[geos-commits] [SCM] GEOS branch master updated. 339f8caaa6e778dd579db70ca618018e4a8ca507
Wed Mar 3 15:24:49 PST 2021
the project "GEOS".
       via  339f8caaa6e778dd579db70ca618018e4a8ca507 (commit)
      from  72b58feb34343f40a27badb2bbba9e6e1050a62a (commit)
revisions in full, below.
commit 339f8caaa6e778dd579db70ca618018e4a8ca507
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Mar 3 15:24:36 2021 -0800
    Add NaN coordinate test turned up in PyGEOS. https://github.com/pygeos/pygeos/issues/306
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index f97eedb..3d03d03 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -15,6 +15,7 @@
 #include <geos/io/WKTReader.h>
 #include <geos/util/GEOSException.h>
 #include <geos/util/IllegalArgumentException.h>
+#include <geos/constants.h>
 // std
 #include <string>
 #include <cmath>
@@ -540,6 +541,38 @@ void object::test<30>()
     ensure_equals(cs->getSize(), 2u);
+// Test of LinearRing constructor with a NaN coordinate
+template<>
+template<>
+void object::test<31>
+    using geos::geom::Coordinate;
+    // Non-empty sequence of coordinates
+    const std::size_t size3 = 3;
+    CoordArrayPtr pseq = new geos::geom::CoordinateArraySequence();
+    ensure("sequence is null pointer.", pseq != nullptr);
+    pseq->add(Coordinate(0, geos::DoubleNotANumber));
+    pseq->add(Coordinate(5, 5));
+    ensure_equals(pseq->size(), size3);
+    try {
+        // Create non-empty LineString instance
+        auto lr(factory_->createLinearRing(pseq));
+        fail("IllegalArgumentException expected.");
+        ensure(!lr->isEmpty());
+    catch(geos::util::IllegalArgumentException const& e) {
+        const char* msg = e.what(); // OK
+        ensure(msg != nullptr);
 } // namespace tut
Summary of changes:
 tests/unit/geom/LineStringTest.cpp | 33 +++++++++++++++++++++++++++++++++
 1 file changed, 33 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
