[geos-commits] [SCM] GEOS branch master updated. 4ad366c6c2d6c609a84434793fe8fc106298a4db
git at osgeo.org
git at osgeo.org
Tue Nov 3 15:04:21 PST 2020
the project "GEOS".
via 4ad366c6c2d6c609a84434793fe8fc106298a4db (commit)
from f7be9fe7da9e6eb549f50a68bb9f4a990ffb0d95 (commit)
revisions in full, below.
commit 4ad366c6c2d6c609a84434793fe8fc106298a4db
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Nov 3 15:04:17 2020 -0800
Add GitHub Actions recipe in preparation for the loss of Travis
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
new file mode 100644
index 0000000..2007c7f
--- /dev/null
+++ b/.github/workflows/ci.yml
@@ -0,0 +1,113 @@
+# GitHub Actions for GEOS
+# Paul Ramsey <pramsey at cleverelephant dot ca>
+# Based on AZP configuration by Mateusz Loskot <mateusz at loskot dot net>
+name: CI
+on: [push, pull_request]
+env:
+ BUILD_TYPE: 'Release'
+ MAKEFLAGS: '-j2'
+jobs:
+ linux:
+ name: 'Linux'
+ strategy:
+ matrix:
+ ci:
+ compiler: g++,
+ build: cmake,
+ cxxstd: 11,
+ arch: 64,
+ packages: 'g++ cmake doxygen',
+ os: ubuntu-18.04
+ compiler: g++,
+ build: autotools,
+ cxxstd: 11,
+ arch: 64,
+ packages: 'g++ automake doxygen git2cl',
+ os: ubuntu-18.04
+ compiler: g++,
+ build: autotools,
+ cxxstd: 11,
+ arch: 32,
+ packages: 'g++-4.8-multilib gcc-4.8-multilib g++-multilib gcc-multilib doxygen automake git2cl',
+ os: ubuntu-18.04
+ compiler: clang++,
+ build: cmake,
+ cxxstd: 11,
+ arch: 64,
+ packages: 'clang cmake doxygen',
+ os: ubuntu-18.04
+ compiler: g++,
+ build: cmake,
+ cxxstd: 11,
+ arch: 64,
+ os: ubuntu-20.04
+ build: cmake,
+ cxxstd: 11,
+ arch: 64,
+ os: ubuntu-16.04
+ build: cmake,
+ cxxstd: 14,
+ arch: 64,
+ os: ubuntu-20.04
+ runs-on: ${{ matrix.ci.os }}
+ steps:
+ - name: 'Install'
+ run: |
+ set -e
+ uname -a
+ sudo -E apt-get update
+ sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make ${{ matrix.ci.packages }}
+ - name: 'Check Out'
+ uses: actions/checkout at v2
+ - name: 'Build'
+ run: |
+ set -e
+ if [ ${{ matrix.ci.build }} == 'cmake' ];
+ then
+ mkdir build.cmake
+ cd build.cmake
+ cmake --version
+ cmake -DCMAKE_CXX_COMPILER=${{ matrix.ci.compiler }} -DCMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} -DBUILD_DOCUMENTATION=YES -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+ make
+ cmake --build . --target docs
+ ctest --output-on-failure .
+ else
+ set -e
+ ./autogen.sh
+ mkdir build.autotools
+ cd build.autotools
+ CFLAGS="-std=c++${{ matrix.ci.cxxstd }} -m${{ matrix.ci.arch }}"
+ ../configure CC=${{ matrix.ci.compiler }} CXX=${{ matrix.ci.compiler }} CXXFLAGS="$CFLAGS" CFLAGS="$CFLAGS"
+ make && make check && make distcheck
+ fi
diff --git a/tests/geostest/geostest.c b/tests/geostest/geostest.c
index fbce49d..95db390 100644
--- a/tests/geostest/geostest.c
+++ b/tests/geostest/geostest.c
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
* Author: Sandro Santilli <strk at kbt.io>
@@ -36,7 +36,7 @@ notice(const char *fmt, ...) {
va_list ap;
fprintf( stdout, "NOTICE: ");
va_start (ap, fmt);
vfprintf( stdout, fmt, ap);
va_end(ap);
@@ -48,7 +48,7 @@ log_and_exit(const char *fmt, ...) {
va_list ap;
fprintf( stdout, "ERROR: ");
va_start (ap, fmt);
va_end(ap);
@@ -56,7 +56,7 @@ log_and_exit(const char *fmt, ...) {
exit(1);
-GEOSGeometry*
+GEOSGeometry*
fineGrainedReconstructionTest(const GEOSGeometry* g1)
GEOSCoordSequence* cs;
@@ -91,7 +91,7 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1)
cs = GEOSCoordSeq_clone(GEOSGeom_getCoordSeq(gtmp));
shell = GEOSGeom_createLinearRing(cs);
ngeoms = GEOSGetNumInteriorRings(g1);
- geoms = malloc(ngeoms*sizeof(GEOSGeometry*));
+ geoms = (GEOSGeometry**)malloc(ngeoms*sizeof(GEOSGeometry*));
for (i=0; i<ngeoms; i++)
gtmp = GEOSGetInteriorRingN(g1, i);
@@ -107,7 +107,7 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1)
case GEOS_MULTIPOLYGON:
case GEOS_GEOMETRYCOLLECTION:
ngeoms = GEOSGetNumGeometries(g1);
gtmp = GEOSGetGeometryN(g1, i);
@@ -115,7 +115,7 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1)
g2 = GEOSGeom_createCollection(type, geoms, ngeoms);
free(geoms);
- return g2;
+ return g2;
break;
default:
log_and_exit("Unknown geometry type %d\n", type);
@@ -165,7 +165,7 @@ do_all(char *inputfile)
/* WKT output */
ptr = GEOSGeomToWKT(g1);
- printf("Input (WKT): %s\n", ptr);
+ printf("Input (WKT): %s\n", ptr);
free(ptr);
/* WKB output */
@@ -203,7 +203,7 @@ do_all(char *inputfile)
log_and_exit("GEOSConvexHull() raised an exception");
ptr = GEOSGeomToWKT(g2);
- printf("ConvexHull: %s\n", ptr);
+ printf("ConvexHull: %s\n", ptr);
free(ptr);
/* Buffer */
@@ -214,7 +214,7 @@ do_all(char *inputfile)
log_and_exit("GEOSBuffer() raised an exception");
- printf("Buffer: %s\n", ptr);
+ printf("Buffer: %s\n", ptr);
free(ptr);
@@ -228,27 +228,27 @@ do_all(char *inputfile)
log_and_exit("Intersection(g, Buffer(g)) didn't return g");
ptr = GEOSGeomToWKT(g3);
- printf("Intersection: %s\n", ptr);
+ printf("Intersection: %s\n", ptr);
GEOSGeom_destroy(g3);
free(ptr);
/* Difference */
g3 = GEOSDifference(g1, g2);
- printf("Difference: %s\n", ptr);
+ printf("Difference: %s\n", ptr);
free(ptr);
/* SymDifference */
g3 = GEOSSymDifference(g1, g2);
- printf("SymDifference: %s\n", ptr);
+ printf("SymDifference: %s\n", ptr);
free(ptr);
/* Boundary */
g4 = GEOSBoundary(g3);
ptr = GEOSGeomToWKT(g4);
- printf("Boundary: %s\n", ptr);
+ printf("Boundary: %s\n", ptr);
GEOSGeom_destroy(g4);
free(ptr);
@@ -263,13 +263,13 @@ do_all(char *inputfile)
log_and_exit("Union(g, Buffer(g)) didn't return Buffer(g)");
- printf("Union: %s\n", ptr);
+ printf("Union: %s\n", ptr);
free(ptr);
/* PointOnSurcace */
g4 = GEOSPointOnSurface(g3);
- printf("PointOnSurface: %s\n", ptr);
+ printf("PointOnSurface: %s\n", ptr);
free(ptr);
@@ -277,7 +277,7 @@ do_all(char *inputfile)
/* Centroid */
g3 = GEOSGetCentroid(g2);
- printf("Centroid: %s\n", ptr);
+ printf("Centroid: %s\n", ptr);
free(ptr);
@@ -290,7 +290,7 @@ do_all(char *inputfile)
free(ptr);
log_and_exit("! RelatePattern(g1, g2, Relate(g1, g2))");
- printf("Relate: %s\n", ptr);
+ printf("Relate: %s\n", ptr);
free(ptr);
/* Polygonize */
@@ -305,7 +305,7 @@ do_all(char *inputfile)
- printf("Polygonize: %s\n", ptr);
+ printf("Polygonize: %s\n", ptr);
free(ptr);
/* LineMerge */
@@ -315,7 +315,7 @@ do_all(char *inputfile)
log_and_exit("Exception running GEOSLineMerge");
- printf("LineMerge: %s\n", ptr);
+ printf("LineMerge: %s\n", ptr);
free(ptr);
@@ -352,14 +352,14 @@ do_all(char *inputfile)
/* Simplify */
g3 = GEOSSimplify(g1, 0.5);
- printf("Simplify: %s\n", ptr);
+ printf("Simplify: %s\n", ptr);
free(ptr);
/* Topology Preserve Simplify */
g3 = GEOSTopologyPreserveSimplify(g1, 0.5);
free(ptr);
diff --git a/tests/thread/badthreadtest.c b/tests/thread/badthreadtest.c
index 422ddea..bc1f412 100644
--- a/tests/thread/badthreadtest.c
+++ b/tests/thread/badthreadtest.c
@@ -7,7 +7,7 @@
@@ -62,7 +62,7 @@ notice(const char *fmt, ...) {
va_list ap;
va_start (ap, fmt);
va_end(ap);
@@ -74,7 +74,7 @@ log_and_exit(const char *fmt, ...) {
va_list ap;
va_start (ap, fmt);
va_end(ap);
@@ -108,7 +108,7 @@ log_and_exit2(const char *fmt, ...) {
pthread_exit(NULL);
-GEOSGeometry*
+GEOSGeometry*
@@ -143,7 +143,7 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1)
@@ -159,7 +159,7 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1)
@@ -167,7 +167,7 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1)
free(geoms);
- return g2;
+ return g2;
break;
default:
@@ -217,7 +217,7 @@ do_all(char *inputfile)
/* WKT output */
free(ptr);
/* WKB output */
@@ -255,7 +255,7 @@ do_all(char *inputfile)
free(ptr);
/* Buffer */
@@ -266,7 +266,7 @@ do_all(char *inputfile)
free(ptr);
@@ -280,27 +280,27 @@ do_all(char *inputfile)
free(ptr);
/* Difference */
free(ptr);
/* SymDifference */
free(ptr);
/* Boundary */
free(ptr);
@@ -315,13 +315,13 @@ do_all(char *inputfile)
free(ptr);
free(ptr);
@@ -329,7 +329,7 @@ do_all(char *inputfile)
/* Centroid */
free(ptr);
@@ -342,7 +342,7 @@ do_all(char *inputfile)
free(ptr);
free(ptr);
/* Polygonize */
@@ -357,7 +357,7 @@ do_all(char *inputfile)
free(ptr);
/* LineMerge */
@@ -367,7 +367,7 @@ do_all(char *inputfile)
free(ptr);
@@ -392,14 +392,14 @@ do_all(char *inputfile)
/* Simplify */
free(ptr);
free(ptr);
diff --git a/tests/thread/threadtest.c b/tests/thread/threadtest.c
index bb67759..87a37aa 100644
--- a/tests/thread/threadtest.c
+++ b/tests/thread/threadtest.c
@@ -7,7 +7,7 @@
@@ -38,7 +38,7 @@ notice1(const char *fmt, ...) {
va_list ap;
fprintf( stdout, "NOTICE1: ");
va_start (ap, fmt);
va_end(ap);
@@ -50,7 +50,7 @@ notice2(const char *fmt, ...) {
va_list ap;
fprintf( stdout, "NOTICE2: ");
va_start (ap, fmt);
va_end(ap);
@@ -62,7 +62,7 @@ log_and_exit(const char *fmt, ...) {
va_list ap;
va_start (ap, fmt);
va_end(ap);
@@ -75,7 +75,7 @@ log_and_exit1(const char *fmt, ...) {
va_list ap;
fprintf( stdout, "ERROR1: ");
va_start (ap, fmt);
va_end(ap);
@@ -88,7 +88,7 @@ log_and_exit2(const char *fmt, ...) {
va_list ap;
fprintf( stdout, "ERROR2: ");
va_start (ap, fmt);
va_end(ap);
@@ -96,8 +96,8 @@ log_and_exit2(const char *fmt, ...) {
pthread_exit(NULL);
-GEOSGeometry*
-fineGrainedReconstructionTest(const GEOSGeometry* g1,
+GEOSGeometry*
+fineGrainedReconstructionTest(const GEOSGeometry* g1,
GEOSContextHandle_t handle)
@@ -113,36 +113,36 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1,
switch ( type )
case GEOS_POINT:
- cs = GEOSCoordSeq_clone_r(handle,
+ cs = GEOSCoordSeq_clone_r(handle,
GEOSGeom_getCoordSeq_r(handle, g1));
g2 = GEOSGeom_createPoint_r(handle, cs);
return g2;
break;
case GEOS_LINESTRING:
g2 = GEOSGeom_createLineString_r(handle, cs);
return g2;
break;
case GEOS_LINEARRING:
g2 = GEOSGeom_createLinearRing_r(handle, cs);
return g2;
break;
case GEOS_POLYGON:
gtmp = GEOSGetExteriorRing_r(handle, g1);
GEOSGeom_getCoordSeq_r(handle, gtmp));
shell = GEOSGeom_createLinearRing_r(handle, cs);
ngeoms = GEOSGetNumInteriorRings_r(handle, g1);
gtmp = GEOSGetInteriorRingN_r(handle, g1, i);
- geoms[i] = GEOSGeom_createLinearRing_r(handle,
+ geoms[i] = GEOSGeom_createLinearRing_r(handle,
cs);
g2 = GEOSGeom_createPolygon_r(handle, shell, geoms,
@@ -155,7 +155,7 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1,
ngeoms = GEOSGetNumGeometries_r(handle, g1);
gtmp = GEOSGetGeometryN_r(handle, g1, i);
@@ -165,7 +165,7 @@ fineGrainedReconstructionTest(const GEOSGeometry* g1,
g2 = GEOSGeom_createCollection_r(handle, type, geoms,
ngeoms);
free(geoms);
- return g2;
+ return g2;
break;
default:
@@ -215,7 +215,7 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
/* WKT output */
ptr = GEOSGeomToWKT_r(handle, g1);
free(ptr);
/* WKB output */
@@ -253,7 +253,7 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
ptr = GEOSGeomToWKT_r(handle, g2);
free(ptr);
/* Buffer */
@@ -264,7 +264,7 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
free(ptr);
@@ -278,27 +278,27 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
ptr = GEOSGeomToWKT_r(handle, g3);
GEOSGeom_destroy_r(handle, g3);
free(ptr);
/* Difference */
g3 = GEOSDifference_r(handle, g1, g2);
free(ptr);
/* SymDifference */
g3 = GEOSSymDifference_r(handle, g1, g2);
free(ptr);
/* Boundary */
g4 = GEOSBoundary_r(handle, g3);
ptr = GEOSGeomToWKT_r(handle, g4);
GEOSGeom_destroy_r(handle, g4);
free(ptr);
@@ -313,13 +313,13 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
free(ptr);
g4 = GEOSPointOnSurface_r(handle, g3);
free(ptr);
@@ -327,7 +327,7 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
/* Centroid */
g3 = GEOSGetCentroid_r(handle, g2);
free(ptr);
@@ -340,7 +340,7 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
free(ptr);
free(ptr);
/* Polygonize */
@@ -355,7 +355,7 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
free(ptr);
/* LineMerge */
@@ -365,7 +365,7 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
free(ptr);
@@ -390,14 +390,14 @@ do_all(char *inputfile, GEOSContextHandle_t handle)
/* Simplify */
g3 = GEOSSimplify_r(handle, g1, 0.5);
free(ptr);
g3 = GEOSTopologyPreserveSimplify_r(handle, g1, 0.5);
free(ptr);
@@ -411,7 +411,7 @@ void *threadfunc1( void *arg )
GEOSContextHandle_t handle = NULL;
handle = initGEOS_r( notice1, log_and_exit1 );
- printf("GEOS version %s\n", GEOSversion(handle));
+ printf("GEOS version %s\n", GEOSversion());
putc('.', stderr); fflush(stderr);
do_all((char*)arg, handle);
putc('+', stderr); fflush(stderr);
@@ -425,7 +425,7 @@ void *threadfunc2( void *arg )
handle = initGEOS_r( notice2, log_and_exit2 );
do_all((char *)arg, handle);
Summary of changes:
.github/workflows/ci.yml | 113 +++++++++++++++++++++++++++++++++++++++++++
tests/geostest/geostest.c | 46 +++++++++---------
tests/thread/badthreadtest.c | 46 +++++++++---------
tests/thread/threadtest.c | 70 +++++++++++++--------------
4 files changed, 194 insertions(+), 81 deletions(-)
create mode 100644 .github/workflows/ci.yml
hooks/post-receive
More information about the geos-commits
