[geos-commits] [SCM] GEOS branch main updated. 26cd20a73d72032da3812e77431334cdae620c5c
git at osgeo.org
git at osgeo.org
Thu Aug 26 14:23:50 PDT 2021
the project "GEOS".
The branch, main has been updated
via 26cd20a73d72032da3812e77431334cdae620c5c (commit)
from 907636d6bbd5c29f0cfb6713b30323902704f6aa (commit)
revisions in full, below.
commit 26cd20a73d72032da3812e77431334cdae620c5c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Aug 26 14:23:46 2021 -0700
Change BufferOp to return unique_ptr result. Removes potential double-free/memory-leak condition by clarifying semantics of return. Incidentally repair small memleak in GeoJSON tests and add CI facility to save memcheck results log on failure.
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index fbedddb..13e6548 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -125,7 +125,15 @@ jobs:
--overwrite MemoryCheckCommandOptions="--leak-check=full --error-exitcode=100" \
-R ^all-unit -C Valgrind -T memcheck
- - name: Upload coverage to Codecov
+ - name: 'Upload Valgrind Log'
+ if: failure()
+ uses: actions/upload-artifact at v2
+ with:
+ name: valgrind-log
+ path: build.cmake/Testing/Temporary/MemoryChecker.**.log
+ retention-days: 1
+ - name: Upload Coverage to Codecov
if: matrix.ci.build_type == 'Coverage'
run: |
curl -o codecov.sh https://codecov.io/bash
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 4a1b299..2211d0f 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1120,9 +1120,9 @@ extern "C" {
bp.setMitreLimit(mitreLimit);
BufferOp op(g1, bp);
- Geometry* g3 = op.getResultGeometry(width);
+ std::unique_ptr<Geometry> g3 = op.getResultGeometry(width);
g3->setSRID(g1->getSRID());
- return g3;
+ return g3.release();
@@ -1163,9 +1163,9 @@ extern "C" {
width = -width;
BufferBuilder bufBuilder(bp);
- Geometry* g3 = bufBuilder.bufferLineSingleSided(g1, width, isLeftSide);
+ std::unique_ptr<Geometry> g3 = bufBuilder.bufferLineSingleSided(g1, width, isLeftSide);
- return g3;
@@ -1189,9 +1189,9 @@ extern "C" {
bool isLeftSide = leftSide == 0 ? false : true;
- return g3;
@@ -3642,9 +3642,9 @@ extern "C" {
return execute(extHandle, [&]() {
BufferOp op(g1, *bp);
- return g3;
diff --git a/include/geos/operation/buffer/BufferBuilder.h b/include/geos/operation/buffer/BufferBuilder.h
index 651aa2c..1feda77 100644
--- a/include/geos/operation/buffer/BufferBuilder.h
+++ b/include/geos/operation/buffer/BufferBuilder.h
@@ -156,8 +156,7 @@ public:
- geom::Geometry* buffer(const geom::Geometry* g, double distance);
- // throw (GEOSException);
+ std::unique_ptr<geom::Geometry> buffer(const geom::Geometry* g, double distance);
* Generates offset curve for linear geometry.
@@ -177,9 +176,9 @@ public:
* @note Not in JTS: this is a GEOS extension
- geom::Geometry* bufferLineSingleSided(const geom::Geometry* g,
- double distance, bool leftSide) ;
+ std::unique_ptr<geom::Geometry> bufferLineSingleSided(
+ const geom::Geometry* g,
+ double distance, bool leftSide);
private:
@@ -255,7 +254,7 @@ private:
* @return the empty result geometry, transferring ownership to caller.
- geom::Geometry* createEmptyResultGeometry() const;
+ std::unique_ptr<geom::Geometry> createEmptyResultGeometry() const;
// Declare type as noncopyable
BufferBuilder(const BufferBuilder& other) = delete;
diff --git a/include/geos/operation/buffer/BufferOp.h b/include/geos/operation/buffer/BufferOp.h
index c166e55..4280c20 100644
--- a/include/geos/operation/buffer/BufferOp.h
+++ b/include/geos/operation/buffer/BufferOp.h
@@ -89,7 +89,19 @@ private:
* This value should be less than the decimal precision of double-precision values (16).
- static const int MAX_PRECISION_DIGITS = 12;
+ static constexpr int MAX_PRECISION_DIGITS = 12;
+ const geom::Geometry* argGeom;
+ util::TopologyException saveException;
+ double distance;
+ BufferParameters bufParams;
+ std::unique_ptr<geom::Geometry> resultGeometry;
+ bool isInvertOrientation = false;
* Compute a reasonable scale factor to limit the precision of
@@ -110,19 +122,6 @@ private:
static double precisionScaleFactor(const geom::Geometry* g,
double distance, int maxPrecisionDigits);
- const geom::Geometry* argGeom;
- util::TopologyException saveException;
- double distance;
- //int quadrantSegments;
- //int endCapStyle;
- BufferParameters bufParams;
- geom::Geometry* resultGeometry;
- bool isInvertOrientation = false;
void computeGeometry();
@@ -134,22 +133,9 @@ private:
void bufferFixedPrecision(const geom::PrecisionModel& fixedPM);
- * Combines the elements of two polygonal geometries together.
- * The input geometries must be non-adjacent, to avoid
- * creating an invalid result.
- * @param poly0 a polygonal geometry (which may be empty)
- * @param poly1 a polygonal geometry (which may be empty)
- * @return a combined polygonal geometry
- static geom::Geometry* combine(
- const geom::Geometry* poly0,
- const geom::Geometry* poly1);
static void extractPolygons(
- std::vector<std::unique_ptr<geom::Geometry>>& polys) ;
+ std::vector<std::unique_ptr<geom::Geometry>>& polys);
public:
@@ -179,11 +165,11 @@ public:
* @return the buffer of the input geometry
- static geom::Geometry* bufferOp(const geom::Geometry* g,
- double distance,
- int quadrantSegments =
- BufferParameters::DEFAULT_QUADRANT_SEGMENTS,
- int endCapStyle = BufferParameters::CAP_ROUND);
+ static std::unique_ptr<geom::Geometry> bufferOp(
+ double distance,
+ int quadrantSegments = BufferParameters::DEFAULT_QUADRANT_SEGMENTS,
+ int endCapStyle = BufferParameters::CAP_ROUND);
/** \brief
* Initializes a buffer computation for the given geometry.
@@ -262,7 +248,7 @@ public:
* @param nDistance the buffer distance
- geom::Geometry* getResultGeometry(double nDistance);
+ std::unique_ptr<geom::Geometry> getResultGeometry(double nDistance);
* Buffers a geometry with distance zero.
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index 9da2749..a942034 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -127,7 +127,7 @@ BufferBuilder::~BufferBuilder()
/*public*/
-Geometry*
+std::unique_ptr<Geometry>
BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
bool leftSide)
@@ -140,7 +140,7 @@ BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
// Nothing to do for a distance of zero
if(distance == 0) {
- return g->clone().release();
+ return g->clone();
// Get geometry factory and precision model.
@@ -260,7 +260,7 @@ BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
// Remove end points if they are a part of the original line to be
// buffered.
CoordinateSequence::Ptr coords(mergedLines.back()->getCoordinates());
- if(nullptr != coords.get()) {
+ if(nullptr != coords) {
// Use 98% of the buffer width as the point-distance requirement - this
// is to ensure that the point that is "distance" +/- epsilon is not
// included.
@@ -358,22 +358,22 @@ BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
intersectedLines.reset();
if(mergedLinesGeom->size() > 1) {
- return geomFact->createMultiLineString(mergedLinesGeom);
+ return std::unique_ptr<Geometry>(geomFact->createMultiLineString(mergedLinesGeom));
else if(mergedLinesGeom->size() == 1) {
- Geometry* single = (*mergedLinesGeom)[0];
+ std::unique_ptr<Geometry> single((*mergedLinesGeom)[0]);
delete mergedLinesGeom;
return single;
else {
- return geomFact->createLineString().release();
+ return geomFact->createLineString();
/*public*/
-Geometry*
BufferBuilder::buffer(const Geometry* g, double distance)
// throw(GEOSException *)
@@ -423,7 +423,7 @@ BufferBuilder::buffer(const Geometry* g, double distance)
std::cerr << std::endl << edgeList << std::endl;
#endif
- Geometry* resultGeom = nullptr;
+ std::unique_ptr<Geometry> resultGeom(nullptr);
std::unique_ptr< std::vector<Geometry*> > resultPolyList;
std::vector<BufferSubgraph*> subgraphList;
@@ -476,7 +476,7 @@ BufferBuilder::buffer(const Geometry* g, double distance)
// resultPolyList ownership transferred here
- resultGeom = geomFact->buildGeometry(resultPolyList.release());
+ resultGeom.reset(geomFact->buildGeometry(resultPolyList.release()));
catch(const util::GEOSException& /* exc */) {
@@ -714,11 +714,10 @@ BufferBuilder::buildSubgraphs(const std::vector<BufferSubgraph*>& subgraphList,
/*private*/
-geom::Geometry*
+std::unique_ptr<geom::Geometry>
BufferBuilder::createEmptyResultGeometry() const
- geom::Geometry* emptyGeom = geomFact->createPolygon().release();
- return emptyGeom;
+ return geomFact->createPolygon();
} // namespace geos.operation.buffer
diff --git a/src/operation/buffer/BufferOp.cpp b/src/operation/buffer/BufferOp.cpp
index 772688f..95dd9e2 100644
--- a/src/operation/buffer/BufferOp.cpp
+++ b/src/operation/buffer/BufferOp.cpp
@@ -61,24 +61,6 @@ namespace buffer { // geos.operation.buffer
static Profiler* profiler = Profiler::instance();
#endif
-#if 0
-double
-OLDprecisionScaleFactor(const Geometry* g,
- double distance, int maxPrecisionDigits)
- const Envelope* env = g->getEnvelopeInternal();
- double envSize = std::max(env->getHeight(), env->getWidth());
- double expandByDistance = distance > 0.0 ? distance : 0.0;
- double bufEnvSize = envSize + 2 * expandByDistance;
- // the smallest power of 10 greater than the buffer envelope
- int bufEnvLog10 = (int)(std::log(bufEnvSize) / std::log(10.0) + 1.0);
- int minUnitLog10 = bufEnvLog10 - maxPrecisionDigits;
- // scale factor is inverse of min Unit size, so flip sign of exponent
- double scaleFactor = std::pow(10.0, -minUnitLog10);
- return scaleFactor;
-#endif
/*private*/
double
BufferOp::precisionScaleFactor(const Geometry* g,
@@ -104,7 +86,7 @@ BufferOp::precisionScaleFactor(const Geometry* g,
/*public static*/
-Geometry*
BufferOp::bufferOp(const Geometry* g, double distance,
int quadrantSegments,
int nEndCapStyle)
@@ -116,12 +98,12 @@ BufferOp::bufferOp(const Geometry* g, double distance,
/*public*/
-Geometry*
BufferOp::getResultGeometry(double nDistance)
distance = nDistance;
computeGeometry();
- return resultGeometry;
+ return std::unique_ptr<Geometry>(resultGeometry.release());
/*private*/
@@ -174,8 +156,6 @@ BufferOp::bufferReducedPrecision()
if(resultGeometry != nullptr) {
- // debug
- //if ( saveException ) std::cerr<<saveException->toString()<<std::endl;
return;
@@ -190,7 +170,6 @@ BufferOp::bufferOriginalPrecision()
BufferBuilder bufBuilder(bufParams);
bufBuilder.setInvertOrientation(isInvertOrientation);
- //std::cerr<<"computing with original precision"<<std::endl;
try {
resultGeometry = bufBuilder.buffer(argGeom, distance);
@@ -198,10 +177,7 @@ BufferOp::bufferOriginalPrecision()
// don't propagate the exception - it will be detected by
// fact that resultGeometry is null
saveException = ex;
- //std::cerr<<ex->toString()<<std::endl;
- //std::cerr<<"done"<<std::endl;
void
diff --git a/src/operation/buffer/OffsetCurveBuilder.cpp b/src/operation/buffer/OffsetCurveBuilder.cpp
index b51b514..4058c8d 100644
--- a/src/operation/buffer/OffsetCurveBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveBuilder.cpp
@@ -25,7 +25,6 @@
#include <geos/algorithm/Angle.h>
#include <geos/operation/buffer/OffsetCurveBuilder.h>
#include <geos/operation/buffer/BufferInputLineSimplifier.h>
-#include <geos/operation/buffer/BufferOp.h>
#include <geos/operation/buffer/BufferParameters.h>
#include <geos/geom/Position.h>
#include <geos/geom/CoordinateArraySequence.h>
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 9d76427..885f576 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -24,7 +24,6 @@
#include <geos/operation/buffer/OffsetSegmentGenerator.h>
#include <geos/operation/buffer/OffsetSegmentString.h>
diff --git a/tests/unit/capi/GEOSGeomGeoJSONReadTest.cpp b/tests/unit/capi/GEOSGeomGeoJSONReadTest.cpp
index 0b1f852..b16dd36 100644
--- a/tests/unit/capi/GEOSGeomGeoJSONReadTest.cpp
+++ b/tests/unit/capi/GEOSGeomGeoJSONReadTest.cpp
@@ -30,7 +30,8 @@ struct test_capigeosgeomreadgeojson_data : public capitest::utility {
geom1_ = GEOSGeoJSONReader_readGeometry(reader_, &geojson[0]);
ensure("GEOSGeoJSONReader_readGeometry failed to create geometry", nullptr != geom1_);
- ensure_geometry_equals(geom1_, fromWKT(&wkt[0]));
+ geom2_ = fromWKT(wkt.c_str());
+ ensure_geometry_equals(geom1_, geom2_);
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 1b0318d..59846f0 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -69,7 +69,7 @@ void object::test<1>
double const distance = 0.0;
BufferOp op(g0.get());
- GeomPtr gBuffer(op.getResultGeometry(distance));
+ GeomPtr gBuffer = op.getResultGeometry(distance);
ensure(gBuffer->isEmpty());
ensure(gBuffer->isValid());
@@ -90,7 +90,7 @@ void object::test<2>
// Buffer point with default buffering parameters
double const distance = 1.0;
ensure_not(gBuffer->isEmpty());
@@ -116,7 +116,7 @@ void object::test<3>
BufferOp op(g0.get(), params);
@@ -143,7 +143,7 @@ void object::test<4>
BufferParameters params(segments);
double const distance = 0.0001;
ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
@@ -156,7 +156,7 @@ void object::test<4>
@@ -181,7 +181,7 @@ void object::test<5>
BufferParameters params(default_quadrant_segments * 4);
double const distance = -75.0;
@@ -206,7 +206,7 @@ void object::test<6>
@@ -231,7 +231,7 @@ void object::test<7>
@@ -256,7 +256,7 @@ void object::test<8>
@@ -281,7 +281,7 @@ void object::test<9>
@@ -310,7 +310,7 @@ void object::test<10>
BufferParameters params1(segments, BufferParameters::CAP_ROUND);
BufferOp op1(g0.get(), params1);
- GeomPtr gBuffer1(op1.getResultGeometry(distance));
+ GeomPtr gBuffer1 = op1.getResultGeometry(distance);
ensure_not(gBuffer1->isEmpty());
ensure(gBuffer1->isValid());
ensure_equals(gBuffer1->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
@@ -363,7 +363,7 @@ MULTILINESTRING( \
1.0);
const double distance = 5.0;
// We're basically only interested an rough sense of a
// meaningful result.
@@ -390,7 +390,7 @@ void object::test<12>
double const distance = 80.0;
@@ -418,7 +418,7 @@ void object::test<13>
BufferOp op(g0.get(), param);
double const distance = 40.0;
@@ -440,7 +440,7 @@ void object::test<14>
double const distance = 0.5;
// std::cout << wktwriter.write(gBuffer.get()) << std::endl;
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 01f22f7..0f430dd 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -1710,7 +1710,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
BufferOp op(p_gT, params);
- gRealRes.reset(op.getResultGeometry(dist));
+ gRealRes = op.getResultGeometry(dist);
profile.stop();
gRealRes->normalize();
@@ -1754,8 +1754,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
BufferBuilder bufBuilder(params) ;
- gRealRes.reset(bufBuilder.bufferLineSingleSided(
- p_gT, dist, leftSide)) ;
+ gRealRes = bufBuilder.bufferLineSingleSided(p_gT, dist, leftSide);
profile.stop();
@@ -1796,7 +1795,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
profile.stop();
Summary of changes:
.github/workflows/ci.yml | 10 ++++-
capi/geos_ts_c.cpp | 16 ++++----
include/geos/operation/buffer/BufferBuilder.h | 11 +++--
include/geos/operation/buffer/BufferOp.h | 54 +++++++++----------------
src/operation/buffer/BufferBuilder.cpp | 23 +++++------
src/operation/buffer/BufferOp.cpp | 30 ++------------
src/operation/buffer/OffsetCurveBuilder.cpp | 1 -
src/operation/buffer/OffsetSegmentGenerator.cpp | 1 -
tests/unit/capi/GEOSGeomGeoJSONReadTest.cpp | 3 +-
tests/unit/operation/buffer/BufferOpTest.cpp | 30 +++++++-------
tests/xmltester/XMLTester.cpp | 7 ++--
11 files changed, 76 insertions(+), 110 deletions(-)
hooks/post-receive
More information about the geos-commits
