[geos-commits] [SCM] GEOS branch master updated. dcf4f0b9fa4bd9ff02755889a482be9ee5a444b7
git at osgeo.org
git at osgeo.org
Fri Jan 22 16:14:48 PST 2021
the project "GEOS".
via dcf4f0b9fa4bd9ff02755889a482be9ee5a444b7 (commit)
from e412de675adc237886acc83780b8a0496aaf2561 (commit)
revisions in full, below.
commit dcf4f0b9fa4bd9ff02755889a482be9ee5a444b7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jan 22 16:14:41 2021 -0800
Rename CAPI examples to use .c extension
diff --git a/examples/README.md b/examples/README.md
index ddfbe48..e4622fc 100644
--- a/examples/README.md
+++ b/examples/README.md
@@ -2,14 +2,41 @@
* `capi_read` uses the standard C API to read two WKT geometries, calculate the intersection and print the result
* `capi_read_ts` uses the "re-entrant" C API (threadsafe) to read two WKT geometries, calculate the intersection and print the result
-* `cpp_read` uses the C++ API to read two WKT geometries, calculate the intersection and print the result
* `capi_prepared` uses the standard C API to read one WKT geometry, and fill it with a point grid, applying a high performance "prepared" geometry to speed up intersection testing
+* `cpp_read` uses the C++ API to read two WKT geometries, calculate the intersection and print the result
## Build
+To build the examples _in situ_:
mkdir _build
cd _build
cmake ..
make
+To build programs in general, you will need to ensure that the appropriate header and include files are available to the compiler. Here's a raw compile command example for a CAPI program:
+cc -I/usr/local/include \
+ capi_read.c \
+ -o capi_read \
+ -L/usr/local/lib \
+ -lgeos_c
+* Ensure the header files can be found by the compiler
+* Ensure the library files can be found by the compiler
+* Ensure the C API library is passed to the linker
+To build a C++ API program, you must pass a define indicating you're OK with the fact that the API will change over time.
+ -D USE_UNSTABLE_GEOS_CPP_API \
+ cpp_read.cpp \
+ -o cpp_read \
+ -lgeos
diff --git a/examples/capi_prepared.cpp b/examples/capi_prepared.c
similarity index 100%
rename from examples/capi_prepared.cpp
rename to examples/capi_prepared.c
diff --git a/examples/capi_read.cpp b/examples/capi_read.c
rename from examples/capi_read.cpp
rename to examples/capi_read.c
diff --git a/examples/capi_read_ts.cpp b/examples/capi_read_ts.c
rename from examples/capi_read_ts.cpp
rename to examples/capi_read_ts.c
Summary of changes:
examples/README.md | 29 ++++++++++++++++++++++++-
examples/{capi_prepared.cpp => capi_prepared.c} | 0
examples/{capi_read.cpp => capi_read.c} | 0
examples/{capi_read_ts.cpp => capi_read_ts.c} | 0
4 files changed, 28 insertions(+), 1 deletion(-)
rename examples/{capi_prepared.cpp => capi_prepared.c} (100%)
rename examples/{capi_read.cpp => capi_read.c} (100%)
rename examples/{capi_read_ts.cpp => capi_read_ts.c} (100%)
hooks/post-receive
More information about the geos-commits
