[geos-commits] [SCM] GEOS branch master updated. 632c219c80d91881521e9f5fcb92de4b6cf6023d
git at osgeo.org
git at osgeo.org
Thu Nov 19 08:42:33 PST 2020
the project "GEOS".
via 632c219c80d91881521e9f5fcb92de4b6cf6023d (commit)
from 8825bd16cbbbe2154862da47be6c3c67fc511738 (commit)
revisions in full, below.
commit 632c219c80d91881521e9f5fcb92de4b6cf6023d
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Nov 19 17:41:57 2020 +0100
Port new tests from JTS overlayng-z branch
diff --git a/tests/unit/algorithm/RobustLineIntersectorZTest.cpp b/tests/unit/algorithm/RobustLineIntersectorZTest.cpp
index 08733de..baf378d 100644
--- a/tests/unit/algorithm/RobustLineIntersectorZTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectorZTest.cpp
@@ -1,5 +1,7 @@
-// Ported from JTS junit/algorithm/RobustLineIntersectorZTest.java e85881c1c179a49976fe38f0dbbff7d9fa61e65a
+// Ported from JTS
+// junit/algorithm/RobustLineIntersectorZTest.java
+// 1ecc94caa9e188beb63bfb95089e7dd6869bab20
#include <tut/tut.hpp>
#include <utility.h>
diff --git a/tests/unit/operation/overlayng/OverlayNGZTest.cpp b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
index 8ac55b4..6814b0c 100644
--- a/tests/unit/operation/overlayng/OverlayNGZTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
@@ -4,7 +4,7 @@
// Ported from JTS
// modules/core/src/test/java/org/locationtech/jts/operation/overlayng/OverlyNGZTest.java
-// 0524f550f76e32fb0c2f1badc3775d67a9fa9189
@@ -36,7 +36,7 @@ struct test_overlayngz_data {
std::unique_ptr<Geometry> b = r.read(wktB);
std::unique_ptr<Geometry> expected = r.read(wktExpected);
std::unique_ptr<Geometry> result = OverlayNG::overlay(a.get(), b.get(), opCode);
- ensure_equals_geometry_xyz(expected.get(), result.get());
+ ensure_equals_geometry_xyz(result.get(), expected.get());
void checkIntersection(const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
@@ -49,6 +49,11 @@ struct test_overlayngz_data {
checkOverlay(OverlayNG::DIFFERENCE, wktA, wktB, wktExpected);
+ void checkUnion(const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
+ checkOverlay(OverlayNG::UNION, wktA, wktB, wktExpected);
typedef test_group<test_overlayngz_data> group;
@@ -80,7 +85,7 @@ void object::test<2> ()
-// testLineDifferenceLineInterpolated
+// testLineLineXYDifferenceLineInterpolate
template<>
template<>
void object::test<3> ()
@@ -92,5 +97,68 @@ void object::test<3> ()
+// testLineLineUnionOverlay
+template<>
+template<>
+void object::test<4> ()
+ checkUnion(
+ "LINESTRING (0 0 0, 10 10 10)",
+ "LINESTRING (5 5 990, 15 15 999)",
+ "MULTILINESTRING Z((0 0 0, 5 5 990), (5 5 990, 10 10 10), (10 10 10, 15 15 999))"
+// testLinePolygonIntersectionLine
+template<>
+template<>
+void object::test<5> ()
+ checkIntersection(
+ "LINESTRING Z (0 0 0, 5 5 5)",
+ "POLYGON Z ((1 9 5, 9 9 9, 9 1 5, 1 1 1, 1 9 5))",
+ "LINESTRING Z (1 1 1, 5 5 5)"
+// testLinePolygonDifferenceLine
+template<>
+template<>
+void object::test<6> ()
+ checkDifference(
+ "LINESTRING Z (0 5 0, 10 5 10)",
+ "MULTILINESTRING Z((0 5 0, 1 5 2), (9 5 8, 10 5 10))"
+// testLinePolygonXYDifferenceLine
+template<>
+template<>
+void object::test<7> ()
+ checkDifference(
+ "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
+ "MULTILINESTRING Z((0 5 0, 1 5 1), (9 5 9, 10 5 10))"
+//// TODO: add Z population from model
+//// testLineXYPolygonDifferenceLine
+//template<>
+//template<>
+//void object::test<8> ()
+// checkDifference(
+// "LINESTRING (0 5, 10 5)",
+// "POLYGON Z ((1 9 5, 9 9 9, 9 1 5, 1 1 1, 1 9 5))",
+// "MULTILINESTRING Z((0 5 0, 1 5 2), (9 5 8, 10 5 10))"
} // namespace tut
Summary of changes:
.../unit/algorithm/RobustLineIntersectorZTest.cpp | 4 +-
tests/unit/operation/overlayng/OverlayNGZTest.cpp | 74 +++++++++++++++++++++-
2 files changed, 74 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
