[geos-commits] [SCM] GEOS branch master updated. e30955844dc6ad36669caee1c19619ebf8c54df4
git at osgeo.org
git at osgeo.org
Mon Feb 8 17:16:03 PST 2021
the project "GEOS".
via e30955844dc6ad36669caee1c19619ebf8c54df4 (commit)
from df1d6c99428266c6314dce033bdcc9e9b499bc3b (commit)
revisions in full, below.
commit e30955844dc6ad36669caee1c19619ebf8c54df4
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Feb 8 17:15:58 2021 -0800
Fix OverlayNG handling of flat interior line
diff --git a/src/operation/overlayng/OverlayUtil.cpp b/src/operation/overlayng/OverlayUtil.cpp
index b424933..eb6f3a8 100644
--- a/src/operation/overlayng/OverlayUtil.cpp
+++ b/src/operation/overlayng/OverlayUtil.cpp
@@ -48,6 +48,10 @@ OverlayUtil::safeExpandDistance(const Envelope* env, const PrecisionModel* pm)
if (isFloating(pm)) {
// if PM is FLOAT then there is no scale factor, so add 10%
double minSize = std::min(env->getHeight(), env->getWidth());
+ // heuristic to ensure zero-width envelopes don't cause total clipping
+ if (minSize <= 0.0) {
+ minSize = std::max(env->getHeight(), env->getWidth());
envExpandDist = SAFE_ENV_BUFFER_FACTOR * minSize;
else {
diff --git a/tests/unit/operation/overlayng/OverlayNGTest.cpp b/tests/unit/operation/overlayng/OverlayNGTest.cpp
index b753159..ce73231 100644
--- a/tests/unit/operation/overlayng/OverlayNGTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGTest.cpp
@@ -553,10 +553,33 @@ template<>
template<>
void object::test<43> ()
+ set_test_name("testPolygonLineIntersectionOrder");
std::string a = "POLYGON ((1 1, 1 9, 9 9, 9 7, 3 7, 3 3, 9 3, 9 1, 1 1))";
std::string b = "MULTILINESTRING ((2 10, 2 0), (4 10, 4 0))";
std::string exp = "MULTILINESTRING ((2 9, 2 1), (4 9, 4 7), (4 3, 4 1))";
testOverlay(a, b, exp, OverlayNG::INTERSECTION, 0);
+template<>
+template<>
+void object::test<44> ()
+ set_test_name("testPolygonLineVerticalntersection");
+ std::string a = "POLYGON ((-200 -200, 200 -200, 200 200, -200 200, -200 -200))";
+ std::string b = "LINESTRING (-100 100, -100 -100)";
+ std::string exp = "LINESTRING (-100 100, -100 -100)";
+ testOverlay(a, b, exp, OverlayNG::INTERSECTION, 0);
+template<>
+template<>
+void object::test<45> ()
+ set_test_name("testPolygonLineHorizontalIntersection");
+ std::string a = "POLYGON ((10 90, 90 90, 90 10, 10 10, 10 90))";
+ std::string b = "LINESTRING (20 50, 80 50)";
+ std::string exp = "LINESTRING (20 50, 80 50)";
} // namespace tut
diff --git a/tests/xmltester/tests/general/TestNGOverlayL.xml b/tests/xmltester/tests/general/TestNGOverlayL.xml
index a928edf..4ec2fab 100644
--- a/tests/xmltester/tests/general/TestNGOverlayL.xml
+++ b/tests/xmltester/tests/general/TestNGOverlayL.xml
@@ -205,6 +205,31 @@ MULTILINESTRING ((150 150, 200 200, 300 300, 400 200), (100 100, 150 150), (190
</case>
<case>
+ <desc>LA - vertical Line</desc>
+ <a>
+ LINESTRING (50 50, 50 20)
+ </a>
+ <b>
+ POLYGON ((10 60, 90 60, 90 10, 10 10, 10 60))
+ </b>
+<test> <op name="intersectionNG" arg1="A" arg2="B">
+LINESTRING (50 50, 50 20)
+ </op></test>
+<test> <op name="unionNG" arg1="A" arg2="B">
+POLYGON ((90 60, 90 10, 10 10, 10 60, 90 60))
+ </op></test>
+<test> <op name="differenceNG" arg1="A" arg2="B">
+LINESTRING EMPTY
+ </op></test>
+<test> <op name="differenceNG" arg1="B" arg2="A">
+ </op></test>
+<test> <op name="symdifferenceNG" arg1="A" arg2="B">
+ </op></test>
+</case>
+<case>
<desc>mLmA - disjoint and overlaps in lines and points</desc>
<a>
MULTILINESTRING ((50 150, 150 150), (100 350, 200 350), (320 350, 350 350), (300 150, 400 150), (150 300, 400 300))
Summary of changes:
src/operation/overlayng/OverlayUtil.cpp | 4 ++++
tests/unit/operation/overlayng/OverlayNGTest.cpp | 23 ++++++++++++++++++++++
tests/xmltester/tests/general/TestNGOverlayL.xml | 25 ++++++++++++++++++++++++
3 files changed, 52 insertions(+)
hooks/post-receive
More information about the geos-commits
