[geos-commits] [SCM] GEOS branch 3.10 updated. 94853b664293e808dbcf6964e5943a36a261ef29
git at osgeo.org
git at osgeo.org
Fri Oct 29 14:45:45 PDT 2021
the project "GEOS".
The branch, 3.10 has been updated
via 94853b664293e808dbcf6964e5943a36a261ef29 (commit)
via 20aec05fd1973b029e27ec06259ab8b63f351db2 (commit)
via 14f0a696b8d7a1c26a32d3fd79e5da5e4b66c219 (commit)
from 793f3cbf3d701d124f94bf2d0eaa98df43199973 (commit)
revisions in full, below.
commit 94853b664293e808dbcf6964e5943a36a261ef29
Merge: 20aec05fd 793f3cbf3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 29 14:45:41 2021 -0700
Merge branch '3.10' of https://git.osgeo.org/gitea/geos/geos into 3.10
commit 20aec05fd1973b029e27ec06259ab8b63f351db2
Date: Fri Oct 29 14:45:32 2021 -0700
NEWS item for 1135 fix
diff --git a/NEWS b/NEWS
index 8acfd4889..03ac7e6c1 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ Changes in 3.10.1
- Fixes/Improvements:
- Fix mistake in constants used to select WKB flavor in C API (GH489, Paul Ramsey)
+ - Fix crash when reducing precision on a LinearRing (#1135, Paul Ramsey)
Changes in 3.10.0
commit 14f0a696b8d7a1c26a32d3fd79e5da5e4b66c219
Date: Fri Oct 29 14:33:35 2021 -0700
Check for empty Sequence when collapsing linear ring. References #1135
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index faa7f8f3f..19c4bd5f0 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -202,7 +202,7 @@ GeometryTransformer::transformLinearRing(
CoordinateSequence::Ptr seq(transformCoordinates(
geom->getCoordinatesRO(), geom));
- auto seqSize = seq->size();
+ std::size_t seqSize = seq ? seq->size() : 0;
// ensure a valid LinearRing
if(seqSize > 0 && seqSize < 4 && ! preserveType) {
diff --git a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
index 06f4148fa..4864d02a0 100644
--- a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
@@ -158,5 +158,16 @@ void object::test<9> ()
ensure_geometry_equals(geom2_, "LINESTRING (0 0, 0 0)");
+// Collapse a linearRing / Trac #1135
+template<>
+template<>
+void object::test<10> ()
+ geom1_ = fromWKT("LINEARRING (0 0, 0.1 0, 0.1 0.1, 0 0.1, 0 0)");
+ geom2_ = GEOSGeom_setPrecision(geom1_, 1.0, 0);
+ ensure_geometry_equals(geom2_, "LINEARRING EMPTY");
} // namespace tut
Summary of changes:
NEWS | 1 +
src/geom/util/GeometryTransformer.cpp | 2 +-
tests/unit/capi/GEOSGeom_setPrecisionTest.cpp | 11 +++++++++++
3 files changed, 13 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
