[geos-commits] [SCM] GEOS branch master updated. 587049c216625a6444984e3e7293cd62dd494fb6
Tue Feb 2 07:03:52 PST 2021
the project "GEOS".
       via  587049c216625a6444984e3e7293cd62dd494fb6 (commit)
      from  2d335df0c3ffccec58dcd71508c94ef76c836a46 (commit)
revisions in full, below.
commit 587049c216625a6444984e3e7293cd62dd494fb6
Author: Brendan C. Ward <bcward at astutespruce.com>
Date:   Mon Feb 1 14:19:19 2021 -0800
    Make sure that Polygon::compareToSameClass compares holes
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index 8d3712a..4b85e25 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -134,8 +134,6 @@ public:
     std::unique_ptr<Geometry> reverse() const override;
-    int compareToSameClass(const Geometry* p) const override; //was protected
     const Coordinate* getCoordinate() const override;
     double getArea() const override;
@@ -150,6 +148,8 @@ protected:
     Polygon(const Polygon& p);
+    int compareToSameClass(const Geometry* p) const override;
      * Constructs a <code>Polygon</code> with the given exterior
      * and interior boundaries.
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 2acf1f2..708563a 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -329,7 +329,30 @@ int
 Polygon::compareToSameClass(const Geometry* g) const
     const Polygon* p = dynamic_cast<const Polygon*>(g);
-    return shell->compareToSameClass(p->shell.get());
+    int shellComp = shell->compareToSameClass(p->shell.get());
+    if (shellComp != 0) {
+        return shellComp;
+    size_t nHole1 = getNumInteriorRing();
+    size_t nHole2 = p->getNumInteriorRing();
+    if (nHole1 < nHole2) {
+        return -1;
+    if (nHole1 > nHole2) {
+        return 1;
+    int holeComp = 0;
+    for (size_t i=0; i < nHole1; i++) {
+        const LinearRing *lr = p->getInteriorRingN(i);
+        holeComp = getInteriorRingN(i)->compareToSameClass(lr);
+        if (holeComp != 0) {
+            return holeComp;
+    return 0;
diff --git a/tests/unit/geom/PolygonTest.cpp b/tests/unit/geom/PolygonTest.cpp
index cd62ae2..970aee2 100644
--- a/tests/unit/geom/PolygonTest.cpp
+++ b/tests/unit/geom/PolygonTest.cpp
@@ -611,4 +611,25 @@ void object::test<42>
     ensure(!poly_->isDimensionStrict(geos::geom::Dimension::L));
+// test compareToSameClass for polygons including holes
+template<>
+template<>
+void object::test<43>
+    auto poly = reader_.read("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+    ensure("polygon should equal self",
+        poly->compareTo(poly.get()) == 0);
+    auto poly2 = reader_.read("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (2 2, 2 3, 3 3, 3 2, 2 2))");
+    ensure("polygons with different holes but same shell are not equal",
+        poly->compareTo(poly2.get()) != 0);
+    auto poly3 = reader_.read("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
+    ensure("polygons with and without holes are not equal",
+        poly->compareTo(poly3.get()) != 0);
 } // namespace tut
Summary of changes:
 include/geos/geom/Polygon.h     |  4 ++--
 src/geom/Polygon.cpp            | 25 ++++++++++++++++++++++++-
 tests/unit/geom/PolygonTest.cpp | 21 +++++++++++++++++++++
 3 files changed, 47 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
