[geos-commits] [SCM] GEOS branch main updated. 2696f86ec20ce4100c742b730c87ab401492f1b7
git at osgeo.org
git at osgeo.org
Mon Oct 4 08:24:24 PDT 2021
the project "GEOS".
The branch, main has been updated
via 2696f86ec20ce4100c742b730c87ab401492f1b7 (commit)
via 12bd49a4c6a08413d8e2e74ac4ae188d3e5d49a9 (commit)
from 98ecf63991261f4690e2d06be921809f720d5090 (commit)
revisions in full, below.
commit 2696f86ec20ce4100c742b730c87ab401492f1b7
Merge: 98ecf63 12bd49a
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Oct 4 17:23:58 2021 +0200
Merge branch 'more_geosdistancewithin_tests' of https://github.com/brendan-ward/geos into main
commit 12bd49a4c6a08413d8e2e74ac4ae188d3e5d49a9
Author: Brendan C. Ward <bcward at astutespruce.com>
Date: Sat Oct 2 06:18:25 2021 -0700
Adds several CAPI tests for GEOSDistanceWithin
diff --git a/tests/unit/capi/GEOSDistanceWithinTest.cpp b/tests/unit/capi/GEOSDistanceWithinTest.cpp
index 6d18b4e..9469179 100644
--- a/tests/unit/capi/GEOSDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSDistanceWithinTest.cpp
@@ -1,16 +1,16 @@
-// Test Suite for C-API GEOSDistance
+// Test Suite for C-API GEOSDistanceWithin
#include <tut/tut.hpp>
// geos
-#include <geos_c.h>
#include <geos/constants.h>
+#include <geos_c.h>
// std
#include <cstdarg>
#include <cstdio>
#include <cstdlib>
-#include <memory>
#include <math.h>
+#include <memory>
#include "capi_test_utils.h"
@@ -19,11 +19,23 @@ namespace tut {
// Test Group
-// Common data used in test cases.
struct test_capigeosdistancewithin_data : public capitest::utility {
- test_capigeosdistancewithin_data() {
- GEOSWKTWriter_setTrim(wktw_, 1);
+ void testGEOSDistanceWithin(const char* wkt1, const char* wkt2,
+ double distance, char expectedResult) {
+ GEOSGeometry *input1 = GEOSGeomFromWKT(wkt1);
+ ensure(input1 != nullptr);
+ GEOSGeometry *input2 = GEOSGeomFromWKT(wkt2);
+ ensure(input2 != nullptr);
+ char ret = GEOSDistanceWithin(input1, input2, distance);
+ GEOSGeom_destroy(input1);
+ GEOSGeom_destroy(input2);
+ ensure_equals("return code", (int)ret, (int)expectedResult);
typedef test_group<test_capigeosdistancewithin_data> group;
@@ -31,25 +43,348 @@ typedef group::object object;
group test_capigeosdistancewithin_group("capi::GEOSDistanceWithin");
-// Test Cases
+// point within distance should return true
+template <>
+template <>
+void object::test<1>() {
+ testGEOSDistanceWithin(
+ "POINT(0 0)",
+ "POINT(0 1)",
+ 1.0,
+ 1
-template<>
-template<>
-void object::test<1>
- geom1_ = GEOSGeomFromWKT("POINT(10 10)");
- geom2_ = GEOSGeomFromWKT("POINT(3 6)");
+// point not within distance should return false
+template <>
+template <>
+void object::test<2>() {
+ "POINT(0 0)",
+ "POINT(0 1)",
+ 0.999999,
+ 0
- double dist = 8.1;
- char ret = GEOSDistanceWithin(geom1_, geom2_, dist);
- ensure_equals(ret, 1);
+// point at same location should return true even if distance is 0
+template <>
+template <>
+void object::test<3>() {
+ "POINT(0 0)",
+ "POINT(0 0)",
+ 0.0,
+ 1
- ret = GEOSDistanceWithin(geom1_, geom2_, dist-0.1);
- ensure_equals(ret, 0);
+// line within distance of another line should return true
+template <>
+template <>
+void object::test<4>() {
+ "LINESTRING(0 0, 1 1)",
+ "LINESTRING(0 1, 1 2)",
+ 1.0,
+ 1
-} // namespace tut
+// line not within distance of another line should return false
+template <>
+template <>
+void object::test<5>() {
+ "LINESTRING(0 0, 1 0)",
+ "LINESTRING(0 1, 1 1)",
+ 0.999999,
+ 0
+// line that equals another line should return true even if distance is 0
+template <>
+template <>
+void object::test<6>() {
+ 0.0,
+ 1
+// line that intersects another line should return true even if distance is 0
+template <>
+template <>
+void object::test<7>() {
+ "LINESTRING(1 1, 0 0)",
+ 0.0,
+ 1
+// line that shares segment with other line should return true even if distance is 0
+template <>
+template <>
+void object::test<8>() {
+ "LINESTRING(0 0, 2 2)",
+ 0.0,
+ 1
+// point within distance of line should return true
+template <>
+template <>
+void object::test<9>() {
+ "POINT( 0 1)",
+ 1.0,
+ 1
+// point not within distance of line should return false
+template <>
+template <>
+void object::test<10>() {
+ "POINT(0 1)",
+ 0.999999,
+ 0
+// line within distance of point should return true
+template <>
+template <>
+void object::test<11>() {
+ "POINT( 0 1)",
+ 1.0,
+ 1
+// line not within distance of point should return false
+template <>
+template <>
+void object::test<12>() {
+ "POINT(0 1)",
+ 0.999999,
+ 0
+// point that intersects line should return true even if distance is 0
+template <>
+template <>
+void object::test<13>() {
+ "POINT(0.5 0.5)",
+ 0.0,
+ 1
+// polygon within distance of other polygon should return true
+template <>
+template <>
+void object::test<14>() {
+ "POLYGON((0 0, 1 1, 2 0, 0 0))",
+ "POLYGON((0 3, 2 3, 1 2, 0 3))",
+ 1.0,
+ 1
+// polygon not within distance of other polygon should return true
+template <>
+template <>
+void object::test<15>() {
+ 0.999999,
+ 0
+// polygon that intersects polygon should return true even if distance is 0
+template <>
+template <>
+void object::test<16>() {
+ "POLYGON((0 3, 2 3, 1 0, 0 3))",
+ 0.0,
+ 1
+// polygon that is equal to polygon should return true even if distance is 0
+template <>
+template <>
+void object::test<17>() {
+ "POLYGON((1 1, 2 0, 0 0, 1 1))",
+ 0.0,
+ 1
+// point within distance of polygon should return true
+template <>
+template <>
+void object::test<18>() {
+ "POINT(1 2)",
+ 1.0,
+ 1
+// point not within distance of polygon should return false
+template <>
+template <>
+void object::test<19>() {
+ "POINT(1 2)",
+ 0.999999,
+ 0
+// polygon within distance of point should return true
+template <>
+template <>
+void object::test<20>() {
+ "POINT(1 2)",
+ 1.0,
+ 1
+template <>
+template <>
+void object::test<21>() {
+ "POINT(1 2)",
+ 0.999999,
+ 0
+// polygon that intersects point should return true even if distance is 0
+template <>
+template <>
+void object::test<22>() {
+ "POINT(1 0)",
+ 0.0,
+ 1
+// polygon within distance of line should return true
+template <>
+template <>
+void object::test<23>() {
+ "LINESTRING(0 -1, 2 -1)",
+ 1.0,
+ 1
+// polygon not within distance of line should return false
+template <>
+template <>
+void object::test<24>() {
+ 0.999999,
+ 0
+// polygon that intersects line should return true even if distance is 0
+template <>
+template <>
+void object::test<25>() {
+ "LINESTRING(0 -1, 0.5 0.5, 2 -1)",
+ 0.0,
+ 1
+// polygon that shares edge with line should return true even if distance is 0
+template <>
+template <>
+void object::test<26>() {
+ "LINESTRING(0 0, 1 1, 2 0)",
+ 0.0,
+ 1
+// empty geometries should always return true (distance 1)
+template <>
+template <>
+void object::test<27>() {
+ "POINT EMPTY",
+ "LINESTRING EMPTY",
+ 1.0,
+ 1
+// empty geometries should always return true (distance 0)
+template <>
+template <>
+void object::test<28>() {
+ "POINT EMPTY",
+ 0.0,
+ 1
+} // namespace tut
Summary of changes:
tests/unit/capi/GEOSDistanceWithinTest.cpp | 381 +++++++++++++++++++++++++++--
1 file changed, 358 insertions(+), 23 deletions(-)
hooks/post-receive
More information about the geos-commits
