[geos-commits] [SCM] GEOS branch master updated. 0fc01f50865069e17557d45112c8c361db8e89b4
git at osgeo.org
git at osgeo.org
Fri Nov 27 11:01:39 PST 2020
the project "GEOS".
via 0fc01f50865069e17557d45112c8c361db8e89b4 (commit)
from 3e37b5caf7a83318ee1483460d14028e3eec4e40 (commit)
revisions in full, below.
commit 0fc01f50865069e17557d45112c8c361db8e89b4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 27 10:42:57 2020 -0800
Quiet compiler warnings (clang macos)
diff --git a/CMakeLists.txt b/CMakeLists.txt
index bbbf153..0a9c32f 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -38,7 +38,6 @@ else()
message(STATUS "GEOS: Build type: ${CMAKE_BUILD_TYPE}")
endif()
# Options
@@ -213,12 +212,6 @@ target_compile_options(geos_developer_cxx_flags
$<$<OR:$<CXX_COMPILER_ID:GNU>,$<CXX_COMPILER_ID:Clang>>:-pedantic -Wall -Wextra -Wno-long-long -Wcast-align -Wconversion -Wchar-subscripts -Wdouble-promotion -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wuninitialized -Wunused-parameter -fno-common>
$<$<CXX_COMPILER_ID:GNU>:-fno-implicit-inline-templates>)
-# Disable TTMath ASM support on Windows due to build issues
-if(WIN32)
- target_compile_definitions(geos_cxx_flags
- INTERFACE TTMATH_NOASM)
-endif()
# Define a coverage build
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 6bf1240..cbc94a8 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -113,10 +113,10 @@
#define GEOSCoordSequence geos::geom::CoordinateSequence
#define GEOSBufferParams geos::operation::buffer::BufferParameters
#define GEOSSTRtree geos::index::strtree::SimpleSTRtree
-#define GEOSWKTReader_t geos::io::WKTReader
-#define GEOSWKTWriter_t geos::io::WKTWriter
-#define GEOSWKBReader_t geos::io::WKBReader
-#define GEOSWKBWriter_t geos::io::WKBWriter
+#define GEOSWKTReader geos::io::WKTReader
+#define GEOSWKTWriter geos::io::WKTWriter
+#define GEOSWKBReader geos::io::WKBReader
+#define GEOSWKBWriter geos::io::WKBWriter
#include "geos_c.h"
@@ -2494,7 +2494,7 @@ extern "C" {
GEOSGeom_getCoordinateDimension_r(GEOSContextHandle_t extHandle, const Geometry* g)
return execute(extHandle, 0, [&]() {
- return g->getCoordinateDimension();
+ return (int)(g->getCoordinateDimension());
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index 2ac07fe..b9b9c03 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -103,7 +103,7 @@ public:
* @return <code>true</code> if either intersection point is in
* the interior of the input segment
- bool isInteriorIntersection(int inputLineIndex);
+ bool isInteriorIntersection(size_t inputLineIndex);
/// Force computed intersection to be rounded to a given precision model.
@@ -128,7 +128,7 @@ public:
/// Same as above but doesn't compute intersection point. Faster.
static bool hasIntersection(const geom::Coordinate& p, const geom::Coordinate& p1, const geom::Coordinate& p2);
- enum intersection_type : unsigned char {
+ enum intersection_type : uint8_t {
/// Indicates that line segments do not intersect
NO_INTERSECTION = 0,
@@ -227,7 +227,7 @@ public:
* @return the intIndex'th intersection point in the direction of the
* specified input line segment
- const geom::Coordinate& getIntersectionAlongSegment(int segmentIndex, int intIndex);
+ const geom::Coordinate& getIntersectionAlongSegment(size_t segmentIndex, size_t intIndex);
/** \brief
* Computes the index of the intIndex'th intersection point in the direction of
@@ -238,7 +238,7 @@ public:
* @return the index of the intersection point along the segment (0 or 1)
- int getIndexAlongSegment(int segmentIndex, int intIndex);
+ size_t getIndexAlongSegment(size_t segmentIndex, size_t intIndex);
/** \brief
* Computes the "edge distance" of an intersection point along the specified
@@ -273,7 +273,7 @@ private:
* The indexes of the endpoints of the intersection lines, in order along
* the corresponding line
- int intLineIndex[2][2];
+ size_t intLineIndex[2][2];
bool isProperVar;
//Coordinate &pa;
@@ -285,8 +285,8 @@ private:
return result == COLLINEAR_INTERSECTION;
- int computeIntersect(const geom::Coordinate& p1, const geom::Coordinate& p2,
- const geom::Coordinate& q1, const geom::Coordinate& q2);
+ uint8_t computeIntersect(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ const geom::Coordinate& q1, const geom::Coordinate& q2);
bool
isEndPoint() const
@@ -296,7 +296,7 @@ private:
void computeIntLineIndex();
- void computeIntLineIndex(int segmentIndex);
+ void computeIntLineIndex(size_t segmentIndex);
int computeCollinearIntersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
diff --git a/include/geos/algorithm/locate/PointOnGeometryLocator.h b/include/geos/algorithm/locate/PointOnGeometryLocator.h
index c755de4..92100c0 100644
--- a/include/geos/algorithm/locate/PointOnGeometryLocator.h
+++ b/include/geos/algorithm/locate/PointOnGeometryLocator.h
@@ -34,7 +34,7 @@ namespace locate { // geos::algorithm::locate
* @author Martin Davis
-class PointOnGeometryLocator {
+class GEOS_DLL PointOnGeometryLocator {
private:
protected:
public:
diff --git a/include/geos/edgegraph/HalfEdge.h b/include/geos/edgegraph/HalfEdge.h
index ccfa334..e8b8e67 100644
--- a/include/geos/edgegraph/HalfEdge.h
+++ b/include/geos/edgegraph/HalfEdge.h
@@ -130,6 +130,8 @@ public:
m_orig(p_orig)
+ virtual ~HalfEdge() {};
* Creates a HalfEdge pair representing an edge
* between two vertices located at coordinates p0 and p1.
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index ea00845..d05d71f 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -370,7 +370,7 @@ public:
/// Returns the coordinate dimension of this Geometry (2=XY, 3=XYZ, 4=XYZM in future).
- virtual int getCoordinateDimension() const = 0; //Abstract
+ virtual uint8_t getCoordinateDimension() const = 0; //Abstract
* \brief
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index fab1fba..434e95f 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -110,7 +110,7 @@ public:
bool isDimensionStrict(Dimension::DimensionType d) const override;
/// Returns coordinate dimension.
- int getCoordinateDimension() const override;
+ uint8_t getCoordinateDimension() const override;
std::unique_ptr<Geometry> getBoundary() const override;
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index 87582d3..4253257 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
int getBoundaryDimension() const override;
* \brief
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index bc84980..6f435f1 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -98,7 +98,7 @@ public:
Dimension::DimensionType getDimension() const override;
/// Returns Dimension::False (Point has no boundary)
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index abc1a99..6f3e678 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -92,7 +92,7 @@ public:
/// Returns 1 (Polygon boundary is a MultiLineString)
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index d40e281..3b3799c 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -24,6 +24,7 @@
#include <geos/util/Machine.h> // for getMachineByteOrder
#include <iosfwd>
+#include <cstdint>
// Forward declarations
namespace geos {
@@ -97,7 +98,7 @@ public:
* Returns the output dimension used by the
* <code>WKBWriter</code>.
- virtual int
+ virtual uint8_t
getOutputDimension() const
return defaultOutputDimension;
@@ -172,8 +173,8 @@ public:
private:
- int defaultOutputDimension;
- int outputDimension;
+ uint8_t defaultOutputDimension;
+ uint8_t outputDimension;
int byteOrder;
diff --git a/include/geos/io/WKTWriter.h b/include/geos/io/WKTWriter.h
index 6b888c7..e61d9f9 100644
--- a/include/geos/io/WKTWriter.h
+++ b/include/geos/io/WKTWriter.h
@@ -24,6 +24,7 @@
#include <geos/export.h>
#include <string>
+#include <cctype>
#ifdef _MSC_VER
#pragma warning(push)
@@ -261,8 +262,8 @@ private:
int level;
bool old3D;
void writeFormatted(
diff --git a/include/geos/operation/overlayng/OverlayEdge.h b/include/geos/operation/overlayng/OverlayEdge.h
index 243d80e..b1126fb 100644
--- a/include/geos/operation/overlayng/OverlayEdge.h
+++ b/include/geos/operation/overlayng/OverlayEdge.h
@@ -94,6 +94,7 @@ public:
bool isForward() const;
const Coordinate& directionPt() const override;
+ ~OverlayEdge() override {};
OverlayLabel* getLabel() const;
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index 080590c..6f9d101 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -150,7 +150,7 @@ LineIntersector::isIntersection(const Coordinate& pt) const
/*public*/
const Coordinate&
-LineIntersector::getIntersectionAlongSegment(int segmentIndex, int intIndex)
+LineIntersector::getIntersectionAlongSegment(size_t segmentIndex, size_t intIndex)
// lazily compute int line array
@@ -158,8 +158,8 @@ LineIntersector::getIntersectionAlongSegment(int segmentIndex, int intIndex)
/*public*/
-int
-LineIntersector::getIndexAlongSegment(int segmentIndex, int intIndex)
+size_t
+LineIntersector::getIndexAlongSegment(size_t segmentIndex, size_t intIndex)
return intLineIndex[segmentIndex][intIndex];
@@ -167,7 +167,7 @@ LineIntersector::getIndexAlongSegment(int segmentIndex, int intIndex)
/*private*/
void
-LineIntersector::computeIntLineIndex(int segmentIndex)
+LineIntersector::computeIntLineIndex(size_t segmentIndex)
double dist0 = getEdgeDistance(segmentIndex, 0);
double dist1 = getEdgeDistance(segmentIndex, 1);
@@ -206,7 +206,7 @@ LineIntersector::isInteriorIntersection()
/*public*/
bool
-LineIntersector::isInteriorIntersection(int inputLineIndex)
+LineIntersector::isInteriorIntersection(size_t inputLineIndex)
for(size_t i = 0; i < result; ++i) {
if(!(intPt[i].equals2D(*inputLines[inputLineIndex][0])
@@ -316,7 +316,7 @@ LineIntersector::hasIntersection(const Coordinate& p, const Coordinate& p1, cons
/*private*/
-int
+uint8_t
LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2,
const Coordinate& q1, const Coordinate& q2)
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index 4d064f3..2cd1538 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -64,7 +64,7 @@ std::unique_ptr<Geometry>
MinimumBoundingCircle::getMaximumDiameter()
compute();
- size_t dims = input->getCoordinateDimension();
+ uint8_t dims = input->getCoordinateDimension();
size_t len = 2;
switch(extremalPts.size()) {
case 0:
@@ -122,7 +122,7 @@ MinimumBoundingCircle::getDiameter()
case 1:
return std::unique_ptr<Geometry>(input->getFactory()->createPoint(centre));
size_t len = 2;
auto cs = input->getFactory()->getCoordinateSequenceFactory()->create(len, dims);
// TODO: handle case of 3 extremal points, by computing a line from one of
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index 60bfb02..f49d840 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -152,10 +152,10 @@ GeometryCollection::getBoundaryDimension() const
return dimension;
-int
+uint8_t
GeometryCollection::getCoordinateDimension() const
- int dimension = 2;
+ uint8_t dimension = 2;
for(const auto& g : geometries) {
dimension = std::max(dimension, g->getCoordinateDimension());
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index dbd5ab0..0f6881c 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -136,7 +136,7 @@ LineString::getDimension() const
return Dimension::L; // line
-int
+uint8_t
LineString::getCoordinateDimension() const
return (int) points->getDimension();
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 4536640..93bc34b 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -118,7 +118,7 @@ Point::getDimension() const
return Dimension::P; // point
-int
+uint8_t
Point::getCoordinateDimension() const
return (int) getCoordinatesRO()->getDimension();
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 3bdc917..9c3a300 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -157,10 +157,10 @@ Polygon::getDimension() const
return Dimension::A; // area
-int
+uint8_t
Polygon::getCoordinateDimension() const
if(shell != nullptr) {
dimension = std::max(dimension, shell->getCoordinateDimension());
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index db57681..2631416 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -416,7 +416,7 @@ OverlayOp::labelIncompleteNode(Node* n, int targetIndex)
// Only do this if input does have Z
// See https://trac.osgeo.org/geos/ticket/811
- if(targetGeom->getCoordinateDimension() < 3) {
+ if(targetGeom->getCoordinateDimension() < 3u) {
return;
diff --git a/tests/unit/operation/overlayng/LineLimiterTest.cpp b/tests/unit/operation/overlayng/LineLimiterTest.cpp
index deb992c..7832ea9 100644
--- a/tests/unit/operation/overlayng/LineLimiterTest.cpp
+++ b/tests/unit/operation/overlayng/LineLimiterTest.cpp
@@ -65,7 +65,7 @@ struct test_linelimiter_data {
geomRslt = std::move(lines[0]);
else {
- geomRslt = std::move(factory->createMultiLineString(std::move(lines)));
+ geomRslt = factory->createMultiLineString(std::move(lines));
return geomRslt;
diff --git a/tests/unit/shape/fractal/HilbertCodeTest.cpp b/tests/unit/shape/fractal/HilbertCodeTest.cpp
index b28ebaa..74373c8 100644
--- a/tests/unit/shape/fractal/HilbertCodeTest.cpp
+++ b/tests/unit/shape/fractal/HilbertCodeTest.cpp
@@ -27,7 +27,7 @@ struct test_hilbertcode_data {
void checkDecodeEncodeForLevel(uint32_t level)
uint32_t n = HilbertCode::levelSize(level);
- for (int i = 0; i < n; i++) {
+ for (uint32_t i = 0; i < n; i++) {
checkDecodeEncode(level, i);
@@ -53,13 +53,13 @@ template<>
void object::test<1>
- ensure_equals( HilbertCode::levelSize( 0 ), 1);
- ensure_equals( HilbertCode::levelSize( 1 ), 4);
- ensure_equals( HilbertCode::levelSize( 2 ), 16);
- ensure_equals( HilbertCode::levelSize( 3 ), 64);
- ensure_equals( HilbertCode::levelSize( 4 ), 256);
- ensure_equals( HilbertCode::levelSize( 5 ), 1024);
- ensure_equals( HilbertCode::levelSize( 6 ), 4096);
+ ensure_equals( HilbertCode::levelSize( 0 ), 1u);
+ ensure_equals( HilbertCode::levelSize( 1 ), 4u);
+ ensure_equals( HilbertCode::levelSize( 2 ), 16u);
+ ensure_equals( HilbertCode::levelSize( 3 ), 64u);
+ ensure_equals( HilbertCode::levelSize( 4 ), 256u);
+ ensure_equals( HilbertCode::levelSize( 5 ), 1024u);
+ ensure_equals( HilbertCode::levelSize( 6 ), 4096u);
@@ -68,25 +68,25 @@ template<>
void object::test<2>
- ensure_equals( HilbertCode::level( 1 ), 0);
+ ensure_equals( HilbertCode::level( 1 ), 0u);
- ensure_equals( HilbertCode::level( 2 ), 1);
- ensure_equals( HilbertCode::level( 3 ), 1);
- ensure_equals( HilbertCode::level( 4 ), 1);
+ ensure_equals( HilbertCode::level( 2 ), 1u);
+ ensure_equals( HilbertCode::level( 3 ), 1u);
+ ensure_equals( HilbertCode::level( 4 ), 1u);
- ensure_equals( HilbertCode::level( 5 ), 2);
- ensure_equals( HilbertCode::level( 13 ), 2);
- ensure_equals( HilbertCode::level( 15 ), 2);
- ensure_equals( HilbertCode::level( 16 ), 2);
+ ensure_equals( HilbertCode::level( 5 ), 2u);
+ ensure_equals( HilbertCode::level( 13 ), 2u);
+ ensure_equals( HilbertCode::level( 15 ), 2u);
+ ensure_equals( HilbertCode::level( 16 ), 2u);
- ensure_equals( HilbertCode::level( 17 ), 3);
- ensure_equals( HilbertCode::level( 63 ), 3);
- ensure_equals( HilbertCode::level( 64 ), 3);
+ ensure_equals( HilbertCode::level( 17 ), 3u);
+ ensure_equals( HilbertCode::level( 63 ), 3u);
+ ensure_equals( HilbertCode::level( 64 ), 3u);
- ensure_equals( HilbertCode::level( 65 ), 4);
- ensure_equals( HilbertCode::level( 255 ), 4);
- ensure_equals( HilbertCode::level( 256 ), 4);
+ ensure_equals( HilbertCode::level( 65 ), 4u);
+ ensure_equals( HilbertCode::level( 255 ), 4u);
+ ensure_equals( HilbertCode::level( 256 ), 4u);
diff --git a/tests/unit/shape/fractal/MortonCodeTest.cpp b/tests/unit/shape/fractal/MortonCodeTest.cpp
index b606653..0fac995 100644
--- a/tests/unit/shape/fractal/MortonCodeTest.cpp
+++ b/tests/unit/shape/fractal/MortonCodeTest.cpp
@@ -27,7 +27,7 @@ struct test_mortoncode_data {
uint32_t n = MortonCode::levelSize(level);
checkDecodeEncode(i);
- ensure_equals( MortonCode::levelSize( 0 ), 1);
- ensure_equals( MortonCode::levelSize( 1 ), 4);
- ensure_equals( MortonCode::levelSize( 2 ), 16);
- ensure_equals( MortonCode::levelSize( 3 ), 64);
- ensure_equals( MortonCode::levelSize( 4 ), 256);
- ensure_equals( MortonCode::levelSize( 5 ), 1024);
- ensure_equals( MortonCode::levelSize( 6 ), 4096);
+ ensure_equals( MortonCode::levelSize( 0 ), 1u);
+ ensure_equals( MortonCode::levelSize( 1 ), 4u);
+ ensure_equals( MortonCode::levelSize( 2 ), 16u);
+ ensure_equals( MortonCode::levelSize( 3 ), 64u);
+ ensure_equals( MortonCode::levelSize( 4 ), 256u);
+ ensure_equals( MortonCode::levelSize( 5 ), 1024u);
+ ensure_equals( MortonCode::levelSize( 6 ), 4096u);
- ensure_equals( MortonCode::level( 1 ), 0);
+ ensure_equals( MortonCode::level( 1 ), 0u);
- ensure_equals( MortonCode::level( 2 ), 1);
- ensure_equals( MortonCode::level( 3 ), 1);
- ensure_equals( MortonCode::level( 4 ), 1);
+ ensure_equals( MortonCode::level( 2 ), 1u);
+ ensure_equals( MortonCode::level( 3 ), 1u);
+ ensure_equals( MortonCode::level( 4 ), 1u);
- ensure_equals( MortonCode::level( 5 ), 2);
- ensure_equals( MortonCode::level( 13 ), 2);
- ensure_equals( MortonCode::level( 15 ), 2);
- ensure_equals( MortonCode::level( 16 ), 2);
+ ensure_equals( MortonCode::level( 5 ), 2u);
+ ensure_equals( MortonCode::level( 13 ), 2u);
+ ensure_equals( MortonCode::level( 15 ), 2u);
+ ensure_equals( MortonCode::level( 16 ), 2u);
- ensure_equals( MortonCode::level( 17 ), 3);
- ensure_equals( MortonCode::level( 63 ), 3);
- ensure_equals( MortonCode::level( 64 ), 3);
+ ensure_equals( MortonCode::level( 17 ), 3u);
+ ensure_equals( MortonCode::level( 63 ), 3u);
+ ensure_equals( MortonCode::level( 64 ), 3u);
- ensure_equals( MortonCode::level( 65 ), 4);
- ensure_equals( MortonCode::level( 255 ), 4);
- ensure_equals( MortonCode::level( 256 ), 4);
+ ensure_equals( MortonCode::level( 65 ), 4u);
+ ensure_equals( MortonCode::level( 255 ), 4u);
+ ensure_equals( MortonCode::level( 256 ), 4u);
Summary of changes:
CMakeLists.txt | 7 ----
capi/geos_ts_c.cpp | 10 ++---
include/geos/algorithm/LineIntersector.h | 16 ++++----
.../geos/algorithm/locate/PointOnGeometryLocator.h | 2 +-
include/geos/edgegraph/HalfEdge.h | 2 +
include/geos/geom/Geometry.h | 2 +-
include/geos/geom/GeometryCollection.h | 2 +-
include/geos/geom/LineString.h | 2 +-
include/geos/geom/Point.h | 2 +-
include/geos/geom/Polygon.h | 2 +-
include/geos/io/WKBWriter.h | 7 ++--
include/geos/io/WKTWriter.h | 5 ++-
include/geos/operation/overlayng/OverlayEdge.h | 1 +
src/algorithm/LineIntersector.cpp | 12 +++---
src/algorithm/MinimumBoundingCircle.cpp | 4 +-
src/geom/GeometryCollection.cpp | 4 +-
src/geom/LineString.cpp | 2 +-
src/geom/Point.cpp | 2 +-
src/geom/Polygon.cpp | 4 +-
src/operation/overlay/OverlayOp.cpp | 2 +-
tests/unit/operation/overlayng/LineLimiterTest.cpp | 2 +-
tests/unit/shape/fractal/HilbertCodeTest.cpp | 46 +++++++++++-----------
tests/unit/shape/fractal/MortonCodeTest.cpp | 46 +++++++++++-----------
23 files changed, 91 insertions(+), 93 deletions(-)
hooks/post-receive
More information about the geos-commits
