[geos-commits] [SCM] GEOS branch master updated. 1bb072153d7bb195d5065416123de06c34b972a9
Wed Sep 16 16:49:04 PDT 2020
the project "GEOS".
       via  1bb072153d7bb195d5065416123de06c34b972a9 (commit)
       via  a19a9f44527d4be33992c17294b3579f8e85c792 (commit)
       via  7d8efa201d93f39f224758f5e2d15bf3401b1a8b (commit)
      from  c4aebbbc048618e75b39f6c8d85dce8e8216cf9f (commit)
revisions in full, below.
commit 1bb072153d7bb195d5065416123de06c34b972a9
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Thu Sep 17 00:39:09 2020 +0200
    GEOSGeom_setPrecisionTest.cpp: fix warning about initialization of members not in the order of their declaration
diff --git a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
index c11c62b..13000d3 100644
--- a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
@@ -9,10 +9,10 @@ namespace tut {
 // Common data used in test cases.
 struct test_capigeosgeomsetprecision_data : public capitest::utility {
-    GEOSWKTWriter* wktw_;
-    GEOSGeometry* geom1_;
-    GEOSGeometry* geom2_;
-    GEOSGeometry* geom3_;
+    GEOSWKTWriter* wktw_ = nullptr;
+    GEOSGeometry* geom1_ = nullptr;
+    GEOSGeometry* geom2_ = nullptr;
+    GEOSGeometry* geom3_ = nullptr;
     GEOSGeometry*
     fromWKT(const char* wkt)
@@ -32,7 +32,6 @@ struct test_capigeosgeomsetprecision_data : public capitest::utility {
     test_capigeosgeomsetprecision_data()
-        : geom1_(0), geom2_(0), geom3_(0), wktw_(0)
         wktw_ = GEOSWKTWriter_create();
         GEOSWKTWriter_setTrim(wktw_, 1);
commit a19a9f44527d4be33992c17294b3579f8e85c792
Date:   Thu Sep 17 00:38:49 2020 +0200
    WKBReader.cpp: fix warning about signed vs unsigned comparison
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index c38c367..a2b21c9 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -409,7 +409,7 @@ WKBReader::readCoordinateSequence(int size)
     if(targetDim > inputDimension) {
         targetDim = inputDimension;
-    for(unsigned int i = 0; i < size; i++) {
+    for(int i = 0; i < size; i++) {
         readCoordinate();
         for(unsigned int j = 0; j < targetDim; j++) {
             seq->setOrdinate(i, j, ordValues[j]);
commit 7d8efa201d93f39f224758f5e2d15bf3401b1a8b
Date:   Thu Sep 17 00:38:28 2020 +0200
    Orientation.cpp: fix warning about implicit cast of size_t to int
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index 64d3c2a..6fc701c 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -45,7 +45,7 @@ bool
 Orientation::isCCW(const geom::CoordinateSequence* ring)
     // # of points without closing endpoint
-    int nPts = ring->size() - 1;
+    int nPts = static_cast<int>(ring->size()) - 1;
     // sanity check
     if (nPts < 3)
         throw util::IllegalArgumentException(
Summary of changes:
 src/algorithm/Orientation.cpp                 | 2 +-
 src/io/WKBReader.cpp                          | 2 +-
 tests/unit/capi/GEOSGeom_setPrecisionTest.cpp | 9 ++++-----
 3 files changed, 6 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
