[geos-commits] [SCM] GEOS branch master updated. 685aeb9643044376e020ca9d4d3287f3bcafef19
git at osgeo.org
git at osgeo.org
Tue Jan 12 15:50:47 PST 2021
the project "GEOS".
via 685aeb9643044376e020ca9d4d3287f3bcafef19 (commit)
from b77182f363505ccca3969a1f0a4d3e27a69e80b1 (commit)
revisions in full, below.
commit 685aeb9643044376e020ca9d4d3287f3bcafef19
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Jan 12 15:50:41 2021 -0800
Improve geosop timing, add --repeat
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 108f076..4fe4e1c 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -81,6 +81,7 @@ int main(int argc, char** argv) {
("f,format", "Output format (wkt, wkb or txt)", cxxopts::value<std::string>( ))
("h,help", "Print help")
("p,precision", "Sets number of decimal places in output coordinates", cxxopts::value<int>( cmdArgs.precision ) )
+ ("r,repeat", "Repeat operation N times", cxxopts::value<int>( cmdArgs.repeatNum ) )
("t,time", "Print execution time", cxxopts::value<bool>( cmdArgs.isShowTime ) )
("v,verbose", "Verbose output", cxxopts::value<bool>( cmdArgs.isVerbose )->default_value("false"))
@@ -143,6 +144,7 @@ int main(int argc, char** argv) {
cmdArgs.opArg1 = std::stod(val);
GeosOp geosop(cmdArgs);
geosop.run();
@@ -310,6 +312,8 @@ GeosOp::loadInput(std::string name, std::string src, int limit) {
void GeosOp::run() {
+ // ensure at least one op processed
+ if (args.repeatNum < 1) args.repeatNum = 1;
auto geomsLoadA = loadInput("A", args.srcA, args.limitA);
@@ -351,25 +355,19 @@ void GeosOp::execute() {
exit(1);
- geos::util::Profile sw( op );
- sw.start();
if (fun->isBinary()) {
executeBinary(fun);
else {
executeUnary(fun);
- sw.stop();
- totalTime = sw.getTot();
void GeosOp::executeUnary(GeomFunction * fun) {
for (unsigned i = 0; i < geomA.size(); i++) {
opCount++;
vertexCount += geomA[i]->getNumPoints();
- Result* result = executeOp(fun, i, geomA[i], 0, nullptr);
+ Result* result = executeOpRepeat(fun, i, geomA[i], 0, nullptr);
output(result);
delete result;
@@ -382,7 +380,7 @@ void GeosOp::executeBinary(GeomFunction * fun) {
opCount++;
vertexCount += geomA[ia]->getNumPoints();
vertexCount += geomB[ib]->getNumPoints();
- Result* result = executeOp(fun, ia, geomA[ia], ib, geomB[ib]);
+ Result* result = executeOpRepeat(fun, ia, geomA[ia], ib, geomB[ib]);
output(result);
delete result;
@@ -400,6 +398,19 @@ std::string inputDesc(std::string name, int index, const std::unique_ptr<Geometr
return desc;
+Result* GeosOp::executeOpRepeat(GeomFunction * fun,
+ int indexA,
+ const std::unique_ptr<Geometry>& geomA,
+ int indexB,
+ const std::unique_ptr<Geometry>& geomB)
+ Result * res;
+ for (int i = 0; i < args.repeatNum; i++) {
+ res = executeOp(fun, indexA, geomA, indexB, geomB);
+ return res;
Result* GeosOp::executeOp(GeomFunction * fun,
int indexA,
@@ -411,6 +422,8 @@ Result* GeosOp::executeOp(GeomFunction * fun,
Result* result = fun->execute( geomA, geomB, args.opArg1 );
sw.stop();
+ double time = sw.getTot();
+ totalTime += time;
// avoid cost of logging if not verbose
if (args.isVerbose) {
@@ -419,7 +432,7 @@ Result* GeosOp::executeOp(GeomFunction * fun,
+ inputDesc("A", indexA, geomA) + " "
+ inputDesc("B", indexB, geomB)
+ " -> " + result->metadata()
- + " -- " + timeFormatted( sw.getTot() )
+ + " -- " + timeFormatted( time )
diff --git a/util/geosop/GeosOp.h b/util/geosop/GeosOp.h
index f38a754..df8d2f9 100644
--- a/util/geosop/GeosOp.h
+++ b/util/geosop/GeosOp.h
@@ -32,6 +32,7 @@ public:
bool isShowTime = false;
bool isVerbose = false;
int precision = -1;
+ int repeatNum = 1;
//std::string format;
@@ -73,6 +74,9 @@ private:
void execute();
void executeUnary(GeomFunction * fun);
void executeBinary(GeomFunction * fun);
+ Result* executeOpRepeat(GeomFunction * fun,
+ int indexA, const std::unique_ptr<Geometry>& geomA,
+ int indexB, const std::unique_ptr<Geometry>& geomB);
Result* executeOp(GeomFunction * fun,
Summary of changes:
util/geosop/GeosOp.cpp | 31 ++++++++++++++++++++++---------
util/geosop/GeosOp.h | 4 ++++
2 files changed, 26 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
