[geos-commits] [SCM] GEOS branch master updated. f14b2da0ff282d1bdd6b3dafd17783acca1c1938
git at osgeo.org
git at osgeo.org
Tue Nov 17 11:34:31 PST 2020
the project "GEOS".
via f14b2da0ff282d1bdd6b3dafd17783acca1c1938 (commit)
from 4106be37fe1f9b4f0045df676a2dcbc1ed47ddee (commit)
revisions in full, below.
commit f14b2da0ff282d1bdd6b3dafd17783acca1c1938
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Nov 17 11:33:21 2020 -0800
Sort STRtree inputs in the X direction before slicing, then
the Y direction, matching JTS behaviour. Remove old virtual
method set-up for more direct code on the class in question.
Strip out old comparator but retain the comment thread on
why it got so complex.
diff --git a/include/geos/index/strtree/AbstractSTRtree.h b/include/geos/index/strtree/AbstractSTRtree.h
index 6f0f18c..5a5cef2 100644
--- a/include/geos/index/strtree/AbstractSTRtree.h
+++ b/include/geos/index/strtree/AbstractSTRtree.h
@@ -156,7 +156,7 @@ private:
BoundableList* boundablesOfALevel,
int level);
- virtual std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input) = 0;
+ std::unique_ptr<BoundableList> sortBoundablesY(const BoundableList* input);
bool remove(const void* searchBounds, AbstractNode& node, void* item);
bool removeItem(AbstractNode& node, void* item);
@@ -263,16 +263,6 @@ public:
assert(newNodeCapacity > 1);
- static bool
- compareDoubles(double a, double b)
- // NOTE - strk:
- // Ternary operation is a workaround for
- // a probable MingW bug, see
- // http://trac.osgeo.org/geos/ticket/293
- return (a < b) ? true : false;
virtual ~AbstractSTRtree();
/** \brief
diff --git a/include/geos/index/strtree/SIRtree.h b/include/geos/index/strtree/SIRtree.h
index fc8ba26..64be4cf 100644
--- a/include/geos/index/strtree/SIRtree.h
+++ b/include/geos/index/strtree/SIRtree.h
@@ -111,7 +111,7 @@ protected:
return intersectsOp;
- std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input) override;
+ std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input);
private:
IntersectsOp* intersectsOp;
diff --git a/include/geos/index/strtree/STRtree.h b/include/geos/index/strtree/STRtree.h
index 1ceddef..6f83c93 100644
--- a/include/geos/index/strtree/STRtree.h
+++ b/include/geos/index/strtree/STRtree.h
@@ -85,7 +85,8 @@ private:
STRIntersectsOp intersectsOp;
+ std::unique_ptr<BoundableList> sortBoundablesX(const BoundableList* input);
std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlice(
BoundableList* childBoundables,
diff --git a/src/index/strtree/AbstractSTRtree.cpp b/src/index/strtree/AbstractSTRtree.cpp
index ca4722c..1397b56 100644
--- a/src/index/strtree/AbstractSTRtree.cpp
+++ b/src/index/strtree/AbstractSTRtree.cpp
@@ -13,6 +13,7 @@
+#include <geos/geom/Envelope.h>
#include <geos/index/strtree/AbstractSTRtree.h>
#include <geos/index/strtree/AbstractNode.h>
#include <geos/index/strtree/ItemBoundable.h>
@@ -70,7 +71,7 @@ AbstractSTRtree::createParentBoundables(BoundableList* childBoundables,
std::unique_ptr< BoundableList > parentBoundables(new BoundableList());
parentBoundables->push_back(createNode(newLevel));
- std::unique_ptr< BoundableList > sortedChildBoundables(sortBoundables(childBoundables));
+ std::unique_ptr< BoundableList > sortedChildBoundables(sortBoundablesY(childBoundables));
for(Boundable* childBoundable: *sortedChildBoundables)
@@ -358,6 +359,29 @@ AbstractSTRtree::itemsTree()
return valuesTree;
+/*private*/
+std::unique_ptr<BoundableList>
+AbstractSTRtree::sortBoundablesY(const BoundableList* input)
+ assert(input);
+ std::unique_ptr<BoundableList> output(new BoundableList(*input));
+ assert(output->size() == input->size());
+ struct {
+ bool operator()(Boundable* a, Boundable* b) const
+ const geom::Envelope* ea = static_cast<const geom::Envelope*>(a->getBounds());
+ const geom::Envelope* eb = static_cast<const geom::Envelope*>(b->getBounds());
+ double ya = (ea->getMinY() + ea->getMaxY()) / 2.0;
+ double yb = (eb->getMinY() + eb->getMaxY()) / 2.0;
+ return ya < yb ? true : false;
+ } nodeSortByY;
+ sort(output->begin(), output->end(), nodeSortByY);
+ return output;
} // namespace geos.index.strtree
} // namespace geos
diff --git a/src/index/strtree/SIRtree.cpp b/src/index/strtree/SIRtree.cpp
index c7692bf..ee3e5d0 100644
--- a/src/index/strtree/SIRtree.cpp
+++ b/src/index/strtree/SIRtree.cpp
@@ -31,8 +31,8 @@ namespace strtree { // geos.index.strtree
static bool
compareSIRBoundables(Boundable* a, Boundable* b)
- return AbstractSTRtree::compareDoubles(((Interval*)a->getBounds())->getCentre(),
- ((Interval*)b->getBounds())->getCentre());
+ return ((Interval*)a->getBounds())->getCentre() <
+ ((Interval*)b->getBounds())->getCentre() ? true : false;
/*protected*/
diff --git a/src/index/strtree/STRtree.cpp b/src/index/strtree/STRtree.cpp
index 7186dbc..ce89b64 100644
--- a/src/index/strtree/STRtree.cpp
+++ b/src/index/strtree/STRtree.cpp
@@ -37,59 +37,6 @@ namespace index { // geos.index
-static bool
-yComparator(Boundable* a, Boundable* b)
- assert(a);
- assert(b);
- const void* aBounds = a->getBounds();
- const void* bBounds = b->getBounds();
- assert(aBounds);
- assert(bBounds);
- const Envelope* aEnv = static_cast<const Envelope*>(aBounds);
- const Envelope* bEnv = static_cast<const Envelope*>(bBounds);
- // NOTE - mloskot:
- // The problem of instability is directly related to mathematical definition of
- // "strict weak ordering" as a fundamental requirement for binary predicate:
- // if a is less than b then b is not less than a,
- // if a is less than b and b is less than c
- // then a is less than c,
- // and so on.
- // For some very low values, this predicate does not fulfill this requiremnet,
- // NOTE - strk:
- // It seems that the '<' comparison here gives unstable results.
- // In particular, when inlines are on (for Envelope::getMinY and getMaxY)
- // things are fine, but when they are off we can even get a memory corruption !!
- //return STRtree::centreY(aEnv) < STRtree::centreY(bEnv);
- // This comparison does not answer if a is "lower" than b
- // what is required for sorting. This comparison only answeres
- // if a and b are "almost the same" or different
- /*NOTE - cfis
- In debug mode VC++ checks the predicate in both directions.
- If !_Pred(_Left, _Right)
- Then an exception is thrown if _Pred(_Right, _Left).
- See xutility around line 320:
- bool __CLRCALL_OR_CDECL _Debug_lt_pred(_Pr _Pred, _Ty1& _Left, _Ty2& _Right,
- const wchar_t *_Where, unsigned int _Line)*/
- //return std::fabs( STRtree::centreY(aEnv) - STRtree::centreY(bEnv) ) < 1e-30
- // NOTE - strk:
- // See http://trac.osgeo.org/geos/ticket/293
- // as for why simple comparison (<) isn't used here
- return AbstractSTRtree::compareDoubles(STRtree::centreY(aEnv),
- STRtree::centreY(bEnv));
/*public*/
STRtree::STRtree(size_t p_nodeCapacity): AbstractSTRtree(p_nodeCapacity)
@@ -108,7 +55,7 @@ STRtree::createParentBoundables(BoundableList* childBoundables, int newLevel)
assert(!childBoundables->empty());
int minLeafCount = (int) ceil((double)childBoundables->size() / (double)getNodeCapacity());
- std::unique_ptr<BoundableList> sortedChildBoundables(sortBoundables(childBoundables));
+ std::unique_ptr<BoundableList> sortedChildBoundables(sortBoundablesX(childBoundables));
std::unique_ptr< vector<BoundableList*> > verticalSlicesV(
verticalSlices(sortedChildBoundables.get(), (int)ceil(sqrt((double)minLeafCount)))
@@ -411,15 +358,95 @@ STRtree::insert(const Envelope* itemEnv, void* item)
AbstractSTRtree::insert(itemEnv, item);
+// HISTORICAL NOTES - pramsey - 2020-11-17
+// http://trac.osgeo.org/geos/ticket/293
+// 10 years ago, a bug in MinGW resulted in a simple < comparison
+// not returning an expected result, and a lot of fiddling
+// with alternatives. I have returned to simpler logic
+// now but am retaining the comment history for posterity.
+// NOTE - mloskot:
+// The problem of instability is directly related to mathematical definition of
+// "strict weak ordering" as a fundamental requirement for binary predicate:
+// if a is less than b then b is not less than a,
+// if a is less than b and b is less than c
+// then a is less than c,
+// and so on.
+// For some very low values, this predicate does not fulfill this requiremnet,
+// NOTE - strk:
+// It seems that the '<' comparison here gives unstable results.
+// In particular, when inlines are on (for Envelope::getMinY and getMaxY)
+// things are fine, but when they are off we can even get a memory corruption !!
+// return STRtree::centreY(aEnv) < STRtree::centreY(bEnv);
+// NOTE - mloskot:
+// This comparison does not answer if a is "lower" than b
+// what is required for sorting. This comparison only answeres
+// if a and b are "almost the same" or different
+/*NOTE - cfis
+ In debug mode VC++ checks the predicate in both directions.
+ If !_Pred(_Left, _Right)
+ Then an exception is thrown if _Pred(_Right, _Left).
+ See xutility around line 320:
+ bool __CLRCALL_OR_CDECL _Debug_lt_pred(_Pr _Pred, _Ty1& _Left, _Ty2& _Right,
+ const wchar_t *_Where, unsigned int _Line)*/
+// return std::fabs( STRtree::centreY(aEnv) - STRtree::centreY(bEnv) ) < 1e-30
+// NOTE - strk:
+// See http://trac.osgeo.org/geos/ticket/293
+// as for why simple comparison (<) isn't used here
/*private*/
-STRtree::sortBoundables(const BoundableList* input)
+STRtree::sortBoundablesX(const BoundableList* input)
assert(input);
- sort(output->begin(), output->end(), yComparator);
+ struct {
+ double xa = (ea->getMinX() + ea->getMaxX()) / 2.0;
+ double xb = (eb->getMinX() + eb->getMaxX()) / 2.0;
+ return xa < xb ? true : false;
+ } nodeSortByX;
+ sort(output->begin(), output->end(), nodeSortByX);
+ return output;
+/*private*/
+STRtree::sortBoundablesY(const BoundableList* input)
+ assert(input);
+ struct {
+ } nodeSortByY;
return output;
diff --git a/tests/xmltester/tests/issue/issue-geos-488.xml b/tests/xmltester/tests/issue/issue-geos-488.xml
index 6c48a41..672322d 100644
--- a/tests/xmltester/tests/issue/issue-geos-488.xml
+++ b/tests/xmltester/tests/issue/issue-geos-488.xml
@@ -37,7 +37,7 @@
</a>
<test>
<op name='union' arg1='A' >
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
9BC7814D0340D9C5653E127048405F22AF17814D03403BEB43CBF46F48406022AF17814D03403BEB43CBF46F4840CB89B9BF804D03405375B211E66F4840655E3A27EC4703406906F11FE66F4840CA89B9BF804D03405375B211E66F4840380346EB1A4C034069A42AA2C86F4840C0D831A25049034034E549A9C86F4840F7F89D4C504903406558B7EFB96F4840C039DB99564203405A14F300BA6F484021D5163D57420340B6E51774D76F48408DB20FCD273E0340559E0A7ED76F4840676279928D3F0340BA7FE5EDF46F4840040000007285047CEC4703400D8482D9F46F4840485227E839470340C4E33FDBF46F4840655E3A27EC4703406906F11FE66F48407285047CEC4703400D8482D9F46F484004000000B888AA59BD43034025CD6A9D037048403F9518A987460340F4658E9603704840409518A987460340F4658E9603704840B888AA59BD43034025CD6A9D03704840040000001ADA3A20B74A0340A210058C037048402798DAC9B64A0340E1F173D2F46F4840EE4C7DB4694B03403D243B8A037048401ADA3A20B74A0340A210058C03704840050000003089A0A41D4C0340491EB26E3E7048402EF880CF824D034094E2156B3E70484057E87827834D0340EC35A5244D7048409097CDFB1D4C0340957341284D7048403089A0A41D4C0340491EB26E3E704840040000002
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
</op>
</test>
</case>
diff --git a/tests/xmltester/tests/issue/issue-geos-837.xml b/tests/xmltester/tests/issue/issue-geos-837.xml
index f1b729d..1c3df7f 100644
--- a/tests/xmltester/tests/issue/issue-geos-837.xml
+++ b/tests/xmltester/tests/issue/issue-geos-837.xml
@@ -8,7 +8,7 @@
</a>
<test>
<op name="union" arg1="A">
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
167666666DED43B4124A2ED64FCC8294192207E71E7D43B41EC51B81EF1C8294115AE476105D53B41F6285C8FE4C82941C3F5285C25D53B41D7A3703DC8C82941295C8F4235D53B41AE47E1FA3EC82941D7A370BD75D53B4190AEF26A3EC82941FD06003976D53B41AE47E17A1EC829413E0AD7A391D53B415C8FC2F5E1C7294190C2F568ABD53B419A999919B7C729417B14AE47DAD53B4115AE476186C72941C3F5281C01D63B41A6EE472379C72941790F342012D63B41A9847D4773C729419F4463A719D63B41CDCCCCCC71C729413333333376D63B41676666666EC72941676666663ED73B414E9B2C4673C729415D3014A919D63B41CDCCCC4C2CC72941C3F528DC74D63B41B81E856B0FC72941A4703DCAA6D63B411F85EBD1FAC62941D7A370BDC8D63B415C8FC2F597C62941EC51B85EF3D63B41CB2F566B6AC629413FF2F64B3DD73B419A99999968C629410000004040D73B41AE47E1FA67C62941A4703D4A64D73B41A4703D8A55C62941D7A3703D7DD73B41A47CE0D12DC62941D26BBB2AA1D73B4190C2F5A820C629411F85EB11ADD73B419A99991914C62941CDCCCC0CCDD73B4148E17A941BC62941EC51B81EEBD73B41676666E6A6C6294152B81EC51CD83B41B81E856B2CC729413E0AD76342D83B4169089E8569C729414878F78E56D83B414CBAA863A7C72941303F
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
5B8CBB1D72941053C337693D43B4175CCA98A24D7294158A69BC42ED43B410000000058D62941676666E62DD43B416766666620D72941333333B32ED43B4190D9117220D7294167DE1CD92BD43B41C3F5285C05D72941A4703D8A18D43B415C8FC2F501D72941AE47E17AF4D33B41E42E0F89D5D62941ADE2604BCAD33B41D7A3703DADD629417B14AE07A4D33B41B81E856B79D62941A4703DCA95D33B419259E8B55AD629414BDB791C97D33B41F6285C0FBBD52941AE47E1FA9DD33B419A999999EBD42941A4703D0A71D33B41295C8FC203D529413E0AD72369D33B41F0B2D2AC38D529413B383D6A64D33B41F1B2D2AC38D529413B383D6A64D33B419A99991984D52941E17A14AE5DD33B41DD74569393D529411C4462D159D33B410000000095D52941333333B300D33B41CDCCCCCC96D529419A9999999CD23B419A999999CED42941333333B39BD23B4133333333D0D429419A99999937D23B4100000000D2D4294100000080D3D13B41CDCCCCCC09D429419A999999D2D13B410000000008D42941CDCCCCCC36D23B41333333330DD42941676666660AD13B410000000045D329419A99999909D13B41CDCCCCCC3FD32941676666E635D23B419A99999977D229410000000035D23B41CDCCCCCC75D229419A99991999D23B41A7AB32333ED32941D5711D009AD23B419A999999
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
D63B416766666600C9294100000000DCD63B419A999999C8C92941676666E6DCD63B4192B2AD4738C8294157754933DBD63B410400000000000000CCC92941333333B314D63B4167666666CAC92941CDCCCCCC78D63B419A999999C8C92941676666E6DCD63B4100000000CCC92941333333B314D63B41040000003333333352CB2941000000006FD83B419A999999E2CC2941333333B370D83B41676666661ACC2941676666E66FD83B413333333352CB2941000000006FD83B410400000067666666E4CC29419A9999990CD83B4100000000E1CC2941CDCCCCCCD4D83B419A999999E2CC2941333333B370D83B4167666666E4CC29419A9999990CD83B41050000009A99999939CF294167666666D7D83B416766666671CE29419A999999D6D83B4133333333A9CD2941333333B3D5D83B4100000000E1CC2941CDCCCCCCD4D83B419A99999939CF294167666666D7D83B410400000067666666FECF294100000080A0D93B419A999999FCCF29419A99999904DA3B410000000000D02941676666663CD93B4167666666FECF294100000080A0D93B410500000033333333C8D02941333333333DD93B410571B1FFC9D029419C53AA2AD9D83B41B2D7B5FFC9D029417C58AA2AD9D83B419A999999C6D0294167666666A1D93B4133333333C8D02941333333333DD93B4104000000CDCCCCC
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
4703D8AABF22941A4703D0A36D83B41DDE5450736F32941F27BB10B69D83B41F6285C8F66F32941B81E85EB7AD83B41A3AA38FFB6F329417B3D2D629BD83B41676666E6D9F3294185EB5178A9D83B41A58D8AEDFCF3294113744AF4B5D83B4152B81E058DF42941F6285C4FE9D83B411C87B5D6C3F42941BA598B72FED83B41CDCCCC4C10F52941E17A14EE1BD93B413FEEBC828BF52941D106B41C20D93B415C8FC2751EF629419A99991925D93B419142BA4F53F629415C1B0BE439D93B413333333354F62941CDCCCC4C02D93B410000000056F62941333333339ED83B415BF6085B53F6294185D47DE839D93B4103E4CCC5C5F629415744F2EA66D93B41CDCCCCCC1AF72941CDCCCC4C67D93B4182A61DCFC5F629415A639CEE66D93B417945A7351AF729415AEB3A2288D93B41676666E636F72941B81E856B93D93B41291E8C89BAF729419F1CFA15CCD93B4167666666A9F829419A999919CDD93B4133333333E1F72941CDCCCC4CCCD93B416307CBA1BAF729417FFF6920CCD93B410AD7A3F0D1F7294190C2F528D6D93B4185525C03E1F729415815C0FDD7D93B41A74E7FD6A8F829417A578344F0D93B41333333B3C9F82941295C8F42F4D93B418C30C5903DF92941E4B88EDF31DA3B4190C2F5A84CF92941676666E639DA3B4180005DA16FF9294157E173A846DA3B41F6285C
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
66E610D93B419A999999A1032A41CDCCCCCCACD83B41333333339E032A410000000075D93B410400000000000000D6022A413333333374D93B41CDCCCCCC0D022A41CDCCCC4C73D93B41333333339E032A410000000075D93B4100000000D6022A413333333374D93B41040000006766666601FF29419A999999BED43B413333333303FF2941000000805AD43B410000000005FF294167666666F6D33B416766666601FF29419A999999BED43B41040000000000000071FD2941676666E6BCD43B413333333339FE2941333333B3BDD43B416766666601FF29419A999999BED43B410000000071FD2941676666E6BCD43B4104000000676666666FFD29410000000021D53B419A9999996DFD29419A99991985D53B410000000071FD2941676666E6BCD43B41676666666FFD29410000000021D53B4104000000CDCCCCCCFFFE2941333333B322D53B419A99999937FE2941676666E621D53B41676666666FFD29410000000021D53B41CDCCCCCCFFFE2941333333B322D53B410500000000000000C8FF29419A99999923D53B4133333333C6FF2941333333B387D53B4100000000FEFE2941CDCCCCCC86D53B41CDCCCCCCFFFE2941333333B322D53B4100000000C8FF29419A99999923D53B41060000009A999999C4FF2941CDCCCCCCEBD53B41CDCCCCCC8C002A419A999999ECD53B410
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
3B4191999999D0FF2941F40100002FD33B41A2999999D0FF294103FEFFFF2ED33B4104000000000000002B022A4100000080CDD23B419A9999999A002A41CDCCCCCCCBD23B41CDCCCCCC62012A419A999999CCD23B41000000002B022A4100000080CDD23B4104000000676666662E022A41CDCCCC4C05D23B419A9999992C022A416766666669D23B410000000030022A4133333333A1D13B41676666662E022A41CDCCCC4C05D23B41010300000001000000070000006766666658012A41CDCCCC4C25D53B419A99999920022A419A99991926D53B416766666622022A4100000000C2D43B410000000024022A41676666E65DD43B41CDCCCCCC5B012A419A9999195DD43B41333333335A012A4133333333C1D43B416766666658012A41CDCCCC4C25D53B410103000000010000000500000033333333E0022A41000000801BD73B4167666666A8032A41676666661CD73B4133333333AA032A41CDCCCC4CB8D63B4100000000E2022A4167666666B7D63B4133333333E0022A41000000801BD73B41010300000001000000070000009A999999EA022A41676666E6C2D43B41CDCCCCCCE8022A410000000027D53B413333333379042A41333333B328D53B41CDCCCCCC7C042A410000008060D43B4167666666B4032A419A9999995FD43B41CDCCCCCCB2032A41CDCCCCCCC3D43B419A9
99999EA022A41676666E6C2D43B410103000000010000000700000033333333EC022A41CDCCCCCC5ED43B4167666666B4032A419A9999995FD43B4100000000B8032A416766666697D33B4167666666BB032A4133333333CFD23B4133333333F3022A4167666666CED23B41CDCCCCCCEF022A419A99999996D33B4133333333EC022A41CDCCCCCC5ED43B41
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
00000000EFF7294167666666ABD63B4133333333EDF72941000000800FD73B419A999999EBF729419A99999973D73B41CDCCCCCCB3F829410000008074D73B416766666623F72941CDCCCCCC72D73B410000000020F72941000000003BD83B41333333331EF729419A9999199FD83B410000000025F72941333333B30ED73B41CDCCCCCC5CF62941CDCCCCCC0DD73B416766666659F6294100000000D6D73B413333333391F5294133333333D5D73B410000000093F529410000000071D73B419A99999994F52941676666E60CD73B416766666696F52941CDCCCCCCA8D63B4133333333CEF4294100000000A8D63B41CDCCCCCCCFF42941676666E643D63B41562D33B36BF429412D33337343D63B410000000098F52941333333B344D63B41676666669BF52941000000807CD53B4133333333D3F42941333333B37BD53B4100000000D5F429410000008017D53B41CDCCCCCCD6F4294167666666B3D43B4167666666D8F42941CDCCCC4C4FD43B413333333310F42941000000804ED43B410000000048F329419A9999994DD43B41CDCCCCCC7FF22941CDCCCCCC4CD43B41676666667CF229410000000015D53B4133333333B4F129419A99991914D53B41CDCCCCCCB5F1294100000000B0D43B419A999999EDF029419A999919AFD43B4100000000ECF02941CDCCCC4C13D53B4167666
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
1CDCCCC4C6AD23B4100000000BD032A419A9999196BD23B41CDCCCCCCBE032A410000000007D23B419A999999F6022A419A99991906D23B4167666666F8022A4100000000A2D13B419A999999C0032A41676666E6A2D13B4133333333C2032A41CDCCCCCC3ED13B4100000000FA022A41676666E63DD13B41CDCCCCCCFB022A41CDCCCCCCD9D03B419A99999933022A4100000000D9D03B41676666666B012A419A999919D8D03B419A99999969012A41333333333CD13B4167666666A1002A41676666663BD13B4133333333D9FF2941000000803AD13B4167666666D7FF29419A9999999ED13B41333333330FFF2941333333B39DD13B410000000011FF29419A99999939D13B41CDCCCCCC48FE2941CDCCCCCC38D13B410000000047FE2941676666E69CD13B41CDCCCCCC7EFD2941000000009CD13B41676666667BFD29413333333364D23B41040000006766666645FE29410000000001D23B419A99999943FE29419A99991965D23B410000000047FE2941676666E69CD13B416766666645FE29410000000001D23B41040000006766666608FF2941333333332ED33B41000000000AFF29419A999919CAD23B41CDCCCCCC0BFF29410000000066D23B416766666608FF2941333333332ED33B410400000090999999D0FF29412F0200002FD33B41A3999999D0FF2941D1FDFFFF2ED3
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
43B41CDCCCCCCE8022A410000000027D53B413333333379042A41333333B328D53B41CDCCCCCC7C042A410000008060D43B4167666666B4032A419A9999995FD43B41CDCCCCCCB2032A41CDCCCCCCC3D43B410103000000010000000700000033333333EC022A41CDCCCCCC5ED43B4167666666B4032A419A9999995FD43B4100000000B8032A416766666697D33B4167666666BB032A4133333333CFD23B4133333333F3022A4167666666CED23B41CDCCCCCCEF022A419A99999996D33B4133333333EC022A41CDCCCCCC5ED43B41
</op>
</test>
</case>
Summary of changes:
include/geos/index/strtree/AbstractSTRtree.h | 12 +--
include/geos/index/strtree/SIRtree.h | 2 +-
include/geos/index/strtree/STRtree.h | 3 +-
src/index/strtree/AbstractSTRtree.cpp | 26 ++++-
src/index/strtree/SIRtree.cpp | 4 +-
src/index/strtree/STRtree.cpp | 139 +++++++++++++++----------
tests/xmltester/tests/issue/issue-geos-488.xml | 2 +-
tests/xmltester/tests/issue/issue-geos-837.xml | 2 +-
8 files changed, 116 insertions(+), 74 deletions(-)
hooks/post-receive
More information about the geos-commits
