[geos-commits] [SCM] GEOS branch master updated. c771461c6caa6d7e2daad88b1ac64f9949cea80f
git at osgeo.org
git at osgeo.org
Fri Nov 27 14:18:38 PST 2020
the project "GEOS".
via c771461c6caa6d7e2daad88b1ac64f9949cea80f (commit)
from 1502648acea4405b1923d23be70d33bdf115cd63 (commit)
revisions in full, below.
commit c771461c6caa6d7e2daad88b1ac64f9949cea80f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 27 14:18:03 2020 -0800
Implement SimpleSTRtree::remove() for final piece of compatibility
with origin STRtree implementation.
diff --git a/include/geos/index/strtree/SimpleSTRnode.h b/include/geos/index/strtree/SimpleSTRnode.h
index 909de7b..426f787 100644
--- a/include/geos/index/strtree/SimpleSTRnode.h
+++ b/include/geos/index/strtree/SimpleSTRnode.h
@@ -67,6 +67,9 @@ public:
void toString(std::ostream& os, int indentLevel) const;
+ std::size_t getNumNodes() const;
+ std::size_t getNumLeafNodes() const;
const std::vector<SimpleSTRnode*>&
getChildNodes() const
@@ -77,6 +80,9 @@ public:
return item;
+ bool removeItem(void *item);
+ bool removeChild(SimpleSTRnode *child);
* Returns a representation of space that encloses this Node
diff --git a/include/geos/index/strtree/SimpleSTRtree.h b/include/geos/index/strtree/SimpleSTRtree.h
index 6baa271..c01bd5e 100644
--- a/include/geos/index/strtree/SimpleSTRtree.h
+++ b/include/geos/index/strtree/SimpleSTRtree.h
@@ -106,6 +106,8 @@ private:
std::vector<SimpleSTRnode*>& childNodes,
int newLevel);
+ bool remove(const geom::Envelope* searchBounds, SimpleSTRnode* node, void* item);
public:
@@ -124,9 +126,11 @@ public:
std::size_t getNumLeafNodes() const {
- return nodes.size();
+ return root->getNumLeafNodes();
bool getBuilt() const {
return built;
@@ -146,7 +150,7 @@ public:
void query(const geom::Envelope* searchEnv, ItemVisitor& visitor) override;
- bool remove(const geom::Envelope* itemEnv, void* item) override;
+ bool remove(const geom::Envelope* searchBounds, void* item) override;
friend std::ostream& operator<<(std::ostream& os, const SimpleSTRtree& tree);
diff --git a/src/index/strtree/SimpleSTRnode.cpp b/src/index/strtree/SimpleSTRnode.cpp
index a11ca3e..ee66664 100644
--- a/src/index/strtree/SimpleSTRnode.cpp
+++ b/src/index/strtree/SimpleSTRnode.cpp
@@ -15,6 +15,7 @@
#include <geos/index/strtree/SimpleSTRnode.h>
#include <geos/geom/Envelope.h>
+#include <iostream>
using namespace geos::geom;
@@ -48,6 +49,54 @@ SimpleSTRnode::addChildNode(SimpleSTRnode* childNode)
childNodes.push_back(childNode);
+/*public*/
+std::size_t
+SimpleSTRnode::getNumNodes() const
+ std::size_t count = 1;
+ if (isLeaf())
+ return count;
+ for (auto* node: getChildNodes())
+ count += node->getNumNodes();
+ return count;
+/*public*/
+std::size_t
+SimpleSTRnode::getNumLeafNodes() const
+ std::size_t count = isLeaf() ? 1 : 0;
+ count += node->getNumLeafNodes();
+ return count;
+bool
+SimpleSTRnode::removeItem(void *item)
+ for (auto it = childNodes.begin(); it != childNodes.end(); ++it) {
+ if ((*it)->getItem() == item) {
+ childNodes.erase(it);
+ return true;
+ return false;
+bool
+SimpleSTRnode::removeChild(SimpleSTRnode *child)
+ if ((*it) == child) {
+ return true;
+ return false;
} // namespace geos.index.strtree
diff --git a/src/index/strtree/SimpleSTRtree.cpp b/src/index/strtree/SimpleSTRtree.cpp
index f922e4e..9d60adc 100644
--- a/src/index/strtree/SimpleSTRtree.cpp
+++ b/src/index/strtree/SimpleSTRtree.cpp
@@ -268,14 +268,47 @@ SimpleSTRtree::query(const geom::Envelope* searchEnv,
/* public */
bool
-SimpleSTRtree::remove(const geom::Envelope* itemEnv, void* item)
+SimpleSTRtree::remove(const geom::Envelope* searchBounds, void* item)
- ::geos::ignore_unused_variable_warning(itemEnv);
- ::geos::ignore_unused_variable_warning(item);
- assert(false);
+ build();
+ if(root->getEnvelope().intersects(searchBounds)) {
+ return remove(searchBounds, root, item);
return false;
+/* private */
+bool
+ SimpleSTRnode* node, void* item)
+ bool found = node->removeItem(item);
+ if (found)
+ return true;
+ SimpleSTRnode* childToPrune = nullptr;
+ auto childNodes = node->getChildNodes();
+ for (auto* child: childNodes) {
+ if (! searchBounds->intersects(child->getEnvelope())) {
+ continue;
+ if (!child->isLeaf()) {
+ found = remove(searchBounds, child, item);
+ if (found) {
+ childToPrune = child;
+ break;
+ if (childToPrune != nullptr) {
+ // Only remove empty child nodes
+ if (childToPrune->getChildNodes().empty()) {
+ node->removeChild(childToPrune);
+ return found;
/*public static*/
std::ostream&
diff --git a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
index 5bae49b..5c7d239 100644
--- a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
+++ b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
@@ -6,6 +6,7 @@
#include <geos/index/strtree/SimpleSTRtree.h>
#include <geos/index/strtree/GeometryItemDistance.h>
#include <geos/index/ItemVisitor.h>
+#include <geos/io/WKTReader.h>
using namespace geos;
@@ -114,5 +115,42 @@ void object::test<2>
+template<>
+template<>
+void object::test<3>
+ auto gf = geom::GeometryFactory::create();
+ geos::io::WKTReader wkt(*gf);
+ index::strtree::SimpleSTRtree t(10);
+ std::vector<std::unique_ptr<geom::Geometry>> geoms;
+ geoms.emplace_back(wkt.read(std::string("LINESTRING(0 0, 10 10)")).release());
+ geoms.emplace_back(wkt.read(std::string("LINESTRING(5 5, 15 15)")).release());
+ geoms.emplace_back(wkt.read(std::string("LINESTRING(10 10, 20 20)")).release());
+ geoms.emplace_back(wkt.read(std::string("LINESTRING(15 15, 25 25)")).release());
+ for (auto& g: geoms) {
+ t.insert(g.get());
+ std::size_t leaf_before = t.getRoot()->getNumLeafNodes();
+ // std::cout << "leaf_before " << leaf_before << std::endl;
+ std::size_t all_before = t.getRoot()->getNumNodes();
+ // std::cout << "all_before " << all_before << std::endl;
+ ensure(leaf_before = 4u);
+ ensure(all_before = 5u);
+ t.remove(geoms[3]->getEnvelopeInternal(), geoms[3].get());
+ std::size_t leaf_after = t.getRoot()->getNumLeafNodes();
+ // std::cout << "leaf_after " << leaf_after << std::endl;
+ std::size_t all_after = t.getRoot()->getNumNodes();
+ // std::cout << "all_after " << all_after << std::endl;
+ ensure(leaf_after = 3u);
+ ensure(all_after = 4u);
} // namespace tut
Summary of changes:
include/geos/index/strtree/SimpleSTRnode.h | 6 ++++
include/geos/index/strtree/SimpleSTRtree.h | 8 +++--
src/index/strtree/SimpleSTRnode.cpp | 49 ++++++++++++++++++++++++++
src/index/strtree/SimpleSTRtree.cpp | 41 ++++++++++++++++++---
tests/unit/index/strtree/SimpleSTRtreeTest.cpp | 38 ++++++++++++++++++++
5 files changed, 136 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
