the project "GEOS".
via 26cd4782faf7451c7a3df6a33a462b2669ef5153 (commit)
from 07e60468a9a155c63b06fa1e24db7c113f03004a (commit)
revisions in full, below.
commit 26cd4782faf7451c7a3df6a33a462b2669ef5153
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Nov 5 15:13:35 2020 -0800
Remove incorrect isoceles heuristic in QuadEdgeSubdivision::TriangleCircumcentreVisitor, fix unit test
References #976 in master (3.9.0dev)
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index bc0a019..b3b0911 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -388,10 +388,9 @@ public:
Triangle triangle(triEdges[0]->orig().getCoordinate(),
triEdges[1]->orig().getCoordinate(), triEdges[2]->orig().getCoordinate());
Coordinate cc;
- if (triangle.isIsoceles())
- triangle.circumcentreDD(cc);
- else
- triangle.circumcentre(cc);
+ //TODO: identify heuristic to allow calling faster circumcentre() when possible
+ triangle.circumcentreDD(cc);
Vertex ccVertex(cc);
diff --git a/tests/unit/triangulate/VoronoiTest.cpp b/tests/unit/triangulate/VoronoiTest.cpp
index 3a6948e..d036697 100644
--- a/tests/unit/triangulate/VoronoiTest.cpp
+++ b/tests/unit/triangulate/VoronoiTest.cpp
@@ -228,10 +228,9 @@ void object::test<10>
const char* wkt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
1E856B85A51C414160E5D022DB354001010000807B14AE470BA20741B81E856B85A51C414160E5D022DB35400101000080A70D74DA08A20741B81E856B85A51C414160E5D022DB35400101000080D4063A6D06A20741B81E856B85A51C414160E5D022DB354001010000807B14AE470BA207411F85EB1184A51C414160E5D022DB35400101000080A70D74DA08A207411F85EB1184A51C414160E5D022DB35400101000080D4063A6D06A207411F85EB1184A51C414160E5D022DB3540";
const char* expected =
- "GEOMETRYCOLLECTION EMPTY";
+ "GEOMETRYCOLLECTION (POLYGON ((193602.7711332133 469345.898980198, 193604.4418848486 469348.6016666667, 193605.9466666667 469348.6016666667, 193605.9466666667 469347.7638144172, 193603.2325 469345.391, 193602.9475 469345.391, 193602.8169643859 469345.5051185583, 193602.7711332133 469345.898980198)), POLYGON ((193601.8569454336 469344.9208636514, 193601.865 469344.9666851849, 193602.2037556305 469345.52375, 193602.2585544897 469345.5401343054, 193602.4642389841 469345.148354316, 193602.4577210526 469345.065, 193602.0579897448 469344.3617689955, 193601.8569454336 469344.9208636514)), POLYGON ((193601.2583333333 469342.0043333333, 193601.2583333333 469345.18625, 193601.5616666667 469345.18625, 193601.8569454336 469344.9208636514, 193602.0579897448 469344.3617689955, 193602.0222507725 469343.9301164729, 193601.5161595486 469342.0043333333, 193601.2583333333 469342.0043333333)), POLYGON ((193600.8486366758 469348.6016666667, 193604.4418848486 469348.6016666667, 193602.7711332133
469345.898980198, 193602.3274661311 469345.7182269423, 193601.865 469346.1338755144, 193601.5616666667 469346.6791265432, 193600.8486366758 469348.6016666667)), POLYGON ((193599.3943641253 469348.6016666667, 193600.8486366758 469348.6016666667, 193601.5616666667 469346.6791265432, 193601.5616666667 469345.52375, 193601.2583333333 469345.52375, 193600.955 469345.7963755144, 193599.3943641253 469348.6016666667)), POLYGON ((193602.4577210526 469345.065, 193602.4642389841 469345.148354316, 193602.8169643859 469345.5051185583, 193602.9475 469345.391, 193602.9475 469345.065, 193602.4577210526 469345.065)), POLYGON ((193602.2585544897 469345.5401343054, 193602.3274661311 469345.7182269423, 193602.7711332133 469345.898980198, 193602.8169643859 469345.5051185583, 193602.4642389841 469345.148354316, 193602.2585544897 469345.5401343054)), POLYGON ((193602.0222507725 469343.9301164729, 193602.0579897448 469344.3617689955, 193602.4577210526 469345.065, 193602.9475 469345.065, 193602.9475 469344.
739, 193602.0222507725 469343.9301164729)), POLYGON ((193601.865 469345.52375, 193601.865 469346.1338755144, 193602.3274661311 469345.7182269423, 193602.2585544897 469345.5401343054, 193602.2037556305 469345.52375, 193601.865 469345.52375)), POLYGON ((193601.5616666667 469345.18625, 193601.5616666667 469345.52375, 193601.865 469345.52375, 193601.865 469344.9666851849, 193601.8569454336 469344.9208636514, 193601.5616666667 469345.18625)), POLYGON ((193601.5161595486 469342.0043333333, 193602.0222507725 469343.9301164729, 193602.9475 469344.739, 193603.2325 469344.739, 193603.2325 469342.0043333333, 193601.5161595486 469342.0043333333)), POLYGON ((193598.2316666667 469345.18625, 193598.2316666667 469348.6016666667, 193599.3943641253 469348.6016666667, 193600.955 469345.7963755144, 193600.955 469345.18625, 193598.2316666667 469345.18625)), POLYGON ((193603.2325 469345.065, 193603.2325 469345.391, 193605.9466666667 469347.7638144172, 193605.9466666667 469345.065, 193603.2325 469345.065)
), POLYGON ((193603.2325 469344.739, 193603.2325 469345.065, 193605.9466666667 469345.065, 193605.9466666667 469344.739, 193603.2325 469344.739)), POLYGON ((193603.2325 469342.0043333333, 193603.2325 469344.739, 193605.9466666667 469344.739, 193605.9466666667 469342.0043333333, 193603.2325 469342.0043333333)), POLYGON ((193602.9475 469345.065, 193602.9475 469345.391, 193603.2325 469345.391, 193603.2325 469345.065, 193602.9475 469345.065)), POLYGON ((193602.9475 469344.739, 193602.9475 469345.065, 193603.2325 469345.065, 193603.2325 469344.739, 193602.9475 469344.739)), POLYGON ((193601.5616666667 469345.52375, 193601.5616666667 469346.6791265432, 193601.865 469346.1338755144, 193601.865 469345.52375, 193601.5616666667 469345.52375)), POLYGON ((193601.2583333333 469345.18625, 193601.2583333333 469345.52375, 193601.5616666667 469345.52375, 193601.5616666667 469345.18625, 193601.2583333333 469345.18625)), POLYGON ((193600.955 469345.18625, 193600.955 469345.7963755144, 193601.258333333
3 469345.52375, 193601.2583333333 469345.18625, 193600.955 469345.18625)), POLYGON ((193600.955 469342.0043333333, 193600.955 469345.18625, 193601.2583333333 469345.18625, 193601.2583333333 469342.0043333333, 193600.955 469342.0043333333)), POLYGON ((193598.2316666667 469342.0043333333, 193598.2316666667 469345.18625, 193600.955 469345.18625, 193600.955 469342.0043333333, 193598.2316666667 469342.0043333333)), POLYGON ((193601.865 469344.9666851849, 193601.865 469345.52375, 193602.2037556305 469345.52375, 193601.865 469344.9666851849)))";
- runVoronoi(wkt, expected, 100);
+ runVoronoi(wkt, expected, 0);
} // namespace tut
Summary of changes:
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 7 +++----
tests/unit/triangulate/VoronoiTest.cpp | 5 ++---
2 files changed, 5 insertions(+), 7 deletions(-)
hooks/post-receive
