[geos-commits] [SCM] GEOS branch main updated. 927419638aef65e362403beb5110c15ea3ec2290
git at osgeo.org
git at osgeo.org
Tue Jul 6 13:35:13 PDT 2021
the project "GEOS".
The branch, main has been updated
via 927419638aef65e362403beb5110c15ea3ec2290 (commit)
from a752894f42e5c7b601cb6810fd03e011a0117eb6 (commit)
revisions in full, below.
commit 927419638aef65e362403beb5110c15ea3ec2290
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jul 6 13:35:00 2021 -0700
Port https://github.com/locationtech/jts/pull/754, Fix IsSimpleOp to support FindAllLocations for all geometry types
diff --git a/include/geos/operation/valid/IsSimpleOp.h b/include/geos/operation/valid/IsSimpleOp.h
index 1ae8e8f..7a8043d 100644
--- a/include/geos/operation/valid/IsSimpleOp.h
+++ b/include/geos/operation/valid/IsSimpleOp.h
@@ -47,7 +47,49 @@ namespace geos { // geos
namespace operation { // geos.operation
namespace valid { // geos.operation.valid
+ * Tests whether a Geometry is simple as defined by the OGC SFS specification.
+ * Simplicity is defined for each geom::Geometry type as follows:
+ * * geom::Point geometries are simple.
+ * * geom::MultiPoint geometries are simple if every point is unique
+ * * geom::LineString geometries are simple if they do not self-intersect at interior points
+ * (i.e. points other than the endpoints).
+ * * geom::MultiLineString geometries are simple if
+ * their elements are simple and they intersect only at points
+ * which are boundary points of both elements.
+ * (The notion of boundary points can be user-specified - see below).
+ * * Polygonal geometries have no definition of simplicity.
+ * The isSimple code checks if all polygon rings are simple.
+ * (Note: this means that isSimple cannot be used to test
+ * for ALL self-intersections in Polygons.
+ * In order to check if a Polygonal geometry has self-intersections,
+ * use geom::Geometry::isValid()).
+ * * geom::GeometryCollection geometries are simple if all their elements are simple.
+ * * Empty geometries are simple
+ * For linear geometries the evaluation of simplicity
+ * can be customized by supplying a BoundaryNodeRule
+ * to define how boundary points are determined.
+ * The default is the SFS-standard.
+ * Note that under the Mod-2 rule, closed LineStrings (rings)
+ * have no boundary.
+ * This means that an intersection at their endpoints makes the geometry non-simple.
+ * If it is required to test whether a set of LineStrings touch
+ * only at their endpoints, use BoundaryNodeRule::getBoundaryEndPoint().
+ * For example, this can be used to validate that a collection of lines
+ * form a topologically valid linear network.
+ * By default this class finds a single non-simple location.
+ * To find all non-simple locations, set setFindAllLocations(bool)
+ * before calling isSimple(), and retrieve the locations
+ * via getNonSimpleLocations().
+ * This can be used to find all intersection points in a linear network.
+ * @see BoundaryNodeRule
class GEOS_DLL IsSimpleOp {
private:
@@ -101,10 +143,10 @@ private:
std::vector<geom::Coordinate>& intersectionPts;
algorithm::LineIntersector li;
- bool hasInteriorInt;
- bool hasInteriorVertexInt;
- bool hasEqualSegments;
- bool hasInteriorEndpointInt;
+ // bool hasInteriorInt;
+ // bool hasInteriorVertexInt;
+ // bool hasEqualSegments;
+ // bool hasInteriorEndpointInt;
bool findIntersection(
noding::SegmentString* ss0, std::size_t segIndex0,
@@ -179,10 +221,10 @@ public:
- * Creates a simplicity checker using a given {@link BoundaryNodeRule}
+ * Creates a simplicity checker using a given {@link algorithm::BoundaryNodeRule}
* @param geom the geometry to test
- * @param boundaryNodeRule the boundary node rule to use.
+ * @param p_boundaryNodeRule the boundary node rule to use.
IsSimpleOp(const geom::Geometry& geom, const algorithm::BoundaryNodeRule& p_boundaryNodeRule)
: inputGeom(geom)
diff --git a/src/operation/valid/IsSimpleOp.cpp b/src/operation/valid/IsSimpleOp.cpp
index 3659638..da7c60e 100644
--- a/src/operation/valid/IsSimpleOp.cpp
+++ b/src/operation/valid/IsSimpleOp.cpp
@@ -140,6 +140,7 @@ bool
IsSimpleOp::isSimpleMultiPoint(const MultiPoint& mp)
if (mp.isEmpty()) return true;
+ bool bIsSimple = true;
std::unordered_set<Coordinate, Coordinate::HashCode> points;
for (std::size_t i = 0; i < mp.getNumGeometries(); i++) {
@@ -147,11 +148,15 @@ IsSimpleOp::isSimpleMultiPoint(const MultiPoint& mp)
const Coordinate* p = pt->getCoordinate();
if (points.find(*p) != points.end()) {
nonSimplePts.push_back(*p);
- return false;
+ bIsSimple = false;
+ if (!isFindAllLocations)
+ break;
+ else {
+ points.emplace(*p);
- points.emplace(*p);
- return true;
+ return bIsSimple;
@@ -159,15 +164,18 @@ IsSimpleOp::isSimpleMultiPoint(const MultiPoint& mp)
bool
IsSimpleOp::isSimplePolygonal(const Geometry& geom)
std::vector<const LineString*> rings;
LinearComponentExtracter::getLines(geom, rings);
for (const LineString* ring : rings) {
- if (! isSimpleLinearGeometry(*ring))
- return false;
+ if (! isSimpleLinearGeometry(*ring)) {
+ break;
- return true;
+ return bIsSimple;
@@ -175,12 +183,16 @@ IsSimpleOp::isSimplePolygonal(const Geometry& geom)
bool
IsSimpleOp::isSimpleGeometryCollection(const Geometry& geom)
for (std::size_t i = 0; i < geom.getNumGeometries(); i++) {
const Geometry* comp = geom.getGeometryN(i);
- if (! computeSimple(*comp))
- return false;
+ if (! computeSimple(*comp)) {
+ break;
- return true;
+ return bIsSimple;
/* private */
@@ -254,9 +266,16 @@ IsSimpleOp::NonSimpleIntersectionFinder::processIntersections(
ss0, segIndex0, ss1, segIndex1,
p00, p01, p10, p11);
+ // found an intersection!
if (hasInt) {
- // found an intersection!
- intersectionPts.emplace_back(li.getIntersection(0));
+ const Coordinate& intPt = li.getIntersection(0);
+ // don't save dupes
+ for (auto& pt: intersectionPts) {
+ if (intPt.equals2D(pt))
+ return;
+ // do save new ones!
+ intersectionPts.emplace_back(intPt);
@@ -275,7 +294,7 @@ IsSimpleOp::NonSimpleIntersectionFinder::findIntersection(
* Check for an intersection in the interior of a segment.
- hasInteriorInt = li.isInteriorIntersection();
+ bool hasInteriorInt = li.isInteriorIntersection();
if (hasInteriorInt) return true;
@@ -284,7 +303,7 @@ IsSimpleOp::NonSimpleIntersectionFinder::findIntersection(
* (This is not triggered by zero-length segments, since they
* are filtered out by the MC index).
- hasEqualSegments = li.getIntersectionNum() >= 2;
+ bool hasEqualSegments = li.getIntersectionNum() >= 2;
if (hasEqualSegments) return true;
@@ -306,7 +325,7 @@ IsSimpleOp::NonSimpleIntersectionFinder::findIntersection(
bool isIntersectionEndpt0 = isIntersectionEndpoint(ss0, segIndex0, li, 0);
bool isIntersectionEndpt1 = isIntersectionEndpoint(ss1, segIndex1, li, 1);
- hasInteriorVertexInt = ! (isIntersectionEndpt0 && isIntersectionEndpt1);
+ bool hasInteriorVertexInt = ! (isIntersectionEndpt0 && isIntersectionEndpt1);
if (hasInteriorVertexInt) return true;
@@ -317,7 +336,7 @@ IsSimpleOp::NonSimpleIntersectionFinder::findIntersection(
* (which avoids reporting ring endpoints).
if (isClosedEndpointsInInterior && !isSameSegString) {
- hasInteriorEndpointInt = ss0->isClosed() || ss1->isClosed();
+ bool hasInteriorEndpointInt = ss0->isClosed() || ss1->isClosed();
if (hasInteriorEndpointInt) return true;
return false;
diff --git a/tests/unit/operation/valid/IsSimpleOpTest.cpp b/tests/unit/operation/valid/IsSimpleOpTest.cpp
index 31afac1..25b5b1a 100644
--- a/tests/unit/operation/valid/IsSimpleOpTest.cpp
+++ b/tests/unit/operation/valid/IsSimpleOpTest.cpp
@@ -84,6 +84,7 @@ struct test_issimpleop_data {
auto nonSimpleCoords = op.getNonSimpleLocations();
std::unique_ptr<Geometry> nsPts(g->getFactory()->createMultiPoint(nonSimpleCoords));
+ // std::cout << *nsPts << std::endl;
auto expectedPts = reader_.read(wktExpectedPts);
ensure_equals_geometry(expectedPts.get(), nsPts.get());
@@ -202,7 +203,35 @@ void object::test<7> ()
checkIsSimpleAll(a, BoundaryNodeRule::getBoundaryRuleMod2(), b);
+// testPolygonAll
+template<>
+template<>
+void object::test<8> ()
+ std::string a("POLYGON ((0 0, 7 0, 6 -1, 6 -0.1, 6 0.1, 3 5.9, 3 6.1, 3.1 6, 2.9 6, 0 0))");
+ std::string b("MULTIPOINT((6 0), (3 6))");
+ checkIsSimpleAll(a, BoundaryNodeRule::getBoundaryRuleMod2(), b);
+// testMultiPointAll
+template<>
+template<>
+void object::test<9> ()
+ std::string a("MULTIPOINT((1 1), (1 2), (1 2), (1 3), (1 4), (1 4), (1 5), (1 5))");
+ std::string b("MULTIPOINT((1 2), (1 4), (1 5))");
+// testGeometryCollectionAll
+template<>
+template<>
+void object::test<10> ()
+ std::string a("GEOMETRYCOLLECTION(MULTILINESTRING ((10 20, 90 20), (10 30, 90 30), (50 40, 50 10)), MULTIPOINT((1 1), (1 2), (1 2), (1 3), (1 4), (1 4), (1 5), (1 5)))");
+ std::string b("MULTIPOINT((50 20), (50 30), (1 2), (1 4), (1 5))");
} // namespace tut
Summary of changes:
include/geos/operation/valid/IsSimpleOp.h | 56 +++++++++++++++++++++++----
src/operation/valid/IsSimpleOp.cpp | 51 ++++++++++++++++--------
tests/unit/operation/valid/IsSimpleOpTest.cpp | 29 ++++++++++++++
3 files changed, 113 insertions(+), 23 deletions(-)
hooks/post-receive
More information about the geos-commits
