[geos-commits] [SCM] GEOS branch 3.7 updated. 88d176e8662250034900f0578bc38736c21c4194
Wed Feb 3 14:58:08 PST 2021
the project "GEOS".
The branch, 3.7 has been updated
       via  88d176e8662250034900f0578bc38736c21c4194 (commit)
      from  2926110b6beed74fe4182f73c6c9dac60c02a255 (commit)
revisions in full, below.
commit 88d176e8662250034900f0578bc38736c21c4194
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Feb 3 14:58:03 2021 -0800
    Add github actions to 3.7
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
new file mode 100644
index 0000000..2007c7f
--- /dev/null
+++ b/.github/workflows/ci.yml
@@ -0,0 +1,113 @@
+# GitHub Actions for GEOS
+# Paul Ramsey <pramsey at cleverelephant dot ca>
+# Based on AZP configuration by Mateusz Loskot <mateusz at loskot dot net>
+name: CI
+on: [push, pull_request]
+env:
+  BUILD_TYPE: 'Release'
+  MAKEFLAGS: '-j2'
+jobs:
+  linux:
+    name: 'Linux'
+    strategy:
+      matrix:
+        ci:
+          compiler: g++,
+          build: cmake,
+          cxxstd: 11,
+          arch: 64,
+          packages: 'g++ cmake doxygen',
+          os: ubuntu-18.04
+          compiler: g++,
+          build: autotools,
+          cxxstd: 11,
+          arch: 64,
+          packages: 'g++ automake doxygen git2cl',
+          os: ubuntu-18.04
+          compiler: g++,
+          build: autotools,
+          cxxstd: 11,
+          arch: 32,
+          packages: 'g++-4.8-multilib gcc-4.8-multilib g++-multilib gcc-multilib doxygen automake git2cl',
+          os: ubuntu-18.04
+          compiler: clang++,
+          build: cmake,
+          cxxstd: 11,
+          arch: 64,
+          packages: 'clang cmake doxygen',
+          os: ubuntu-18.04
+          compiler: g++,
+          build: cmake,
+          cxxstd: 11,
+          arch: 64,
+          os: ubuntu-20.04
+          build: cmake,
+          cxxstd: 11,
+          arch: 64,
+          os: ubuntu-16.04
+          build: cmake,
+          cxxstd: 14,
+          arch: 64,
+          os: ubuntu-20.04
+    runs-on: ${{ matrix.ci.os }}
+    steps:
+    - name: 'Install'
+      run: |
+        set -e
+        uname -a
+        sudo -E apt-get update
+        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make ${{ matrix.ci.packages }}
+    - name: 'Check Out'
+      uses: actions/checkout at v2
+    - name: 'Build'
+      run: |
+        set -e
+        if [ ${{ matrix.ci.build }} == 'cmake' ];
+        then
+          mkdir build.cmake
+          cd build.cmake
+          cmake --version
+          cmake -DCMAKE_CXX_COMPILER=${{ matrix.ci.compiler }} -DCMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} -DBUILD_DOCUMENTATION=YES -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+          make
+          cmake --build . --target docs
+          ctest --output-on-failure .
+        else
+          set -e
+          ./autogen.sh
+          mkdir build.autotools
+          cd build.autotools
+          CFLAGS="-std=c++${{ matrix.ci.cxxstd }} -m${{ matrix.ci.arch }}"
+          ../configure CC=${{ matrix.ci.compiler }} CXX=${{ matrix.ci.compiler }} CXXFLAGS="$CFLAGS" CFLAGS="$CFLAGS"
+          make && make check && make distcheck
+        fi
Summary of changes:
 .github/workflows/ci.yml | 113 +++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 113 insertions(+)
 create mode 100644 .github/workflows/ci.yml
hooks/post-receive
More information about the geos-commits mailing list
