[geos-commits] [SCM] GEOS branch 3.10 updated. 42a9ba786d75f98c9e90dbe316bab923963eb3f6
git at osgeo.org
git at osgeo.org
Sat Oct 30 14:17:25 PDT 2021
the project "GEOS".
The branch, 3.10 has been updated
via 42a9ba786d75f98c9e90dbe316bab923963eb3f6 (commit)
via 9846ac3184ea8bc304738f7003f868393da9ff49 (commit)
from 94853b664293e808dbcf6964e5943a36a261ef29 (commit)
revisions in full, below.
commit 42a9ba786d75f98c9e90dbe316bab923963eb3f6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sat Oct 30 14:17:18 2021 -0700
Add NEWS entry about GeoJSON invalid crash fix
diff --git a/NEWS b/NEWS
index 03ac7e6c1..3830546d2 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ Changes in 3.10.1
- Fixes/Improvements:
- Fix mistake in constants used to select WKB flavor in C API (GH489, Paul Ramsey)
- Fix crash when reducing precision on a LinearRing (#1135, Paul Ramsey)
+ - Fix GeoJSON crash on invalid input (GH498, Even Rouault)
Changes in 3.10.0
commit 9846ac3184ea8bc304738f7003f868393da9ff49
Author: Even Rouault <even.rouault at spatialys.com>
Date: Sat Oct 30 22:44:26 2021 +0200
GeoJSON reader: fix crashes (in debug mode) on invalid GeoJSON
json::operator[] is advertised as having undefined behavior when the
request member doesn't exist or the json item is not an object.
json::at() is similar but emits a C++ exception on those situations.
Fixes #1138
diff --git a/src/io/GeoJSONReader.cpp b/src/io/GeoJSONReader.cpp
index 82cb922a5..4733bbe4d 100644
--- a/src/io/GeoJSONReader.cpp
+++ b/src/io/GeoJSONReader.cpp
@@ -49,7 +49,7 @@ std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonTe
try {
const json& j = json::parse(geoJsonText);
- const std::string& type = j["type"];
+ const std::string& type = j.at("type");
if (type == "Feature") {
return readFeatureForGeometry(j);
@@ -69,7 +69,7 @@ GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonT
try {
const auto& feature = readFeature(j);
return GeoJSONFeatureCollection { std::vector<GeoJSONFeature>{feature} };
@@ -90,15 +90,15 @@ GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonT
std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureForGeometry(
const geos_nlohmann::json& j) const
- const auto& geometryJson = j["geometry"];
+ const auto& geometryJson = j.at("geometry");
auto geometry = readGeometry(geometryJson);
return geometry;
GeoJSONFeature GeoJSONReader::readFeature(const geos_nlohmann::json& j) const
- const auto& properties = j["properties"];
+ const auto& properties = j.at("properties");
return GeoJSONFeature{readGeometry(geometryJson), readProperties(properties)};
@@ -147,7 +147,7 @@ GeoJSONValue GeoJSONReader::readProperty(
std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureCollectionForGeometry(
- const auto& featuresJson = j["features"];
+ const auto& featuresJson = j.at("features");
std::vector<std::unique_ptr<geom::Geometry>> geometries;
geometries.reserve(featuresJson.size());
for (const auto& featureJson : featuresJson) {
@@ -160,7 +160,7 @@ std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureCollectionForGeometry(
GeoJSONFeatureCollection GeoJSONReader::readFeatureCollection(
std::vector<GeoJSONFeature> features;
features.reserve(featuresJson.size());
@@ -173,7 +173,7 @@ GeoJSONFeatureCollection GeoJSONReader::readFeatureCollection(
std::unique_ptr<geom::Geometry> GeoJSONReader::readGeometry(
if (type == "Point") {
return readPoint(j);
@@ -217,7 +217,7 @@ geom::Coordinate GeoJSONReader::readCoordinate(
std::unique_ptr<geom::Point> GeoJSONReader::readPoint(
- const auto& coords = j["coordinates"].get<std::vector<double>>();
+ const auto& coords = j.at("coordinates").get<std::vector<double>>();
if (coords.size() == 1) {
throw ParseException("Expected two coordinates found one");
@@ -233,7 +233,7 @@ std::unique_ptr<geom::Point> GeoJSONReader::readPoint(
std::unique_ptr<geom::LineString> GeoJSONReader::readLineString(
- const auto& coords = j["coordinates"].get<std::vector<std::vector<double>>>();
+ const auto& coords = j.at("coordinates").get<std::vector<std::vector<double>>>();
std::vector<geom::Coordinate> coordinates;
coordinates.reserve(coords.size());
for (const auto& coord : coords) {
@@ -245,9 +245,9 @@ std::unique_ptr<geom::LineString> GeoJSONReader::readLineString(
std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(
- const geos_nlohmann::json& json) const
+ const geos_nlohmann::json& j) const
- const auto& polygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
+ const auto& polygonCoords = j.at("coordinates").get<std::vector<std::vector<std::vector<double>>>>();
return readPolygon(polygonCoords);
@@ -286,7 +286,7 @@ std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(
std::unique_ptr<geom::MultiPoint> GeoJSONReader::readMultiPoint(
std::vector<std::unique_ptr<geom::Point>> points;
points.reserve(coords.size());
@@ -297,9 +297,9 @@ std::unique_ptr<geom::MultiPoint> GeoJSONReader::readMultiPoint(
std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(
- const auto& listOfCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
+ const auto& listOfCoords = j.at("coordinates").get<std::vector<std::vector<std::vector<double>>>>();
std::vector<std::unique_ptr<geom::LineString>> lines;
lines.reserve(listOfCoords.size());
for (const auto& coords : listOfCoords) {
@@ -316,9 +316,9 @@ std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(
std::unique_ptr<geom::MultiPolygon> GeoJSONReader::readMultiPolygon(
- const auto& multiPolygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<std::vector<double>>>>>();
+ const auto& multiPolygonCoords = j.at("coordinates").get<std::vector<std::vector<std::vector<std::vector<double>>>>>();
std::vector<std::unique_ptr<geom::Polygon>> polygons;
polygons.reserve(multiPolygonCoords.size());
for (const auto& polygonCoords : multiPolygonCoords) {
@@ -330,7 +330,7 @@ std::unique_ptr<geom::MultiPolygon> GeoJSONReader::readMultiPolygon(
std::unique_ptr<geom::GeometryCollection> GeoJSONReader::readGeometryCollection(
- const auto& jsonGeometries = j["geometries"];
+ const auto& jsonGeometries = j.at("geometries");
geometries.reserve(jsonGeometries.size());
for (const auto& jsonGeometry : jsonGeometries) {
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index 462ca11fa..cfba3f020 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -437,5 +437,22 @@ void object::test<29>
ensure_equals("ParseException: Expected two coordinates found more than two", errorMessage);
+// Throw ParseException for bad GeoJSON
+template<>
+template<>
+void object::test<30>
+ std::string errorMessage;
+ std::string geojson { "{ \"missing\": \"type\" }" };
+ bool error = false;
+ try {
+ GeomPtr geom(geojsonreader.read(geojson));
+ } catch (geos::io::ParseException& e) {
+ error = true;
+ ensure(error == true);
Summary of changes:
NEWS | 1 +
src/io/GeoJSONReader.cpp | 36 ++++++++++++++++++------------------
tests/unit/io/GeoJSONReaderTest.cpp | 17 +++++++++++++++++
3 files changed, 36 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits
