[geos-commits] [SCM] GEOS branch master updated. c6abbf9f980bd21d4a0ce2818bc0480a4707afc9
Tue Mar 2 13:37:18 PST 2021
the project "GEOS".
       via  c6abbf9f980bd21d4a0ce2818bc0480a4707afc9 (commit)
      from  b4a786c910080d716cbf8c1230eada9077f118c2 (commit)
revisions in full, below.
commit c6abbf9f980bd21d4a0ce2818bc0480a4707afc9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 2 13:28:49 2021 -0800
    Allow build on older cmake
diff --git a/src/deps/CMakeLists.txt b/src/deps/CMakeLists.txt
index 7a6fac1..d8a1c3d 100644
--- a/src/deps/CMakeLists.txt
+++ b/src/deps/CMakeLists.txt
@@ -9,7 +9,7 @@
 # See the COPYING file for more information.
 file(GLOB_RECURSE _sources ${CMAKE_CURRENT_LIST_DIR}/*.c  CONFIGURE_DEPEND)
-add_library(ryu OBJECT ${_sources})
+add_library(ryu STATIC ${_sources})
 target_include_directories(ryu PUBLIC ${CMAKE_CURRENT_LIST_DIR})
 set_target_properties(ryu PROPERTIES POSITION_INDEPENDENT_CODE ON)
 unset(_sources)
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 87113ac..388dd05 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -14,7 +14,7 @@ add_executable(test_simplewkttester SimpleWKTTester.cpp)
 target_link_libraries(test_simplewkttester PRIVATE geos)
 # Setup tinyxml as a separate library so we can avoid picking up GEOS compile flags
-add_library(tinyxml2 OBJECT
+add_library(tinyxml2 STATIC
         tinyxml2/tinyxml2.h
         tinyxml2/tinyxml2.cpp)
 target_compile_options(
Summary of changes:
 src/deps/CMakeLists.txt        | 2 +-
 tests/xmltester/CMakeLists.txt | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
