[geos-commits] [SCM] GEOS branch master updated. 4b6ccd37d457db83e1c26d2dc051dfe29f83b0d0
git at osgeo.org
git at osgeo.org
Thu Feb 4 16:06:01 PST 2021
the project "GEOS".
via 4b6ccd37d457db83e1c26d2dc051dfe29f83b0d0 (commit)
via 0726ed493068994a4675266cc6cba18430f4a661 (commit)
via 63fc947c1669dd42e2b4e4731ea2b91dfbfd1a6d (commit)
via 77663b3d32d677e873cf5dec9cc7c3c94476e7f6 (commit)
via b7bcd68145a5bcdd2c56a91352aa4bb59f06d8c1 (commit)
from caa54c38e85d5393d7f045f4f3253fff61de72a9 (commit)
revisions in full, below.
commit 4b6ccd37d457db83e1c26d2dc051dfe29f83b0d0
Merge: 0726ed4 63fc947
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Feb 4 19:05:47 2021 -0500
Merge remote-tracking branch 'eyal0/patch-1'
commit 0726ed493068994a4675266cc6cba18430f4a661
Merge: caa54c3 77663b3
Date: Thu Feb 4 19:05:19 2021 -0500
Merge branch 'combiner-rehab'
commit 63fc947c1669dd42e2b4e4731ea2b91dfbfd1a6d
Author: Eyal <109809+eyal0 at users.noreply.github.com>
Date: Wed Feb 3 21:14:25 2021 -0700
Remove autotools configuration instructions
autotools configuration was already removed in 29802a665505aa5fa00f942754d6d16ddfed5823
diff --git a/INSTALL b/INSTALL
index e9ea10a..c9895a8 100644
--- a/INSTALL
+++ b/INSTALL
@@ -7,24 +7,7 @@ compiler.
### Unix
-GEOS can be built on Unix systems using either the autotools or CMake build
-systems.
-#### Using Autotools:
-When building GEOS using autotools, a `configure` script must first be generated
-using the `autogen.sh` file included in the root of the repository:
- ./autogen.sh
-An out-of-tree build can then be initiated by creating a subdirectory and
-running the generated `configure` script from that subdirectory:
- mkdir obj && cd obj && ../configure
-Once the `configure` script has run, GEOS can be built by running `make` and
-installed by running `make install`. The test suite can be run using `make
-check`.
+GEOS can be built on Unix systems using the CMake build system.
#### Using CMake:
commit 77663b3d32d677e873cf5dec9cc7c3c94476e7f6
Date: Wed Feb 3 20:15:35 2021 -0500
Fix MSVC build
diff --git a/include/geos/geom/util/GeometryCombiner.h b/include/geos/geom/util/GeometryCombiner.h
index 44da3de..dbe06a6 100644
--- a/include/geos/geom/util/GeometryCombiner.h
+++ b/include/geos/geom/util/GeometryCombiner.h
@@ -22,6 +22,8 @@
#include <memory>
#include <vector>
+#include <geos/export.h>
// Forward declarations
namespace geos {
namespace geom {
@@ -46,7 +48,7 @@ namespace util { // geos.geom.util
* @see GeometryFactory#buildGeometry
-class GeometryCombiner {
+class GEOS_DLL GeometryCombiner {
public:
/** \brief
* Copies a collection of geometries and combines the result.
commit b7bcd68145a5bcdd2c56a91352aa4bb59f06d8c1
Date: Wed Feb 3 17:32:09 2021 -0500
Enable GeometryCombiner to consume its inputs
Add test cases and make "skipEmpty" flag settable.
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 9953e70..23d74c3 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -353,7 +353,7 @@ public:
/// Will clone the geometries accessible trough the iterator.
- /// @tparam T an iterator yelding something which casts to const Geometry*
+ /// @tparam T an iterator yielding something which casts to const Geometry*
/// @param from start iterator
/// @param toofar end iterator
index 3faf21b..44da3de 100644
@@ -49,16 +49,23 @@ namespace util { // geos.geom.util
public:
/** \brief
- * Combines a collection of geometries.
+ * Copies a collection of geometries and combines the result.
* @param geoms the geometries to combine (ownership left to caller)
* @return the combined geometry
static std::unique_ptr<Geometry> combine(std::vector<const Geometry*> const& geoms);
- static std::unique_ptr<Geometry> combine(std::vector<std::unique_ptr<Geometry>> const& geoms);
/** \brief
- * Combines two geometries.
+ * Combines a collection of geometries.
+ * @param geoms the geometries to combine (ownership transferred to combined geometry)
+ * @return the combined geometry
+ static std::unique_ptr<Geometry> combine(std::vector<std::unique_ptr<Geometry>> && geoms);
+ /** \brief
+ * Copies two geometries and combines the result.
* @param g0 a geometry to combine (ownership left to caller)
* @param g1 a geometry to combine (ownership left to caller)
@@ -67,7 +74,17 @@ public:
static std::unique_ptr<Geometry> combine(const Geometry* g0, const Geometry* g1);
/** \brief
- * Combines three geometries.
+ * Combines two geometries.
+ * @param g0 a geometry to combine (ownership transferred to combined geometry)
+ * @param g1 a geometry to combine (ownership transferred to combined geometry)
+ static std::unique_ptr<Geometry> combine(std::unique_ptr<Geometry> && g0,
+ std::unique_ptr<Geometry> && g1);
+ /** \brief
+ * Copies three geometries and combines the result.
@@ -76,10 +93,21 @@ public:
static std::unique_ptr<Geometry> combine(const Geometry* g0, const Geometry* g1, const Geometry* g2);
+ /** \brief
+ * Combines three geometries.
+ * @param g2 a geometry to combine (ownership transferred to combined geometry)
+ std::unique_ptr<Geometry> && g1,
+ std::unique_ptr<Geometry> && g2);
private:
- GeometryFactory const* geomFactory;
+ std::vector<std::unique_ptr<Geometry>> inputGeoms;
bool skipEmpty;
- std::vector<const Geometry*> const& inputGeoms;
public:
/** \brief
@@ -87,15 +115,16 @@ public:
- GeometryCombiner(std::vector<const Geometry*> const& geoms);
+ explicit GeometryCombiner(std::vector<const Geometry*> const& geoms);
+ explicit GeometryCombiner(std::vector<std::unique_ptr<Geometry>> && geoms);
/** \brief
* Extracts the GeometryFactory used by the geometries in a collection.
- * @param geoms
* @return a GeometryFactory
- static GeometryFactory const* extractFactory(std::vector<const Geometry*> const& geoms);
+ GeometryFactory const* extractFactory() const;
/** \brief
* Computes the combination of the input geometries
@@ -105,8 +134,10 @@ public:
std::unique_ptr<Geometry> combine();
-private:
- void extractElements(const Geometry* geom, std::vector<const Geometry*>& elems);
+ /** \brief
+ * Set a flag indicating that empty geometries should be omitted from the result.
+ void setSkipEmpty(bool);
// Declare type as noncopyable
GeometryCombiner(const GeometryCombiner& other) = delete;
diff --git a/src/geom/util/GeometryCombiner.cpp b/src/geom/util/GeometryCombiner.cpp
index d99c350..3a5b174 100644
--- a/src/geom/util/GeometryCombiner.cpp
+++ b/src/geom/util/GeometryCombiner.cpp
@@ -19,20 +19,15 @@
#include <geos/geom/util/GeometryCombiner.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/GeometryCollection.h>
namespace geos {
namespace geom { // geos.geom
-GeometryCombiner::combine(std::vector<std::unique_ptr<Geometry>> const& geoms)
+GeometryCombiner::combine(std::vector<std::unique_ptr<Geometry>>&& geoms)
- std::vector<const Geometry*> geomptrs;
- for(const auto& g : geoms) {
- geomptrs.push_back(g.get());
- GeometryCombiner combiner(geomptrs);
+ GeometryCombiner combiner(std::move(geoms));
return combiner.combine();
@@ -55,6 +50,30 @@ GeometryCombiner::combine(const Geometry* g0, const Geometry* g1)
+GeometryCombiner::combine(std::unique_ptr<Geometry> && g0,
+ std::vector<std::unique_ptr<Geometry>> geoms(2);
+ geoms[0] = std::move(g0);
+ geoms[1] = std::move(g1);
+ return combiner.combine();
+std::unique_ptr<Geometry>
+ std::vector<std::unique_ptr<Geometry>> geoms(3);
+ geoms[2] = std::move(g2);
GeometryCombiner::combine(const Geometry* g0, const Geometry* g1,
const Geometry* g2)
@@ -67,51 +86,47 @@ GeometryCombiner::combine(const Geometry* g0, const Geometry* g1,
-GeometryCombiner::GeometryCombiner(std::vector<const Geometry*> const& geoms)
- : geomFactory(extractFactory(geoms)), skipEmpty(false), inputGeoms(geoms)
+GeometryCombiner::GeometryCombiner(std::vector<const Geometry*> const& geoms) : skipEmpty(false)
+ for(const auto& geom : geoms) {
+ for (std::size_t i = 0; i < geom->getNumGeometries(); i++) {
+ auto part = geom->getGeometryN(i);
+ inputGeoms.push_back(part->clone());
-GeometryFactory const*
-GeometryCombiner::extractFactory(std::vector<const Geometry*> const& geoms)
+GeometryCombiner::GeometryCombiner(std::vector<std::unique_ptr<Geometry>> && geoms) : skipEmpty(false)
- return geoms.empty() ? nullptr : geoms.front()->getFactory();
+ for(auto& geom : geoms) {
+ auto coll = dynamic_cast<GeometryCollection *>(geom.get());
+ if (coll) {
+ for (auto &part : coll->releaseGeometries()) {
+ inputGeoms.push_back(std::move(part));
+ } else {
+ inputGeoms.push_back(std::move(geom));
GeometryCombiner::combine()
- std::vector<const Geometry*> elems;
+ auto geomFactory = inputGeoms.empty() ? GeometryFactory::getDefaultInstance() : inputGeoms.front()->getFactory();
- for(const auto& geom : inputGeoms) {
- extractElements(geom, elems);
- if(elems.empty()) {
- if(geomFactory != nullptr) {
- return std::unique_ptr<Geometry>(geomFactory->createGeometryCollection());
- return nullptr;
+ if (skipEmpty) {
+ inputGeoms.erase(std::remove_if(inputGeoms.begin(), inputGeoms.end(), [](std::unique_ptr<Geometry> & g) {
+ return g->isEmpty();
+ }), inputGeoms.end());
// return the "simplest possible" geometry
- return std::unique_ptr<Geometry>(geomFactory->buildGeometry(elems));
+ return geomFactory->buildGeometry(std::move(inputGeoms));
-void
-GeometryCombiner::extractElements(const Geometry* geom, std::vector<const Geometry*>& elems)
- if(geom == nullptr) {
- return;
- for(std::size_t i = 0; i < geom->getNumGeometries(); ++i) {
- const Geometry* elemGeom = geom->getGeometryN(i);
- if(skipEmpty && elemGeom->isEmpty()) {
- continue;
- elems.push_back(elemGeom);
+void GeometryCombiner::setSkipEmpty(bool b) {
+ skipEmpty = b;
} // namespace geos.geom.util
diff --git a/src/operation/union/OverlapUnion.cpp b/src/operation/union/OverlapUnion.cpp
index 7e21ed2..c17e06c 100644
--- a/src/operation/union/OverlapUnion.cpp
+++ b/src/operation/union/OverlapUnion.cpp
@@ -84,7 +84,7 @@ OverlapUnion::combine(std::unique_ptr<Geometry>& unionGeom, std::vector<std::uni
return std::move(unionGeom);
disjointPolys.push_back(std::move(unionGeom));
- return GeometryCombiner::combine(disjointPolys);
+ return GeometryCombiner::combine(std::move(disjointPolys));
/* private */
diff --git a/tests/unit/geom/util/GeometryCombinerTest.cpp b/tests/unit/geom/util/GeometryCombinerTest.cpp
new file mode 100644
index 0000000..7ec489b
--- /dev/null
+++ b/tests/unit/geom/util/GeometryCombinerTest.cpp
@@ -0,0 +1,125 @@
+// Test Suite for geos::geom::util::GeometryCombiner class.
+// tut
+#include <tut/tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/geom/util/GeometryCombiner.h>
+#include <utility.h>
+// std
+#include <vector>
+namespace tut {
+// Test Group
+// Common data used by tests
+struct test_geometrycombiner_data {
+ using GeometryCombiner = geos::geom::util::GeometryCombiner;
+ geos::io::WKTReader wktreader_;
+typedef test_group<test_geometrycombiner_data> group;
+typedef group::object object;
+group test_geometrycombiner_group("geos::geom::util::GeometryCombiner");
+// Two-argument version
+template<>
+template<>
+void object::test<1>(){
+ auto g1 = wktreader_.read("POINT (1 1)");
+ auto g2 = wktreader_.read("POINT (2 2)");
+ auto result_via_copy = GeometryCombiner::combine(g1.get(), g2.get());
+ ensure_equals_geometry(result_via_copy.get(), "MULTIPOINT ((1 1), (2 2))");
+ auto result_via_move = GeometryCombiner::combine(std::move(g1), std::move(g2));
+ ensure_equals_geometry(result_via_move.get(), result_via_copy.get());
+// Three-argument version
+template<>
+template<>
+void object::test<2>(){
+ auto g3 = wktreader_.read("LINESTRING (3 3, 4 4)");
+ auto result_via_copy = GeometryCombiner::combine(g1.get(), g2.get(), g3.get());
+ ensure_equals_geometry(result_via_copy.get(), "GEOMETRYCOLLECTION (POINT (1 1), POINT (2 2), LINESTRING (3 3, 4 4))");
+ auto result_via_move = GeometryCombiner::combine(std::move(g1), std::move(g2), std::move(g3));
+// Vector version
+template<>
+template<>
+void object::test<3>() {
+ std::vector<std::unique_ptr<geos::geom::Geometry>> geoms;
+ geoms.push_back(wktreader_.read("POINT (1 1)"));
+ geoms.push_back(wktreader_.read("POLYGON EMPTY"));
+ geoms.push_back(wktreader_.read("POINT (2 2)"));
+ GeometryCombiner gc(std::move(geoms));
+ gc.setSkipEmpty(true);
+ auto result = gc.combine();
+ ensure_equals_geometry(result.get(), "MULTIPOINT ((1 1), (2 2))");
+// Outermost level of GeometryCollection is collapsed
+template<>
+template<>
+void object::test<4>() {
+ auto g1 = wktreader_.read("MULTIPOINT ((1 1), (2 2))");
+ auto g2 = wktreader_.read("MULTILINESTRING ((3 3, 4 4), (5 5, 6 6))");
+ auto result_via_copy = GeometryCombiner::combine(g1->clone(), g2->clone());
+ ensure_equals_geometry(result_via_copy.get(), "GEOMETRYCOLLECTION("
+ "POINT (1 1),"
+ "POINT (2 2),"
+ "LINESTRING (3 3, 4 4),"
+ "LINESTRING (5 5, 6 6))");
+// Test behavior when only empty inputs provided
+template<>
+template<>
+void object::test<5>()
+ geoms.emplace_back(wktreader_.read("POINT EMPTY"));
+ ensure_equals_geometry(result.get(), "GEOMETRYCOLLECTION EMPTY");
+// Test behavior when no inputs provided
+template<>
+template<>
+void object::test<6>()
+ std::vector<const geos::geom::Geometry*> geoms;
+ GeometryCombiner gc(geoms);
+} // namespace tut
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index d239a76..12e3c47 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -125,6 +125,7 @@ ensure_equals_geometry(T1 const* lhs, T2 const* rhs)
ensure(lhs != 0 && rhs != 0 && lhs != rhs);
template <typename T>
inline void
ensure_equals_geometry(T const* lhs_in, T const* rhs_in, double tolerance = 0.0)
@@ -189,7 +190,21 @@ ensure_equals_geometry(T const* lhs_in, T const* rhs_in, double tolerance = 0.0)
+template<typename T>
+inline void
+ensure_equals_geometry(const T& lhs, const char* rhs, double tolerance = 0.0) {
+ geos::io::WKTReader reader(lhs->getFactory());
+ auto rhs_geom = reader.read(rhs);
+ ensure_equals_geometry(lhs, rhs_geom.get(), tolerance);
+inline void
+ensure_equals_geometry(const T& lhs, const std::string& rhs, double tolerance = 0.0) {
template <>
inline void
Summary of changes:
INSTALL | 19 +---
include/geos/geom/GeometryFactory.h | 2 +-
include/geos/geom/util/GeometryCombiner.h | 57 +++++++++---
src/geom/util/GeometryCombiner.cpp | 89 ++++++++++--------
src/operation/union/OverlapUnion.cpp | 2 +-
tests/unit/geom/util/GeometryCombinerTest.cpp | 125 ++++++++++++++++++++++++++
tests/unit/utility.h | 15 ++++
7 files changed, 240 insertions(+), 69 deletions(-)
create mode 100644 tests/unit/geom/util/GeometryCombinerTest.cpp
hooks/post-receive
More information about the geos-commits
