[geos-commits] [SCM] GEOS branch master updated. 7732d9b6339e4b75b567cc0f5e33d753c5a9f528
git at osgeo.org
git at osgeo.org
Tue Mar 24 11:17:31 PDT 2020
the project "GEOS".
via 7732d9b6339e4b75b567cc0f5e33d753c5a9f528 (commit)
from 14b98cfd8fd72834f82e623910b413824ef33d7e (commit)
revisions in full, below.
commit 7732d9b6339e4b75b567cc0f5e33d753c5a9f528
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Mar 24 10:30:37 2020 -0700
Fix buffer fillet generation to avoid extra segments JTS-526, https://trac.osgeo.org/geos/ticket/743
diff --git a/include/geos/operation/buffer/OffsetSegmentGenerator.h b/include/geos/operation/buffer/OffsetSegmentGenerator.h
index 97b53b2..56e1d8c 100644
--- a/include/geos/operation/buffer/OffsetSegmentGenerator.h
+++ b/include/geos/operation/buffer/OffsetSegmentGenerator.h
@@ -329,7 +329,7 @@ private:
* @param direction the orientation of the fillet
* @param radius the radius of the fillet
- void addFillet(const geom::Coordinate& p, const geom::Coordinate& p0,
+ void addDirectedFillet(const geom::Coordinate& p, const geom::Coordinate& p0,
const geom::Coordinate& p1,
int direction, double radius);
@@ -342,7 +342,7 @@ private:
* @param direction is -1 for a CW angle, 1 for a CCW angle
- void addFillet(const geom::Coordinate& p, double startAngle,
+ void addDirectedFillet(const geom::Coordinate& p, double startAngle,
double endAngle, int direction, double radius);
private:
// An OffsetSegmentGenerator cannot be copied because of member "const BufferParameters& bufParams"
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 06f1634..26fbfec 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -207,7 +207,7 @@ OffsetSegmentGenerator::addLineEndCap(const Coordinate& p0, const Coordinate& p1
case BufferParameters::CAP_ROUND:
// add offset seg points with a fillet between them
segList.addPt(offsetL.p1);
- addFillet(p1, angle + PI / 2.0, angle - PI / 2.0,
+ addDirectedFillet(p1, angle + PI / 2.0, angle - PI / 2.0,
Orientation::CLOCKWISE, distance);
segList.addPt(offsetR.p1);
break;
@@ -237,7 +237,7 @@ OffsetSegmentGenerator::addLineEndCap(const Coordinate& p0, const Coordinate& p1
/*private*/
void
-OffsetSegmentGenerator::addFillet(const Coordinate& p, const Coordinate& p0,
+OffsetSegmentGenerator::addDirectedFillet(const Coordinate& p, const Coordinate& p0,
const Coordinate& p1, int direction, double radius)
double dx0 = p0.x - p.x;
@@ -259,14 +259,14 @@ OffsetSegmentGenerator::addFillet(const Coordinate& p, const Coordinate& p0,
segList.addPt(p0);
- addFillet(p, startAngle, endAngle, direction, radius);
+ addDirectedFillet(p, startAngle, endAngle, direction, radius);
segList.addPt(p1);
/*private*/
void
-OffsetSegmentGenerator::addFillet(const Coordinate& p, double startAngle,
- double endAngle, int direction, double radius)
+OffsetSegmentGenerator::addDirectedFillet(const Coordinate& p, double startAngle,
+ double endAngle, int direction, double radius)
int directionFactor = direction == Orientation::CLOCKWISE ? -1 : 1;
@@ -274,28 +274,19 @@ OffsetSegmentGenerator::addFillet(const Coordinate& p, double startAngle,
int nSegs = (int)(totalAngle / filletAngleQuantum + 0.5);
// no segments because angle is less than increment-nothing to do!
- if(nSegs < 1) {
- return;
- double initAngle, currAngleInc;
+ if(nSegs < 1) return;
- // choose angle increment so that each segment has equal length
- initAngle = 0.0;
- currAngleInc = totalAngle / nSegs;
- double currAngle = initAngle;
+ // double initAngle, currAngleInc;
+ double angleInc = totalAngle / nSegs;
Coordinate pt;
- while(currAngle < totalAngle) {
- double angle = startAngle + directionFactor * currAngle;
+ for (int i = 0; i < nSegs; i++) {
+ double angle = startAngle + directionFactor * i * angleInc;
pt.x = p.x + radius * cos(angle);
pt.y = p.y + radius * sin(angle);
segList.addPt(pt);
- currAngle += currAngleInc;
/*private*/
void
OffsetSegmentGenerator::createCircle(const Coordinate& p, double p_distance)
@@ -303,7 +294,7 @@ OffsetSegmentGenerator::createCircle(const Coordinate& p, double p_distance)
// add start point
Coordinate pt(p.x + p_distance, p.y);
segList.addPt(pt);
- addFillet(p, 0.0, 2.0 * PI, -1, p_distance);
+ addDirectedFillet(p, 0.0, 2.0 * PI, -1, p_distance);
segList.closeRing();
@@ -354,7 +345,7 @@ OffsetSegmentGenerator::addCollinear(bool addStartPoint)
segList.addPt(offset1.p0);
else {
- addFillet(s1, offset0.p1, offset1.p0,
+ addDirectedFillet(s1, offset0.p1, offset1.p0,
@@ -392,7 +383,7 @@ OffsetSegmentGenerator::addOutsideTurn(int orientation, bool addStartPoint)
// TESTING - comment out to produce beveled joins
- addFillet(s1, offset0.p1, offset1.p0, orientation, distance);
+ addDirectedFillet(s1, offset0.p1, offset1.p0, orientation, distance);
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index d8599bf..cef4333 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -117,7 +117,7 @@ void object::test<3>
ensure_not(gBuffer->isEmpty());
ensure(gBuffer->isValid());
ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
- ensure(gBuffer->getNumPoints() > std::size_t(129));
+ ensure(gBuffer->getNumPoints() >= std::size_t(129));
template<>
@@ -143,7 +143,7 @@ void object::test<4>
- ensure(gBuffer->getNumPoints() >= std::size_t(245));
+ ensure(gBuffer->getNumPoints() >= std::size_t(243));
// Buffer point with custom parameters: 32 quadrant segments
@@ -156,7 +156,7 @@ void object::test<4>
- ensure(gBuffer->getNumPoints() >= std::size_t(318));
+ ensure(gBuffer->getNumPoints() >= std::size_t(317));
@@ -367,5 +367,32 @@ MULTILINESTRING( \
ensure_equals(int(gBuffer->getArea()), 3520);
+template<>
+template<>
+void object::test<12>
+ using geos::operation::buffer::BufferOp;
+ using geos::operation::buffer::BufferParameters;
+ std::string wkt0("POINT(100 100)");
+ GeomPtr g0(wktreader.read(wkt0));
+ // Buffer point with custom parameters: 32 quadrant segments
+ int const segments = 53;
+ int expected_segments = 4 * segments + 1;
+ BufferParameters params(segments);
+ BufferOp op(g0.get(), params);
+ double const distance = 80.0;
+ GeomPtr gBuffer(op.getResultGeometry(distance));
+ ensure_not(gBuffer->isEmpty());
+ ensure(gBuffer->isValid());
+ ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
+ ensure(gBuffer->getNumPoints() >= std::size_t(expected_segments));
} // namespace tut
Summary of changes:
.../geos/operation/buffer/OffsetSegmentGenerator.h | 4 +--
src/operation/buffer/OffsetSegmentGenerator.cpp | 35 ++++++++--------------
tests/unit/operation/buffer/BufferOpTest.cpp | 33 ++++++++++++++++++--
3 files changed, 45 insertions(+), 27 deletions(-)
hooks/post-receive
More information about the geos-commits
