[geos-commits] [SCM] GEOS branch main updated. 655aacfea244e9ab0c57d96312522a4b5ac636af
git at osgeo.org
git at osgeo.org
Mon Oct 18 05:55:59 PDT 2021
the project "GEOS".
The branch, main has been updated
via 655aacfea244e9ab0c57d96312522a4b5ac636af (commit)
via 3455abb137ea89b5f9184827f72af966c2d0a172 (commit)
from 9915ef54ef2648a6d5e149c8e19f7e0f24be0bb9 (commit)
revisions in full, below.
commit 655aacfea244e9ab0c57d96312522a4b5ac636af
Merge: 9915ef54e 3455abb13
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Oct 18 05:55:56 2021 -0700
Merge pull request 'pkg-config: add -lgeos -lstdc++ -lm for static build options' (!115) from mwtoews/geos:pc-static into main
Reviewed-on: https://git.osgeo.org/gitea/geos/geos/pulls/115
commit 3455abb137ea89b5f9184827f72af966c2d0a172
Author: Mike Taves <mwtoews at gmail.com>
Date: Mon Oct 18 00:14:27 2021 +1300
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 56d94946b..20c890702 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -259,6 +259,12 @@ target_compile_options(geos_developer_cxx_flags
set(CMAKE_CXX_FLAGS_COVERAGE "-fprofile-arcs -ftest-coverage")
+# Extra libraries
+include(CheckLibraryExists)
+check_library_exists(m pow "" HAVE_LIBM)
# Target geos: C++ API library
add_library(geos "")
diff --git a/tools/CMakeLists.txt b/tools/CMakeLists.txt
index bca151992..bc0e774b5 100644
--- a/tools/CMakeLists.txt
+++ b/tools/CMakeLists.txt
@@ -45,6 +45,11 @@ function(configure_install_geos_pc)
set(includedir "$\{prefix\}/${CMAKE_INSTALL_INCLUDEDIR}")
set(libdir "$\{exec_prefix\}/${CMAKE_INSTALL_LIBDIR}")
set(VERSION ${GEOS_VERSION})
+ set(EXTRA_LIBS "-lstdc++")
+ if(HAVE_LIBM)
+ list(APPEND EXTRA_LIBS "-lm")
+ endif()
+ list(JOIN EXTRA_LIBS " " EXTRA_LIBS)
configure_file(
${CMAKE_CURRENT_SOURCE_DIR}/geos.pc.in
diff --git a/tools/geos.pc.in b/tools/geos.pc.in
index df0e07b7f..1cbd5a217 100644
--- a/tools/geos.pc.in
+++ b/tools/geos.pc.in
@@ -9,3 +9,4 @@ Requires:
Version: @VERSION@
Cflags: -I${includedir}
Libs: -L${libdir} -lgeos_c
+Libs.private: -lgeos @EXTRA_LIBS@
Summary of changes:
CMakeLists.txt | 6 ++++++
tools/CMakeLists.txt | 5 +++++
tools/geos.pc.in | 1 +
3 files changed, 12 insertions(+)
hooks/post-receive
More information about the geos-commits
