[geos-commits] [SCM] GEOS branch 3.8 updated. a241b05f90a966e127d5c733028abd1ed811f687
git at osgeo.org
git at osgeo.org
Tue Nov 3 15:20:14 PST 2020
the project "GEOS".
The branch, 3.8 has been updated
via a241b05f90a966e127d5c733028abd1ed811f687 (commit)
via 1ca273d8057483b72f6887fc6ca30ff33e3ce32c (commit)
from 0795362e9ea64c0784b9a6dd2a3611376b145d84 (commit)
revisions in full, below.
commit a241b05f90a966e127d5c733028abd1ed811f687
Merge: 1ca273d 0795362
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Nov 3 15:20:10 2020 -0800
Merge branch '3.8' of https://git.osgeo.org/gitea/geos/geos into 3.8
commit 1ca273d8057483b72f6887fc6ca30ff33e3ce32c
Date: Tue Nov 3 15:20:03 2020 -0800
Add Github Actions recipe to 3.8 branch
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
new file mode 100644
index 0000000..2007c7f
--- /dev/null
+++ b/.github/workflows/ci.yml
@@ -0,0 +1,113 @@
+# GitHub Actions for GEOS
+# Paul Ramsey <pramsey at cleverelephant dot ca>
+# Based on AZP configuration by Mateusz Loskot <mateusz at loskot dot net>
+name: CI
+on: [push, pull_request]
+env:
+ BUILD_TYPE: 'Release'
+ MAKEFLAGS: '-j2'
+jobs:
+ linux:
+ name: 'Linux'
+ strategy:
+ matrix:
+ ci:
+ compiler: g++,
+ build: cmake,
+ cxxstd: 11,
+ arch: 64,
+ packages: 'g++ cmake doxygen',
+ os: ubuntu-18.04
+ compiler: g++,
+ build: autotools,
+ cxxstd: 11,
+ arch: 64,
+ packages: 'g++ automake doxygen git2cl',
+ os: ubuntu-18.04
+ compiler: g++,
+ build: autotools,
+ cxxstd: 11,
+ arch: 32,
+ packages: 'g++-4.8-multilib gcc-4.8-multilib g++-multilib gcc-multilib doxygen automake git2cl',
+ os: ubuntu-18.04
+ compiler: clang++,
+ build: cmake,
+ cxxstd: 11,
+ arch: 64,
+ packages: 'clang cmake doxygen',
+ os: ubuntu-18.04
+ compiler: g++,
+ build: cmake,
+ cxxstd: 11,
+ arch: 64,
+ os: ubuntu-20.04
+ build: cmake,
+ cxxstd: 11,
+ arch: 64,
+ os: ubuntu-16.04
+ build: cmake,
+ cxxstd: 14,
+ arch: 64,
+ os: ubuntu-20.04
+ runs-on: ${{ matrix.ci.os }}
+ steps:
+ - name: 'Install'
+ run: |
+ set -e
+ uname -a
+ sudo -E apt-get update
+ sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make ${{ matrix.ci.packages }}
+ - name: 'Check Out'
+ uses: actions/checkout at v2
+ - name: 'Build'
+ run: |
+ set -e
+ if [ ${{ matrix.ci.build }} == 'cmake' ];
+ then
+ mkdir build.cmake
+ cd build.cmake
+ cmake --version
+ cmake -DCMAKE_CXX_COMPILER=${{ matrix.ci.compiler }} -DCMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} -DBUILD_DOCUMENTATION=YES -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+ make
+ cmake --build . --target docs
+ ctest --output-on-failure .
+ else
+ set -e
+ ./autogen.sh
+ mkdir build.autotools
+ cd build.autotools
+ CFLAGS="-std=c++${{ matrix.ci.cxxstd }} -m${{ matrix.ci.arch }}"
+ ../configure CC=${{ matrix.ci.compiler }} CXX=${{ matrix.ci.compiler }} CXXFLAGS="$CFLAGS" CFLAGS="$CFLAGS"
+ make && make check && make distcheck
+ fi
Summary of changes:
.github/workflows/ci.yml | 113 +++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 113 insertions(+)
create mode 100644 .github/workflows/ci.yml
hooks/post-receive
More information about the geos-commits
