[geos-commits] [SCM] GEOS branch master updated. 1539ef17c42541ffb0d69b56ba80a03618bafdc2
git at osgeo.org
git at osgeo.org
Mon Nov 2 06:19:20 PST 2020
the project "GEOS".
via 1539ef17c42541ffb0d69b56ba80a03618bafdc2 (commit)
from 708d32b2cd2dd3bedc38ff1d839368656b1f9626 (commit)
revisions in full, below.
commit 1539ef17c42541ffb0d69b56ba80a03618bafdc2
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Nov 2 12:25:11 2020 +0100
Avoid crash from IndexedFacetDistance with empty input
Closes #1065
Include test
diff --git a/src/operation/distance/FacetSequenceTreeBuilder.cpp b/src/operation/distance/FacetSequenceTreeBuilder.cpp
index 7ce3e8a..b737810 100644
--- a/src/operation/distance/FacetSequenceTreeBuilder.cpp
+++ b/src/operation/distance/FacetSequenceTreeBuilder.cpp
@@ -73,6 +73,7 @@ FacetSequenceTreeBuilder::addFacetSequences(const Geometry* geom, const Coordina
size_t i = 0;
size_t size = pts->size();
+ if ( size == 0 ) return;
while(i <= size - 1) {
size_t end = i + FACET_SEQUENCE_SIZE + 1;
diff --git a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
index aed155a..b2e0a08 100644
--- a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
+++ b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
@@ -11,6 +11,7 @@
// tut
#include <tut/tut.hpp>
+#include <tut/tut_macros.hpp>
// geos
#include <geos/profiler.h>
#include <geos/constants.h>
@@ -26,6 +27,7 @@
#include <geos/io/WKTWriter.h>
#include <geos/operation/distance/DistanceOp.h>
#include <geos/operation/distance/IndexedFacetDistance.h>
+#include <geos/util/GEOSException.h>
#ifndef M_PI
#define M_PI 3.14159265358979323846
@@ -336,6 +338,34 @@ void object::test<10>
+// EMPTY polygon
+template<>
+template<>
+void object::test<11>
+ using geos::operation::distance::IndexedFacetDistance;
+ using geos::util::GEOSException;
+ std::string wkt0("POLYGON EMPTY");
+ std::string wkt1("POINT(150 150)");
+ GeomPtr g0(_wktreader.read(wkt0));
+ GeomPtr g1(_wktreader.read(wkt1));
+ IndexedFacetDistance ifd(g0.get());
+ try {
+ ifd.distance(g1.get());
+ fail("IndexedFacedDistance::distance did not throw on empty input");
+ catch (const GEOSException&) { }
+ try {
+ ifd.nearestPoints(g1.get());
+ fail("IndexedFacedDistance::nearestPoints did not throw on empty input");
// TODO: finish the tests by adding:
Summary of changes:
.../distance/FacetSequenceTreeBuilder.cpp | 1 +
.../distance/IndexedFacetDistanceTest.cpp | 30 ++++++++++++++++++++++
2 files changed, 31 insertions(+)
hooks/post-receive
More information about the geos-commits
