[geos-commits] [SCM] GEOS branch main updated. 2a8d88202d0a4d124d1ff15b699d9e6b95e1563f
Thu Nov 11 15:10:14 PST 2021
the project "GEOS".
The branch, main has been updated
       via  2a8d88202d0a4d124d1ff15b699d9e6b95e1563f (commit)
      from  f0d7ac29dffae2318ae130cd1775fe3c755d8312 (commit)
revisions in full, below.
commit 2a8d88202d0a4d124d1ff15b699d9e6b95e1563f
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 11 22:12:02 2021 +0200
    Use custom rings comparator in BuildArea
    References #1122 in main branch (3.11.0dev)
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index fa2711533..e1c66f1a8 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -159,10 +159,9 @@ public:
     static CoordinateSequence* atLeastNCoordinatesOrNothing(std::size_t n,
             CoordinateSequence* c);
-    /// Return position of a Coordinate, or -1 if not found
-    /// FIXME: return std::size_t, using numeric_limits<std::size_t>::max
-    /// as 'not found' value.
+    /// Return position of a Coordinate
+    /// or numeric_limits<std::size_t>::max() if not found
     static std::size_t indexOf(const Coordinate* coordinate,
                           const CoordinateSequence* cl);
diff --git a/src/operation/polygonize/BuildArea.cpp b/src/operation/polygonize/BuildArea.cpp
index b47a32cf2..ac76a1647 100644
--- a/src/operation/polygonize/BuildArea.cpp
+++ b/src/operation/polygonize/BuildArea.cpp
@@ -66,6 +66,74 @@ struct Face {
+static bool ringsEqualAnyDirection(const LinearRing* r1, const LinearRing* r2)
+    const CoordinateSequence *cs1 = r1->getCoordinatesRO();
+    const CoordinateSequence *cs2 = r2->getCoordinatesRO();
+    /* Check same number of points */
+    size_t npoints = cs1->size();
+    if ( npoints != cs2->size() )
+        return false;
+    if ( npoints == 0 ) return true; /* if empty, they are equal */
+    /* Check same envelope (probably better avoid, as it'd need to
+     * compute the envelope doing an additional scan for each) */
+    if ( ! r1->getEnvelopeInternal()->equals(r2->getEnvelopeInternal()) )
+        return false;
+    /* Pretend the rings had one less point, as the last one will be
+     * equal to the first one anyway */
+    --npoints;
+    const Coordinate& firstPoint = cs1->getAt(0);
+    size_t offset = CoordinateSequence::indexOf(&firstPoint, cs2);
+    if ( offset == std::numeric_limits<std::size_t>::max() ) return false;
+    bool equal = true;
+    /* Check equals forward (skip first point, we checked it alread) */
+    for (size_t i=1; i<npoints; ++i)
+        size_t j = ( i + offset ) % npoints;
+        const Coordinate& c1 = cs1->getAt(i);
+        const Coordinate& c2 = cs2->getAt(j);
+        if ( ! c1.equals(c2) ) {
+            equal = false;
+            break;
+    if ( equal ) return true;
+    /* Check equals backward (skip first point, we checked it already) */
+    equal = true;
+        size_t j;
+        if ( i <= offset ) {
+            j = offset - i;
+        } else {
+            j = npoints - ( i - offset );
+            equal = false;
+            break;
+    return equal;
 static std::unique_ptr<Face> newFace(const geom::Polygon* p) {
     auto f = std::unique_ptr<Face>(new Face());
     f->poly = p;
@@ -100,13 +168,8 @@ static void findFaceHoles(std::vector<std::unique_ptr<Face>>& faces) {
                 if( f2->parent ) {
                     continue; /* hole already assigned */
-                const auto f2er = f2->poly->getExteriorRing();
-                /* TODO: can be optimized as the ring would have the
-                *       same vertices, possibly in different order.
-                *       maybe comparing number of points could already be
-                *       useful.
-                if( f2er->equals(hole) ) {
+                const auto shell = f2->poly->getExteriorRing();
+                if( ringsEqualAnyDirection(shell, hole) ) {
                     f2->parent = f.get();
                     break;
Summary of changes:
 include/geos/geom/CoordinateSequence.h |  7 ++--
 src/operation/polygonize/BuildArea.cpp | 77 ++++++++++++++++++++++++++++++----
 2 files changed, 73 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
