[geos-commits] [SCM] GEOS branch master updated. 518105d6da791a16d05629e2073be19433d93ddf
git at osgeo.org
git at osgeo.org
Thu Jan 7 13:20:27 PST 2021
the project "GEOS".
via 518105d6da791a16d05629e2073be19433d93ddf (commit)
from cb6e27944bf53f683797f314630862d9ee5fa73b (commit)
revisions in full, below.
commit 518105d6da791a16d05629e2073be19433d93ddf
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Jan 7 13:20:22 2021 -0800
Add geosop distance and nearestPoints operations
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index eb75925..7ea8ed7 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -23,6 +23,7 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/prep/PreparedGeometry.h>
#include <geos/geom/prep/PreparedGeometryFactory.h>
+#include <geos/operation/distance/DistanceOp.h>
#include <geos/operation/relate/RelateOp.h>
#include <geos/operation/valid/MakeValid.h>
#include <geos/operation/overlayng/OverlayNG.h>
@@ -77,31 +78,50 @@ GeomFunction::init()
[](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
return new Result( geom->covers( geomB.get() ) );
+ add("distance", "computes distance between geometry A and B", 2, 0,
+ [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
+ return new Result( geom->distance( geomB.get() ) );
add("envelope",
return new Result( geom->getCentroid() );
add("interiorPoint",
return new Result( geom->getInteriorPoint() );
add("intersects", "tests if geometry A and B intersect", 2, 0,
return new Result( geom->intersects( geomB.get() ) );
add("isValid", "tests if geometry A is valid", 1, 0,
return new Result( geom->isValid() );
add("length",
return new Result( geom->getLength() );
add("makeValid",
return new Result( geos::operation::valid::MakeValid().build( geom.get() ) );
+ add("nearestPoints", "computes nearest points of geometry A and B", 2, 0,
+ std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(geom.get(), geomB.get());
+ auto factory = geom->getFactory();
+ auto res = factory->createLineString( std::move(cs) );
+ return new Result( std::move(res) );
add("polygonize",
geos::operation::polygonize::Polygonizer p;
@@ -147,7 +167,7 @@ GeomFunction::init()
return new Result( prepGeomCache->covers( geomB.get() ) );
- add("intersectsPrep", "tests if geometry A intersects geometry B using PreparedGeometry", 2, 0,
+ add("intersectsPrep", "tests if geometry A intersects B using PreparedGeometry", 2, 0,
if (cacheKey == nullptr || cacheKey != geom.get()) {
auto pg = std::unique_ptr<const PreparedGeometry>(
@@ -158,6 +178,30 @@ GeomFunction::init()
return new Result( prepGeomCache->intersects( geomB.get() ) );
+ add("distancePrep", "computes distance between geometry A and B using PreparedGeometry", 2, 0,
+ if (cacheKey == nullptr || cacheKey != geom.get()) {
+ auto pg = std::unique_ptr<const PreparedGeometry>(
+ PreparedGeometryFactory::prepare( geom.get()) );
+ prepGeomCache = std::move( pg );
+ cacheKey = geom.get();
+ return new Result( prepGeomCache->distance( geomB.get() ) );
+ add("nearestPointsPrep", "computes nearest points of geometry A and B using PreparedGeometry", 2, 0,
+ auto cs = prepGeomCache->nearestPoints( geomB.get() );
add("reducePrecision", "reduces precision of geometry to a precision scale factor", 1, 1,
Summary of changes:
util/geosop/GeomFunction.cpp | 46 +++++++++++++++++++++++++++++++++++++++++++-
1 file changed, 45 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
