[geos-commits] [SCM] GEOS branch master updated. 862ed68db6977aceb5767fd92748ecc6c06e3ad2
git at osgeo.org
git at osgeo.org
Mon Nov 16 06:12:53 PST 2020
the project "GEOS".
via 862ed68db6977aceb5767fd92748ecc6c06e3ad2 (commit)
from d66382ff8150a468a2f376da5ebb74c8cabdc437 (commit)
revisions in full, below.
commit 862ed68db6977aceb5767fd92748ecc6c06e3ad2
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Nov 16 15:10:38 2020 +0100
Add OverlayNG Z tests
Porting commit 0524f550f76e32fb0c2f1badc3775d67a9fa9189 from JTS
diff --git a/tests/unit/operation/overlayng/OverlayNGZTest.cpp b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
index 6ee56af..8ac55b4 100644
--- a/tests/unit/operation/overlayng/OverlayNGZTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
@@ -1,5 +1,11 @@
// Test Suite for handling of Z in geos::operation::overlayng::OverlayNG class.
+// Ported from JTS
+// modules/core/src/test/java/org/locationtech/jts/operation/overlayng/OverlyNGZTest.java
+// 0524f550f76e32fb0c2f1badc3775d67a9fa9189
#include <tut/tut.hpp>
#include <utility.h>
@@ -24,13 +30,23 @@ struct test_overlayngz_data {
WKTReader r;
- void checkIntersection(const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
+ void checkOverlay(int opCode, const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
std::unique_ptr<Geometry> a = r.read(wktA);
std::unique_ptr<Geometry> b = r.read(wktB);
std::unique_ptr<Geometry> expected = r.read(wktExpected);
- std::unique_ptr<Geometry> result = OverlayNG::overlay(a.get(), b.get(), OverlayNG::INTERSECTION);
- ensure_equals_geometry(expected.get(), result.get());
+ std::unique_ptr<Geometry> result = OverlayNG::overlay(a.get(), b.get(), opCode);
+ ensure_equals_geometry_xyz(expected.get(), result.get());
+ void checkIntersection(const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
+ checkOverlay(OverlayNG::INTERSECTION, wktA, wktB, wktExpected);
+ void checkDifference(const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
+ checkOverlay(OverlayNG::DIFFERENCE, wktA, wktB, wktExpected);
@@ -44,7 +60,7 @@ group test_overlayngz_group("geos::operation::overlayng::OverlayNGZ");
// Test Cases
-// testLineIntersectionInterpolated
+// testLineIntersectionPointInterpolated
template<>
template<>
void object::test<1> ()
@@ -52,5 +68,29 @@ void object::test<1> ()
checkIntersection("LINESTRING (0 0 0, 10 10 10)", "LINESTRING (10 0 0, 0 10 10)", "POINT(5 5 5)");
+template<>
+template<>
+void object::test<2> ()
+ checkIntersection(
+ "LINESTRING (0 0 0, 10 10 10)",
+ "LINESTRING (10 0 0, 5 5 999, 0 10 10)",
+ "POINT(5 5 999)"
+// testLineDifferenceLineInterpolated
+template<>
+template<>
+void object::test<3> ()
+ checkDifference(
+ "LINESTRING (5 5, 6 6)",
+ "MULTILINESTRING ((0 0 0, 5 5 5), (6 6 6, 10 10 10))"
} // namespace tut
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index c3da601..a24c126 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -235,6 +235,98 @@ ensure_equals_geometry(geos::geom::Geometry const* lhs,
ensure_equals_geometry(lhs, &pg);
+template <typename T>
+inline void
+ensure_equals_dims(T const *, T const *,
+ unsigned int dims,
+ double tolerance = 0.0);
+template <>
+inline void
+ensure_equals_dims(const geos::geom::CoordinateSequence *seq1,
+ const geos::geom::CoordinateSequence *seq2,
+ unsigned int dims, double tolerance)
+ assert(nullptr != seq1);
+ assert(nullptr != seq2);
+ ensure_equals (seq1->size(), seq2->size());
+ ensure( seq1->getDimension() >= dims );
+ ensure( seq2->getDimension() >= dims );
+ for (unsigned int i = 0; i < seq1->size(); i++) {
+ for (unsigned int j = 0; j < dims; j++) {
+ double val1 = seq1->getOrdinate(i, j);
+ double val2 = seq2->getOrdinate(i, j);
+ if ( std::isnan(val1) )
+ ensure( std::isnan(val2) );
+ else
+ if ( tolerance )
+ ensure_distance( val1, val2, tolerance );
+ else
+ ensure_equals( val1, val2 );
+template <typename T> inline void ensure_equals_exact_geometry_xyz(const T *lhs_in, const T *rhs_in, double tolerance = 0.0);
+template <>
+inline void
+ensure_equals_exact_geometry_xyz(const geos::geom::Geometry *lhs_in,
+ const geos::geom::Geometry *rhs_in,
+ double tolerance)
+ assert(nullptr != lhs_in);
+ assert(nullptr != rhs_in);
+ using geos::geom::Point;
+ using geos::geom::LineString;
+ using geos::geom::Polygon;
+ using geos::geom::CoordinateSequence;
+ using geos::geom::GeometryCollection;
+ ensure_equals("type id do not match",
+ lhs_in->getGeometryTypeId(), rhs_in->getGeometryTypeId());
+ if (const Point* g = dynamic_cast<const Point *>(lhs_in)) {
+ const Point *g2 = static_cast<const Point *>(rhs_in);
+ return ensure_equals_dims( g->getCoordinatesRO(), g2->getCoordinatesRO(), 3, tolerance);
+ else if (const LineString* g = dynamic_cast<const LineString *>(lhs_in)) {
+ const LineString *g2 = static_cast<const LineString *>(rhs_in);
+ else if (dynamic_cast<const Polygon *>(lhs_in)) {
+ assert("Not implemented yet" == 0);
+ else if (const GeometryCollection* g = dynamic_cast<const GeometryCollection *>(lhs_in)) {
+ const GeometryCollection *g2 = static_cast<const GeometryCollection *>(rhs_in);
+ for (unsigned int i = 0; i < g->getNumGeometries(); i++) {
+ ensure_equals_exact_geometry_xyz(g->getGeometryN(i), g2->getGeometryN(i), tolerance);
+inline void
+ensure_equals_geometry_xyz(const T *lhs_in,
+ const T *rhs_in,
+ double tolerance=0.0)
+ std::unique_ptr<geos::geom::Geometry> g1 = lhs_in->clone();
+ g1->normalize();
+ std::unique_ptr<geos::geom::Geometry> g2 = rhs_in->clone();
+ g2->normalize();
+ ensure_equals_exact_geometry_xyz(g1.get(), g2.get(), tolerance);
// Utility functions
Summary of changes:
tests/unit/operation/overlayng/OverlayNGZTest.cpp | 48 +++++++++++-
tests/unit/utility.h | 92 +++++++++++++++++++++++
2 files changed, 136 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
