[geos-commits] [SCM] GEOS branch master updated. 2a0e6675221a3e0d21bfd32313c24ec159814bba
git at osgeo.org
git at osgeo.org
Tue Nov 3 13:49:28 PST 2020
the project "GEOS".
via 2a0e6675221a3e0d21bfd32313c24ec159814bba (commit)
via 1198e06ef656ffdce71d1a3bc6e65cd146056677 (commit)
via 6a0cb9e5abdd3e76bfbb807c7bb3f99bfbfe7520 (commit)
from b03d45bf4c7bf55c087260728579e656d2299bf7 (commit)
revisions in full, below.
commit 2a0e6675221a3e0d21bfd32313c24ec159814bba
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Nov 3 13:40:33 2020 -0800
Add QuadEdge output
diff --git a/include/geos/triangulate/quadedge/QuadEdge.h b/include/geos/triangulate/quadedge/QuadEdge.h
index 51513bb..44e4911 100644
--- a/include/geos/triangulate/quadedge/QuadEdge.h
+++ b/include/geos/triangulate/quadedge/QuadEdge.h
@@ -436,10 +436,10 @@ public:
std::unique_ptr<geom::LineSegment> toLineSegment() const;
+GEOS_DLL std::ostream& operator<< (std::ostream& os, const QuadEdge* e);
} //namespace geos.triangulate.quadedge
} //namespace geos
#endif //GEOS_TRIANGULATE_QUADEDGE_QUADEDGE_H
diff --git a/src/triangulate/quadedge/QuadEdge.cpp b/src/triangulate/quadedge/QuadEdge.cpp
index 344c6ec..c692580 100644
--- a/src/triangulate/quadedge/QuadEdge.cpp
+++ b/src/triangulate/quadedge/QuadEdge.cpp
@@ -118,7 +118,13 @@ QuadEdge::toLineSegment() const
new geom::LineSegment(vertex.getCoordinate(), dest().getCoordinate()));
+std::ostream&
+operator<< (std::ostream& os, const QuadEdge* e)
+ os << "( " << e->orig().getCoordinate() << ", " << e->dest().getCoordinate() << " )";
+ return os;
} //namespace goes
commit 1198e06ef656ffdce71d1a3bc6e65cd146056677
Date: Tue Nov 3 13:38:04 2020 -0800
Simplify logic for edge erase-remove
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index 6629002..14c07fa 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -133,11 +133,8 @@ QuadEdgeSubdivision::remove(QuadEdge& e)
// rot edges do not need to be tested because they are not removed
quadEdges.erase(
std::remove_if(quadEdges.begin(), quadEdges.end(),
- [e](QuadEdgeQuartet& es) { return &es.base() == &e; }),
- quadEdges.end());
- quadEdges.erase(
- std::remove_if(quadEdges.begin(), quadEdges.end(),
- [e](QuadEdgeQuartet& es) { return &es.base() == &e.sym(); }),
+ [e](QuadEdgeQuartet& es) {
+ return &es.base() == &e || &es.base() == &e.sym(); }),
quadEdges.end());
//mark these edges as removed
e.remove();
commit 6a0cb9e5abdd3e76bfbb807c7bb3f99bfbfe7520
Date: Tue Nov 3 13:14:23 2020 -0800
Fix QuadEdgeSubdivision remove method
index 1a4e249..6629002 100644
@@ -129,11 +129,16 @@ QuadEdgeSubdivision::remove(QuadEdge& e)
QuadEdge::splice(e.sym(), e.sym().oPrev());
// this is inefficient but this should be called infrequently
+ // check base edge against both edge and sym, since either may be removed
+ // rot edges do not need to be tested because they are not removed
quadEdges.erase(
- [&e](QuadEdgeQuartet& es) { return &es.base() == &e; }),
+ [e](QuadEdgeQuartet& es) { return &es.base() == &e; }),
+ quadEdges.end());
+ quadEdges.erase(
+ std::remove_if(quadEdges.begin(), quadEdges.end(),
+ [e](QuadEdgeQuartet& es) { return &es.base() == &e.sym(); }),
quadEdges.end());
e.remove();
diff --git a/tests/unit/triangulate/DelaunayTest.cpp b/tests/unit/triangulate/DelaunayTest.cpp
index aa8b168..50ff9df 100644
--- a/tests/unit/triangulate/DelaunayTest.cpp
+++ b/tests/unit/triangulate/DelaunayTest.cpp
@@ -227,6 +227,34 @@ void object::test<10>
+// 11 - Regular grid of points, tol = 0 (see https://trac.osgeo.org/geos/ticket/1035)
+template<>
+template<>
+void object::test<11>
+ const char* wkt =
+"MULTIPOINT ((-10 40), (5 40), (20 40), (-10 55), (5 55), (20 55), (-10 70), (5 70), (20 70))";
+ const char* expectedEdges =
+ "GEOMETRYCOLLECTION (POLYGON ((5 70, 20 70, 20 55, 5 70)), POLYGON ((5 55, 20 55, 20 40, 5 55)), POLYGON ((5 55, 5 70, 20 55, 5 55)), POLYGON ((5 40, 5 55, 20 40, 5 40)), POLYGON ((-10 70, 5 70, 5 55, -10 70)), POLYGON ((-10 55, 5 55, 5 40, -10 55)), POLYGON ((-10 55, -10 70, 5 55, -10 55)), POLYGON ((-10 40, -10 55, 5 40, -10 40)))";
+ if(sizeof(long double) > sizeof(double)) {
+ runDelaunay(wkt, true, expectedEdges, 0.0);
-} // namespace tut
+// 12 - Regular grid of points, tol > 0 (see https://trac.osgeo.org/geos/ticket/1035)
+template<>
+template<>
+void object::test<12>
+ const char* wkt =
+ runDelaunay(wkt, true, expectedEdges, 0.01);
+} // namespace tut
Summary of changes:
include/geos/triangulate/quadedge/QuadEdge.h | 2 +-
src/triangulate/quadedge/QuadEdge.cpp | 8 ++++++-
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 6 +++--
tests/unit/triangulate/DelaunayTest.cpp | 30 +++++++++++++++++++++++-
4 files changed, 41 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
