[geos-commits] [SCM] GEOS branch main updated. 13a3bbb015f82c4458fb7768fd24fc6231a11367
git at osgeo.org
git at osgeo.org
Wed Jul 14 15:17:12 PDT 2021
the project "GEOS".
The branch, main has been updated
via 13a3bbb015f82c4458fb7768fd24fc6231a11367 (commit)
from 67a1b10487bbbe3df8d746fd44ec42d3f91eb949 (commit)
revisions in full, below.
commit 13a3bbb015f82c4458fb7768fd24fc6231a11367
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jul 14 15:17:07 2021 -0700
Reorganize isCCW assignments a little
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index a36c9f2..e32a550 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -62,12 +62,10 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
* Note this relies on the convention that
* rings have the same start and end point.
- geom::Coordinate upHiPt;
- ring->getAt(0, upHiPt);
+ geom::Coordinate upHiPt(ring->getAt(0));
+ geom::Coordinate upLowPt(geom::Coordinate::getNull());
double prevY = upHiPt.y;
- geom::Coordinate upLowPt;
- upLowPt.setNull();
- // const geom::Coordinate& upLowPt = nullptr;
uint32_t iUpHi = 0;
for (uint32_t i = 1; i <= nPts; i++) {
double py = ring->getY(i);
@@ -75,9 +73,9 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
* If segment is upwards and endpoint is higher, record it
if (py > prevY && py >= upHiPt.y) {
- ring->getAt(i, upHiPt);
iUpHi = i;
- ring->getAt(i-1, upLowPt);
+ upHiPt = ring->getAt(i);
+ upLowPt = ring->getAt(i-1);
prevY = py;
@@ -110,29 +108,29 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
* The ring orientation is given by the direction of the flat segment
if (upHiPt.equals2D(downHiPt)) {
- * Check for the case where the cap has configuration A-B-A.
- * This can happen if the ring does not contain 3 distinct points
- * (including the case where the input array has fewer than 4 elements), or
- * it contains coincident line segments.
- if (upLowPt.equals2D(upHiPt) || downLowPt.equals2D(upHiPt) || upLowPt.equals2D(downLowPt))
- return false;
- * It can happen that the top segments are coincident.
- * This is an invalid ring, which cannot be computed correctly.
- * In this case the orientation is 0, and the result is false.
- int orientationIndex = index(upLowPt, upHiPt, downLowPt);
- return orientationIndex == COUNTERCLOCKWISE;
+ * Check for the case where the cap has configuration A-B-A.
+ * This can happen if the ring does not contain 3 distinct points
+ * (including the case where the input array has fewer than 4 elements), or
+ * it contains coincident line segments.
+ if (upLowPt.equals2D(upHiPt) || downLowPt.equals2D(upHiPt) || upLowPt.equals2D(downLowPt))
+ return false;
+ * It can happen that the top segments are coincident.
+ * This is an invalid ring, which cannot be computed correctly.
+ * In this case the orientation is 0, and the result is false.
+ int orientationIndex = index(upLowPt, upHiPt, downLowPt);
+ return orientationIndex == COUNTERCLOCKWISE;
else {
- * Flat cap - direction of flat top determines orientation
- double delX = downHiPt.x - upHiPt.x;
- return delX < 0;
+ * Flat cap - direction of flat top determines orientation
+ double delX = downHiPt.x - upHiPt.x;
+ return delX < 0;
Summary of changes:
src/algorithm/Orientation.cpp | 54 +++++++++++++++++++++----------------------
1 file changed, 26 insertions(+), 28 deletions(-)
hooks/post-receive
More information about the geos-commits
