[geos-commits] [SCM] GEOS branch main updated. 1bfc5b27493c552fd9a28823358a4c1f4c3b65f7
git at osgeo.org
git at osgeo.org
Tue Jul 13 16:01:04 PDT 2021
the project "GEOS".
The branch, main has been updated
via 1bfc5b27493c552fd9a28823358a4c1f4c3b65f7 (commit)
from 917aeecadaaa5db9e7361ecfef2bca7bb64c8ec9 (commit)
revisions in full, below.
commit 1bfc5b27493c552fd9a28823358a4c1f4c3b65f7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jul 13 16:00:10 2021 -0700
Port JTS https://github.com/locationtech/jts/pull/756 to match
IsValidReason more closely to historic reasons for self-intersecting
polygons.
diff --git a/src/operation/valid/PolygonIntersectionAnalyzer.cpp b/src/operation/valid/PolygonIntersectionAnalyzer.cpp
index fbdf35d..a8ebe83 100644
--- a/src/operation/valid/PolygonIntersectionAnalyzer.cpp
+++ b/src/operation/valid/PolygonIntersectionAnalyzer.cpp
@@ -68,6 +68,8 @@ PolygonIntersectionAnalyzer::findInvalidIntersection(
return TopologyValidationError::oNoInvalidIntersection;
+ bool isSameSegString = (ss0 == ss1);
* Check for an intersection in the interior of both segments.
* Collinear intersections by definition contain an interior intersection.
@@ -89,7 +91,6 @@ PolygonIntersectionAnalyzer::findInvalidIntersection(
* (since they are not collinear).
* This is valid.
- bool isSameSegString = ss0 == ss1;
bool isAdjacentSegments = isSameSegString && isAdjacentInRing(ss0, segIndex0, segIndex1);
// Assert: intersection is an endpoint of both segs
if (isAdjacentSegments) return TopologyValidationError::oNoInvalidIntersection;
@@ -99,7 +100,7 @@ PolygonIntersectionAnalyzer::findInvalidIntersection(
* So the intersection is invalid.
if (isSameSegString && ! isInvertedRingValid) {
- return TopologyValidationError::eSelfIntersection;
+ return TopologyValidationError::eRingSelfIntersection;
diff --git a/tests/unit/capi/GEOSisValidDetailTest.cpp b/tests/unit/capi/GEOSisValidDetailTest.cpp
index b342b17..20092ba 100644
--- a/tests/unit/capi/GEOSisValidDetailTest.cpp
+++ b/tests/unit/capi/GEOSisValidDetailTest.cpp
@@ -116,7 +116,7 @@ void object::test<4>
geom1_ = GEOSGeomFromWKT("POLYGON((0 1, -10 10, 10 10, 0 1, 4 6, -4 6, 0 1))");
int r = GEOSisValidDetail(geom1_, 0, &reason_, &loc_);
ensure_equals(r, 0); // invalid
- ensure_equals(std::string(reason_), std::string("Self-intersection"));
+ ensure_equals(std::string(reason_), std::string("Ring Self-intersection"));
ensure_equals(toWKT(loc_), "POINT (0 1)");
diff --git a/tests/unit/operation/valid/IsValidOpTest.cpp b/tests/unit/operation/valid/IsValidOpTest.cpp
index 30ae4d5..e68c88d 100644
--- a/tests/unit/operation/valid/IsValidOpTest.cpp
+++ b/tests/unit/operation/valid/IsValidOpTest.cpp
@@ -188,6 +188,16 @@ void object::test<8> ()
"POLYGON ((10 90, 90 10, 90 90, 10 10, 10 90))");
+// testInvalidPolygonInverted
+template<>
+template<>
+void object::test<22> ()
+ checkInvalid(
+ TopologyValidationError::eRingSelfIntersection,
+ "POLYGON ((70 250, 40 500, 100 400, 70 250, 80 350, 60 350, 70 250))");
// testSimplePolygonHole
template<>
template<>
@@ -309,6 +319,58 @@ void object::test<21> ()
"MULTIPOLYGON (((20 380, 420 380, 420 20, 20 20, 20 380), (220 340, 180 240, 60 200, 140 100, 340 60, 300 240, 220 340)), ((60 200, 340 60, 220 340, 60 200)))");
+// testLineString
+template<>
+template<>
+void object::test<23> ()
+ checkInvalid(
+ "LINESTRING(0 0, 0 0)");
+// testLinearRingTriangle
+template<>
+template<>
+void object::test<24> ()
+ checkValid(
+ "LINEARRING (100 100, 150 200, 200 100, 100 100)");
+// testLinearRingSelfCrossing
+template<>
+template<>
+void object::test<25> ()
+ checkInvalid(TopologyValidationError::eRingSelfIntersection,
+ "LINEARRING (150 100, 300 300, 100 300, 350 100, 150 100)");
+// testLinearRingSelfCrossing2
+template<>
+template<>
+void object::test<26> ()
+ "LINEARRING (0 0, 100 100, 100 0, 0 100, 0 0)");
+template<>
+template<>
+void object::test<27> ()
+template<>
+template<>
+void object::test<28> ()
+ checkInvalid(TopologyValidationError::eSelfIntersection,
+ "POLYGON ((70 250, 70 500, 80 400, 40 400, 70 250))");
} // namespace tut
Summary of changes:
.../valid/PolygonIntersectionAnalyzer.cpp | 5 +-
tests/unit/capi/GEOSisValidDetailTest.cpp | 2 +-
tests/unit/operation/valid/IsValidOpTest.cpp | 62 ++++++++++++++++++++++
3 files changed, 66 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
