[geos-commits] [SCM] GEOS branch master updated. 2522fba2d8851500a8d9f39337e07bbf5c0a5653
git at osgeo.org
git at osgeo.org
Mon Nov 30 17:34:23 PST 2020
the project "GEOS".
via 2522fba2d8851500a8d9f39337e07bbf5c0a5653 (commit)
from 401aee7981dafba8ef82cdd83d59d3d56ddfef03 (commit)
revisions in full, below.
commit 2522fba2d8851500a8d9f39337e07bbf5c0a5653
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Nov 30 17:34:06 2020 -0800
Use SnapRoundingNoder in BufferOp
This avoids doing a precision reduction on the input geometry.
It maps more closely to the implementation in JTS.
It still does an increasing loop of larger tolerance,
in the event of a failure.
This is to address the regression reported by GEOSwift
downstream on 3.9.0beta1
diff --git a/src/operation/buffer/BufferOp.cpp b/src/operation/buffer/BufferOp.cpp
index 3e815fd..d0f1b9a 100644
--- a/src/operation/buffer/BufferOp.cpp
+++ b/src/operation/buffer/BufferOp.cpp
@@ -34,6 +34,7 @@
#include <geos/noding/snapround/MCIndexSnapRounder.h>
#include <geos/noding/snapround/MCIndexPointSnapper.h>
+#include <geos/noding/snapround/SnapRoundingNoder.h>
//FIXME: for temporary use, see other FIXME in file
#include <geos/algorithm/LineIntersector.h>
@@ -222,26 +223,37 @@ BufferOp::bufferReducedPrecision(int precisionDigits)
void
BufferOp::bufferFixedPrecision(const PrecisionModel& fixedPM)
+ PrecisionModel pm(1.0); // fixed as well
+#define SNAP_WITH_NODER
+#ifdef SNAP_WITH_NODER
+ // Reduce precision using SnapRoundingNoder
+ // This more closely aligns with JTS implementation,
+ // and avoids reducing the precision of the input
+ // geometry.
+ // TODO: Add a finer fallback sequence. Full
+ // precision, then SnappingNoder, then
+ // SnapRoundingNoder.
- PrecisionModel pm(1.0); // fixed as well
+ snapround::SnapRoundingNoder inoder(&pm);
+ ScaledNoder noder(inoder, fixedPM.getScale());
+ BufferBuilder bufBuilder(bufParams);
+ bufBuilder.setWorkingPrecisionModel(&fixedPM);
+ bufBuilder.setNoder(&noder);
+ resultGeometry = bufBuilder.buffer(argGeom, distance);
-#if 0 /* FIXME: MCIndexSnapRounder seems to be still bogus */
- snapround::MCIndexSnapRounder inoder(pm);
#else
algorithm::LineIntersector li(&fixedPM);
IntersectionAdder ia(li);
MCIndexNoder inoder(&ia);
-#endif
- // Reduce precision of the input geometry
+ // Snap by reducing the precision of the input geometry
// NOTE: this reduction is not in JTS and should supposedly
// not be needed because the PrecisionModel we pass
@@ -266,6 +278,7 @@ BufferOp::bufferFixedPrecision(const PrecisionModel& fixedPM)
// this may throw an exception, if robustness errors are encountered
resultGeometry = bufBuilder.buffer(workGeom, distance);
+#endif
} // namespace geos.operation.buffer
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index b2dc84f..ac05b9b 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -12,6 +12,7 @@
#include <geos/geom/Geometry.h>
#include <geos/algorithm/PointLocator.h>
#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
#include <geos/geom/CoordinateSequence.h>
// std
#include <memory>
@@ -27,6 +28,7 @@ namespace tut {
struct test_bufferop_data {
const geos::geom::GeometryFactory& gf;
geos::io::WKTReader wktreader;
+ geos::io::WKTWriter wktwriter;
int const default_quadrant_segments;
typedef geos::geom::Geometry::Ptr GeomPtr;
@@ -363,7 +365,7 @@ MULTILINESTRING( \
// We're basically only interested an rough sense of a
// meaningful result.
- ensure_equals(gBuffer->getNumPoints(), std::size_t(47));
+ ensure_equals(gBuffer->getNumPoints(), std::size_t(46));
ensure_equals(int(gBuffer->getArea()), 3520);
@@ -421,5 +423,29 @@ void object::test<13>
ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
+// Test for GEOSwift regression failure
+template<>
+template<>
+void object::test<14>
+ using geos::operation::buffer::BufferOp;
+ using geos::operation::buffer::BufferParameters;
+ std::string wkt0("GEOMETRYCOLLECTION (POINT (1 2), MULTIPOINT ((1 2), (3 4)), LINESTRING (1 2, 3 4), MULTILINESTRING ((1 2, 3 4), (5 6, 7 8)), POLYGON ((2 2, -2 2, -2 -2, 2 -2, 2 2), (1 1, 1 -1, -1 -1, -1 1, 1 1)), MULTIPOLYGON (((2 2, -2 2, -2 -2, 2 -2, 2 2), (1 1, 1 -1, -1 -1, -1 1, 1 1)), ((7 2, 3 2, 3 -2, 7 -2, 7 2))))");
+ GeomPtr g0(wktreader.read(wkt0));
+ BufferOp op(g0.get());
+ double const distance = 0.5;
+ GeomPtr gBuffer(op.getResultGeometry(distance));
+ // std::cout << wktwriter.write(gBuffer.get()) << std::endl;
+ ensure_not(gBuffer->isEmpty());
+ ensure(gBuffer->isValid());
+ ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_MULTIPOLYGON);
} // namespace tut
Summary of changes:
src/operation/buffer/BufferOp.cpp | 29 ++++++++++++++++++++--------
tests/unit/operation/buffer/BufferOpTest.cpp | 28 ++++++++++++++++++++++++++-
2 files changed, 48 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
