[geos-commits] [SCM] GEOS branch 3.10 updated. da8ebd004e52d5753a5c4aaae80dec25cf62679f
git at osgeo.org
git at osgeo.org
Thu Nov 11 15:12:03 PST 2021
the project "GEOS".
The branch, 3.10 has been updated
via da8ebd004e52d5753a5c4aaae80dec25cf62679f (commit)
from 9d1f78a58cb907cc011f2e4a349c2e5b24b141f0 (commit)
revisions in full, below.
commit da8ebd004e52d5753a5c4aaae80dec25cf62679f
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Aug 11 22:12:02 2021 +0200
Use custom rings comparator in BuildArea
References #1122 in 3.10 branch (3.10.2dev)
diff --git a/NEWS b/NEWS
index b61e8f8ff..dc6434700 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ Changes in 3.10.2
- Fixes/Improvements:
- Fix crash in GeoJSONWriter in case of empty points (#1139, Paul Ramsey)
+ - Improve BuildArea performance (#1122, Sandro Santilli)
Changes in 3.10.1
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index fa2711533..e1c66f1a8 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -159,10 +159,9 @@ public:
static CoordinateSequence* atLeastNCoordinatesOrNothing(std::size_t n,
CoordinateSequence* c);
- /// Return position of a Coordinate, or -1 if not found
- /// FIXME: return std::size_t, using numeric_limits<std::size_t>::max
- /// as 'not found' value.
+ /// Return position of a Coordinate
+ /// or numeric_limits<std::size_t>::max() if not found
static std::size_t indexOf(const Coordinate* coordinate,
const CoordinateSequence* cl);
diff --git a/src/operation/polygonize/BuildArea.cpp b/src/operation/polygonize/BuildArea.cpp
index b47a32cf2..ac76a1647 100644
--- a/src/operation/polygonize/BuildArea.cpp
+++ b/src/operation/polygonize/BuildArea.cpp
@@ -66,6 +66,74 @@ struct Face {
+static bool ringsEqualAnyDirection(const LinearRing* r1, const LinearRing* r2)
+ const CoordinateSequence *cs1 = r1->getCoordinatesRO();
+ const CoordinateSequence *cs2 = r2->getCoordinatesRO();
+ /* Check same number of points */
+ size_t npoints = cs1->size();
+ if ( npoints != cs2->size() )
+ return false;
+ if ( npoints == 0 ) return true; /* if empty, they are equal */
+ /* Check same envelope (probably better avoid, as it'd need to
+ * compute the envelope doing an additional scan for each) */
+ if ( ! r1->getEnvelopeInternal()->equals(r2->getEnvelopeInternal()) )
+ return false;
+ /* Pretend the rings had one less point, as the last one will be
+ * equal to the first one anyway */
+ --npoints;
+ const Coordinate& firstPoint = cs1->getAt(0);
+ size_t offset = CoordinateSequence::indexOf(&firstPoint, cs2);
+ if ( offset == std::numeric_limits<std::size_t>::max() ) return false;
+ bool equal = true;
+ /* Check equals forward (skip first point, we checked it alread) */
+ for (size_t i=1; i<npoints; ++i)
+ size_t j = ( i + offset ) % npoints;
+ const Coordinate& c1 = cs1->getAt(i);
+ const Coordinate& c2 = cs2->getAt(j);
+ if ( ! c1.equals(c2) ) {
+ equal = false;
+ break;
+ if ( equal ) return true;
+ /* Check equals backward (skip first point, we checked it already) */
+ equal = true;
+ size_t j;
+ if ( i <= offset ) {
+ j = offset - i;
+ } else {
+ j = npoints - ( i - offset );
+ equal = false;
+ break;
+ return equal;
static std::unique_ptr<Face> newFace(const geom::Polygon* p) {
auto f = std::unique_ptr<Face>(new Face());
f->poly = p;
@@ -100,13 +168,8 @@ static void findFaceHoles(std::vector<std::unique_ptr<Face>>& faces) {
if( f2->parent ) {
continue; /* hole already assigned */
- const auto f2er = f2->poly->getExteriorRing();
- /* TODO: can be optimized as the ring would have the
- * same vertices, possibly in different order.
- * maybe comparing number of points could already be
- * useful.
- if( f2er->equals(hole) ) {
+ const auto shell = f2->poly->getExteriorRing();
+ if( ringsEqualAnyDirection(shell, hole) ) {
f2->parent = f.get();
break;
Summary of changes:
NEWS | 1 +
include/geos/geom/CoordinateSequence.h | 7 ++--
src/operation/polygonize/BuildArea.cpp | 77 ++++++++++++++++++++++++++++++----
3 files changed, 74 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits
