[geos-commits] [SCM] GEOS branch master updated. a03a9ec61629aa68d6f78ff514e759a10db60fcf
git at osgeo.org
git at osgeo.org
Mon Jan 11 12:27:17 PST 2021
the project "GEOS".
via a03a9ec61629aa68d6f78ff514e759a10db60fcf (commit)
via 07b1228117cada1fa49c6f6cf1ede24aee14d015 (commit)
from f038da4f59a6acc1084b22c884bfe239f5cf401e (commit)
revisions in full, below.
commit a03a9ec61629aa68d6f78ff514e759a10db60fcf
Merge: f038da4 07b1228
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Jan 11 15:26:59 2021 -0500
Merge branch 'remove-stackwalker'
commit 07b1228117cada1fa49c6f6cf1ede24aee14d015
Date: Sun Jan 10 20:15:04 2021 -0500
Remove StackWalker
It is not used in any GEOS code and not included in the build.
diff --git a/tests/xmltester/Stackwalker.cpp b/tests/xmltester/Stackwalker.cpp
deleted file mode 100644
index 928c8e5..0000000
--- a/tests/xmltester/Stackwalker.cpp
+++ /dev/null
@@ -1,2333 +0,0 @@
- * Project:
- * Memory_and_Exception_Trace
- * File:
- * Stackwalker.cpp
- * Remarks:
- * Dumps memory leaks (unreleased allocations) for CRT-Allocs and COM-Allocs
- * Dumps the stack of an thread if an exepction occurs
- * Known bugs:
- * - If the allocation-RequestID wrap, then allocations will get lost...
- * Author:
- * Jochen Kalmbach, Germany
-#include <windows.h>
-#include <string>
-#include <vector>
-#include <stdio.h>
-#include <stdlib.h>
-#include <time.h>
-#include <crtdbg.h>
-#include <tchar.h>
-#include "Stackwalker.h"
-// If the following is defined, only the used memories are stored in the hash-table.
-// If the memory is freed, it will be removed from the hash-table (to reduce memory)
-// Consequences: At DeInitAllocHook, only Leaks will be reported
-#define HASH_ENTRY_REMOVE_AT_FREE
-// 0 = Do not write any output during runtime-alloc-call
-// 1 = Write only the alloc action (malloc, realloc, free)
-// 2 = Write alloc action and callstack only for malloc/realloc
-// 3 = Write alloc action and callstack for all actions
-static ULONG g_ulShowStackAtAlloc = 0;
-// the form of the output file
-static eAllocCheckOutput g_CallstackOutputType = ACOutput_Simple;
-// Size of Hash-Table
-#define ALLOC_HASH_ENTRIES 1024
-// Size of Callstack-trace in bytes (0x500 => appr. 5-9 functions, depending on parameter count for each function)
-#define MAX_ESP_LEN_BUF 0x500
-// Normally we can ignore allocations from the Runtime-System
-#define IGNORE_CRT_ALLOC
-// MaxSize: 128 KByte (only for StackwalkFilter)
-#define LOG_FILE_MAX_SIZE 1024*128
-// If the following is defined, then COM-Leaks will also be tracked
-#define WITH_IMALLOC_SPY
-#ifdef WITH_IMALLOC_SPY
-//forwards:
-void IMallocHashInsert(void *pData, CONTEXT &Context, std::size_t nDataSize);
-BOOL IMallocHashRemove(void *pData);
-// IMallocSpy-Interface
-class CMallocSpy : public IMallocSpy
-public:
- CMallocSpy(void) {
- m_cbRequest = 0;
- ~CMallocSpy(void) {
- // IUnknown methods
- STDMETHOD(QueryInterface) (REFIID riid, LPVOID *ppUnk) {
- HRESULT hr = S_OK;
- if (IsEqualIID(riid, IID_IUnknown)) {
- *ppUnk = (IUnknown *) this;
- else if (IsEqualIID(riid, IID_IMallocSpy)) {
- *ppUnk = (IMalloc *) this;
- else {
- *ppUnk = NULL;
- hr = E_NOINTERFACE;
- AddRef();
- return hr;
- STDMETHOD_(ULONG, AddRef) (void) {
- return InterlockedIncrement(&m_cRef);
- STDMETHOD_(ULONG, Release) (void) {
- LONG cRef;
- cRef = InterlockedDecrement(&m_cRef);
- if (cRef == 0)
- delete this;
- return cRef;
- // IMallocSpy methods
- STDMETHOD_(ULONG, PreAlloc) (ULONG cbRequest) {
- m_cbRequest = cbRequest;
- return cbRequest;
- STDMETHOD_(void *, PostAlloc) (void *pActual) {
- HANDLE hThread;
- if (DuplicateHandle( GetCurrentProcess(), GetCurrentThread(),
- GetCurrentProcess(), &hThread, 0, false, DUPLICATE_SAME_ACCESS ) != 0) {
- // Ok
- CONTEXT c;
- memset( &c, '\0', sizeof c );
- c.ContextFlags = CONTEXT_FULL;
- if ( GetThreadContext( hThread, &c ) != 0) {
- // Ok
- IMallocHashInsert(pActual, c, m_cbRequest);
- CloseHandle(hThread);
- return pActual;
- STDMETHOD_(void *, PreFree) (void *pRequest, BOOL fSpyed) {
- IMallocHashRemove(pRequest);
- return pRequest;
- STDMETHOD_(void, PostFree) (BOOL fSpyed) {
- return;
- STDMETHOD_(ULONG, PreRealloc) (void *pRequest, ULONG cbRequest,
- void **ppNewRequest, BOOL fSpyed) {
- return cbRequest;
- STDMETHOD_(void *, PostRealloc) (void *pActual, BOOL fSpyed) {
- HANDLE hThread;
- // Ok
- CONTEXT c;
- // Ok
- return pActual;
- STDMETHOD_(void *, PreGetSize) (void *pRequest, BOOL fSpyed) {
- return pRequest;
- STDMETHOD_(ULONG, PostGetSize) (ULONG cbActual, BOOL fSpyed) {
- return cbActual;
- STDMETHOD_(void *, PreDidAlloc) (void *pRequest, BOOL fSpyed) {
- return pRequest;
- STDMETHOD_(BOOL, PostDidAlloc) (void *pRequest, BOOL fSpyed, BOOL fActual) {
- return fActual;
- STDMETHOD_(void, PreHeapMinimize) (void) {
- return;
- STDMETHOD_(void, PostHeapMinimize) (void) {
- return;
-private:
- LONG m_cRef;
- ULONG m_cbRequest;
-#endif
-#ifdef _IMAGEHLP_
-#error "'imagehlp.h' should only included here, not before this point! Otherwise there are some problems!"
-#endif
-#pragma pack( push, before_imagehlp, 8 )
-#include <imagehlp.h>
-#pragma pack( pop, before_imagehlp )
-#if API_VERSION_NUMBER < 7 // ImageHelp-Version is older.... so define it by mayself
-// The following definition is only available with VC++ 6.0 or higher, so include it here
-extern "C" {
-// source file line data structure
-typedef struct _IMAGEHLP_LINE
- DWORD SizeOfStruct; // set to sizeof(IMAGEHLP_LINE)
- DWORD Key; // internal
- DWORD LineNumber; // line number in file
- PCHAR FileName; // full filename
- DWORD Address; // first instruction of line
-} IMAGEHLP_LINE, *PIMAGEHLP_LINE;
-#define SYMOPT_LOAD_LINES 0x00000010
-} // extern "C"
-#endif
-// Forward definitions of functions:
-static void ShowStackRM( HANDLE hThread, CONTEXT& c, FILE *fLogFile, PREAD_PROCESS_MEMORY_ROUTINE ReadMemoryFunction, HANDLE hProcess);
-static void ShowStack( HANDLE hThread, CONTEXT& c, FILE *fLogFile);
-static void AllocHashOut(FILE*);
-static ULONG AllocHashOutLeaks(FILE*);
-// Globale Vars:
-static TCHAR *g_pszAllocLogName = NULL;
-static FILE *g_fFile = NULL;
-// AllocCheckFileOpen
-// Checks if the log-file is already opened
-// if not, try to open file (append or create if not exists)
-// if open failed, redirect output to stdout
-static void AllocCheckFileOpen(bool bAppend = true) {
- // is the File already open? If not open it...
- if (g_fFile == NULL)
- if (g_pszAllocLogName != NULL)
- if (bAppend == false)
- g_fFile = _tfopen(g_pszAllocLogName, _T("w"));
- else
- g_fFile = _tfopen(g_pszAllocLogName, _T("a"));
- g_fFile = stdout;
-// Write Date/Time to specified file (will also work after 2038)
-static void WriteDateTime(FILE *fFile, BOOL asXMLAttrs = FALSE) {
- TCHAR pszTemp[11], pszTemp2[11];
- if (fFile != NULL) {
- _tstrdate( pszTemp );
- _tstrtime( pszTemp2 );
- if (asXMLAttrs == FALSE)
- _ftprintf(fFile, _T("%s %s"), pszTemp, pszTemp2 ); // also ok after year 2038 (asctime is NOT ok)
- else
- _ftprintf(fFile, _T("date=\"%s\" time=\"%s\" "), pszTemp, pszTemp2 ); // also ok after year 2038 (asctime is NOT ok)
-} // WriteDateTime
- * Hash-Tabelle
-// Memory for the EIP-Address (is used by the ShowStack-method)
-#define MAX_EIP_LEN_BUF 4
-#define ALLOC_ENTRY_NOT_FOUND 0xFFFFFFFF
-typedef struct AllocHashEntryType {
- long lRequestID; // RequestID from CRT (if 0, then this entry is empty)
- std::size_t nDataSize; // Size of the allocated memory
- char cRemovedFlag; // 0 => memory was not yet released
- struct AllocHashEntryType *Next;
- // Callstack for EIP
- DWORD dwEIPOffset;
- DWORD dwEIPLen;
- char pcEIPAddr[MAX_EIP_LEN_BUF];
- // Callstack for ESP
- DWORD dwESPOffset;
- DWORD dwESPLen;
- char pcESPAddr[MAX_ESP_LEN_BUF];
-} AllocHashEntryType;
-static AllocHashEntryType AllocHashTable[ALLOC_HASH_ENTRIES];
-static ULONG AllocHashEntries = 0;
-static ULONG AllocHashCollisions = 0;
-static ULONG AllocHashFreed = 0;
-static ULONG AllocHashMaxUsed = 0; // maximal number of concurrent entries
-static ULONG AllocHashCurrentCount = 0;
-static ULONG AllocHashMaxCollisions = 0;
-static ULONG AllocHashCurrentCollisions = 0;
-// eigene Tabelle für die IMallocs:
-typedef struct IMallocHashEntryType {
- void *pData; // Key-Word
- std::size_t nDataSize; // größe des Datenblocks (optional)
- char cRemovedFlag; // 0 => nicht wurde noch nicht freigegeben
- struct IMallocHashEntryType *Next;
- // Callstack für EIP
- DWORD dwEIPLen;
- // Callstack für ESP
- DWORD dwESPLen;
-} IMallocHashEntryType;
-static IMallocHashEntryType IMallocHashTable[ALLOC_HASH_ENTRIES];
-static ULONG IMallocHashEntries = 0;
-static ULONG IMallocHashCollisions = 0;
-static ULONG IMallocHashFreed = 0;
-static ULONG IMallocHashMaxUsed = 0; // maximal number of concurrent entries
-static ULONG IMallocHashCurrentCount = 0;
-static ULONG IMallocHashMaxCollisions = 0;
-static ULONG IMallocHashCurrentCollisions = 0;
-//static void AllocHashOut(FILE*);
-static ULONG IMallocHashOutLeaks(FILE*);
-// AllocHashFunction
-// Die eigentliche Hash-Funktion (hier ganz simpel)
-static ULONG IMallocHashFunction(void *pData) {
- ULONG ulTemp;
- DWORD dwPointer = (DWORD) pData;
- // relativ simpler Mechanismus für die Hash-Funktion,
- // mir ist nur nix besseres eingefallen...
- ulTemp = dwPointer % ALLOC_HASH_ENTRIES;
- _ASSERTE( (ulTemp >= 0) && (ulTemp < ALLOC_HASH_ENTRIES) );
- return ulTemp;
-} // AllocHashFunction
-// IMallocHashInsert
-// pData: Key-Word (Pointer to address)
-// pContext: Context-Record, for retrieving Callstack (EIP and EBP is only needed)
-// nDataSize: How many bytes
-void IMallocHashInsert(void *pData, CONTEXT &Context, std::size_t nDataSize) {
- ULONG HashIdx;
- IMallocHashEntryType *pHashEntry;
- // ermittle Statistische Werte
- IMallocHashEntries++;
- IMallocHashCurrentCount++;
- if (IMallocHashCurrentCount > IMallocHashMaxUsed)
- IMallocHashMaxUsed = IMallocHashCurrentCount;
- // ermittle den Hash-Wert
- HashIdx = IMallocHashFunction(pData);
- // Eintrag darf nicht größer als die Hash-Tabelle sein
- _ASSERTE(HashIdx < ALLOC_HASH_ENTRIES);
- pHashEntry = &IMallocHashTable[HashIdx];
- if (pHashEntry->pData == 0) {
- // es ist noch kein Eintrag da
- else {
- //Statistische Daten:
- IMallocHashCollisions++;
- IMallocHashCurrentCollisions++;
- if (IMallocHashCurrentCollisions > IMallocHashMaxCollisions)
- IMallocHashMaxCollisions = IMallocHashCurrentCollisions;
- // Eintrag ist schon belegt, verkette die Einträge
- // wenn dies oft vorkommt, sollte man entweder die Tabelle vergrößern oder eine
- // andere Hash-Funktion wählen
- while(pHashEntry->Next != NULL) {
- pHashEntry = pHashEntry->Next;
- pHashEntry->Next = (IMallocHashEntryType*) _calloc_dbg(sizeof(IMallocHashEntryType), 1, _CRT_BLOCK, __FILE__, __LINE__);
- pHashEntry->pData = pData; // Key-Word
- pHashEntry->nDataSize = nDataSize;
- pHashEntry->Next = NULL;
- // Get EIP and save it in the record
- pHashEntry->dwEIPOffset = Context.Eip;
- if (ReadProcessMemory(GetCurrentProcess(), (LPCVOID) Context.Eip, &(pHashEntry->pcEIPAddr), MAX_EIP_LEN_BUF, &(pHashEntry->dwEIPLen)) == 0) {
- // Could not read memory... remove everything...
- memset(pHashEntry->pcEIPAddr, 0, MAX_EIP_LEN_BUF);
- pHashEntry->dwEIPLen = 0;
- pHashEntry->dwEIPOffset = 0;
- // Get ESP and save it in the record
- pHashEntry->dwESPOffset = Context.Ebp;
- if (ReadProcessMemory(GetCurrentProcess(), (LPCVOID) Context.Ebp, &(pHashEntry->pcESPAddr), MAX_ESP_LEN_BUF, &(pHashEntry->dwESPLen)) == 0) {
- memset(pHashEntry->pcESPAddr, 0, MAX_ESP_LEN_BUF);
- pHashEntry->dwESPLen = 0;
- pHashEntry->dwESPOffset = 0;
- // Check if I tried to read too much...
- if (GetLastError() == ERROR_PARTIAL_COPY)
- // ask how many I can read:
- MEMORY_BASIC_INFORMATION MemBuffer;
- DWORD dwRet = VirtualQuery((LPCVOID) Context.Ebp, &MemBuffer, sizeof(MemBuffer));
- if (dwRet > 0)
- // calculate the length
- DWORD len = ((DWORD) MemBuffer.BaseAddress + MemBuffer.RegionSize) - Context.Ebp;
- if ( (len > 0) && (len < MAX_ESP_LEN_BUF) )
- // try to read it again (with the shorter length)
- if (ReadProcessMemory(GetCurrentProcess(), (LPCVOID) Context.Ebp, &(pHashEntry->pcESPAddr), len, &(pHashEntry->dwESPLen)) == 0)
- // ok, now everything goes wrong... remove it...
- else
- } // VirtualQuery was successfully
- } // ERROR_PARTIAL_COPY
-// IMallocHashFind
-// Wird ALLOC_ENTRY_NOT_FOUND zurückgegeben, so wurde der Key nicht
-// gefunden, ansonsten wird ein Zeiger auf den Hash-Eintrag zurückgegeben
-// ACHTUNG: In einem preemptiven Tasking-System kann hier nicht
-// garantiert werden, ob der Zeiger noch gültig ist, wenn er
-// zurückgegeben wird, da er von einem anderen Thread schon
-// freigegeben sein könnte.
-// Die synchronisation muß eine Ebene höher erfolgen
-static IMallocHashEntryType *IMallocHashFind(void *pData) {
- ULONG HashIdx;
- while(pHashEntry != NULL) {
- if (pHashEntry->pData == pData) {
- return pHashEntry;
- // wenn hier angelangt, dann wurde der Eintrag nicht gefunden!
- return (IMallocHashEntryType*) ALLOC_ENTRY_NOT_FOUND;
-} // AllocHashFind
-// IMallocHashRemove
-// Return: FALSE (0) : Key wurde gefunden und entfernt/markiert
-// TRUE (!=0): Key wurde nicht gefunden!
-BOOL IMallocHashRemove(void *pData) {
- ULONG HashIdx;
- IMallocHashEntryType *pHashEntry, *pHashEntryLast;
- pHashEntryLast = NULL;
-#ifdef HASH_ENTRY_REMOVE_AT_FREE
- IMallocHashFreed++;
- IMallocHashCurrentCount--;
- // gebe den Speicher frei
- if (pHashEntryLast == NULL) {
- // Es ist ein Eintrag direkt in der Tabelle
- if (pHashEntry->Next == NULL) {
- // Es ist der letze Eintrag lösche also die Tabelle
- memset(&IMallocHashTable[HashIdx], 0, sizeof(IMallocHashTable[HashIdx]));
- else {
- // Es sind noch Einträge verkettet, überschreibe einfach den nicht mehr gebrauchten...
- *pHashEntry = *(pHashEntry->Next);
- return TRUE;
- else {
- // ich bin in einem dynamischen Bereich
- // dies war eine kollisions, zähle also wieder zurück:
- IMallocHashCurrentCollisions--;
- pHashEntryLast->Next = pHashEntry->Next;
- _free_dbg(pHashEntry, _CRT_BLOCK);
- return TRUE;
-#else
- // erhöhe nur den Removed counter und behalte das Object im Speicher
- pHashEntry->cRemovedFlag++;
- return TRUE; // erfolgreich
-#endif
- pHashEntryLast = pHashEntry;
- return FALSE;
-// Callback-Funtion for StackWalk für meine CallStack-Ausgabe aus der Hash-Tabelle
-#if API_VERSION_NUMBER >= 9
-static BOOL __stdcall ReadProcMemoryFromIMallocHash(HANDLE pData, DWORD lpBaseAddress, PVOID lpBuffer, DWORD nSize, PDWORD lpNumberOfBytesRead) {
-#else
-static BOOL __stdcall ReadProcMemoryFromIMallocHash(HANDLE pData, LPCVOID lpBaseAddress, PVOID lpBuffer, DWORD nSize, PDWORD lpNumberOfBytesRead) {
-#endif
- // Versuche die hRequestID zu finden
- *lpNumberOfBytesRead = 0;
- pHashEntry = IMallocHashFind((PVOID) pData);
- if (pHashEntry == (IMallocHashEntryType*) ALLOC_ENTRY_NOT_FOUND) {
- // nicht gefunden, somit kann ich den Speicher nicht lesen
- return FALSE;
- if ( ((DWORD) lpBaseAddress >= pHashEntry->dwESPOffset) && ((DWORD) lpBaseAddress <= (pHashEntry->dwESPOffset+pHashEntry->dwESPLen)) ) {
- // Speicher liegt im ESP:
- // Errechne den Offset
- DWORD dwOffset = (DWORD) lpBaseAddress - pHashEntry->dwESPOffset;
- DWORD dwSize = __min(nSize, MAX_ESP_LEN_BUF-dwOffset);
- memcpy(lpBuffer, &(pHashEntry->pcESPAddr[dwOffset]), dwSize);
- *lpNumberOfBytesRead = dwSize;
- if (dwSize != nSize)
- return FALSE;
- if ( ((DWORD) lpBaseAddress >= pHashEntry->dwEIPOffset) && ((DWORD) lpBaseAddress <= (pHashEntry->dwEIPOffset+pHashEntry->dwEIPLen)) ) {
- // Speicher liegt im EIP:
- DWORD dwOffset = (DWORD) lpBaseAddress - pHashEntry->dwEIPOffset;
- memcpy(lpBuffer, &(pHashEntry->pcEIPAddr[dwOffset]), dwSize);
- return FALSE;
- if (*lpNumberOfBytesRead == 0) // Der Speicher konnte nicht gefunden werden
- return FALSE;
- return TRUE;
-// AllocHashOutLeaks
-// Gibt allen Speicher aus, der noch nicht wieder freigegeben wurde
-// Returns the number of bytes, that are not freed (leaks)
-ULONG IMallocHashOutLeaks(FILE *fFile) {
- ULONG ulTemp;
- ULONG ulCount = 0;
- ULONG ulLeaksByte = 0;
- // Gehe jeden Eintrag durch und gebe ihn aus
- for(ulTemp = 0; ulTemp < ALLOC_HASH_ENTRIES; ulTemp++) {
- pHashEntry = &IMallocHashTable[ulTemp];
- if (pHashEntry->pData != 0) {
- // gebe die Zeile aus
- if ( (pHashEntry->cRemovedFlag <= 0) || (pHashEntry->cRemovedFlag > 1) ) {
- ulCount++;
- if (g_CallstackOutputType == ACOutput_XML)
- _ftprintf(fFile, _T("<LEAK requestID=\"%u\" size=\"%u\">\n"), pHashEntry->pData, pHashEntry->nDataSize);
- else
- _ftprintf(fFile, _T("Pointer (RequestID): %12i, Removed: %i, Size: %12i\n"), pHashEntry->pData, pHashEntry->cRemovedFlag, pHashEntry->nDataSize);
- CONTEXT c;
- c.Eip = pHashEntry->dwEIPOffset;
- c.Ebp = pHashEntry->dwESPOffset;
- ShowStackRM( NULL, c, fFile, &ReadProcMemoryFromIMallocHash, (HANDLE) pHashEntry->pData);
- // Zähle zusammen wieviel Byte noch nicht freigegeben wurden
- if (pHashEntry->nDataSize > 0)
- ulLeaksByte += pHashEntry->nDataSize;
- else
- ulLeaksByte++; // Wenn zwar Speicher allokiert wurde, dieser aber 0 Bytes lang war, so reserviere für diesen zumindest 1 Byte
- _ftprintf(fFile, _T("</LEAK>\n")); // terminate the xml-node
- if (g_CallstackOutputType != ACOutput_XML)
- _ftprintf(fFile, _T("\n**** Number of leaks: %i\n"), ulCount);
- return ulLeaksByte;
-} // AllocHashOutLeaks
-#endif
-static void AllocHashInit(void) {
- memset(AllocHashTable, 0, sizeof(AllocHashTable));
- AllocHashEntries = 0;
- AllocHashCollisions = 0;
- AllocHashFreed = 0;
- AllocHashCurrentCount = 0;
- AllocHashMaxUsed = 0;
- AllocHashMaxCollisions = 0;
- AllocHashCurrentCollisions = 0;
- memset(IMallocHashTable, 0, sizeof(IMallocHashTable));
- IMallocHashEntries = 0;
- IMallocHashCollisions = 0;
- IMallocHashFreed = 0;
- IMallocHashCurrentCount = 0;
- IMallocHashMaxUsed = 0;
- IMallocHashMaxCollisions = 0;
- IMallocHashCurrentCollisions = 0;
-#endif
- return;
-} // AllocHashInit
-// AllocHashDeinit
-static ULONG AllocHashDeinit(void) {
- ULONG ulRet = 0;
- bool bAppend = g_CallstackOutputType != ACOutput_XML;
- AllocCheckFileOpen(bAppend); // open global log-file
- _ftprintf(g_fFile, _T("<MEMREPORT "));
- WriteDateTime(g_fFile, TRUE);
- _ftprintf(g_fFile, _T(">\n"));
- else
- _ftprintf(g_fFile, _T("\n##### Memory Report ########################################\n"));
- WriteDateTime(g_fFile);
- _ftprintf(g_fFile, _T("\n"));
-#ifndef HASH_ENTRY_REMOVE_AT_FREE
- // output the used memory
- _ftprintf(g_fFile, _T("##### Memory used: #########################################\n"));
- AllocHashOut(g_fFile);
-#endif
- // output the Memoty leaks
- _ftprintf(g_fFile, _T("\n##### Leaks: ###############################################\n"));
- ulRet = AllocHashOutLeaks(g_fFile);
- if (g_CallstackOutputType == ACOutput_Advanced)
- // output some statistics from the hash-table
- _ftprintf(g_fFile, _T("***** Hash-Table statistics:\n"));
- _ftprintf(g_fFile, _T(" Table-Size: %i\n"), ALLOC_HASH_ENTRIES);
- _ftprintf(g_fFile, _T(" Inserts: %i\n"), AllocHashEntries);
- _ftprintf(g_fFile, _T(" Freed: %i\n"), AllocHashFreed);
- _ftprintf(g_fFile, _T(" Sum Collisions: %i\n"), AllocHashCollisions);
- _ftprintf(g_fFile, _T(" Max used: %i\n"), AllocHashMaxUsed);
- _ftprintf(g_fFile, _T(" Max Collisions: %i\n"), AllocHashMaxCollisions);
- // Free Hash-Table
- ULONG ulTemp;
- AllocHashEntryType *pHashEntry, *pHashEntryOld;
- // Now, free my own memory
- pHashEntry = &AllocHashTable[ulTemp];
- pHashEntryOld = pHashEntry;
- if (pHashEntryOld != &AllocHashTable[ulTemp]) {
- // now free the dynamically allocated memory
- free(pHashEntryOld);
- } // while
- } // for
- // empty the hash-table
- _ftprintf(g_fFile, _T("\n##### COM-Leaks: ###############################################\n"));
- ulRet = IMallocHashOutLeaks(g_fFile);
- _ftprintf(g_fFile, _T(" Inserts: %i\n"), IMallocHashEntries);
- _ftprintf(g_fFile, _T(" Freed: %i\n"), IMallocHashFreed);
- _ftprintf(g_fFile, _T(" Sum Collisions: %i\n"), IMallocHashCollisions);
- _ftprintf(g_fFile, _T(" Max used: %i\n"), IMallocHashMaxUsed);
- _ftprintf(g_fFile, _T(" Max Collisions: %i\n"), IMallocHashMaxCollisions);
- //ULONG ulTemp;
- IMallocHashEntryType *pIMHashEntry, *pIMHashEntryOld;
- // Gehe jeden Eintrag durch und gebe ihn frei
- pIMHashEntry = &IMallocHashTable[ulTemp];
- pIMHashEntryOld = pIMHashEntry;
- pIMHashEntry = pIMHashEntry->Next;
- if (pIMHashEntryOld != &IMallocHashTable[ulTemp]) {
- // es ist dynamischer Speicher, gebe ihn also frei:
- _free_dbg(pIMHashEntryOld, _CRT_BLOCK);
- } // while
- } // for
- // Lösche die gesamte Hash-Tabelle
-#endif
- _ftprintf(g_fFile, _T("</MEMREPORT>\n"));
- return ulRet;
-} // AllocHashDeinit
-// The has-function (very simple)
-static inline ULONG AllocHashFunction(long lRequestID) {
- // I couldn´t find any better and faster
- return lRequestID % ALLOC_HASH_ENTRIES;
-// AllocHashInsert
-// lRequestID: Key-Word (RequestID from AllocHook)
-static void AllocHashInsert(long lRequestID, CONTEXT &Context, std::size_t nDataSize) {
- ULONG HashIdx;
- AllocHashEntryType *pHashEntry;
- // change statistical data
- AllocHashEntries++;
- AllocHashCurrentCount++;
- if (AllocHashCurrentCount > AllocHashMaxUsed)
- AllocHashMaxUsed = AllocHashCurrentCount;
- // generate hash-value
- HashIdx = AllocHashFunction(lRequestID);
- pHashEntry = &AllocHashTable[HashIdx];
- if (pHashEntry->lRequestID == 0) {
- // Entry is empty...
- else {
- // Entry is not empy! make a list of entries for this hash value...
- // if this happens often, you should increase the hah size or change the heash-function;
- // to fasten the allocation time
- AllocHashCollisions++;
- AllocHashCurrentCollisions++;
- if (AllocHashCurrentCollisions > AllocHashMaxCollisions)
- AllocHashMaxCollisions = AllocHashCurrentCollisions;
- pHashEntry->Next = (AllocHashEntryType*) calloc(sizeof(AllocHashEntryType), 1);
- pHashEntry->lRequestID = lRequestID; // Key-Word
- if (dwRet > 0)
- else
-// AllocHashFind
-// If ALLOC_ENTRY_NOT_FOUND is returned, the Key was not found!
-// If the Key was found, a pointer to the entry is returned
-static AllocHashEntryType *AllocHashFind(long lRequestID) {
- ULONG HashIdx;
- // get the Hash-Value
- // Just do some simple checks:
- if (pHashEntry->lRequestID == lRequestID) {
- // entry was not found!
- return (AllocHashEntryType*) ALLOC_ENTRY_NOT_FOUND;
-} // AllocHashFind
-// AllocHashRemove
-// Return: FALSE (0) : Key was found and removed/marked
-// TRUE (!=0): Key was not found
-static BOOL AllocHashRemove(long lRequestID) {
- ULONG HashIdx;
- AllocHashEntryType *pHashEntry, *pHashEntryLast;
- AllocHashFreed++;
- AllocHashCurrentCount--;
- // release my memory
- // It is an entry in the table, so do not release this memory
- // It was the last entry, so empty the table entry
- memset(&AllocHashTable[HashIdx], 0, sizeof(AllocHashTable[HashIdx]));
- else {
- // There are some more entries, so shorten the list
- // TODO: Do I need to free the memory here !? I think I should do this...
- return TRUE;
- else {
- // now, I am in an dynamic allocated entry
- // it was a collision, so decrease the current collision count
- AllocHashCurrentCollisions--;
- free(pHashEntry);
- return TRUE;
-#else
- // increase the Remove-Count and let the objet stay in memory
- return TRUE;
-#endif
- // if we are here, we could not find the RequestID
- return FALSE;
-// ReadProcMemoryFromHash
-// Callback-Funtion for StackWalk for my own CallStack from the Hash-Table-Entries
-static BOOL __stdcall ReadProcMemoryFromHash(HANDLE hRequestID, DWORD lpBaseAddress, PVOID lpBuffer, DWORD nSize, PDWORD lpNumberOfBytesRead) {
-#else
-static BOOL __stdcall ReadProcMemoryFromHash(HANDLE hRequestID, LPCVOID lpBaseAddress, PVOID lpBuffer, DWORD nSize, PDWORD lpNumberOfBytesRead) {
-#endif
- // Try to find the RequestID
- pHashEntry = AllocHashFind((LONG) hRequestID);
- if (pHashEntry == (AllocHashEntryType*) ALLOC_ENTRY_NOT_FOUND) {
- // Not found, so I cannot return any memory
- return FALSE;
- // Memory is located in ESP:
- // Calculate the offset
- return FALSE;
- // Memory is located in EIP:
- return FALSE;
- if (*lpNumberOfBytesRead == 0) // Memory could not be found
- return FALSE;
- return TRUE;
-// Write all Memory (with callstack) which was not freed yet
-ULONG AllocHashOutLeaks(FILE *fFile) {
- ULONG ulTemp;
- // Move throu every entry
- if (pHashEntry->lRequestID != 0) {
- ulCount++;
- _ftprintf(fFile, _T("<LEAK requestID=\"%u\" size=\"%u\">\n"), pHashEntry->lRequestID, pHashEntry->nDataSize);
- else
- _ftprintf(fFile, _T("RequestID: %12i, Removed: %i, Size: %12i\n"), pHashEntry->lRequestID, pHashEntry->cRemovedFlag, pHashEntry->nDataSize);
- CONTEXT c;
- ShowStackRM( NULL, c, fFile, &ReadProcMemoryFromHash, (HANDLE) pHashEntry->lRequestID);
- // Count the number of leaky bytes
- else
- ulLeaksByte++; // If memory was allocated with zero bytes, then just increase the counter 1
-// Write all used memory to a file
-void AllocHashOut(FILE *fFile) {
- ULONG ulTemp;
- _ftprintf(fFile, _T("<MEMUSED requestID=\"%u\" size=\"%u\"\n"), pHashEntry->lRequestID, pHashEntry->nDataSize);
- else
-} // AllocHashOut
- * Ende der Hash-Tabelle
-// The follwoing is copied from dbgint.h:
-// <CRT_INTERNALS>
- * For diagnostic purpose, blocks are allocated with extra information and
- * stored in a doubly-linked list. This makes all blocks registered with
- * how big they are, when they were allocated, and what they are used for.
-#define nNoMansLandSize 4
-typedef struct _CrtMemBlockHeader
- struct _CrtMemBlockHeader * pBlockHeaderNext;
- struct _CrtMemBlockHeader * pBlockHeaderPrev;
- char * szFileName;
- int nLine;
-#ifdef _WIN64
- /* These items are reversed on Win64 to eliminate gaps in the struct
- * and ensure that sizeof(struct)%16 == 0, so 16-byte alignment is
- * maintained in the debug heap.
- int nBlockUse;
-#else /* _WIN64 */
- int nBlockUse;
-#endif /* _WIN64 */
- long lRequest;
- unsigned char gap[nNoMansLandSize];
- /* followed by:
- * unsigned char data[nDataSize];
- * unsigned char anotherGap[nNoMansLandSize];
-} _CrtMemBlockHeader;
-#define pbData(pblock) ((unsigned char *)((_CrtMemBlockHeader *)pblock + 1))
-#define pHdr(pbData) (((_CrtMemBlockHeader *)pbData)-1)
-// </CRT_INTERNALS>
-// Global data:
-static BOOL g_bInitialized = FALSE;
-static HINSTANCE g_hImagehlpDll = NULL;
-static DWORD g_dwShowCount = 0; // increase at every ShowStack-Call
-static CRITICAL_SECTION g_csFileOpenClose = {0};
-// Is used for syncronising call to MyAllocHook (to prevent reentrant calls)
-static LONG g_lMallocCalled = 0;
-static _CRT_ALLOC_HOOK pfnOldCrtAllocHook = NULL;
-// Deaktivate AllocHook, by increasing the Syncronisation-Counter
-static void DeactivateMallocStackwalker(void) {
- InterlockedIncrement(&g_lMallocCalled);
-// MyAllocHook is Single-Threaded, that means the the calls are serialized in the calling function!
-// Special case for VC 5
-#if _MSC_VER <= 1100
-static int MyAllocHook(int nAllocType, void *pvData,
- std::size_t nSize, int nBlockUse, long lRequest,
- const char * szFileName, int nLine ) {
-#else
- const unsigned char * szFileName, int nLine ) {
-#endif
- static TCHAR *operation[] = { _T(""), _T("ALLOCATIONG"), _T("RE-ALLOCATING"), _T("FREEING") };
- static TCHAR *blockType[] = { _T("Free"), _T("Normal"), _T("CRT"), _T("Ignore"), _T("Client") };
-#ifdef IGNORE_CRT_ALLOC
- if (_BLOCK_TYPE(nBlockUse) == _CRT_BLOCK) // Ignore internal C runtime library allocations
- return TRUE;
-#endif
- extern int _crtDbgFlag;
- if ( ((_CRTDBG_ALLOC_MEM_DF & _crtDbgFlag) == 0) && ( (nAllocType == _HOOK_ALLOC) || (nAllocType == _HOOK_REALLOC) ) )
- // Someone has disabled that the runtime should log this allocation
- // so we do not log this allocation
- if (pfnOldCrtAllocHook != NULL)
- pfnOldCrtAllocHook(nAllocType, pvData, nSize, nBlockUse, lRequest, szFileName, nLine);
- return TRUE;
- // Prevent from reentrat calls
- if (InterlockedIncrement(&g_lMallocCalled) > 1) { // I was already called
- InterlockedDecrement(&g_lMallocCalled);
- // call the previous alloc hook
- return TRUE;
- if (g_ulShowStackAtAlloc > 0) {
- AllocCheckFileOpen(); // Open logfile
- _ASSERT( (nAllocType == _HOOK_ALLOC) || (nAllocType == _HOOK_REALLOC) || (nAllocType == _HOOK_FREE) );
- _ASSERT( ( _BLOCK_TYPE(nBlockUse) >= 0 ) && ( _BLOCK_TYPE(nBlockUse) < 5 ) );
- if (nAllocType == _HOOK_FREE) { // freeing
- // Try to get the header information
- if (_CrtIsValidHeapPointer(pvData)) { // it is a valid Heap-Pointer
- // get the ID
- _CrtMemBlockHeader *pHead;
- // get a pointer to memory block header
- pHead = pHdr(pvData);
- nSize = pHead->nDataSize;
- lRequest = pHead->lRequest; // This is the ID!
- if (pHead->nBlockUse == _IGNORE_BLOCK)
- return TRUE;
- _ftprintf( g_fFile, _T("##### Memory operation: %s a %d-byte '%s' block (# %ld)"),
- operation[nAllocType], nSize, blockType[_BLOCK_TYPE(nBlockUse)], lRequest );
- if ( pvData != NULL )
- _ftprintf( g_fFile, _T(" at 0x%X"), pvData );
- if (nAllocType == _HOOK_FREE) { // freeing:
- if (lRequest != 0) { // RequestID was found
- BOOL bRet;
- // Try to find the RequestID in the Hash-Table, mark it that it was freed
- bRet = AllocHashRemove(lRequest);
- if(g_ulShowStackAtAlloc > 0) {
- if (bRet == FALSE) {
- // RequestID not found!
- _ftprintf(g_fFile, _T("###### RequestID not found in hash table for FREEING (%i)!\n"), lRequest);
- } // g_ulShowStackAtAlloc > 0
- else {
- // No valid RequestID found, display error
- _ftprintf(g_fFile, _T("###### No valid RequestID for FREEING! (0x%X)\n"), pvData);
- } // freeing
- if (nAllocType == _HOOK_REALLOC) { // re-allocating
- BOOL bRet;
- LONG lReallocRequest;
- // get the ID
- lReallocRequest = pHead->lRequest;
- bRet = AllocHashRemove(lReallocRequest);
- _ftprintf(g_fFile, _T("###### RequestID not found in hash table for RE-ALLOCATING (%i)!\n"), lReallocRequest);
- else {
- _ftprintf(g_fFile, _T("##### Implicit freeing because of re-allocation (# old: %ld, new: %ld)\n"), lReallocRequest, lRequest);
- } // ValidHeapPointer
- } // re-allocating
- if ( (g_ulShowStackAtAlloc < 3) && (nAllocType == _HOOK_FREE) ) {
- return TRUE;
- // Get the context DIESES of this Thread
- HANDLE hThread;
- GetCurrentProcess(), &hThread, 0, false, DUPLICATE_SAME_ACCESS ) == 0) {
- // Something was wrong...
- _ftprintf(g_fFile, _T("###### Could not call 'DuplicateHandle' successfully\n"));
- return TRUE;
- CONTEXT c;
- // init CONTEXT record so we know where to start the stackwalk
- if ( GetThreadContext( hThread, &c ) == 0) {
- if(g_ulShowStackAtAlloc > 1) {
- _ftprintf(g_fFile, _T("###### Could not call 'GetThreadContext' successfully\n"));
- return TRUE; // could not get context
- if(g_ulShowStackAtAlloc > 2) {
- // output the callstack
- ShowStack( hThread, c, g_fFile);
- else {
- // Output only (re)allocs
- if (nAllocType != _HOOK_FREE) {
- } // g_ulShowStackAtAlloc > 1
- CloseHandle( hThread );
- // Only isert in the Hash-Table if it is not a "freeing"
- if(lRequest != 0) // Always a valid RequestID should be provided (see comments in the header)
- AllocHashInsert(lRequest, c, nSize);
- return TRUE; // allow the memory operation to proceed
-#define gle (GetLastError())
-#define lenof(a) (sizeof(a) / sizeof((a)[0]))
-#define MAXNAMELEN 1024 // max name length for found symbols
-#define IMGSYMLEN ( sizeof IMAGEHLP_SYMBOL )
-#define TTBUFLEN 8096 // for a temp buffer (2^13)
-// SymCleanup()
-typedef BOOL (__stdcall *tSC)( IN HANDLE hProcess );
-tSC pSC = NULL;
-// SymFunctionTableAccess()
-typedef PVOID (__stdcall *tSFTA)( HANDLE hProcess, DWORD AddrBase );
-tSFTA pSFTA = NULL;
-// SymGetLineFromAddr()
-typedef BOOL (__stdcall *tSGLFA)( IN HANDLE hProcess, IN DWORD dwAddr,
- OUT PDWORD pdwDisplacement, OUT PIMAGEHLP_LINE Line );
-tSGLFA pSGLFA = NULL;
-// SymGetModuleBase()
-typedef DWORD (__stdcall *tSGMB)( IN HANDLE hProcess, IN DWORD dwAddr );
-tSGMB pSGMB = NULL;
-// SymGetModuleInfo()
-typedef BOOL (__stdcall *tSGMI)( IN HANDLE hProcess, IN DWORD dwAddr, OUT PIMAGEHLP_MODULE ModuleInfo );
-tSGMI pSGMI = NULL;
-// SymGetOptions()
-typedef DWORD (__stdcall *tSGO)( VOID );
-tSGO pSGO = NULL;
-// SymGetSymFromAddr()
-typedef BOOL (__stdcall *tSGSFA)( IN HANDLE hProcess, IN DWORD dwAddr,
- OUT PDWORD pdwDisplacement, OUT PIMAGEHLP_SYMBOL Symbol );
-tSGSFA pSGSFA = NULL;
-// SymInitialize()
-typedef BOOL (__stdcall *tSI)( IN HANDLE hProcess, IN PSTR UserSearchPath, IN BOOL fInvadeProcess );
-tSI pSI = NULL;
-// SymLoadModule()
-typedef DWORD (__stdcall *tSLM)( IN HANDLE hProcess, IN HANDLE hFile,
- IN PSTR ImageName, IN PSTR ModuleName, IN DWORD BaseOfDll, IN DWORD SizeOfDll );
-tSLM pSLM = NULL;
-// SymSetOptions()
-typedef DWORD (__stdcall *tSSO)( IN DWORD SymOptions );
-tSSO pSSO = NULL;
-// StackWalk()
-typedef BOOL (__stdcall *tSW)( DWORD MachineType, HANDLE hProcess,
- HANDLE hThread, LPSTACKFRAME StackFrame, PVOID ContextRecord,
- PREAD_PROCESS_MEMORY_ROUTINE ReadMemoryRoutine,
- PFUNCTION_TABLE_ACCESS_ROUTINE FunctionTableAccessRoutine,
- PGET_MODULE_BASE_ROUTINE GetModuleBaseRoutine,
- PTRANSLATE_ADDRESS_ROUTINE TranslateAddress );
-tSW pSW = NULL;
-// UnDecorateSymbolName()
-typedef DWORD (__stdcall WINAPI *tUDSN)( PCSTR DecoratedName, PSTR UnDecoratedName,
- DWORD UndecoratedLength, DWORD Flags );
-tUDSN pUDSN = NULL;
-struct ModuleEntry
- std::string imageName;
- std::string moduleName;
- DWORD baseAddress;
- DWORD size;
-typedef std::vector< ModuleEntry > ModuleList;
-typedef ModuleList::iterator ModuleListIter;
-// **************************************** ToolHelp32 ************************
-#define MAX_MODULE_NAME32 255
-#define TH32CS_SNAPMODULE 0x00000008
-#pragma pack( push, 8 )
-typedef struct tagMODULEENTRY32
- DWORD dwSize;
- DWORD th32ModuleID; // This module
- DWORD th32ProcessID; // owning process
- DWORD GlblcntUsage; // Global usage count on the module
- DWORD ProccntUsage; // Module usage count in th32ProcessID's context
- BYTE * modBaseAddr; // Base address of module in th32ProcessID's context
- DWORD modBaseSize; // Size in bytes of module starting at modBaseAddr
- HMODULE hModule; // The hModule of this module in th32ProcessID's context
- char szModule[MAX_MODULE_NAME32 + 1];
- char szExePath[MAX_PATH];
-} MODULEENTRY32;
-typedef MODULEENTRY32 * PMODULEENTRY32;
-typedef MODULEENTRY32 * LPMODULEENTRY32;
-#pragma pack( pop )
-static bool GetModuleListTH32(ModuleList& modules, DWORD pid, FILE *fLogFile)
- // CreateToolhelp32Snapshot()
- typedef HANDLE (__stdcall *tCT32S)(DWORD dwFlags, DWORD th32ProcessID);
- // Module32First()
- typedef BOOL (__stdcall *tM32F)(HANDLE hSnapshot, LPMODULEENTRY32 lpme);
- // Module32Next()
- typedef BOOL (__stdcall *tM32N)(HANDLE hSnapshot, LPMODULEENTRY32 lpme);
- // try both dlls...
- const TCHAR *dllname[] = { _T("kernel32.dll"), _T("tlhelp32.dll") };
- HINSTANCE hToolhelp;
- tCT32S pCT32S;
- tM32F pM32F;
- tM32N pM32N;
- HANDLE hSnap;
- MODULEENTRY32 me;
- me.dwSize = sizeof(me);
- bool keepGoing;
- ModuleEntry e;
- int i;
- for (i = 0; i<lenof(dllname); i++ )
- hToolhelp = LoadLibrary( dllname[i] );
- if (hToolhelp == NULL)
- continue;
- pCT32S = (tCT32S) GetProcAddress(hToolhelp, "CreateToolhelp32Snapshot");
- pM32F = (tM32F) GetProcAddress(hToolhelp, "Module32First");
- pM32N = (tM32N) GetProcAddress(hToolhelp, "Module32Next");
- if ( pCT32S != 0 && pM32F != 0 && pM32N != 0 )
- break; // found the functions!
- FreeLibrary(hToolhelp);
- hToolhelp = NULL;
- return false;
- hSnap = pCT32S( TH32CS_SNAPMODULE, pid );
- if (hSnap == (HANDLE) -1)
- return false;
- keepGoing = !!pM32F( hSnap, &me );
- while (keepGoing)
- e.imageName = me.szExePath;
- e.moduleName = me.szModule;
- e.baseAddress = (DWORD) me.modBaseAddr;
- e.size = me.modBaseSize;
- modules.push_back( e );
- keepGoing = !!pM32N( hSnap, &me );
- CloseHandle(hSnap);
- return !modules.empty();
-} // GetModuleListTH32
-// **************************************** PSAPI ************************
-typedef struct _MODULEINFO {
- LPVOID lpBaseOfDll;
- DWORD SizeOfImage;
- LPVOID EntryPoint;
-} MODULEINFO, *LPMODULEINFO;
-static bool GetModuleListPSAPI(ModuleList &modules, DWORD pid, HANDLE hProcess, FILE *fLogFile)
- // EnumProcessModules()
- typedef BOOL (__stdcall *tEPM)(HANDLE hProcess, HMODULE *lphModule, DWORD cb, LPDWORD lpcbNeeded );
- // GetModuleFileNameEx()
- typedef DWORD (__stdcall *tGMFNE)(HANDLE hProcess, HMODULE hModule, LPSTR lpFilename, DWORD nSize );
- // GetModuleBaseName()
- typedef DWORD (__stdcall *tGMBN)(HANDLE hProcess, HMODULE hModule, LPSTR lpFilename, DWORD nSize );
- // GetModuleInformation()
- typedef BOOL (__stdcall *tGMI)(HANDLE hProcess, HMODULE hModule, LPMODULEINFO pmi, DWORD nSize );
- HINSTANCE hPsapi;
- tEPM pEPM;
- tGMFNE pGMFNE;
- tGMBN pGMBN;
- tGMI pGMI;
- DWORD i;
- ModuleEntry e;
- DWORD cbNeeded;
- MODULEINFO mi;
- HMODULE *hMods = 0;
- char *tt = 0;
- hPsapi = LoadLibrary( _T("psapi.dll") );
- if ( hPsapi == 0 )
- return false;
- modules.clear();
- pEPM = (tEPM) GetProcAddress( hPsapi, "EnumProcessModules" );
- pGMFNE = (tGMFNE) GetProcAddress( hPsapi, "GetModuleFileNameExA" );
- pGMBN = (tGMFNE) GetProcAddress( hPsapi, "GetModuleBaseNameA" );
- pGMI = (tGMI) GetProcAddress( hPsapi, "GetModuleInformation" );
- if ( pEPM == 0 || pGMFNE == 0 || pGMBN == 0 || pGMI == 0 )
- // we couldn´t find all functions
- FreeLibrary( hPsapi );
- return false;
- hMods = (HMODULE*) malloc(sizeof(HMODULE) * (TTBUFLEN / sizeof HMODULE));
- tt = (char*) malloc(sizeof(char) * TTBUFLEN);
- if ( ! pEPM( hProcess, hMods, TTBUFLEN, &cbNeeded ) )
- _ftprintf(fLogFile, _T("%lu: EPM failed, GetLastError = %lu\n"), g_dwShowCount, gle );
- goto cleanup;
- if ( cbNeeded > TTBUFLEN )
- _ftprintf(fLogFile, _T("%lu: More than %lu module handles. Huh?\n"), g_dwShowCount, lenof( hMods ) );
- goto cleanup;
- for ( i = 0; i < cbNeeded / sizeof hMods[0]; i++ )
- // base address, size
- pGMI(hProcess, hMods[i], &mi, sizeof mi );
- e.baseAddress = (DWORD) mi.lpBaseOfDll;
- e.size = mi.SizeOfImage;
- // image file name
- tt[0] = 0;
- pGMFNE(hProcess, hMods[i], tt, TTBUFLEN );
- e.imageName = tt;
- // module name
- tt[0] = 0;
- pGMBN(hProcess, hMods[i], tt, TTBUFLEN );
- e.moduleName = tt;
- modules.push_back(e);
-cleanup:
- if (hPsapi)
- FreeLibrary(hPsapi);
- free(tt);
- free(hMods);
-} // GetModuleListPSAPI
-static bool GetModuleList(ModuleList& modules, DWORD pid, HANDLE hProcess, FILE *fLogFile)
- // first try toolhelp32
- if (GetModuleListTH32(modules, pid, fLogFile) )
- return true;
- // then try psapi
- return GetModuleListPSAPI(modules, pid, hProcess, fLogFile);
-} // GetModuleList
-static void EnumAndLoadModuleSymbols( HANDLE hProcess, DWORD pid, FILE *fLogFile )
- static ModuleList modules;
- static ModuleListIter it;
- char *img, *mod;
- // fill in module list
- GetModuleList(modules, pid, hProcess, fLogFile);
- for ( it = modules.begin(); it != modules.end(); ++ it )
- // SymLoadModule() wants writeable strings
- img = strdup(it->imageName.c_str());
- mod = strdup(it->moduleName.c_str());
- pSLM( hProcess, 0, img, mod, it->baseAddress, it->size );
- free(img);
- free(mod);
- std::string s;
-} // EnumAndLoadModuleSymbols
-static int InitStackWalk(void)
- if (g_bInitialized != FALSE)
- return 0; // already initialized
- // old: we load imagehlp.dll dynamically because the NT4-version does not
- // old: offer all the functions that are in the NT5 lib
- // 02-12-19: Now we only support dbghelp.dll!
- // To use it on NT you have to install the redistrubutable for DBGHELP.DLL
- g_hImagehlpDll = LoadLibrary( _T("dbghelp.dll") );
- if ( g_hImagehlpDll == NULL )
- printf( "LoadLibrary( \"dbghelp.dll\" ): GetLastError = %lu\n", gle );
- g_bInitialized = FALSE;
- return 1;
- pSC = (tSC) GetProcAddress( g_hImagehlpDll, "SymCleanup" );
- pSFTA = (tSFTA) GetProcAddress( g_hImagehlpDll, "SymFunctionTableAccess" );
- pSGLFA = (tSGLFA) GetProcAddress( g_hImagehlpDll, "SymGetLineFromAddr" );
- pSGMB = (tSGMB) GetProcAddress( g_hImagehlpDll, "SymGetModuleBase" );
- pSGMI = (tSGMI) GetProcAddress( g_hImagehlpDll, "SymGetModuleInfo" );
- pSGO = (tSGO) GetProcAddress( g_hImagehlpDll, "SymGetOptions" );
- pSGSFA = (tSGSFA) GetProcAddress( g_hImagehlpDll, "SymGetSymFromAddr" );
- pSI = (tSI) GetProcAddress( g_hImagehlpDll, "SymInitialize" );
- pSSO = (tSSO) GetProcAddress( g_hImagehlpDll, "SymSetOptions" );
- pSW = (tSW) GetProcAddress( g_hImagehlpDll, "StackWalk" );
- pUDSN = (tUDSN) GetProcAddress( g_hImagehlpDll, "UnDecorateSymbolName" );
- pSLM = (tSLM) GetProcAddress( g_hImagehlpDll, "SymLoadModule" );
- if ( pSC == NULL || pSFTA == NULL || pSGMB == NULL || pSGMI == NULL ||
- pSGO == NULL || pSGSFA == NULL || pSI == NULL || pSSO == NULL ||
- pSW == NULL || pUDSN == NULL || pSLM == NULL )
- printf( "GetProcAddress(): some required function not found.\n" );
- FreeLibrary( g_hImagehlpDll );
- return 1;
- g_bInitialized = TRUE;
- InitializeCriticalSection(&g_csFileOpenClose);
- return 0;
-// This function if NOT multi-threading capable
-// It should only be called from the main-Function!
-int InitAllocCheckWN(eAllocCheckOutput eOutput, LPCTSTR pszFileName, ULONG ulShowStackAtAlloc) {
- if (g_bInitialized) {
- return 2; // already initialized!
- if (ulShowStackAtAlloc <= 3)
- g_ulShowStackAtAlloc = ulShowStackAtAlloc;
- else
- g_ulShowStackAtAlloc = 0;
- if (pszFileName != NULL)
- g_pszAllocLogName = _tcsdup(pszFileName);
- else
- g_pszAllocLogName = NULL;
- g_CallstackOutputType = eOutput;
-#ifdef _DEBUG
- AllocHashInit();
- HRESULT hr;
- // erzeuge mein malloc-Spy object
- LPMALLOCSPY pMallocSpy = new CMallocSpy(); // wird später durch Release freigegeben
- if (pMallocSpy != NULL)
- // CoInitilize(); // ??? Ist dies notwendig ?
- hr = CoRegisterMallocSpy(pMallocSpy);
- if FAILED(hr)
- _tprintf(_T("\nCoRegisterMallocSpay failed with %.8x"), hr);
-#endif
- // save the previous alloc hook
- pfnOldCrtAllocHook = _CrtSetAllocHook(MyAllocHook);
-#endif
- return InitStackWalk();
-} // InitAllocCheckWN
-static TCHAR s_szExceptionLogFileName[_MAX_PATH] = _T("\\exceptions.log"); // default
-static BOOL s_bUnhandledExeptionFilterSet = FALSE;
-static LONG __stdcall CrashHandlerExceptionFilter(EXCEPTION_POINTERS* pExPtrs)
- LONG lRet;
- lRet = StackwalkFilter(pExPtrs, /*EXCEPTION_CONTINUE_SEARCH*/EXCEPTION_EXECUTE_HANDLER, s_szExceptionLogFileName);
- TCHAR lString[500];
- _stprintf(lString,
- _T("*** Unhandled Exception!\n")
- _T(" ExpCode: 0x%8.8X\n")
- _T(" ExpFlags: %d\n")
- _T(" ExpAddress: 0x%8.8X\n")
- _T(" Please report!"),
- pExPtrs->ExceptionRecord->ExceptionCode,
- pExPtrs->ExceptionRecord->ExceptionFlags,
- pExPtrs->ExceptionRecord->ExceptionAddress);
- FatalAppExit(-1,lString);
- return lRet;
-int InitAllocCheck(eAllocCheckOutput eOutput, BOOL bSetUnhandledExeptionFilter, ULONG ulShowStackAtAlloc) // will create the filename by itself
- TCHAR szModName[_MAX_PATH];
- if (GetModuleFileName(NULL, szModName, sizeof(szModName)/sizeof(TCHAR)) != 0)
- _tcscpy(s_szExceptionLogFileName, szModName);
- if (eOutput == ACOutput_XML)
- _tcscat(s_szExceptionLogFileName, _T(".exp.xml"));
- else
- _tcscat(s_szExceptionLogFileName, _T(".exp.log"));
- _tcscat(szModName, _T(".mem.xml-leaks"));
- else
- _tcscat(szModName, _T(".mem.log"));
- else
- _tcscpy(szModName, _T("\\mem-leaks.xml-leaks")); // default
- else
- _tcscpy(szModName, _T("\\mem-leaks.log")); // default
- if (bSetUnhandledExeptionFilter != FALSE)
- // set global exception handler (for handling all unhandled exceptions)
- SetUnhandledExceptionFilter(CrashHandlerExceptionFilter);
- s_bUnhandledExeptionFilterSet = TRUE;
- return InitAllocCheckWN(eOutput, szModName, ulShowStackAtAlloc);
-// Returns the number of bytes that are not freed (leaks)
-ULONG DeInitAllocCheck(void) {
- ULONG ulRet = 0;
-#ifdef _DEBUG
- InterlockedIncrement(&g_lMallocCalled); // No deactivate MyAllocHook, because StackWalker will allocate some memory)
- ulRet = AllocHashDeinit(); // output the not freed memory
- // remove the hook and set the old one
- _CrtSetAllocHook(pfnOldCrtAllocHook);
- CoRevokeMallocSpy();
-#endif
-#endif
- EnterCriticalSection(&g_csFileOpenClose); // wait until a running stack dump was created
- // de-init symbol handler etc. (SymCleanup())
- if (pSC != NULL)
- pSC( GetCurrentProcess() );
- LeaveCriticalSection(&g_csFileOpenClose);
- if (g_pszAllocLogName != NULL) {
- free(g_pszAllocLogName);
- if (g_fFile != NULL) {
- fclose(g_fFile);
- g_fFile = NULL;
- DeleteCriticalSection(&g_csFileOpenClose);
- if (s_bUnhandledExeptionFilterSet != TRUE)
- SetUnhandledExceptionFilter(NULL);
- s_bUnhandledExeptionFilterSet = FALSE;
- return ulRet;
-} // DeInitAllocCheck
-static TCHAR *GetExpectionCodeText(DWORD dwExceptionCode) {
- switch(dwExceptionCode) {
- case EXCEPTION_ACCESS_VIOLATION: return _T("ACCESS VIOLATION");
- case EXCEPTION_ARRAY_BOUNDS_EXCEEDED: return _T("ARRAY BOUNDS EXCEEDED");
- case EXCEPTION_BREAKPOINT: return _T("BREAKPOINT");
- case EXCEPTION_DATATYPE_MISALIGNMENT: return _T("DATATYPE MISALIGNMENT");
- case EXCEPTION_FLT_DENORMAL_OPERAND: return _T("FLT DENORMAL OPERAND");
- case EXCEPTION_FLT_DIVIDE_BY_ZERO: return _T("FLT DIVIDE BY ZERO");
- case EXCEPTION_FLT_INEXACT_RESULT: return _T("FLT INEXACT RESULT");
- case EXCEPTION_FLT_INVALID_OPERATION: return _T("FLT INVALID OPERATION");
- case EXCEPTION_FLT_OVERFLOW: return _T("FLT OVERFLOW");
- case EXCEPTION_FLT_STACK_CHECK: return _T("FLT STACK CHECK");
- case EXCEPTION_FLT_UNDERFLOW: return _T("FLT UNDERFLOW");
- case EXCEPTION_ILLEGAL_INSTRUCTION: return _T("ILLEGAL INSTRUCTION");
- case EXCEPTION_IN_PAGE_ERROR: return _T("IN PAGE ERROR");
- case EXCEPTION_INT_DIVIDE_BY_ZERO: return _T("INT DIVIDE BY ZERO");
- case EXCEPTION_INT_OVERFLOW: return _T("INT OVERFLOW");
- case EXCEPTION_INVALID_DISPOSITION: return _T("INVALID DISPOSITION");
- case EXCEPTION_NONCONTINUABLE_EXCEPTION: return _T("NONCONTINUABLE EXCEPTION");
- case EXCEPTION_PRIV_INSTRUCTION: return _T("PRIV INSTRUCTION");
- case EXCEPTION_SINGLE_STEP: return _T("SINGLE STEP");
- case EXCEPTION_STACK_OVERFLOW: return _T("STACK OVERFLOW");
- case DBG_CONTROL_C : return _T("DBG CONTROL C ");
- default:
- return _T("<unkown exception>");
-} // GetExpectionCodeText
-// Function is not multi-threading safe, because of static char!
-static TCHAR *GetAdditionalExpectionCodeText(PEXCEPTION_RECORD pExceptionRecord) {
- static TCHAR szTemp[100];
- switch(pExceptionRecord->ExceptionCode) {
- if (pExceptionRecord->NumberParameters == 2) {
- switch(pExceptionRecord->ExceptionInformation[0]) {
- case 0: // read attempt
- _stprintf(szTemp, _T(" read attempt to address 0x%8.8X "), pExceptionRecord->ExceptionInformation[1]);
- return szTemp;
- case 1: // write attempt
- _stprintf(szTemp, _T(" write attempt to address 0x%8.8X "), pExceptionRecord->ExceptionInformation[1]);
- return szTemp;
- default:
- return _T("");
- } // if (pExceptionRecord->NumberParameters == 2)
- return _T("");
- default:
- return _T("");
- } // switch(pExceptionRecord->ExceptionCode)
-} // GetAdditionalExpectionCodeText
-std::string SimpleXMLEncode(PCSTR szText)
- std::string szRet;
- for (std::size_t i=0; i<strlen(szText); i++)
- switch(szText[i])
- case '&':
- szRet.append("&");
- break;
- case '<':
- szRet.append("<");
- break;
- case '>':
- szRet.append(">");
- break;
- case '"':
- szRet.append(""");
- break;
- case '\'':
- szRet.append("'");
- break;
- default:
- szRet += szText[i];
- return szRet;
-// Here the Stackwalk-Part begins.
-// Some of the code is from an example from a book
-// But I couldn´t find the reference anymore... sorry...
-// If someone knowns, please let me know...
-// if you use C++ exception handling: install a translator function
-// with set_se_translator(). In the context of that function (but *not*
-// afterwards), you can either do your stack dump, or save the CONTEXT
-// record as a local copy. Note that you must do the stack sump at the
-// earliest opportunity, to avoid the interesting stackframes being gone
-// by the time you do the dump.
-// status:
-// - EXCEPTION_CONTINUE_SEARCH: exception wird weitergereicht
-// - EXCEPTION_CONTINUE_EXECUTION:
-// - EXCEPTION_EXECUTE_HANDLER:
-DWORD StackwalkFilter( EXCEPTION_POINTERS *ep, DWORD status, LPCTSTR pszLogFile)
- HANDLE hThread;
- FILE *fFile = stdout; // default to stdout
- if (pszLogFile != NULL) { // a filename is provided
- // Open the logfile
- fFile = _tfopen(pszLogFile, _T("a"));
- if (fFile != NULL) { // Is the file too big?
- long size;
- fseek(fFile, 0, SEEK_END);
- size = ftell(fFile); // Get the size of the file
- if (size >= LOG_FILE_MAX_SIZE) {
- TCHAR *pszTemp = (TCHAR*) malloc(MAX_PATH);
- // It is too big...
- fclose(fFile);
- _tcscpy(pszTemp, pszLogFile);
- _tcscat(pszTemp, _T(".old"));
- _tremove(pszTemp); // Remove an old file, if exists
- _trename(pszLogFile, pszTemp); // rename the actual file
- fFile = _tfopen(pszLogFile, _T("w")); // create a new file
- free(pszTemp);
- } // if (pszLogFile != NULL)
- if (fFile == NULL) {
- fFile = stdout;
- // Write infos about the exception
- _ftprintf(fFile, _T("<EXCEPTION code=\"%8.8X\" addr=\"%8.8X\" "),
- ep->ExceptionRecord->ExceptionCode,
- ep->ExceptionRecord->ExceptionAddress);
- WriteDateTime(fFile, TRUE);
- _ftprintf(fFile, _T("code_desc=\"%s\" more_desc=\"%s\">\n"), GetExpectionCodeText(ep->ExceptionRecord->ExceptionCode),
- GetAdditionalExpectionCodeText(ep->ExceptionRecord));
- else
- _ftprintf(fFile, _T("######## EXCEPTION: 0x%8.8X at address: 0x%8.8X"),
- _ftprintf(fFile, _T(": %s %s\n"), GetExpectionCodeText(ep->ExceptionRecord->ExceptionCode),
- DuplicateHandle( GetCurrentProcess(), GetCurrentThread(),
- GetCurrentProcess(), &hThread, 0, false, DUPLICATE_SAME_ACCESS );
- ShowStack( hThread, *(ep->ContextRecord), fFile);
- _ftprintf(fFile, _T("</EXCEPTION>\n"));
- fclose(fFile);
- return status;
-} // StackwalkFilter
-void ShowStack( HANDLE hThread, CONTEXT& c, LPCTSTR pszLogFile)
- if (pszLogFile != NULL) { // a filename is available
- long size;
- fclose(fFile);
- fFile = _tfopen(pszLogFile, _T("w")); // open new file
- free(pszTemp);
- fFile = stdout;
- ShowStack( hThread, c, fFile);
- fclose(fFile);
-static void ShowStack( HANDLE hThread, CONTEXT& c, FILE *fLogFile) {
- ShowStackRM(hThread, c, fLogFile, NULL, GetCurrentProcess());
-static void ShowStackRM( HANDLE hThread, CONTEXT& c, FILE *fLogFile, PREAD_PROCESS_MEMORY_ROUTINE ReadMemoryFunction, HANDLE hSWProcess) {
- // normally, call ImageNtHeader() and use machine info from PE header
- DWORD imageType = IMAGE_FILE_MACHINE_I386;
- HANDLE hProcess = GetCurrentProcess(); // hProcess normally comes from outside
- int frameNum; // counts walked frames
- DWORD offsetFromSymbol; // tells us how far from the symbol we were
- DWORD offsetFromLine; // tells us how far from the line we were
- DWORD symOptions; // symbol handler settings
- static IMAGEHLP_SYMBOL *pSym = NULL;
- char undName[MAXNAMELEN]; // undecorated name
- char undFullName[MAXNAMELEN]; // undecorated name with all shenanigans
- IMAGEHLP_MODULE Module;
- IMAGEHLP_LINE Line;
- BOOL bXMLTagWrote;
- std::string symSearchPath;
- static bool bFirstTime = TRUE;
- // If no logfile is present, outpur to "stdout"
- if (fLogFile == NULL) {
- fLogFile = stdout;
- STACKFRAME s; // in/out stackframe
- memset( &s, '\0', sizeof s );
- if ( (g_bInitialized == FALSE) && (bFirstTime == TRUE) ) {
- InitStackWalk();
- if (g_bInitialized == FALSE)
- // Could not init!!!!
- bFirstTime = FALSE;
- _ftprintf(fLogFile, _T("%lu: Stackwalker not initialized (or was not able to initialize)!\n"), g_dwShowCount);
- return;
-// Critical section begin...
- InterlockedIncrement((long*) &g_dwShowCount); // erhöhe counter
- // NOTE: normally, the exe directory and the current directory should be taken
- // from the target process. The current dir would be gotten through injection
- // of a remote thread; the exe fir through either ToolHelp32 or PSAPI.
- if (pSym == NULL) {
- pSym = (IMAGEHLP_SYMBOL *) malloc( IMGSYMLEN + MAXNAMELEN );
- if (!pSym) goto cleanup; // not enough memory...
- _ftprintf(fLogFile, _T("%lu: "), g_dwShowCount);
- WriteDateTime(fLogFile);
- _ftprintf(fLogFile, _T("\n"));
- if (bFirstTime) {
- CHAR *tt, *p;
- tt = (CHAR*) malloc(sizeof(CHAR) * TTBUFLEN); // Get the temporary buffer
- if (!tt) goto cleanup; // not enough memory...
- // build symbol search path from:
- symSearchPath = "";
- // current directory
- if ( GetCurrentDirectoryA( TTBUFLEN, tt ) )
- symSearchPath += tt + std::string( ";" );
- // dir with executable
- if ( GetModuleFileNameA( 0, tt, TTBUFLEN ) )
- for ( p = tt + strlen( tt ) - 1; p >= tt; -- p )
- // locate the rightmost path separator
- if ( *p == '\\' || *p == '/' || *p == ':' )
- break;
- // if we found one, p is pointing at it; if not, tt only contains
- // an exe name (no path), and p points before its first byte
- if ( p != tt ) // path sep found?
- if ( *p == ':' ) // we leave colons in place
- ++ p;
- *p = '\0'; // eliminate the exe name and last path sep
- // environment variable _NT_SYMBOL_PATH
- if ( GetEnvironmentVariableA( "_NT_SYMBOL_PATH", tt, TTBUFLEN ) )
- // environment variable _NT_ALTERNATE_SYMBOL_PATH
- if ( GetEnvironmentVariableA( "_NT_ALTERNATE_SYMBOL_PATH", tt, TTBUFLEN ) )
- // environment variable SYSTEMROOT
- if ( GetEnvironmentVariableA( "SYSTEMROOT", tt, TTBUFLEN ) )
- if ( !symSearchPath.empty() ) // if we added anything, we have a trailing semicolon
- symSearchPath = symSearchPath.substr( 0, symSearchPath.size() - 1 );
- // why oh why does SymInitialize() want a writeable string?
- strncpy( tt, symSearchPath.c_str(), TTBUFLEN );
- tt[TTBUFLEN - 1] = '\0'; // if strncpy() overruns, it doesn't add the null terminator
- // init symbol handler stuff (SymInitialize())
- if ( ! pSI( hProcess, tt, false ) )
- _ftprintf(fLogFile, _T("%lu: SymInitialize(): GetLastError = %lu\n"), g_dwShowCount, gle );
- if (tt) free( tt );
- goto cleanup;
- // SymGetOptions()
- symOptions = pSGO();
- symOptions |= SYMOPT_LOAD_LINES;
- symOptions &= ~SYMOPT_UNDNAME;
- symOptions &= ~SYMOPT_DEFERRED_LOADS;
- pSSO( symOptions ); // SymSetOptions()
- // Enumerate modules and tell imagehlp.dll about them.
- // On NT, this is not necessary, but it won't hurt.
- EnumAndLoadModuleSymbols( hProcess, GetCurrentProcessId(), fLogFile );
- if (tt)
- free( tt );
- } // bFirstTime = TRUE
- // init STACKFRAME for first call
- // Notes: AddrModeFlat is just an assumption. I hate VDM debugging.
- // Notes: will have to be #ifdef-ed for Alphas; MIPSes are dead anyway,
- // and good riddance.
- s.AddrPC.Offset = c.Eip;
- s.AddrPC.Mode = AddrModeFlat;
- s.AddrFrame.Offset = c.Ebp;
- s.AddrFrame.Mode = AddrModeFlat;
- memset( pSym, '\0', IMGSYMLEN + MAXNAMELEN );
- pSym->SizeOfStruct = IMGSYMLEN;
- pSym->MaxNameLength = MAXNAMELEN;
- memset( &Line, '\0', sizeof Line );
- Line.SizeOfStruct = sizeof Line;
- memset( &Module, '\0', sizeof Module );
- Module.SizeOfStruct = sizeof Module;
- for ( frameNum = 0; ; ++ frameNum )
- // get next stack frame (StackWalk(), SymFunctionTableAccess(), SymGetModuleBase())
- // if this returns ERROR_INVALID_ADDRESS (487) or ERROR_NOACCESS (998), you can
- // assume that either you are done, or that the stack is so hosed that the next
- // deeper frame could not be found.
- // CONTEXT need not to be suplied if imageTyp is IMAGE_FILE_MACHINE_I386!
- if ( ! pSW( imageType, hSWProcess, hThread, &s, NULL, ReadMemoryFunction, pSFTA, pSGMB, NULL ) )
- break;
- bXMLTagWrote = FALSE;
- _ftprintf(fLogFile, _T("\n%lu: %3d"), g_dwShowCount, frameNum);
- if ( s.AddrPC.Offset == 0 )
- // Special case: If we are here, we have no valid callstack entry!
- switch(g_CallstackOutputType)
- case ACOutput_Simple:
- _ftprintf(fLogFile, _T("%lu: (-nosymbols- PC == 0)\n"), g_dwShowCount);
- break;
- case ACOutput_Advanced:
- _ftprintf(fLogFile, _T(" (-nosymbols- PC == 0)\n"));
- break;
- case ACOutput_XML:
- // TODO: ....
- _ftprintf(fLogFile, _T("<STACKENTRY decl=\"(-nosymbols- PC == 0)\"/>\n"));
- break;
- else
- // we seem to have a valid PC
- undName[0] = 0;
- undFullName[0] = 0;
- offsetFromSymbol = 0;
- // show procedure info (SymGetSymFromAddr())
- if ( ! pSGSFA( hProcess, s.AddrPC.Offset, &offsetFromSymbol, pSym ) )
- if ( gle != 487 )
- _ftprintf(fLogFile, _T(" SymGetSymFromAddr(): GetLastError = %lu\n"), gle );
- else
- else
- // UnDecorateSymbolName()
- pUDSN( pSym->Name, undName, MAXNAMELEN, UNDNAME_NAME_ONLY );
- pUDSN( pSym->Name, undFullName, MAXNAMELEN, UNDNAME_COMPLETE );
- if (strlen(undName) > 0)
- fprintf(fLogFile, " %s %+ld bytes\n", undName, (long) offsetFromSymbol );
- else
- fprintf(fLogFile, " Sig: %s %+ld bytes\n", pSym->Name, (long) offsetFromSymbol );
- strcpy(undName, pSym->Name);
- fprintf(fLogFile, "%lu: Decl: %s\n", g_dwShowCount, undFullName );
- //if (g_CallstackOutputType == ACOutput_XML)
- // fprintf(fLogFile, "decl=\"%s\" decl_offset=\"%+ld\" ", SimpleXMLEncode(undName).c_str(), (long) offsetFromSymbol);
- // show line number info, NT5.0-method (SymGetLineFromAddr())
- offsetFromLine = 0;
- if ( pSGLFA != NULL )
- { // yes, we have SymGetLineFromAddr()
- if ( ! pSGLFA( hProcess, s.AddrPC.Offset, &offsetFromLine, &Line ) )
- if ( (gle != 487) && (frameNum > 0) ) // ignore error for first frame
- _ftprintf(fLogFile, _T("<STACKENTRY "));
- bXMLTagWrote = TRUE;
- fprintf(fLogFile, "decl=\"%s\" decl_offset=\"%+ld\" ", SimpleXMLEncode(undName).c_str(), (long) offsetFromSymbol);
- _ftprintf(fLogFile, _T("srcfile=\"SymGetLineFromAddr(): GetLastError = %lu\" "), gle);
- else
- _ftprintf(fLogFile, _T("%lu: SymGetLineFromAddr(): GetLastError = %lu\n"), g_dwShowCount, gle );
- else
- fprintf(fLogFile, "%lu: Line: %s(%lu) %+ld bytes\n", g_dwShowCount,
- Line.FileName, Line.LineNumber, offsetFromLine );
- break;
- fprintf(fLogFile, "%lu: %s(%lu) %+ld bytes (%s)\n", g_dwShowCount,
- Line.FileName, Line.LineNumber, offsetFromLine, undName);
- break;
- fprintf(fLogFile, "srcfile=\"%s\" line=\"%lu\" line_offset=\"%+ld\" ",
- SimpleXMLEncode(Line.FileName).c_str(), Line.LineNumber, offsetFromLine, undName);
- break;
- } // yes, we have SymGetLineFromAddr()
- // show module info (SymGetModuleInfo())
- if ( (g_CallstackOutputType == ACOutput_Advanced) || (g_CallstackOutputType == ACOutput_XML) )
- if ( ! pSGMI( hProcess, s.AddrPC.Offset, &Module ) )
- _ftprintf(fLogFile, _T("%lu: SymGetModuleInfo): GetLastError = %lu\n"), g_dwShowCount, gle );
- else
- { // got module info OK
- char ty[80];
- switch ( Module.SymType )
- case SymNone:
- strcpy( ty, "-nosymbols-" );
- break;
- case SymCoff:
- strcpy( ty, "COFF" );
- break;
- case SymCv:
- strcpy( ty, "CV" );
- break;
- case SymPdb:
- strcpy( ty, "PDB" );
- break;
- case SymExport:
- strcpy( ty, "-exported-" );
- break;
- case SymDeferred:
- strcpy( ty, "-deferred-" );
- break;
- case SymSym:
- strcpy( ty, "SYM" );
- break;
- /* // TODO: #if API_VERSION_NUMBER >= 9 ?
- case SymDia:
- strcpy( ty, "DIA" );
- break;*/
- default:
- _snprintf( ty, sizeof ty, "symtype=%ld", (long) Module.SymType );
- break;
- // now, check if the XML-Entry is written...
- if (bXMLTagWrote == FALSE)
- _ftprintf(fLogFile, _T("srcfile=\"\" "));
- fprintf(fLogFile, "%lu: Mod: %s, base: %08lxh\n", g_dwShowCount,
- Module.ModuleName, Module.BaseOfImage );
- if (Module.SymType == SymNone) { // Gebe nur aus, wenn keine Symbole vorhanden sind!
- _ftprintf(fLogFile, _T("%lu: Offset: 0x%8.8x\n"), g_dwShowCount, s.AddrPC.Offset);
- fprintf(fLogFile, "%lu: Sym: type: %s, file: %s\n", g_dwShowCount,
- ty, Module.LoadedImageName );
- else
- // XML:
- if (bXMLTagWrote == TRUE)
- fprintf(fLogFile, "module=\"%s\" base=\"%08lx\" ", Module.ModuleName, Module.BaseOfImage);
- } // got module info OK
- if ( (g_CallstackOutputType == ACOutput_XML) && (bXMLTagWrote == TRUE) )
- _ftprintf(fLogFile, _T("/>\n")); // terminate the XML node
- } // we seem to have a valid PC
- // no return address means no deeper stackframe
- if ( s.AddrReturn.Offset == 0 )
- // avoid misunderstandings in the printf() following the loop
- SetLastError( 0 );
- break;
- } // for ( frameNum )
- if ( (g_CallstackOutputType != ACOutput_XML) && (gle != 0) )
- _ftprintf(fLogFile, _T("\n%lu: StackWalk(): GetLastError = %lu\n"), g_dwShowCount, gle );
-cleanup:
- //if (pSym) free( pSym );
- if (fLogFile) {
- _ftprintf(fLogFile, _T("\n\n"));
- if (g_dwShowCount % 1000)
- fflush(fLogFile);
-// Critical section end...
-} // ShowStackRM
diff --git a/tests/xmltester/Stackwalker.h b/tests/xmltester/Stackwalker.h
index 7e342b2..0000000
--- a/tests/xmltester/Stackwalker.h
+++ /dev/null
@@ -1,70 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Project:
- * File:
- * Stackwalker.h
- * Remarks:
- * Note:
- * Author:
- * Jochen Kalmbach
-#ifndef __STACKWALKER_H__
-#define __STACKWALKER_H__
-// Only valid in the following environment: Intel platform, MS VC++ 5/6/7
-#ifndef _X86_
-#error Only INTEL envirnoments are supported!
-#endif
-// Only MS VC++ 5 to 7
-#if (_MSC_VER < 1100) || (_MSC_VER > 1300)
-//#warning Only MS VC++ 5/6/7 supported. Check if the '_CrtMemBlockHeader' has not changed with this compiler!
-#endif
-typedef enum eAllocCheckOutput
- ACOutput_Simple,
- ACOutput_Advanced,
- ACOutput_XML
-// Make extern "C", so it will also work with normal C-Programs
-#ifdef __cplusplus
-extern "C" {
-#endif
-extern int InitAllocCheckWN(eAllocCheckOutput eOutput, LPCTSTR pszFilename, ULONG ulShowStackAtAlloc = 0);
-extern int InitAllocCheck(eAllocCheckOutput eOutput = ACOutput_Simple, BOOL bSetUnhandledExeptionFilter = TRUE, ULONG ulShowStackAtAlloc = 0); // will create the filename by itself
-extern ULONG DeInitAllocCheck();
-extern DWORD StackwalkFilter( EXCEPTION_POINTERS *ep, DWORD status, LPCTSTR pszLogFile);
-#ifdef __cplusplus
-#endif
-#endif // __STACKWALKER_H__
Summary of changes:
tests/xmltester/Stackwalker.cpp | 2333 ---------------------------------------
tests/xmltester/Stackwalker.h | 70 --
2 files changed, 2403 deletions(-)
delete mode 100644 tests/xmltester/Stackwalker.cpp
delete mode 100644 tests/xmltester/Stackwalker.h
hooks/post-receive
More information about the geos-commits
