector<const LineString*> ConstVect;
- ~LineString() override = default;
+ ~LineString() override;
* \brief
diff --git a/src/geom/CoordinateArraySequenceFactory.cpp b/src/geom/CoordinateArraySequenceFactory.cpp
index decd6bd..ab0a6e8 100644
--- a/src/geom/CoordinateArraySequenceFactory.cpp
+++ b/src/geom/CoordinateArraySequenceFactory.cpp
@@ -25,6 +25,14 @@ namespace geom { // geos::geom
static CoordinateArraySequenceFactory defaultCoordinateSequenceFactory;
+std::unique_ptr<CoordinateSequence>
+CoordinateArraySequenceFactory::create() const
+ return std::unique_ptr<CoordinateSequence>(
+ new CoordinateArraySequence(
+ reinterpret_cast<std::vector<Coordinate>*>(0), 0));
const CoordinateSequenceFactory*
CoordinateArraySequenceFactory::instance()
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index cfcbb2b..65f86a0 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -45,6 +45,8 @@ using namespace geos::algorithm;
namespace geos {
+LineString::~LineString(){};
/*protected*/
LineString::LineString(const LineString& ls)
diff --git a/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp b/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp
index caea683..a69413c 100644
--- a/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp
+++ b/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp
@@ -52,10 +52,8 @@ void object::test<1>
ensure(nullptr != derived);
ensure(typeid(derived).name(), typeid(derived) == typeid(CoordinateArrayFactoryCPtr));
- catch(std::exception& /* e */) {
- /** ignore failure. TODO figure out why this fails on BSD/Clang
- * https://trac.osgeo.org/geos/ticket/894 and then put back**/
- //fail( e.what() );
+ catch(std::exception& e) {
+ fail( e.what() );
Summary of changes:
NEWS | 4 +++-
include/geos/geom/CoordinateArraySequenceFactory.inl | 8 --------
include/geos/geom/LineString.h | 2 +-
src/geom/CoordinateArraySequenceFactory.cpp | 8 ++++++++
src/geom/LineString.cpp | 2 ++
tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp | 6 ++----
tests/unit/geom/LineStringTest.cpp | 15 +++++++++++++++
7 files changed, 31 insertions(+), 14 deletions(-)
hooks/post-receive
More information about the geos-commits
