[geos-commits] [SCM] GEOS branch 3.10 updated. 8809f7c9ab68594e843151008899bd7d9b10223f
git at osgeo.org
git at osgeo.org
Sun Oct 31 16:55:09 PDT 2021
the project "GEOS".
The branch, 3.10 has been updated
via 8809f7c9ab68594e843151008899bd7d9b10223f (commit)
from 0543d5b59dd0141bc13cf714dcdcf3c90ce19344 (commit)
revisions in full, below.
commit 8809f7c9ab68594e843151008899bd7d9b10223f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sun Oct 31 16:54:07 2021 -0700
Add MSCV 2022 to GH Actions
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 0c3c2e12f..12cf28803 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -165,6 +165,51 @@ jobs:
cmake --build . -j 2
ctest --output-on-failure .
+ windows-mingw-release:
+ name: 'Windows (mingw-w64, Release, 11, x86_64, windows-2019)'
+ runs-on: windows-2019
+ defaults:
+ run:
+ shell: msys2 {0}
+ steps:
+ - name: 'Check Out'
+ uses: actions/checkout at v2
+ - name: 'Setup'
+ uses: msys2/setup-msys2 at v2
+ with:
+ install: mingw-w64-x86_64-gcc mingw-w64-x86_64-cmake make
+ update: true
+ - name: 'Build'
+ run: |
+ mkdir build
+ cd build
+ cmake --version
+ cmake -DCMAKE_BUILD_TYPE=Release -G"MSYS Makefiles" ..
+ cmake --build . -j 2
+ ctest --output-on-failure .
+ windows-msvc-22:
+ name: 'Windows (Visual Studio 2022, Release, windows-2022)'
+ runs-on: windows-2022
+ steps:
+ - name: 'Build'
+ run: |
+ mkdir build
+ cd build
+ cmake --version
+ cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_STANDARD=14 -DBUILD_SHARED_LIBS=ON ..
+ cmake --build . --config Release -j 2
+ - name: 'Test'
+ run: |
+ cd build
+ ctest --output-on-failure -C Release
windows-msvc-19:
name: 'Windows (Visual Studio 2019, Release, windows-2019)'
@@ -178,7 +223,7 @@ jobs:
cd build
cmake --version
- cmake --build . --config Release
- name: 'Test'
run: |
@@ -198,7 +243,7 @@ jobs:
cd build
cmake --version
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_STANDARD=11 -DBUILD_SHARED_LIBS=ON ..
- name: 'Test'
run: |
Summary of changes:
.github/workflows/ci.yml | 49 ++++++++++++++++++++++++++++++++++++++++++++++--
1 file changed, 47 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
