[geos-commits] [SCM] GEOS branch 3.9 updated. 5c31f0f130c8bedd729fe7785c2be24854d2adfb
git at osgeo.org
git at osgeo.org
Tue Apr 13 16:40:27 PDT 2021
the project "GEOS".
The branch, 3.9 has been updated
via 5c31f0f130c8bedd729fe7785c2be24854d2adfb (commit)
from 9d4cf22fe9608c58d7fe330bd38edbc682cbfaa8 (commit)
revisions in full, below.
commit 5c31f0f130c8bedd729fe7785c2be24854d2adfb
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Apr 13 16:43:03 2021 -0700
Fix BufferOp to avoid artifacts in certain polygon buffers
diff --git a/NEWS b/NEWS
index f157ba8..7a90f89 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ Changes in 3.9.2
- Fix crash in GEOSPreparedIntersects and GEOSPreparedContains for
POINT EMPTY input (Even Rouault)
- Fix IsValidOp to correctly report invalid nested MultiPolygons (#1112, Martin Davis)
+ - Fix BufferOp to avoid artifacts in certain polygon buffers (#1101, Martin Davis)
Changes in 3.9.1
diff --git a/include/geos/operation/buffer/OffsetCurveSetBuilder.h b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
index abe99d3..78950e6 100644
--- a/include/geos/operation/buffer/OffsetCurveSetBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
@@ -140,6 +140,42 @@ private:
geom::Location cwRightLoc);
+ * Tests whether the offset curve for a ring is fully inverted.
+ * An inverted ("inside-out") curve occurs in some specific situations
+ * involving a buffer distance which should result in a fully-eroded (empty) buffer.
+ * It can happen that the sides of a small, convex polygon
+ * produce offset segments which all cross one another to form
+ * a curve with inverted orientation.
+ * This happens at buffer distances slightly greater than the distance at
+ * which the buffer should disappear.
+ * The inverted curve will produce an incorrect non-empty buffer (for a shell)
+ * or an incorrect hole (for a hole).
+ * It must be discarded from the set of offset curves used in the buffer.
+ * Heuristics are used to reduce the number of cases which area checked,
+ * for efficiency and correctness.
+ * <p>
+ * See https://github.com/locationtech/jts/issues/472
+ * @param inputPts the input ring
+ * @param distance the buffer distance
+ * @param curvePts the generated offset curve
+ * @return true if the offset curve is inverted
+ static bool isRingCurveInverted(
+ const geom::CoordinateSequence* inputPts, double dist,
+ const geom::CoordinateSequence* curvePts);
+ * Computes the maximum distance out of a set of points to a linestring.
+ * @param pts the points
+ * @param line the linestring vertices
+ * @return the maximum distance
+ static double maxDistance(
+ const geom::CoordinateSequence* pts, const geom::CoordinateSequence* line);
* The ringCoord is assumed to contain no repeated points.
* It may be degenerate (i.e. contain only 1, 2, or 3 points).
* In this case it has no area, and hence has a minimum diameter of 0.
@@ -216,4 +252,3 @@ public:
#endif
#endif // ndef GEOS_OP_BUFFER_OFFSETCURVESETBUILDER_H
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index ba07011..fc6ef78 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -332,9 +332,78 @@ OffsetCurveSetBuilder::addRingSide(const CoordinateSequence* coord,
std::vector<CoordinateSequence*> lineList;
curveBuilder.getRingCurve(coord, side, offsetDistance, lineList);
+ // ASSERT: lineList contains exactly 1 curve (this is teh JTS semantics)
+ if (lineList.size() > 0) {
+ const CoordinateSequence* curve = lineList[0];
+ * If the offset curve has inverted completely it will produce
+ * an unwanted artifact in the result, so skip it.
+ if (isRingCurveInverted(coord, offsetDistance, curve)) {
+ return;
addCurves(lineList, leftLoc, rightLoc);
+static const int MAX_INVERTED_RING_SIZE = 9;
+static const double NEARNESS_FACTOR = 0.99;
+/* private static*/
+bool
+OffsetCurveSetBuilder::isRingCurveInverted(
+ const CoordinateSequence* inputPts, double dist,
+ const CoordinateSequence* curvePts)
+ if (dist == 0.0) return false;
+ * Only proper rings can invert.
+ if (inputPts->size() <= 3) return false;
+ * Heuristic based on low chance that a ring with many vertices will invert.
+ * This low limit ensures this test is fairly efficient.
+ if (inputPts->size() >= MAX_INVERTED_RING_SIZE) return false;
+ * An inverted curve has no more points than the input ring.
+ * This also eliminates concave inputs (which will produce fillet arcs)
+ if (curvePts->size() > inputPts->size()) return false;
+ * Check if the curve vertices are all closer to the input ring
+ * than the buffer distance.
+ * If so, the curve is NOT a valid buffer curve.
+ double distTol = NEARNESS_FACTOR * fabs(dist);
+ double maxDist = maxDistance(curvePts, inputPts);
+ bool isCurveTooClose = maxDist < distTol;
+ return isCurveTooClose;
+/* private static */
+double
+OffsetCurveSetBuilder::maxDistance(const CoordinateSequence* pts, const CoordinateSequence* line) {
+ double maxDistance = 0;
+ for (size_t i = 0; i < pts->size(); i++) {
+ Coordinate p = pts->getAt(i);
+ double dist = Distance::pointToSegmentString(p, line);
+ if (dist > maxDistance) {
+ maxDistance = dist;
+ return maxDistance;
/*private*/
bool
OffsetCurveSetBuilder::isErodedCompletely(const LinearRing* ring,
@@ -358,28 +427,6 @@ OffsetCurveSetBuilder::isErodedCompletely(const LinearRing* ring,
if(bufferDistance < 0.0 && 2 * std::abs(bufferDistance) > envMinDimension) {
return true;
- * The following is a heuristic test to determine whether an
- * inside buffer will be eroded completely->
- * It is based on the fact that the minimum diameter of the ring
- * pointset
- * provides an upper bound on the buffer distance which would erode the
- * ring->
- * If the buffer distance is less than the minimum diameter, the ring
- * may still be eroded, but this will be determined by
- * a full topological computation->
- /* MD 7 Feb 2005 - there's an unknown bug in the MD code,
- so disable this for now */
-#if 0
- MinimumDiameter md(ring); //=new MinimumDiameter(ring);
- double minDiam = md.getLength();
- return minDiam < (2 * std::fabs(bufferDistance));
-#endif
return false;
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 8fdd2fd..badc3b2 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -11,6 +11,7 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
#include <geos/algorithm/PointLocator.h>
#include <geos/io/WKTReader.h>
#include <geos/io/WKTWriter.h>
@@ -464,6 +465,71 @@ void object::test<15>
ensure_equals_geometry(gresult.get(), gexpected.get());
+// Test for #1101 - Non-empty negative buffer of 4-pt convex polygon
+template<>
+template<>
+void object::test<16>
+ std::string wkt0("POLYGON ((666360.09 429614.71, 666344.4 429597.12, 666358.47 429584.52, 666374.5 429602.33, 666360.09 429614.71))");
+ GeomPtr g0(wktreader.read(wkt0));
-} // namespace tut
+ ensure_not( g0->buffer( -9 )->isEmpty() );
+ ensure( g0->buffer( -10 )->isEmpty() );
+ ensure( g0->buffer( -15 )->isEmpty() );
+ ensure( g0->buffer( -18 )->isEmpty() );
+// Test for #1101 - Non-empty negative buffer of 5-pt convex polygon
+template<>
+template<>
+void object::test<17>
+ std::string wkt0("POLYGON ((6 20, 16 20, 21 9, 9 0, 0 10, 6 20))");
+ ensure_not( g0->buffer( -8 )->isEmpty() );
+ ensure( g0->buffer( -8.6 )->isEmpty() );
+ ensure( g0->buffer( -9.6 )->isEmpty() );
+ ensure( g0->buffer( -11 )->isEmpty() );
+// Test for #1101 - Buffer of Polygon with hole with hole eroded
+template<>
+template<>
+void object::test<18>
+ std::string wkt0("POLYGON ((-6 26, 29 26, 29 -5, -6 -5, -6 26), (6 20, 16 20, 21 9, 9 0, 0 10, 6 20))");
+ GeomPtr result1 = g0->buffer( -8 );
+ ensure( 0 == dynamic_cast<const geos::geom::Polygon*>(result1.get())->getNumInteriorRing() );
+ GeomPtr result2 = g0->buffer( -8.6 );
+ ensure( 0 == dynamic_cast<const geos::geom::Polygon*>(result2.get())->getNumInteriorRing() );
+ GeomPtr result3 = g0->buffer( -9.6 );
+ GeomPtr result4 = g0->buffer( -11 );
+template<>
+template<>
+void object::test<19>
+ std::string wkt0("MULTIPOLYGON (((30 18, 14 0, 0 13, 16 30, 30 18)), ((180 210, 60 50, 154 6, 270 40, 290 130, 250 190, 180 210)))");
+ ensure( 2 == g0->buffer( -9 )->getNumGeometries() );
+ ensure( 1 == g0->buffer( -10 )->getNumGeometries() );
+ ensure( 1 == g0->buffer( -15 )->getNumGeometries() );
+ ensure( 1 == g0->buffer( -18 )->getNumGeometries() );
+} // namespace tut
Summary of changes:
NEWS | 1 +
.../geos/operation/buffer/OffsetCurveSetBuilder.h | 37 ++++++++-
src/operation/buffer/OffsetCurveSetBuilder.cpp | 91 ++++++++++++++++------
tests/unit/operation/buffer/BufferOpTest.cpp | 68 +++++++++++++++-
4 files changed, 173 insertions(+), 24 deletions(-)
hooks/post-receive
More information about the geos-commits
