[geos-commits] [SCM] GEOS branch main updated. dcba3b6a323523b3ef6ab5016ccb9b19f719c144
git at osgeo.org
git at osgeo.org
Thu Oct 14 01:37:26 PDT 2021
the project "GEOS".
The branch, main has been updated
via dcba3b6a323523b3ef6ab5016ccb9b19f719c144 (commit)
from ba5ad9eeaa3253ef100c4b9131b078156468560b (commit)
revisions in full, below.
commit dcba3b6a323523b3ef6ab5016ccb9b19f719c144
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Oct 14 10:37:14 2021 +0200
Stub a cmake wrapper called ./configure
diff --git a/.gitignore b/.gitignore
index d116d9e..edb5a2f 100644
--- a/.gitignore
+++ b/.gitignore
@@ -66,7 +66,6 @@ config.guess
config.log
config.status
config.sub
-configure
depcomp
doc/Doxyfile
doc/example
diff --git a/configure b/configure
new file mode 100755
index 0000000..811a09b
--- /dev/null
+++ b/configure
@@ -0,0 +1,54 @@
+#!/bin/sh
+which cmake > /dev/null 2>&1 || {
+ echo "You need cmake to build this package" >&2
+ exit 1
+srcdir=$(dirname $0)
+usage() {
+ echo "$0 [--prefix=<prefix>] [--help]"
+cmd=cmake
+options=$(getopt -l "help,prefix:" "" "$@")
+#echo XXXX ${options}
+eval set -- "$options"
+while true; do
+ case $1 in
+ --prefix)
+ shift
+ cmd="${cmd} -DCMAKE_INSTALL_PREFIX:PATH=$1"
+ --help)
+ usage
+ exit
+ shift
+ break
+ echo "Unrecognized switch $1" >&2
+ usage >&2
+ exit 1
+ esac
+ shift
+done
+cmd="${cmd} ${srcdir}"
+echo
+echo "WARNING: this script is a wrapper for cmake"
+echo
+echo "INFO: Invoking ${cmd}"
+echo
+$cmd
+echo
+echo "HINT: for interactive configuration use ccmake ${srcdir}"
+echo
Summary of changes:
.gitignore | 1 -
configure | 54 ++++++++++++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 54 insertions(+), 1 deletion(-)
create mode 100755 configure
hooks/post-receive
More information about the geos-commits
