[geos-commits] [SCM] GEOS branch master updated. fff6a78b4567339a5beab9ab30c3abb15c05fb60
git at osgeo.org
git at osgeo.org
Mon Feb 1 08:14:56 PST 2021
the project "GEOS".
via fff6a78b4567339a5beab9ab30c3abb15c05fb60 (commit)
via e5dad0d7b856ea13f5160e20e61836f52c81a39a (commit)
via 9429ff3732080c6391cf01e78698fb214c5bc91a (commit)
via 64ccc7ce96108e720f4f59931b047dcec7807866 (commit)
via 51c6e77ac0ac42f33a41f3eaeef3514c059115dc (commit)
via 7960e9ff4abafc222bf848f55f8b771acac56a9c (commit)
from bb9d66b073cc86faec10954ee79a208433dd51ae (commit)
revisions in full, below.
commit fff6a78b4567339a5beab9ab30c3abb15c05fb60
Merge: bb9d66b e5dad0d
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Feb 1 11:14:37 2021 -0500
Merge remote-tracking branch 'brendan-ward/add_densify_c_api'
commit e5dad0d7b856ea13f5160e20e61836f52c81a39a
Author: Brendan C. Ward <bcward at astutespruce.com>
Date: Fri Jan 29 19:50:44 2021 -0800
Ensure densify results in segments <= tolerance
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index c6f1516..f5d79ec 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -2020,8 +2020,8 @@ extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle(
* Densifies a geometry using a given distance tolerance.
* Additional vertices will be added to every line segment
-* that is greater than or equal to this tolerance; these
-* vertices will evenly subdivide that segment.
+* that is greater this tolerance; these vertices will
+* evenly subdivide that segment.
* Only linear components of input geometry are densified.
* \param g The geometry to densify
* \param tolerance the distance tolerance to densify
diff --git a/src/geom/util/Densifier.cpp b/src/geom/util/Densifier.cpp
index 9cab359..3f5a7cb 100644
--- a/src/geom/util/Densifier.cpp
+++ b/src/geom/util/Densifier.cpp
@@ -18,6 +18,8 @@
+#include <math.h>
#include <geos/geom/util/Densifier.h>
#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/geom/CoordinateList.h>
@@ -113,7 +115,8 @@ Densifier::densifyPoints(const Coordinate::Vect pts, double distanceTolerance, c
seg.p1 = *(it + 1);
coordList.insert(coordList.end(), seg.p0, false);
double len = seg.getLength();
- int densifiedSegCount = (int)(len / distanceTolerance) + 1;
+ int densifiedSegCount = (int)(ceil(len / distanceTolerance));
if(densifiedSegCount > 1) {
double densifiedSegLen = len / densifiedSegCount;
for(int j = 1; j < densifiedSegCount; j++) {
@@ -124,6 +127,10 @@ Densifier::densifyPoints(const Coordinate::Vect pts, double distanceTolerance, c
coordList.insert(coordList.end(), p, false);
+ else {
+ // no densification required; insert the last coordinate and continue
+ coordList.insert(coordList.end(), seg.p1, false);
coordList.insert(coordList.end(), pts[pts.size() - 1], false);
return coordList.toCoordinateArray();
diff --git a/tests/unit/capi/GEOSDensifyTest.cpp b/tests/unit/capi/GEOSDensifyTest.cpp
index b379f16..73ef2d7 100644
--- a/tests/unit/capi/GEOSDensifyTest.cpp
+++ b/tests/unit/capi/GEOSDensifyTest.cpp
@@ -60,7 +60,7 @@ void object::test<1>()
ensure(geom1_ != nullptr);
GEOSSetSRID(geom1_, 3857);
- geom2_ = GEOSDensify(geom1_, 10.00000000001);
+ geom2_ = GEOSDensify(geom1_, 10.0);
ensure("result not null", geom2_ != nullptr);
ensure_geometry_equals(geom2_, geom1_);
@@ -68,61 +68,65 @@ void object::test<1>()
-// Densify with a tolerance equal to length of all outer edges.
-// Outer edges are densified; interior ring edges are not.
+// Densify with a tolerance that evenly subdivides all outer and inner edges.
template<>
template<>
void object::test<2>()
- geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+ geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 7, 7 7, 7 1, 1 1))");
- geom2_ = GEOSDensify(geom1_, 10.0);
+ geom2_ = GEOSDensify(geom1_, 5.0);
geom2_,
- "POLYGON ((0 0, 5 0, 10 0, 10 5, 10 10, 5 10, 0 10, 0 5, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+ "POLYGON ((0 0, 5 0, 10 0, 10 5, 10 10, 5 10, 0 10, 0 5, 0 0), (1 1, 1 4, 1 7, 4 7, 7 7, 7 4, 7 1, 4 1, 1 1))");
ensure_equals("result SRID == expected SRID", GEOSGetSRID(geom2_), 3857);
-// Densify with a tolerance that evenly subdivides all outer and inner edges.
+// Densify a LINESTRING
template<>
template<>
void object::test<3>()
- geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 7, 7 7, 7 1, 1 1))");
+ geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 0 6 )");
+ GEOSSetSRID(geom1_, 3857);
- geom2_ = GEOSDensify(geom1_, 5.00000000001);
+ geom2_ = GEOSDensify(geom1_, 3);
geom2_,
- "POLYGON ((0 0, 5 0, 10 0, 10 5, 10 10, 5 10, 0 10, 0 5, 0 0), (1 1, 1 4, 1 7, 4 7, 7 7, 7 4, 7 1, 4 1, 1 1))");
+ "LINESTRING (0 0, 0 3, 0 6)");
+ ensure_equals("result SRID == expected SRID", GEOSGetSRID(geom2_), 3857);
-// Densify a LINESTRING
+// Ensure that tolerance results in the right number of subdivisions
+// ceil(6 / 2.9999999) = 3 new segments; 2 new vertices
template<>
template<>
void object::test<4>()
- geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 6 6)");
- geom2_ = GEOSDensify(geom1_, 3.0);
+ geom2_ = GEOSDensify(geom1_, 2.9999999);
geom2_,
- "LINESTRING (0 0, 2 2, 4 4, 6 6)");
+ "LINESTRING (0 0, 0 2, 0 4, 0 6)");
// Densify a LINEARRING
template<>
template<>
@@ -137,7 +141,7 @@ void object::test<5>()
geom2_,
- "LINEARRING (0 0, 0 2, 0 4, 0 6, 2 6, 4 6, 6 6, 4 4, 2 2, 0 0)");
+ "LINEARRING (0 0, 0 3, 0 6, 3 6, 6 6, 4 4, 2 2, 0 0)");
@@ -206,6 +210,5 @@ void object::test<9>()
ensure(geom2_ == nullptr);
} // namespace tut
diff --git a/tests/xmltester/tests/general/TestDensify.xml b/tests/xmltester/tests/general/TestDensify.xml
index 3a8fdfc..5a68370 100644
--- a/tests/xmltester/tests/general/TestDensify.xml
+++ b/tests/xmltester/tests/general/TestDensify.xml
@@ -16,39 +16,47 @@
<case>
<desc>L - single segment</desc>
<a> LINESTRING(10 10, 100 10) </a>
-<test><op name="densify" arg1='A' arg2='10.0'>
- LINESTRING (10 10, 19 10, 28 10, 37 10, 46 10, 55 10, 64 10, 73 10, 82 10, 91 10, 100 10)
+<test><op name="densify" arg1='A' arg2='10.0'>
+ LINESTRING (10 10, 20 10, 30 10, 40 10, 50 10, 60 10, 70 10, 80 10, 90 10, 100 10)
</op></test>
</case>
<case>
<desc>mL - multiple lines</desc>
<a> MULTILINESTRING ((10 10, 30 30, 50 10, 70 30), (10 50, 40 50, 70 50)) </a>
-<test><op name="densify" arg1='A' arg2='8.0'>
- MULTILINESTRING ((10 10, 15 15, 20 20, 25 25, 30 30, 35 25, 40 20, 45 15, 50 10, 55 15, 60 20, 65 25, 70 30),
- (10 50, 17.5 50, 25 50, 32.5 50, 40 50, 47.5 50, 55 50, 62.5 50, 70 50))
+<test><op name="densify" arg1='A' arg2='8.0'>
+ MULTILINESTRING ((10 10, 15 15, 20 20, 25 25, 30 30, 35 25, 40 20, 45 15, 50 10, 55 15, 60 20, 65 25, 70 30),
+ (10 50, 17.5 50, 25 50, 32.5 50, 40 50, 47.5 50, 55 50, 62.5 50, 70 50))
</op></test>
</case>
+<case>
+ <desc>A - simple polygon</desc>
+ <a> POLYGON ((0 0, 0 20, 20 20, 20 0, 0 0)) </a>
+ POLYGON ((0 0, 0 10, 0 20, 10 20, 20 20, 20 10, 20 0, 10 0, 0 0))
+ </op></test>
+</case>
<case>
<desc>A - polygon with hole</desc>
<a> POLYGON ((0 0, 0 70, 70 70, 70 0, 0 0), (10 10, 10 60, 60 60, 10 10)) </a>
-POLYGON ((0 0, 0 8.75, 0 17.5, 0 26.25, 0 35, 0 43.75, 0 52.5, 0 61.25, 0 70, 8.75 70, 17.5 70, 26.25 70, 35 70, 43.75 70, 52.5 70, 61.25 70, 70 70, 70 61.25, 70 52.5, 70 43.75, 70 35, 70 26.25, 70 17.5, 70 8.75, 70 0, 61.25 0, 52.5 0, 43.75 0, 35 0, 26.25 0, 17.5 0, 8.75 0, 0 0),
- (10 10, 16.25 16.25, 22.5 22.5, 28.75 28.75, 35 35, 41.25 41.25, 47.5 47.5, 53.75 53.75, 60 60, 51.66666666666667 60, 43.333333333333336 60, 35 60, 26.666666666666668 60, 18.333333333333336 60, 10 60, 10 51.66666666666667, 10 43.333333333333336, 10 35, 10 26.666666666666668, 10 18.333333333333336, 10 10))
+ POLYGON ((0 0, 0 10, 0 20, 0 30, 0 40, 0 50, 0 60, 0 70, 10 70, 20 70, 30 70, 40 70, 50 70, 60 70, 70 70, 70 60, 70 50, 70 40, 70 30, 70 20, 70 10, 70 0, 60 0, 50 0, 40 0, 30 0, 20 0, 10 0, 0 0),
+ (10 10, 16.25 16.25, 22.5 22.5, 28.75 28.75, 35 35, 41.25 41.25, 47.5 47.5, 53.75 53.75, 60 60, 50 60, 40 60, 30 60, 20 60, 10 60, 10 50, 10 40, 10 30, 10 20, 10 10))
</op></test>
</case>
<case>
<desc>mA - multipolygon</desc>
- <a> MULTIPOLYGON (((0 0, 0 70, 70 70, 70 0, 0 0),
- (10 10, 10 60, 60 60, 10 10)),
+ <a> MULTIPOLYGON (((0 0, 0 70, 70 70, 70 0, 0 0),
+ (10 10, 10 60, 60 60, 10 10)),
((80 110, 80 70, 120 70, 120 110, 80 110))) </a>
-MULTIPOLYGON (((80 110, 88 110, 96 110, 104 110, 112 110, 120 110, 120 102, 120 94, 120 86, 120 78, 120 70, 112 70, 104 70, 96 70, 88 70, 80 70, 80 78, 80 86, 80 94, 80 102, 80 110)),
- ((0 0, 0 8.75, 0 17.5, 0 26.25, 0 35, 0 43.75, 0 52.5, 0 61.25, 0 70, 8.75 70, 17.5 70, 26.25 70, 35 70, 43.75 70, 52.5 70, 61.25 70, 70 70, 70 61.25, 70 52.5, 70 43.75, 70 35, 70 26.25, 70 17.5, 70 8.75, 70 0, 61.25 0, 52.5 0, 43.75 0, 35 0, 26.25 0, 17.5 0, 8.75 0, 0 0),
- (10 10, 16.25 16.25, 22.5 22.5, 28.75 28.75, 35 35, 41.25 41.25, 47.5 47.5, 53.75 53.75, 60 60, 51.66666666666667 60, 43.333333333333336 60, 35 60, 26.666666666666668 60, 18.333333333333336 60, 10 60, 10 51.66666666666667, 10 43.333333333333336, 10 35, 10 26.666666666666668, 10 18.333333333333336, 10 10))) </op></test>
+ MULTIPOLYGON (((80 70, 80 80, 80 90, 80 100, 80 110, 90 110, 100 110, 110 110, 120 110, 120 100, 120 90, 120 80, 120 70, 110 70, 100 70, 90 70, 80 70)),
+ ((0 0, 0 10, 0 20, 0 30, 0 40, 0 50, 0 60, 0 70, 10 70, 20 70, 30 70, 40 70, 50 70, 60 70, 70 70, 70 60, 70 50, 70 40, 70 30, 70 20, 70 10, 70 0, 60 0, 50 0, 40 0, 30 0, 20 0, 10 0, 0 0),
+ (10 10, 16.25 16.25, 22.5 22.5, 28.75 28.75, 35 35, 41.25 41.25, 47.5 47.5, 53.75 53.75, 60 60, 50 60, 40 60, 30 60, 20 60, 10 60, 10 50, 10 40, 10 30, 10 20, 10 10)))
+ </op></test>
</case>
commit 9429ff3732080c6391cf01e78698fb214c5bc91a
Date: Thu Jan 28 18:39:30 2021 -0800
Move empty check to Densifier; reduce test boilerplate
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 9e78d9b..34d0d97 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1117,10 +1117,6 @@ extern "C" {
using geos::geom::util::Densifier;
return execute(extHandle, [&]() {
- if (g->isEmpty()) {
- return g->clone().release();
Densifier densifier(g);
densifier.setDistanceTolerance(tolerance);
auto g3 = densifier.getResultGeometry();
index e0c5387..9cab359 100644
@@ -157,6 +157,10 @@ Densifier::setDistanceTolerance(double tol)
Geometry::Ptr
Densifier::getResultGeometry() const
+ if (inputGeom->isEmpty()) {
+ return inputGeom->clone();
DensifyTransformer dt(distanceTolerance);
return dt.transform(inputGeom);
index 11ad056..b379f16 100644
@@ -4,11 +4,9 @@
#include <tut/tut.hpp>
// geos
#include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
+#include "capi_test_utils.h"
namespace tut {
@@ -16,28 +14,14 @@ namespace tut {
// Common data used in test cases.
-struct test_capigeosdensify_data {
+struct test_capigeosdensify_data : public capitest::utility {
GEOSGeometry* geom1_;
GEOSGeometry* geom2_;
- GEOSGeometry* geom3_;
GEOSWKTWriter* w_;
char* wkt_;
- static void
- notice(const char* fmt, ...)
- std::fprintf(stdout, "NOTICE: ");
- va_list ap;
- va_start(ap, fmt);
- std::vfprintf(stdout, fmt, ap);
- va_end(ap);
- std::fprintf(stdout, "\n");
test_capigeosdensify_data()
- : geom1_(nullptr), geom2_(nullptr), geom3_(nullptr), w_(nullptr)
+ : geom1_(nullptr), geom2_(nullptr), w_(nullptr)
initGEOS(notice, notice);
w_ = GEOSWKTWriter_create();
@@ -48,11 +32,9 @@ struct test_capigeosdensify_data {
GEOSGeom_destroy(geom1_);
GEOSGeom_destroy(geom2_);
- GEOSGeom_destroy(geom3_);
GEOSWKTWriter_destroy(w_);
geom1_ = nullptr;
geom2_ = nullptr;
- geom3_ = nullptr;
wkt_ = nullptr;
finishGEOS();
@@ -81,8 +63,8 @@ void object::test<1>()
- ensure_equals("result == expected", GEOSEqualsExact(geom2_, geom1_, 0), 1);
- ensure_equals("result SRID == expected SRID", GEOSGetSRID(geom2_), GEOSGetSRID(geom1_));
+ ensure_geometry_equals(geom2_, geom1_);
@@ -96,15 +78,14 @@ void object::test<2>()
- geom2_ = GEOSGeomFromWKT("POLYGON ((0 0, 5 0, 10 0, 10 5, 10 10, 5 10, 0 10, 0 5, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
- ensure(geom2_ != nullptr);
- GEOSSetSRID(geom2_, 3857);
- geom3_ = GEOSDensify(geom1_, 10.0);
+ ensure("result not null", geom2_ != nullptr);
+ geom2_,
+ "POLYGON ((0 0, 5 0, 10 0, 10 5, 10 10, 5 10, 0 10, 0 5, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
- ensure("result not null", geom3_ != nullptr);
- ensure_equals("result == expected", GEOSEqualsExact(geom3_, geom2_, 0), 1);
- ensure_equals("result SRID == expected SRID", GEOSGetSRID(geom3_), GEOSGetSRID(geom2_));
@@ -115,13 +96,12 @@ void object::test<3>()
- geom2_ = GEOSGeomFromWKT("POLYGON ((0 0, 5 0, 10 0, 10 5, 10 10, 5 10, 0 10, 0 5, 0 0), (1 1, 1 4, 1 7, 4 7, 7 7, 7 4, 7 1, 4 1, 1 1))");
+ geom2_ = GEOSDensify(geom1_, 5.00000000001);
- geom3_ = GEOSDensify(geom1_, 5.00000000001);
+ geom2_,
@@ -133,15 +113,14 @@ void object::test<4>()
- geom2_ = GEOSGeomFromWKT("LINESTRING (0 0, 2 2, 4 4, 6 6)");
- geom3_ = GEOSDensify(geom1_, 3.0);
+ geom2_ = GEOSDensify(geom1_, 3.0);
+ geom2_,
+ "LINESTRING (0 0, 2 2, 4 4, 6 6)");
@@ -153,15 +132,13 @@ void object::test<5>()
- geom2_ = GEOSGeomFromWKT("LINEARRING (0 0, 0 2, 0 4, 0 6, 2 6, 4 6, 6 6, 4 4, 2 2, 0 0)");
+ geom2_,
+ "LINEARRING (0 0, 0 2, 0 4, 0 6, 2 6, 4 6, 6 6, 4 4, 2 2, 0 0)");
// Densify a POINT
@@ -177,8 +154,8 @@ void object::test<6>()
// Densify a MULTIPOINT
@@ -194,8 +171,8 @@ void object::test<7>()
// Densify an empty polygon
@@ -210,7 +187,7 @@ void object::test<8>()
// Densify with an invalid tolerances should fail
commit 64ccc7ce96108e720f4f59931b047dcec7807866
Date: Thu Jan 28 12:09:07 2021 -0800
Remove guard for null geometry and associated test
index 7f7207e..9e78d9b 100644
@@ -1116,10 +1116,6 @@ extern "C" {
- if (g == nullptr) {
- return nullptr;
if (g->isEmpty()) {
index f0a7fcf..11ad056 100644
@@ -213,21 +213,11 @@ void object::test<8>()
-// Densify a null geometry
-// Result should be null
-template<>
-template<>
-void object::test<9>()
- geom2_ = GEOSDensify(nullptr, 3.0);
- ensure("result is null", geom2_ == nullptr);
// Note: this raises "IllegalArgumentException: Tolerance must be positive:
template<>
template<>
-void object::test<10>()
+void object::test<9>()
geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
commit 51c6e77ac0ac42f33a41f3eaeef3514c059115dc
Date: Thu Jan 28 11:52:42 2021 -0800
Fix geometry variable name
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 82faa3f..c6c23a4 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -428,9 +428,9 @@ extern "C" {
Geometry*
- GEOSDensify(const Geometry* g1, double tolerance)
+ GEOSDensify(const Geometry* g, double tolerance)
- return GEOSDensify_r(handle, g1, tolerance);
+ return GEOSDensify_r(handle, g, tolerance);
index e276a51..c6f1516 100644
@@ -2029,7 +2029,7 @@ extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle(
* Caller is responsible for freeing with GEOSGeom_destroy().
extern GEOSGeometry GEOS_DLL *GEOSDensify(
- const GEOSGeometry* g1,
+ const GEOSGeometry* g,
double tolerance);
index 24398ea..7f7207e 100644
@@ -1112,23 +1112,23 @@ extern "C" {
Geometry*
- GEOSDensify_r(GEOSContextHandle_t extHandle, const Geometry* g1, double tolerance)
+ GEOSDensify_r(GEOSContextHandle_t extHandle, const Geometry* g, double tolerance)
- if (g1 == nullptr) {
+ if (g == nullptr) {
return nullptr;
- if (g1->isEmpty()) {
- return g1->clone().release();
+ if (g->isEmpty()) {
+ return g->clone().release();
- Densifier densifier(g1);
+ Densifier densifier(g);
- g3->setSRID(g1->getSRID());
+ g3->setSRID(g->getSRID());
return g3.release();
commit 7960e9ff4abafc222bf848f55f8b771acac56a9c
Date: Thu Jan 28 11:35:58 2021 -0800
Add GEOSDensify to CAPI
diff --git a/NEWS b/NEWS
index 8b1da7a..6c9c555 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ Changes in 3.10.0
library (#868, Paul Ramsey)
- geosop CLI for GEOS (Martin Davis)
- Full doxygen of the C-API (Paul Ramsey)
+ - CAPI: GEOSDensify (Brendan Ward)
- Improvements:
- Preserve ordering of lines in overlay results (Martin Davis)
index 34b1c75..82faa3f 100644
@@ -428,6 +428,13 @@ extern "C" {
Geometry*
+ GEOSDensify(const Geometry* g1, double tolerance)
+ return GEOSDensify_r(handle, g1, tolerance);
+ Geometry*
GEOSSingleSidedBuffer(const Geometry* g, double width, int quadsegs,
int joinStyle, double mitreLimit, int leftSide)
index 863a177..e276a51 100644
@@ -582,6 +582,12 @@ extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle_r(
double width, int quadsegs, int endCapStyle,
int joinStyle, double mitreLimit);
+/** \see GEOSDensify */
+extern GEOSGeometry GEOS_DLL *GEOSDensify_r(
+ GEOSContextHandle_t handle,
+ double tolerance);
/** \see GEOSOffsetCurve */
extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve_r(
@@ -2012,6 +2018,21 @@ extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle(
double mitreLimit);
+* Densifies a geometry using a given distance tolerance.
+* Additional vertices will be added to every line segment
+* that is greater than or equal to this tolerance; these
+* vertices will evenly subdivide that segment.
+* Only linear components of input geometry are densified.
+* \param g The geometry to densify
+* \param tolerance the distance tolerance to densify
+* \return The densified geometry, or NULL on exception.
+* Caller is responsible for freeing with GEOSGeom_destroy().
+extern GEOSGeometry GEOS_DLL *GEOSDensify(
+ const GEOSGeometry* g1,
* Generates offset curve for linear geometry.
* Only LineStrings accepted as input.
* \param g The linear geometry to offset from
index 052c60f..24398ea 100644
@@ -37,6 +37,7 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/IntersectionMatrix.h>
#include <geos/geom/Envelope.h>
+#include <geos/geom/util/Densifier.h>
#include <geos/index/strtree/SimpleSTRtree.h>
#include <geos/index/strtree/GeometryItemDistance.h>
#include <geos/index/ItemVisitor.h>
@@ -1111,6 +1112,28 @@ extern "C" {
Geometry*
+ GEOSDensify_r(GEOSContextHandle_t extHandle, const Geometry* g1, double tolerance)
+ using geos::geom::util::Densifier;
+ if (g1 == nullptr) {
+ return nullptr;
+ return execute(extHandle, [&]() {
+ if (g1->isEmpty()) {
+ return g1->clone().release();
+ Densifier densifier(g1);
+ densifier.setDistanceTolerance(tolerance);
+ auto g3 = densifier.getResultGeometry();
+ g3->setSRID(g1->getSRID());
+ return g3.release();
+ Geometry*
GEOSOffsetCurve_r(GEOSContextHandle_t extHandle, const Geometry* g1, double width, int quadsegs, int joinStyle,
double mitreLimit)
new file mode 100644
index 0000000..f0a7fcf
--- /dev/null
@@ -0,0 +1,244 @@
+// Test Suite for C-API GEOSBuffer and GEOSBufferWithStyle
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capigeosdensify_data {
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ GEOSGeometry* geom3_;
+ GEOSWKTWriter* w_;
+ char* wkt_;
+ static void
+ notice(const char* fmt, ...)
+ std::fprintf(stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeosdensify_data()
+ : geom1_(nullptr), geom2_(nullptr), geom3_(nullptr), w_(nullptr)
+ initGEOS(notice, notice);
+ w_ = GEOSWKTWriter_create();
+ GEOSWKTWriter_setTrim(w_, 1);
+ ~test_capigeosdensify_data()
+ GEOSGeom_destroy(geom1_);
+ GEOSGeom_destroy(geom2_);
+ GEOSGeom_destroy(geom3_);
+ GEOSWKTWriter_destroy(w_);
+ geom1_ = nullptr;
+ geom2_ = nullptr;
+ geom3_ = nullptr;
+ wkt_ = nullptr;
+ finishGEOS();
+typedef test_group<test_capigeosdensify_data> group;
+typedef group::object object;
+group test_capigeosdensify_group("capi::GEOSDensify");
+// Test Cases
+// Densify with a tolerance slightly larger than length of all edges.
+// Result should match inputs.
+template<>
+template<>
+void object::test<1>()
+ geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+ ensure(geom1_ != nullptr);
+ geom2_ = GEOSDensify(geom1_, 10.00000000001);
+ ensure_equals("result == expected", GEOSEqualsExact(geom2_, geom1_, 0), 1);
+ ensure_equals("result SRID == expected SRID", GEOSGetSRID(geom2_), GEOSGetSRID(geom1_));
+// Densify with a tolerance equal to length of all outer edges.
+// Outer edges are densified; interior ring edges are not.
+template<>
+template<>
+void object::test<2>()
+ geom2_ = GEOSGeomFromWKT("POLYGON ((0 0, 5 0, 10 0, 10 5, 10 10, 5 10, 0 10, 0 5, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+ ensure(geom2_ != nullptr);
+ GEOSSetSRID(geom2_, 3857);
+ geom3_ = GEOSDensify(geom1_, 10.0);
+ ensure("result not null", geom3_ != nullptr);
+ ensure_equals("result == expected", GEOSEqualsExact(geom3_, geom2_, 0), 1);
+ ensure_equals("result SRID == expected SRID", GEOSGetSRID(geom3_), GEOSGetSRID(geom2_));
+template<>
+template<>
+void object::test<3>()
+ geom2_ = GEOSGeomFromWKT("POLYGON ((0 0, 5 0, 10 0, 10 5, 10 10, 5 10, 0 10, 0 5, 0 0), (1 1, 1 4, 1 7, 4 7, 7 7, 7 4, 7 1, 4 1, 1 1))");
+ geom3_ = GEOSDensify(geom1_, 5.00000000001);
+template<>
+template<>
+void object::test<4>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 6 6)");
+ geom2_ = GEOSGeomFromWKT("LINESTRING (0 0, 2 2, 4 4, 6 6)");
+ geom3_ = GEOSDensify(geom1_, 3.0);
+// Densify a LINEARRING
+template<>
+template<>
+void object::test<5>()
+ geom1_ = GEOSGeomFromWKT("LINEARRING (0 0, 0 6, 6 6, 0 0)");
+ geom2_ = GEOSGeomFromWKT("LINEARRING (0 0, 0 2, 0 4, 0 6, 2 6, 4 6, 6 6, 4 4, 2 2, 0 0)");
+// Densify a POINT
+// Results should match inputs
+template<>
+template<>
+void object::test<6>()
+ geom1_ = GEOSGeomFromWKT("POINT (0 0)");
+// Densify a MULTIPOINT
+template<>
+template<>
+void object::test<7>()
+ geom1_ = GEOSGeomFromWKT("MULTIPOINT ((0 0), (10 10))");
+// Densify an empty polygon
+template<>
+template<>
+void object::test<8>()
+ geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+// Densify a null geometry
+// Result should be null
+template<>
+template<>
+ geom2_ = GEOSDensify(nullptr, 3.0);
+ ensure("result is null", geom2_ == nullptr);
+// Densify with an invalid tolerances should fail
+// Note: this raises "IllegalArgumentException: Tolerance must be positive:
+template<>
+template<>
+void object::test<10>()
+ geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
+ geom2_ = GEOSDensify(geom1_, 0.0);
+ ensure(geom2_ == nullptr);
+ geom2_ = GEOSDensify(geom1_, -1.0);
+} // namespace tut
Summary of changes:
NEWS | 1 +
capi/geos_c.cpp | 7 +
capi/geos_c.h.in | 21 +++
capi/geos_ts_c.cpp | 15 ++
src/geom/util/Densifier.cpp | 13 +-
tests/unit/capi/GEOSDensifyTest.cpp | 214 ++++++++++++++++++++++++++
tests/xmltester/tests/general/TestDensify.xml | 36 +++--
7 files changed, 292 insertions(+), 15 deletions(-)
create mode 100644 tests/unit/capi/GEOSDensifyTest.cpp
hooks/post-receive
More information about the geos-commits
