[geos-commits] [SCM] GEOS branch 3.10 updated. 2f4f2a402097e2033c95414d5f5f42bd6384b617
git at osgeo.org
git at osgeo.org
Wed Nov 3 08:28:56 PDT 2021
the project "GEOS".
The branch, 3.10 has been updated
via 2f4f2a402097e2033c95414d5f5f42bd6384b617 (commit)
via 9194c25de8cf56726a07b59b71644dca2b683715 (commit)
from a5c7bf16c3fb9b6457f644b66f1312705bee0153 (commit)
revisions in full, below.
commit 2f4f2a402097e2033c95414d5f5f42bd6384b617
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Nov 3 08:28:50 2021 -0700
Add news entry for #1139 fix
diff --git a/NEWS b/NEWS
index 26d924760..b61e8f8ff 100644
--- a/NEWS
+++ b/NEWS
@@ -3,7 +3,7 @@ Changes in 3.10.2
2021-xx-xx
- Fixes/Improvements:
+ - Fix crash in GeoJSONWriter in case of empty points (#1139, Paul Ramsey)
Changes in 3.10.1
commit 9194c25de8cf56726a07b59b71644dca2b683715
Date: Wed Nov 3 08:27:50 2021 -0700
Fix crash in GeoJSONWriter in the case of empty points. Add some tests around empty geometries in general. References #1139
diff --git a/src/dirlist.mk b/src/dirlist.mk
deleted file mode 100644
index 15f2a11ff..000000000
--- a/src/dirlist.mk
+++ /dev/null
@@ -1,48 +0,0 @@
-# List of directories use by makefile.vc to clean .obj files
-GEOS_DIRLIST = \
- algorithm \
- algorithm\distance \
- algorithm\locate \
- examples \
- geom \
- geom\util \
- geom\prep \
- geomgraph \
- geomgraph\index \
- headers \
- headers\geos \
- index \
- index\bintree \
- index\chain \
- index\intervalrtree \
- index\quadtree \
- index\strtree \
- index\sweepline \
- io \
- linearref \
- noding \
- noding\snapround \
- operation \
- operation\buffer \
- operation\distance \
- operation\intersection \
- operation\linemerge \
- operation\overlay \
- operation\overlay\snap \
- operation\overlay\validate \
- operation\polygonize \
- operation\predicate \
- operation\relate \
- operation\sharedpaths \
- operation\union \
- operation\valid \
- planargraph \
- planargraph\algorithm \
- precision \
- simplify \
- triangulate \
- triangulate\quadedge \
- util
diff --git a/src/io/GeoJSONWriter.cpp b/src/io/GeoJSONWriter.cpp
index c8bbab50d..464f26b7c 100644
--- a/src/io/GeoJSONWriter.cpp
+++ b/src/io/GeoJSONWriter.cpp
@@ -205,7 +205,12 @@ void GeoJSONWriter::encodeGeometry(const geom::Geometry* geometry, geos_nlohmann
void GeoJSONWriter::encodePoint(const geom::Point* point, geos_nlohmann::ordered_json& j)
j["type"] = "Point";
- j["coordinates"] = convertCoordinate(point->getCoordinate());
+ if (!point->isEmpty()) {
+ j["coordinates"] = convertCoordinate(point->getCoordinate());
+ else {
+ j["coordinates"] = j.array();
void GeoJSONWriter::encodeLineString(const geom::LineString* line, geos_nlohmann::ordered_json& j)
diff --git a/tests/unit/io/GeoJSONWriterTest.cpp b/tests/unit/io/GeoJSONWriterTest.cpp
index 6faab6ecb..201db101b 100644
--- a/tests/unit/io/GeoJSONWriterTest.cpp
+++ b/tests/unit/io/GeoJSONWriterTest.cpp
@@ -252,4 +252,47 @@ void object::test<14>
ensure_equals(result, "{\"type\":\"FeatureCollection\",\"features\":[{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]},\"properties\":{\"id\":1.0,\"name\":\"One\"}},{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-127.0,53.0]},\"properties\":{\"id\":2.0,\"name\":\"Two\"}}]}");
+// Write an empty point
+template<>
+template<>
+void object::test<15>
+ GeomPtr geom(wktreader.read("POINT EMPTY"));
+ std::string result = geojsonwriter.write(geom.get());
+ ensure_equals(result, "{\"type\":\"Point\",\"coordinates\":[]}");
+// Write an empty linestring
+template<>
+template<>
+void object::test<16>
+ GeomPtr geom(wktreader.read("LINESTRING EMPTY"));
+ ensure_equals(result, "{\"type\":\"LineString\",\"coordinates\":[]}");
+// Write an empty polygon
+template<>
+template<>
+void object::test<17>
+ GeomPtr geom(wktreader.read("POLYGON EMPTY"));
+ ensure_equals(result, "{\"type\":\"Polygon\",\"coordinates\":[[]]}");
+template<>
+template<>
+void object::test<18>
+ GeomPtr geom(wktreader.read("GEOMETRYCOLLECTION EMPTY"));
+ ensure_equals(result, "{\"type\":\"GeometryCollection\",\"geometries\":[]}");
Summary of changes:
NEWS | 2 +-
src/dirlist.mk | 48 -------------------------------------
src/io/GeoJSONWriter.cpp | 7 +++++-
tests/unit/io/GeoJSONWriterTest.cpp | 43 +++++++++++++++++++++++++++++++++
4 files changed, 50 insertions(+), 50 deletions(-)
delete mode 100644 src/dirlist.mk
hooks/post-receive
More information about the geos-commits
