[geos-commits] [SCM] GEOS branch master updated. 65791765e58af02edf6471c4cc7b7fb193abeca7
git at osgeo.org
git at osgeo.org
Fri Jan 29 15:37:30 PST 2021
the project "GEOS".
via 65791765e58af02edf6471c4cc7b7fb193abeca7 (commit)
from d8a1b32762a799ad8364c48ba84924f61c93c132 (commit)
revisions in full, below.
commit 65791765e58af02edf6471c4cc7b7fb193abeca7
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Jan 29 18:36:16 2021 -0500
Quiet clang warnings
diff --git a/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp b/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
index b3c6a22..330e681 100644
--- a/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
+++ b/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
@@ -66,6 +66,6 @@ int main(int argc, char** argv) {
auto num_reps = argc > 2 ? std::atol(argv[2]) : 1;
for (decltype(num_reps) i = 0; i < num_reps; i++) {
- tester.test(num_lines);
+ tester.test(static_cast<std::size_t>(num_lines));
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 052c60f..507b743 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2092,7 +2092,7 @@ extern "C" {
int
GEOS_getWKBOutputDims_r(GEOSContextHandle_t extHandle)
- return execute(extHandle, -1, [&]() {
+ return execute(extHandle, -1, [&]() -> int {
GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
return handle->WKBOutputDims;
diff --git a/include/geos/index/quadtree/Quadtree.h b/include/geos/index/quadtree/Quadtree.h
index e3897c2..c0bbc5e 100644
--- a/include/geos/index/quadtree/Quadtree.h
+++ b/include/geos/index/quadtree/Quadtree.h
@@ -115,7 +115,7 @@ public:
~Quadtree() override = default;
/// Returns the number of levels in the tree.
- int depth();
+ std::size_t depth();
/// Returns the number of items in the tree.
std::size_t size();
diff --git a/include/geos/io/WKTWriter.h b/include/geos/io/WKTWriter.h
index c0af8e7..f25da28 100644
--- a/include/geos/io/WKTWriter.h
+++ b/include/geos/io/WKTWriter.h
@@ -220,7 +220,7 @@ protected:
void appendCoordinate(const geom::Coordinate* coordinate,
Writer* writer);
- std::string writeNumber(double d);
+ std::string writeNumber(double d) const;
void appendLineStringText(
const geom::LineString* lineString,
@@ -270,7 +270,7 @@ private:
const geom::Geometry* geometry,
bool isFormatted, Writer* writer);
- void indent(int level, Writer* writer);
+ void indent(int level, Writer* writer) const;
} // namespace geos::io
diff --git a/include/geos/operation/overlayng/EdgeNodingBuilder.h b/include/geos/operation/overlayng/EdgeNodingBuilder.h
index 033ab66..44cc0d8 100644
--- a/include/geos/operation/overlayng/EdgeNodingBuilder.h
+++ b/include/geos/operation/overlayng/EdgeNodingBuilder.h
@@ -199,7 +199,7 @@ public:
: pm(p_pm)
, inputEdges(new std::vector<SegmentString*>)
, customNoder(p_customNoder)
- , hasEdges({false,false})
+ , hasEdges{{false,false}}
, clipEnv(nullptr)
, intAdder(lineInt)
diff --git a/include/geos/operation/union/OverlapUnion.h b/include/geos/operation/union/OverlapUnion.h
index e0f1db0..383b513 100644
--- a/include/geos/operation/union/OverlapUnion.h
+++ b/include/geos/operation/union/OverlapUnion.h
@@ -123,13 +123,13 @@ private:
geounion::ClassicUnionStrategy defaultUnionFunction;
- geom::Envelope overlapEnvelope(const geom::Geometry* geom0, const geom::Geometry* geom1);
+ static geom::Envelope overlapEnvelope(const geom::Geometry* geom0, const geom::Geometry* geom1);
std::unique_ptr<geom::Geometry> extractByEnvelope(const geom::Envelope& env, const geom::Geometry* geom, std::vector<std::unique_ptr<geom::Geometry>>& disjointGeoms);
- std::unique_ptr<geom::Geometry> combine(std::unique_ptr<geom::Geometry>& unionGeom, std::vector<std::unique_ptr<geom::Geometry>>& disjointPolys);
+ static std::unique_ptr<geom::Geometry> combine(std::unique_ptr<geom::Geometry>& unionGeom, std::vector<std::unique_ptr<geom::Geometry>>& disjointPolys);
std::unique_ptr<geom::Geometry> unionFull(const geom::Geometry* geom0, const geom::Geometry* geom1);
- std::unique_ptr<geom::Geometry> unionBuffer(const geom::Geometry* geom0, const geom::Geometry* geom1);
+ static std::unique_ptr<geom::Geometry> unionBuffer(const geom::Geometry* geom0, const geom::Geometry* geom1);
bool isBorderSegmentsSame(const geom::Geometry* result, const geom::Envelope& env);
- bool isEqual(std::vector<geom::LineSegment>& segs0, std::vector<geom::LineSegment>& segs1);
+ static bool isEqual(std::vector<geom::LineSegment>& segs0, std::vector<geom::LineSegment>& segs1);
std::vector<geom::LineSegment> extractBorderSegments(const geom::Geometry* geom0, const geom::Geometry* geom1, const geom::Envelope& env);
void extractBorderSegments(const geom::Geometry* geom, const geom::Envelope& penv, std::vector<geom::LineSegment>& psegs);
diff --git a/include/geos/shape/fractal/HilbertCode.h b/include/geos/shape/fractal/HilbertCode.h
index 46012ef..76defbc 100644
--- a/include/geos/shape/fractal/HilbertCode.h
+++ b/include/geos/shape/fractal/HilbertCode.h
@@ -113,7 +113,7 @@ private:
static uint32_t descan(uint32_t x);
- static void checkLevel(int level);
+ static void checkLevel(uint32_t level);
diff --git a/include/geos/triangulate/quadedge/QuadEdgeQuartet.h b/include/geos/triangulate/quadedge/QuadEdgeQuartet.h
index 30817d9..0614fa4 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeQuartet.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeQuartet.h
@@ -25,7 +25,7 @@ namespace quadedge {
class GEOS_DLL QuadEdgeQuartet {
public:
- QuadEdgeQuartet() : e{QuadEdge(0), QuadEdge(1), QuadEdge(2), QuadEdge(3)} {
+ QuadEdgeQuartet() : e{{QuadEdge(0), QuadEdge(1), QuadEdge(2), QuadEdge(3)}} {
e[0].next = &(e[0]);
e[1].next = &(e[3]);
e[2].next = &(e[2]);
diff --git a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
index f5852f9..005d096 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
@@ -24,6 +24,7 @@
#include <list>
#include <stack>
#include <unordered_set>
+#include <array>
#include <vector>
#include <geos/geom/MultiLineString.h>
@@ -360,7 +361,7 @@ private:
* Only one visitor is allowed to be active at a time, so this is safe.
- QuadEdge* triEdges[3];
+ std::array<QuadEdge*, 3> m_triEdges;
/** \brief
* Resets the `visited` flag of each `QuadEdge` prior to iteration, if necessary.
@@ -378,7 +379,7 @@ private:
* @return `null` if the triangle should not be visited (for instance, if it is
* outer)
- QuadEdge** fetchTriangleToVisit(QuadEdge* edge, QuadEdgeStack& edgeStack, bool includeFrame);
+ std::array<QuadEdge*, 3>* fetchTriangleToVisit(QuadEdge* edge, QuadEdgeStack& edgeStack, bool includeFrame);
/** \brief
* Gets the coordinates for each triangle in the subdivision as an array.
diff --git a/include/geos/triangulate/quadedge/TriangleVisitor.h b/include/geos/triangulate/quadedge/TriangleVisitor.h
index 443b665..7989a60 100644
--- a/include/geos/triangulate/quadedge/TriangleVisitor.h
+++ b/include/geos/triangulate/quadedge/TriangleVisitor.h
@@ -38,7 +38,7 @@ public:
* @param triEdges an array of the 3 quad edges in a triangle (in CCW order)
- virtual void visit(QuadEdge* triEdges[3]) = 0;
+ virtual void visit(std::array<QuadEdge*, 3> &) = 0;
virtual ~TriangleVisitor() = default;
private:
diff --git a/src/index/quadtree/Quadtree.cpp b/src/index/quadtree/Quadtree.cpp
index 5c72c04..b8834cd 100644
--- a/src/index/quadtree/Quadtree.cpp
+++ b/src/index/quadtree/Quadtree.cpp
@@ -68,7 +68,7 @@ Quadtree::ensureExtent(const Envelope* itemEnv, double minExtent)
/*public*/
-int
+size_t
Quadtree::depth()
return root.depth();
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 1c010a2..7ad23fd 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -358,9 +358,9 @@ WKTWriter::appendCoordinate(const Coordinate* coordinate,
/* protected */
std::string
-WKTWriter::writeNumber(double d)
+WKTWriter::writeNumber(double d) const
- int precision = decimalPlaces >= 0 ? decimalPlaces : 0;
+ uint32_t precision = decimalPlaces >= 0 ? static_cast<std::uint32_t>(decimalPlaces) : 0;
* For a "trimmed" result, with no trailing zeros we use
* the ryu library.
@@ -379,7 +379,7 @@ WKTWriter::writeNumber(double d)
else {
std::stringstream ss;
ss << std::fixed;
- ss << std::setprecision(precision);
+ ss << std::setprecision(static_cast<int>(precision));
ss << d;
return ss.str();
@@ -533,13 +533,13 @@ WKTWriter::appendGeometryCollectionText(
void
-WKTWriter::indent(int p_level, Writer* writer)
+WKTWriter::indent(int p_level, Writer* writer) const
if(!isFormatted || p_level <= 0) {
return;
writer->write("\n");
- writer->write(std::string(INDENT * p_level, ' '));
+ writer->write(std::string(INDENT * static_cast<std::size_t>(p_level), ' '));
} // namespace geos.io
diff --git a/src/noding/OrientedCoordinateArray.cpp b/src/noding/OrientedCoordinateArray.cpp
index 99d4fd0..352d6fb 100644
--- a/src/noding/OrientedCoordinateArray.cpp
+++ b/src/noding/OrientedCoordinateArray.cpp
@@ -70,14 +70,14 @@ OrientedCoordinateArray::compareOriented(const geom::CoordinateSequence& pts1,
int dir1 = orientation1 ? 1 : -1;
int dir2 = orientation2 ? 1 : -1;
- auto limit1 = orientation1 ? pts1.size() : -1;
- auto limit2 = orientation2 ? pts2.size() : -1;
+ int limit1 = orientation1 ? static_cast<int>(pts1.size()) : -1;
+ int limit2 = orientation2 ? static_cast<int>(pts2.size()) : -1;
- auto i1 = orientation1 ? 0 : pts1.size() - 1;
- auto i2 = orientation2 ? 0 : pts2.size() - 1;
+ int i1 = orientation1 ? 0 : static_cast<int>(pts1.size() - 1);
+ int i2 = orientation2 ? 0 : static_cast<int>(pts2.size() - 1);
//int comp = 0; // unused, but is in JTS ...
while(true) {
- int compPt = pts1[i1].compareTo(pts2[i2]);
+ int compPt = pts1[static_cast<std::size_t>(i1)].compareTo(pts2[static_cast<std::size_t>(i2)]);
if(compPt != 0) {
return compPt;
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index 0b2164e..9fc320f 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -228,10 +228,10 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
Rectangle::onEdge(pos) &&
!Rectangle::onSameEdge(prev_pos, pos) // discard if travels along edge
- std::vector<Coordinate>* coords = new std::vector<Coordinate>(2);
- (*coords)[0] = Coordinate(x0, y0);
- (*coords)[1] = Coordinate(x, y);
- auto seq = _csf->create(coords);
+ std::vector<Coordinate> coords(2);
+ coords[0] = Coordinate(x0, y0);
+ coords[1] = Coordinate(x, y);
+ auto seq = _csf->create(std::move(coords));
geom::LineString* line = _gf->createLineString(seq.release());
parts.add(line);
@@ -257,7 +257,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
else {
- // The point is now stricly inside or on the edge.
+ // The point is now strictly inside or on the edge.
// Keep iterating until the end or the point goes
// outside. We may have to output partial linestrings
// while iterating until we go strictly outside
@@ -290,19 +290,20 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
// Output a LineString if it at least one segment long
if(start_index < i - 1 || add_start || through_box) {
- std::vector<Coordinate>* coords = new std::vector<Coordinate>();
+ std::vector<Coordinate> coords;
if(add_start) {
- coords->push_back(Coordinate(x0, y0));
+ coords.emplace_back(x0, y0);
add_start = false;
//line->addSubLineString(&g, start_index, i-1);
- coords->insert(coords->end(), cs.begin() + start_index, cs.begin() + i);
+ coords.insert(coords.end(), cs.begin() + static_cast<long>(start_index), cs.begin() +
+ static_cast<long>(i));
if(through_box) {
- coords->push_back(Coordinate(x, y));
+ coords.emplace_back(x, y);
parts.add(line);
@@ -313,17 +314,18 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
if(Rectangle::onSameEdge(prev_pos, pos)) {
// Nothing to output if we haven't been elsewhere
if(start_index < i - 1 || add_start) {
//geom::LineString * line = new geom::LineString();
if(add_start) {
//line->addPoint(x0,y0);
add_start = false;
parts.add(line);
@@ -346,17 +348,18 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString* gi,
if(!go_outside && // meaning data ended
(start_index < i - 1 || add_start)) { // meaning something has to be generated
if(add_start) {
add_start = false;
parts.add(line);
diff --git a/src/operation/overlay/ElevationMatrix.cpp b/src/operation/overlay/ElevationMatrix.cpp
index 262cb36..f5682d3 100644
--- a/src/operation/overlay/ElevationMatrix.cpp
+++ b/src/operation/overlay/ElevationMatrix.cpp
@@ -166,7 +166,7 @@ ElevationMatrix::getCell(const Coordinate& c)
double xoffset = c.x - env.getMinX();
col = (int)(xoffset / cellwidth);
if(col == (int)cols) {
- col = cols - 1;
+ col = static_cast<int>(cols - 1);
if(cellheight == 0) {
@@ -176,10 +176,10 @@ ElevationMatrix::getCell(const Coordinate& c)
double yoffset = c.y - env.getMinY();
row = (int)(yoffset / cellheight);
if(row == (int)rows) {
- row = rows - 1;
+ row = static_cast<int>(rows - 1);
- int celloffset = (cols * row) + col;
+ int celloffset = static_cast<int>(cols) * row + col;
if(celloffset < 0 || celloffset >= (int)(cols * rows)) {
std::ostringstream s;
@@ -188,7 +188,7 @@ ElevationMatrix::getCell(const Coordinate& c)
throw util::IllegalArgumentException(s.str());
- return cells[celloffset];
+ return cells[static_cast<std::size_t>(celloffset)];
const ElevationMatrixCell&
diff --git a/src/operation/overlayng/InputGeometry.cpp b/src/operation/overlayng/InputGeometry.cpp
index 04d70f3..9df59e0 100644
--- a/src/operation/overlayng/InputGeometry.cpp
+++ b/src/operation/overlayng/InputGeometry.cpp
@@ -21,8 +21,8 @@ namespace overlayng { // geos.operation.overlayng
/*public*/
InputGeometry::InputGeometry(const Geometry* geomA, const Geometry* geomB)
- : geom({geomA, geomB})
- , isCollapsed({false, false})
+ : geom{{geomA, geomB}}
+ , isCollapsed{{false, false}}
/*public*/
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index 8e6d65e..3d99c54 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -213,7 +213,7 @@ const CoordinateSequence*
EdgeRing::getCoordinates()
if(ringPts == nullptr) {
- ringPts = detail::make_unique<CoordinateArraySequence>(0, 0);
+ ringPts = detail::make_unique<CoordinateArraySequence>(0u, 0u);
for(const auto& de : deList) {
auto edge = dynamic_cast<PolygonizeEdge*>(de->getEdge());
addEdge(edge->getLine()->getCoordinatesRO(),
diff --git a/src/operation/predicate/RectangleIntersects.cpp b/src/operation/predicate/RectangleIntersects.cpp
index c8ad09f..a2feea7 100644
--- a/src/operation/predicate/RectangleIntersects.cpp
+++ b/src/operation/predicate/RectangleIntersects.cpp
@@ -157,8 +157,7 @@ protected:
// test each corner of rectangle for inclusion
- for(int i = 0; i < 4; i++) {
+ for(unsigned int i = 0; i < 4; i++) {
const geom::Coordinate& rectPt = rectSeq.getAt(i);
if(!elementEnv.contains(rectPt)) {
diff --git a/src/operation/union/OverlapUnion.cpp b/src/operation/union/OverlapUnion.cpp
index ea4fb8c..7e21ed2 100644
--- a/src/operation/union/OverlapUnion.cpp
+++ b/src/operation/union/OverlapUnion.cpp
@@ -80,7 +80,7 @@ OverlapUnion::overlapEnvelope(const Geometry* geom0, const Geometry* geom1)
std::unique_ptr<Geometry>
OverlapUnion::combine(std::unique_ptr<Geometry>& unionGeom, std::vector<std::unique_ptr<Geometry>>& disjointPolys)
- if (disjointPolys.size() <= 0)
+ if (disjointPolys.empty())
return std::move(unionGeom);
disjointPolys.push_back(std::move(unionGeom));
@@ -221,14 +221,14 @@ OverlapUnion::extractBorderSegments(const Geometry* geom, const Envelope& penv,
class BorderSegmentFilter : public CoordinateSequenceFilter {
private:
- const Envelope env;
- std::vector<LineSegment>* segs;
+ const Envelope m_env;
+ std::vector<LineSegment>* m_segs;
public:
- BorderSegmentFilter(const Envelope& penv, std::vector<LineSegment>* psegs)
- : env(penv),
- segs(psegs) {};
+ BorderSegmentFilter(const Envelope& env, std::vector<LineSegment>* segs)
+ : m_env(env),
+ m_segs(segs) {};
bool
isDone() const override { return false; }
@@ -244,9 +244,9 @@ OverlapUnion::extractBorderSegments(const Geometry* geom, const Envelope& penv,
// extract LineSegment
const Coordinate& p0 = seq.getAt(i-1);
const Coordinate& p1 = seq.getAt(i );
- bool isBorder = intersects(env, p0, p1) && ! containsProperly(env, p0, p1);
+ bool isBorder = intersects(m_env, p0, p1) && ! containsProperly(m_env, p0, p1);
if (isBorder) {
- segs->emplace_back(p0, p1);
+ m_segs->emplace_back(p0, p1);
diff --git a/src/operation/valid/RepeatedPointRemover.cpp b/src/operation/valid/RepeatedPointRemover.cpp
index b4aac9a..2b3dd7c 100644
--- a/src/operation/valid/RepeatedPointRemover.cpp
+++ b/src/operation/valid/RepeatedPointRemover.cpp
@@ -27,7 +27,7 @@ RepeatedPointRemover::removeRepeatedPoints(const geom::CoordinateSequence* seq)
using geom::Coordinate;
if (seq->isEmpty()) {
- return detail::make_unique<geom::CoordinateArraySequence>(0, seq->getDimension());
+ return detail::make_unique<geom::CoordinateArraySequence>(0u, seq->getDimension());
auto pts = detail::make_unique<std::vector<Coordinate>>();
diff --git a/src/shape/fractal/HilbertCode.cpp b/src/shape/fractal/HilbertCode.cpp
index 484f475..8cfdcba 100644
--- a/src/shape/fractal/HilbertCode.cpp
+++ b/src/shape/fractal/HilbertCode.cpp
@@ -89,7 +89,7 @@ HilbertCode::descan(uint32_t x)
/*private static*/
void
-HilbertCode::checkLevel(int level)
+HilbertCode::checkLevel(uint32_t level)
if (level > MAX_LEVEL) {
throw util::IllegalArgumentException("Level out of range");
diff --git a/src/simplify/TopologyPreservingSimplifier.cpp b/src/simplify/TopologyPreservingSimplifier.cpp
index bd99e12..6bec39f 100644
--- a/src/simplify/TopologyPreservingSimplifier.cpp
+++ b/src/simplify/TopologyPreservingSimplifier.cpp
@@ -224,7 +224,7 @@ LineStringMapBuilderFilter::filter_ro(const Geometry* geom)
if(const LineString* ls =
dynamic_cast<const LineString*>(geom)) {
- int minSize = ls->isClosed() ? 4 : 2;
+ std::size_t minSize = ls->isClosed() ? 4 : 2;
taggedLine = new TaggedLineString(ls, minSize);
else {
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index 613e891..4917f87 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -320,15 +320,15 @@ QuadEdgeSubdivision::getPrimaryEdges(bool includeFrame)
return std::unique_ptr<QuadEdgeList>(edges);
-QuadEdge**
+std::array<QuadEdge*, 3>*
QuadEdgeSubdivision::fetchTriangleToVisit(QuadEdge* edge,
QuadEdge* curr = edge;
- int edgeCount = 0;
+ std::size_t edgeCount = 0;
bool isFrame = false;
do {
- triEdges[edgeCount] = curr;
+ m_triEdges[edgeCount] = curr;
if(!includeFrame && isFrameEdge(*curr)) {
isFrame = true;
@@ -351,7 +351,7 @@ QuadEdgeSubdivision::fetchTriangleToVisit(QuadEdge* edge,
if(!includeFrame && isFrame) {
return nullptr;
- return triEdges;
+ return &m_triEdges;
class
@@ -366,7 +366,7 @@ public:
void
- visit(QuadEdge* triEdges[3]) override
+ visit(std::array<QuadEdge*, 3>& triEdges) override
auto coordSeq = coordSeqFact.create(4, 0);
for(std::size_t i = 0; i < 3; i++) {
@@ -383,7 +383,7 @@ class
QuadEdgeSubdivision::TriangleCircumcentreVisitor : public TriangleVisitor {
public:
void
Triangle triangle(triEdges[0]->orig().getCoordinate(),
triEdges[1]->orig().getCoordinate(), triEdges[2]->orig().getCoordinate());
@@ -394,7 +394,7 @@ public:
Vertex ccVertex(cc);
- for(int i = 0 ; i < 3 ; i++) {
+ for(uint8_t i = 0 ; i < 3 ; i++) {
triEdges[i]->rot().setOrig(ccVertex);
@@ -431,9 +431,9 @@ QuadEdgeSubdivision::visitTriangles(TriangleVisitor* triVisitor, bool includeFra
QuadEdge* edge = edgeStack.top();
edgeStack.pop();
if(!edge->isVisited()) {
- QuadEdge** p_triEdges = fetchTriangleToVisit(edge, edgeStack, includeFrame);
- if(p_triEdges != nullptr) {
- triVisitor->visit(p_triEdges);
+ auto triEdges = fetchTriangleToVisit(edge, edgeStack, includeFrame);
+ if(triEdges != nullptr) {
+ triVisitor->visit(*triEdges);
diff --git a/src/util/GeometricShapeFactory.cpp b/src/util/GeometricShapeFactory.cpp
index 6ac97dc..3f04ee4 100644
--- a/src/util/GeometricShapeFactory.cpp
+++ b/src/util/GeometricShapeFactory.cpp
@@ -85,7 +85,7 @@ std::unique_ptr<Polygon>
GeometricShapeFactory::createRectangle()
uint32_t i;
- int ipt = 0;
+ uint32_t ipt = 0;
uint32_t nSide = nPts / 4;
if(nSide < 1) {
nSide = 1;
@@ -135,7 +135,7 @@ GeometricShapeFactory::createCircle()
env.reset();
std::vector<Coordinate> pts(nPts + 1);
- int iPt = 0;
+ uint32_t iPt = 0;
for(uint32_t i = 0; i < nPts; i++) {
double ang = i * (2 * 3.14159265358979 / nPts);
double x = xRadius * cos(ang) + centreX;
@@ -167,7 +167,7 @@ GeometricShapeFactory::createArc(double startAng, double angExtent)
double angInc = angSize / (nPts - 1);
std::vector<Coordinate> pts(nPts);
- int iPt = 0;
+ uint32_t iPt = 0;
double ang = startAng + i * angInc;
@@ -197,7 +197,7 @@ GeometricShapeFactory::createArcPolygon(double startAng, double angExtent)
std::vector<Coordinate> pts(nPts + 2);
- int iPt = 0;
+ uint32_t iPt = 0;
pts[iPt++] = coord(centreX, centreY);
diff --git a/src/util/Profiler.cpp b/src/util/Profiler.cpp
index 524fd4c..be5f411 100644
--- a/src/util/Profiler.cpp
+++ b/src/util/Profiler.cpp
@@ -62,7 +62,7 @@ Profile::getTotFormatted() const
std::string fmt = usec.str();
int insertPosition = static_cast<int>(fmt.length()) - 3;
while (insertPosition > 0) {
- fmt.insert(insertPosition, ",");
+ fmt.insert(static_cast<std::string::size_type>(insertPosition), ",");
insertPosition-=3;
return fmt + " usec";
diff --git a/tests/unit/algorithm/RobustLineIntersectionTest.cpp b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
index 6172352..0e3ef2b 100644
--- a/tests/unit/algorithm/RobustLineIntersectionTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
@@ -111,7 +111,7 @@ struct test_robustlineintersection_data {
void
checkIntersection(const std::string& wkt1,
const std::string& wkt2,
- int expectedIntersectionNum,
+ std::size_t expectedIntersectionNum,
const std::string& expectedWKT,
double distanceTolerance)
//throws ParseException
@@ -150,7 +150,7 @@ struct test_robustlineintersection_data {
void
const std::vector<Coordinate>& intPt,
// throws ParseException
@@ -239,7 +239,7 @@ struct test_robustlineintersection_data {
li.computeIntersection(pt[0], pt[1], pt[2], pt[3]);
// check that input points are unchanged
+ for(std::size_t i = 0; i < 4; i++) {
ensure_equals(savePt[i], pt[i]);
diff --git a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
index 68da373..ab45d3c 100644
--- a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
@@ -83,11 +83,11 @@ template<>
void object::test<2>
- std::array<GEOSGeom, geom_size> geoms = {
+ std::array<GEOSGeom, geom_size> geoms = {{
GEOSGeom_createEmptyPoint_r(handle_),
// takes ownership of individual geometries
geom_ = GEOSGeom_createCollection_r(handle_, GEOS_MULTIPOINT,
geoms.data(), static_cast<int>(geoms.size()));
diff --git a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
index b560975..025d4f6 100644
--- a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
@@ -23,7 +23,7 @@ void object::test<1>
double shell_coords[] = {0,0, 0,10, 10,10, 10,0, 0,0};
double hole_coords[] = {5,5, 5,6, 6,6, 6,5, 5,5};
- for (int i = 0; i < 5; i++) {
+ for (unsigned int i = 0; i < 5; i++) {
GEOSCoordSeq_setXY(shell_seq, i, shell_coords[2*i], shell_coords[2*i+1]);
GEOSCoordSeq_setXY(hole_seq, i, hole_coords[2*i], hole_coords[2*i+1]);
diff --git a/tests/unit/edgegraph/EdgeGraphTest.cpp b/tests/unit/edgegraph/EdgeGraphTest.cpp
index 39fa0bc..7162edd 100644
--- a/tests/unit/edgegraph/EdgeGraphTest.cpp
+++ b/tests/unit/edgegraph/EdgeGraphTest.cpp
@@ -46,7 +46,7 @@ struct test_edgegraph_data {
void checkEdgeRing(EdgeGraph& graph, Coordinate& p, std::vector<Coordinate>& dest) {
HalfEdge* e = graph.findEdge(p, dest[0]);
HalfEdge* onext = e;
- int i = 0;
+ std::size_t i = 0;
do {
ensure(onext->dest().equals2D(dest[i++]));
onext = onext->oNext();
diff --git a/tests/unit/geom/GeometryComponentFilterTest.cpp b/tests/unit/geom/GeometryComponentFilterTest.cpp
index a42551b..afb48ca 100644
--- a/tests/unit/geom/GeometryComponentFilterTest.cpp
+++ b/tests/unit/geom/GeometryComponentFilterTest.cpp
@@ -72,7 +72,7 @@ void object::test<1>
// collection of 4 geometries
- GeometryPtr g(reader.read("GEOMETRYCOLLECTION("
+ GeometryPtr input(reader.read("GEOMETRYCOLLECTION("
"POINT(0 0),"
"LINESTRING(0 0,1 1,1 2),"
"POLYGON((0 0,4 0,4 4,0 4,0 0)),"
@@ -104,7 +104,7 @@ void object::test<1>
GeometryRefArray lineal;
GeometryRefArray nonlineal;
GeometryComponentSplitter splitter(lineal, nonlineal);
- g->apply_ro(&splitter);
+ input->apply_ro(&splitter);
// TODO: Verify the actual results
// lineal:
diff --git a/tests/unit/geom/GeometryFilterTest.cpp b/tests/unit/geom/GeometryFilterTest.cpp
index 13c76a3..010bf03 100644
--- a/tests/unit/geom/GeometryFilterTest.cpp
+++ b/tests/unit/geom/GeometryFilterTest.cpp
@@ -42,7 +42,7 @@ void object::test<1>
"POINT(0 0),"
@@ -74,7 +74,7 @@ void object::test<1>
GeometrySplitter splitter(lineal, nonlineal);
// lineal:
@@ -91,7 +91,7 @@ void object::test<1>
ensure_equals(nonlineal.size(), 3ul);
// TODO: is 7, shouldn't be not 4?
//ensure_equals(lineal.size() + nonlineal.size(), g->getNumGeometries());
- ensure_equals(g->getNumGeometries(), 4ul);
+ ensure_equals(input->getNumGeometries(), 4ul);
ensure_equals(lineal.size() + nonlineal.size(), 7ul);
diff --git a/tests/unit/noding/BasicSegmentStringTest.cpp b/tests/unit/noding/BasicSegmentStringTest.cpp
index cc49126..e0c2f5e 100644
--- a/tests/unit/noding/BasicSegmentStringTest.cpp
+++ b/tests/unit/noding/BasicSegmentStringTest.cpp
@@ -63,7 +63,7 @@ template<>
- auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0, 2);
+ auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0u, 2u);
ensure(nullptr != cs.get());
@@ -108,7 +108,7 @@ template<>
@@ -145,7 +145,7 @@ template<>
void object::test<3>
diff --git a/tests/unit/noding/SegmentNodeTest.cpp b/tests/unit/noding/SegmentNodeTest.cpp
index 50f2139..5c631b7 100644
--- a/tests/unit/noding/SegmentNodeTest.cpp
+++ b/tests/unit/noding/SegmentNodeTest.cpp
@@ -103,7 +103,7 @@ void object::test<2>
// Create coordinates sequence
const std::size_t coords_size = 2;
- auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0, coords_size);
+ auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0u, coords_size);
@@ -146,7 +146,7 @@ void object::test<3>
@@ -189,7 +189,7 @@ void object::test<4>
diff --git a/tests/unit/precision/CommonBitsTest.cpp b/tests/unit/precision/CommonBitsTest.cpp
index 9725f57..fbd4c2c 100644
--- a/tests/unit/precision/CommonBitsTest.cpp
+++ b/tests/unit/precision/CommonBitsTest.cpp
@@ -36,7 +36,7 @@ template<>
- constexpr int64_t val = 0xffffffffffffffffull;
+ constexpr int64_t val = static_cast<int64_t>(0xffffffffffffffffull);
for(int i = 0; i < 64; i++) {
ensure_equals(CommonBits::getBit(val, i), 1);
@@ -48,7 +48,7 @@ template<>
- constexpr int64_t val = 0xffffffff00000000ull;
+ constexpr int64_t val = static_cast<int64_t>(0xffffffff00000000ull);
ensure_equals(CommonBits::getBit(val, 0), 0);
ensure_equals(CommonBits::getBit(val, 63), 1);
diff --git a/tests/unit/shape/fractal/MortonCodeTest.cpp b/tests/unit/shape/fractal/MortonCodeTest.cpp
index 0fac995..276bf41 100644
--- a/tests/unit/shape/fractal/MortonCodeTest.cpp
+++ b/tests/unit/shape/fractal/MortonCodeTest.cpp
@@ -16,7 +16,7 @@ namespace tut {
// Common data used by tests
struct test_mortoncode_data {
- void checkDecode(uint32_t index, int x, int y)
+ static void checkDecode(uint32_t index, int x, int y)
Coordinate p = MortonCode::decode(index);
//System.out.println(p);
@@ -24,7 +24,7 @@ struct test_mortoncode_data {
ensure_equals(y, (int) p.y);
- void checkDecodeEncodeForLevel(uint32_t level)
+ static void checkDecodeEncodeForLevel(uint32_t level)
uint32_t n = MortonCode::levelSize(level);
for (uint32_t i = 0; i < n; i++) {
@@ -33,11 +33,11 @@ struct test_mortoncode_data {
- void
+ static void
checkDecodeEncode(uint32_t index)
- uint32_t encode = MortonCode::encode((uint32_t)(p.x), (uint32_t)(p.y));
+ uint32_t encode = MortonCode::encode(static_cast<int>(p.x), static_cast<int>(p.y));
ensure_equals(index, encode);
Summary of changes:
.../algorithm/UnaryUnionSegmentsPerfTest.cpp | 2 +-
capi/geos_ts_c.cpp | 2 +-
include/geos/index/quadtree/Quadtree.h | 2 +-
include/geos/io/WKTWriter.h | 4 +--
.../geos/operation/overlayng/EdgeNodingBuilder.h | 2 +-
include/geos/operation/union/OverlapUnion.h | 8 ++---
include/geos/shape/fractal/HilbertCode.h | 2 +-
.../geos/triangulate/quadedge/QuadEdgeQuartet.h | 2 +-
.../triangulate/quadedge/QuadEdgeSubdivision.h | 5 +--
.../geos/triangulate/quadedge/TriangleVisitor.h | 2 +-
src/index/quadtree/Quadtree.cpp | 2 +-
src/io/WKTWriter.cpp | 10 +++---
src/noding/OrientedCoordinateArray.cpp | 10 +++---
.../intersection/RectangleIntersection.cpp | 39 ++++++++++++----------
src/operation/overlay/ElevationMatrix.cpp | 8 ++---
src/operation/overlayng/InputGeometry.cpp | 4 +--
src/operation/polygonize/EdgeRing.cpp | 2 +-
src/operation/predicate/RectangleIntersects.cpp | 3 +-
src/operation/union/OverlapUnion.cpp | 16 ++++-----
src/operation/valid/RepeatedPointRemover.cpp | 2 +-
src/shape/fractal/HilbertCode.cpp | 2 +-
src/simplify/TopologyPreservingSimplifier.cpp | 2 +-
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 20 +++++------
src/util/GeometricShapeFactory.cpp | 8 ++---
src/util/Profiler.cpp | 2 +-
.../unit/algorithm/RobustLineIntersectionTest.cpp | 6 ++--
tests/unit/capi/GEOSGeom_createCollectionTest.cpp | 4 +--
tests/unit/capi/GEOSGeom_createPolygonTest.cpp | 2 +-
tests/unit/edgegraph/EdgeGraphTest.cpp | 2 +-
tests/unit/geom/GeometryComponentFilterTest.cpp | 4 +--
tests/unit/geom/GeometryFilterTest.cpp | 6 ++--
tests/unit/noding/BasicSegmentStringTest.cpp | 6 ++--
tests/unit/noding/SegmentNodeTest.cpp | 6 ++--
tests/unit/precision/CommonBitsTest.cpp | 4 +--
tests/unit/shape/fractal/MortonCodeTest.cpp | 8 ++---
35 files changed, 106 insertions(+), 103 deletions(-)
hooks/post-receive
More information about the geos-commits
