[geos-commits] [SCM] GEOS branch master updated. 164de34ba39bcb6e597b8e3db9c4fa802d7c45b5
git at osgeo.org
git at osgeo.org
Mon Feb 1 11:06:06 PST 2021
the project "GEOS".
via 164de34ba39bcb6e597b8e3db9c4fa802d7c45b5 (commit)
via 076d68322f2754a0be4696946187a261264436ba (commit)
from 40e90870c7c0328c5ea2ee67174c6d294dc9b51b (commit)
revisions in full, below.
commit 164de34ba39bcb6e597b8e3db9c4fa802d7c45b5
Merge: 076d683 40e9087
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Feb 1 11:05:56 2021 -0800
Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit 076d68322f2754a0be4696946187a261264436ba
Date: Mon Feb 1 11:05:49 2021 -0800
Remote autotools note and add note on test names
diff --git a/tests/README.md b/tests/README.md
index 5e547af..89f40d5 100644
--- a/tests/README.md
+++ b/tests/README.md
@@ -6,12 +6,6 @@ GEOS Testing
Paths are given relative to GEOS root.
Note some executables have different names.
-### Autotools
-* Executables are in-tree
- * `tests/unit/geos_unit`
- * `tests/xmltests/XMLtester`
### CMake
* Executables are in build directory (usually `../build`)
@@ -47,4 +41,9 @@ CMake - Run test file
bin/test_xmltester ../geos/tests/xmltester/tests/general/TestBoundary.xml
+## Adding New Tests
+* In order for new unit tests to be picked up by the test harness, they **must** be named using the name pattern "\*Test.cpp".
+* In order for new XML tests to be picked up, they must reside in a directory under the `xmltester/` directory and have a `.xml` file suffix.
Summary of changes:
tests/README.md | 11 +++++------
1 file changed, 5 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
