[geos-commits] [SCM] GEOS branch main updated. 5bb0eba2b33b924440b356334540e64b60c86201
git at osgeo.org
git at osgeo.org
Tue Sep 7 19:26:51 PDT 2021
the project "GEOS".
The branch, main has been updated
via 5bb0eba2b33b924440b356334540e64b60c86201 (commit)
from 8ac9e91c1bb602f8a98596d9a4da4f1fd4e3cc34 (commit)
revisions in full, below.
commit 5bb0eba2b33b924440b356334540e64b60c86201
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Sep 7 19:26:36 2021 -0700
Port JTS https://github.com/locationtech/jts/pull/772 GeometryFixer support for unnested holes
diff --git a/NEWS b/NEWS
index cc8b6f1..da9ee04 100644
--- a/NEWS
+++ b/NEWS
@@ -6,11 +6,13 @@ Changes in 3.10.0
library (#868, Paul Ramsey)
- geosop CLI for GEOS (Martin Davis)
- Full doxygen of the C-API (Paul Ramsey)
+ - GeometryFixer class for validity enforcement (Martin Davis, Paul Ramsey)
- CAPI: GEOSDensify (Brendan Ward)
- CAPI: GEOSCoordSeq_copyFromArrays, GEOSCoordSeq_copyFromBuffer,
GEOSCoordSeq_copyToArrays, GEOSCoordSeq_copyToBuffer (Daniel Baston)
- CAPI: GEOSMakeValidWithParams new validity enforcement approach from
- https://github.com/locationtech/jts/pull/704 (Paul Ramsey, Martin Davis)
+ https://github.com/locationtech/jts/pull/704, uses GeometryFixer
+ (Paul Ramsey, Martin Davis)
- Fixes/Improvements:
- Preserve ordering of lines in overlay results (Martin Davis)
diff --git a/include/geos/geom/util/GeometryFixer.h b/include/geos/geom/util/GeometryFixer.h
index 4998857..7896632 100644
--- a/include/geos/geom/util/GeometryFixer.h
+++ b/include/geos/geom/util/GeometryFixer.h
@@ -54,17 +54,20 @@ namespace util { // geos.geom.util
* * Empty atomic geometries are valid and are returned unchanged
* * Empty elements are removed from collections
* * <code>Point</code>: keep valid coordinate, or EMPTY
- * * <code>LineString</code>: fix coordinate list
- * * <code>LinearRing</code>: fix coordinate list, return as valid ring or else <code>LineString</code>
- * * <code>Polygon</code>: transform into a valid polygon, preserving as much of the extent and vertices as possible
- * * <code>MultiPolygon</code>: fix each polygon, then ensure result is non-overlapping (via union)
- * * <code>GeometryCollection</code>: fix each element
+ * * <code>LineString</code>: coordinates are fixed
+ * * <code>LinearRing</code>: coordinates are fixed, Keep valid ring or else convert into <code>LineString</code>
+ * * <code>Polygon</code>: transform into a valid polygon,
+ * * preserving as much of the extent and vertices as possible.
+ * * Rings are fixed to ensure they are valid<
+ * * Holes intersecting the shell are subtracted from the shell
+ * * Holes outside the shell are converted into polygons
+ * * <code>MultiPolygon</code>: each polygon is fixed,
+ * then result made non-overlapping (via union)
+ * * <code>GeometryCollection</code>: each element is fixed
* * Collapsed lines and polygons are handled as follows,
- * depending on the <code>keepCollapsed</code> setting:
- * * <code>false</code>: (default) collapses are converted to empty geometries
- * * <code>true</code>: collapses are converted to a valid geometry of lower dimension
+ * depending on the <code>keepCollapsed</code> setting:
+ * * <code>false</code>: (default) collapses are converted to empty geometries
+ * * <code>true</code>: collapses are converted to a valid geometry of lower dimension
* @author Martin Davis
@@ -123,12 +126,40 @@ private:
std::unique_ptr<geom::Geometry> fixMultiLineString(const MultiLineString* geom) const;
std::unique_ptr<geom::Geometry> fixPolygon(const geom::Polygon* geom) const;
std::unique_ptr<geom::Geometry> fixPolygonElement(const geom::Polygon* geom) const;
- std::unique_ptr<geom::Geometry> fixHoles(const geom::Polygon* geom) const;
+ std::vector<std::unique_ptr<Geometry>> fixHoles(const geom::Polygon* geom) const;
std::unique_ptr<geom::Geometry> removeHoles(const geom::Geometry* shell, const geom::Geometry* holes) const;
std::unique_ptr<geom::Geometry> fixRing(const geom::LinearRing* ring) const;
std::unique_ptr<geom::Geometry> fixMultiPolygon(const geom::MultiPolygon* geom) const;
std::unique_ptr<geom::Geometry> fixCollection(const geom::GeometryCollection* geom) const;
+ void classifyHoles(
+ const Geometry* shell,
+ std::vector<std::unique_ptr<Geometry>>& holesFixed,
+ std::vector<const Geometry*>& holes,
+ std::vector<const Geometry*>& shells) const;
+ * Subtracts a list of polygonal geometries from a polygonal geometry.
+ * @param shell polygonal geometry for shell
+ * @param holes polygonal geometries to subtract
+ * @return the result geometry
+ std::unique_ptr<Geometry> difference(
+ std::vector<const Geometry*>& holes) const;
+ * Unions a list of polygonal geometries.
+ * Optimizes case of zero or one input geometries.
+ * Requires that the inputs are net new objects.
+ * @param polys the polygonal geometries to union
+ * @return the union of the inputs
+ std::unique_ptr<Geometry> unionGeometry(
+ std::vector<const Geometry*>& polys) const;
} // namespace geos.geom.util
diff --git a/src/geom/util/GeometryFixer.cpp b/src/geom/util/GeometryFixer.cpp
index 634380f..67a3026 100644
--- a/src/geom/util/GeometryFixer.cpp
+++ b/src/geom/util/GeometryFixer.cpp
@@ -15,13 +15,18 @@
#include <geos/geom/util/GeometryFixer.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/prep/PreparedGeometry.h>
+#include <geos/geom/prep/PreparedGeometryFactory.h>
#include <geos/operation/overlayng/OverlayNG.h>
#include <geos/operation/overlayng/OverlayNGRobust.h>
#include <geos/operation/buffer/BufferOp.h>
#include <geos/operation/valid/RepeatedPointRemover.h>
#include <geos/util/UnsupportedOperationException.h>
+#include <geos/operation/union/UnaryUnionOp.h>
using geos::operation::valid::RepeatedPointRemover;
+using geos::operation::overlayng::OverlayNGRobust;
+using geos::operation::geounion::UnaryUnionOp;
namespace geos {
namespace geom { // geos.geom
@@ -248,52 +253,99 @@ GeometryFixer::fixPolygonElement(const Polygon* p_geom) const
std::unique_ptr<LineString> line(factory->createLineString(*cs));
return fixLineString(line.get());
- //-- if not allowing collapses then return empty polygon
+ //--- if not allowing collapses then return empty polygon
return nullptr;
- // if no holes then done
+ //--- if no holes then done
if (p_geom->getNumInteriorRing() == 0) {
return fixShell;
- std::unique_ptr<Geometry> fixedHoles = fixHoles(p_geom);
- std::unique_ptr<Geometry> result = removeHoles(fixShell.get(), fixedHoles.get());
- return result;
+ //--- fix holes, classify, and construct shell-true holes
+ std::vector<std::unique_ptr<Geometry>> holesFixed = fixHoles(p_geom);
+ std::vector<const Geometry*> holes;
+ std::vector<const Geometry*> shells;
+ classifyHoles(fixShell.get(), holesFixed, holes, shells);
+ std::unique_ptr<Geometry> polyWithHoles = difference(fixShell.get(), holes);
+ if (shells.empty()) {
+ return polyWithHoles;
+ //--- if some holes converted to shells, union all shells
+ shells.push_back(polyWithHoles.get());
+ return unionGeometry(shells);
/* private */
-std::unique_ptr<Geometry>
-GeometryFixer::fixHoles(const Polygon* p_geom) const
+std::vector<std::unique_ptr<Geometry>>
+GeometryFixer::fixHoles(const Polygon* poly) const
std::vector<std::unique_ptr<Geometry>> holes;
- for (std::size_t i = 0; i < p_geom->getNumInteriorRing(); i++) {
- std::unique_ptr<Geometry> holeRep = fixRing(p_geom->getInteriorRingN(i));
- // Do not preserve null/empty holes
- if (holeRep != nullptr && !holeRep->isEmpty()) {
+ for (std::size_t i = 0; i < poly->getNumInteriorRing(); i++) {
+ std::unique_ptr<Geometry> holeRep = fixRing(poly->getInteriorRingN(i));
+ if (holeRep != nullptr) {
holes.emplace_back(holeRep.release());
- if (holes.empty())
- return nullptr;
+ return holes;
- if (holes.size() == 1) {
- std::unique_ptr<Geometry> h(holes.at(0).release());
- return h;
+/* private */
+void
+GeometryFixer::classifyHoles(
+ std::unique_ptr<prep::PreparedGeometry> shellPrep =
+ prep::PreparedGeometryFactory::prepare(shell);
+ for (auto& hole : holesFixed) {
+ const Geometry* cptrHole = hole.get();
+ if (shellPrep->intersects(cptrHole)) {
+ holes.push_back(cptrHole);
+ else {
+ shells.push_back(cptrHole);
- std::unique_ptr<GeometryCollection> holesGeom = (factory->createGeometryCollection(std::move(holes)));
- return operation::overlayng::OverlayNGRobust::Union(holesGeom.get());
/* private */
-GeometryFixer::removeHoles(const Geometry* shell, const Geometry* holes) const
+GeometryFixer::difference(
- if (holes == nullptr || holes->isEmpty())
+ if (holes.empty())
return shell->clone();
- return operation::overlayng::OverlayNGRobust::Overlay(shell, holes,
- operation::overlayng::OverlayNG::DIFFERENCE);
+ if (holes.size() == 1)
+ return OverlayNGRobust::Difference(shell, holes[0]);
+ std::unique_ptr<Geometry> holesUnion = unionGeometry(holes);
+ return OverlayNGRobust::Difference(shell, holesUnion.get());
+/* private */
+std::unique_ptr<Geometry>
+GeometryFixer::unionGeometry(std::vector<const Geometry*>& polys) const
+ if (polys.empty()) {
+ return factory->createPolygon(geom->getCoordinateDimension());
+ if (polys.size() == 1) {
+ return (polys[0])->clone();
+ UnaryUnionOp op(polys);
+ return op.Union();
+ // return OverlayNGRobust::Union(polys);
/* private */
GeometryFixer::fixRing(const LinearRing* ring) const
@@ -322,7 +374,7 @@ GeometryFixer::fixMultiPolygon(const MultiPolygon* p_geom) const
return factory->createMultiPolygon();
std::unique_ptr<GeometryCollection> polysGeom = (factory->createGeometryCollection(std::move(polys)));
- return operation::overlayng::OverlayNGRobust::Union(polysGeom.get());
+ return OverlayNGRobust::Union(polysGeom.get());
/* private */
diff --git a/tests/unit/geom/util/GeometryFixerTest.cpp b/tests/unit/geom/util/GeometryFixerTest.cpp
index f724b13..1a4d7c4 100644
--- a/tests/unit/geom/util/GeometryFixerTest.cpp
+++ b/tests/unit/geom/util/GeometryFixerTest.cpp
@@ -58,6 +58,7 @@ struct test_geometryfixer_data {
void checkFix(const Geometry* input, bool keepCollapse, const std::string& wktExpected) {
std::unique_ptr<Geometry> actual;
if (keepCollapse) {
GeometryFixer fixer(input);
@@ -110,9 +111,6 @@ struct test_geometryfixer_data {
std::string actualWKT = wktwriter_.write(actual.get());
std::string expectedWKT = wktwriter_.write(expected.get());
ensure_equals(actualWKT, expectedWKT);
- // checkEqualXYZ(expected, actual);
std::unique_ptr<Point> createPoint(double x, double y) {
@@ -123,12 +121,11 @@ struct test_geometryfixer_data {
-typedef test_group<test_geometryfixer_data> group;
+typedef test_group<test_geometryfixer_data, 255> group;
typedef group::object object;
group test_geometryfixer_group("geos::geom::util::GeometryFixer");
template<>
template<>
void object::test<1>()
@@ -170,7 +167,7 @@ void object::test<5>()
checkFix(pt.get() , "POINT EMPTY");
// testMultiPointNaN
template<>
@@ -208,7 +205,7 @@ void object::test<9>()
"MULTIPOINT EMPTY");
// testLineStringEmpty
template<>
@@ -585,6 +582,7 @@ void object::test<47>()
"GEOMETRYCOLLECTION EMPTY");
// testGCWithAllEmpty
template<>
template<>
@@ -595,9 +593,6 @@ void object::test<48>()
"GEOMETRYCOLLECTION (POINT EMPTY, LINESTRING EMPTY, POLYGON EMPTY)");
template<>
template<>
void object::test<49>()
@@ -607,10 +602,20 @@ void object::test<49>()
"MULTIPOLYGON Z(((10 10 1, 10 90 1, 50 50 5, 10 10 1)), ((50 50 5, 90 90 9, 90 10 9, 50 50 5)))");
+// testPolygonHoleOverlapAndOutsideOverlap
template<>
template<>
void object::test<50>()
+ checkFix(
+ "POLYGON ((50 90, 80 90, 80 10, 50 10, 50 90), (70 80, 90 80, 90 20, 70 20, 70 80), (40 80, 40 50, 0 50, 0 80, 40 80), (30 40, 10 40, 10 60, 30 60, 30 40), (60 70, 80 70, 80 30, 60 30, 60 70))",
+ "MULTIPOLYGON (((10 40, 10 50, 0 50, 0 80, 40 80, 40 50, 30 50, 30 40, 10 40)), ((70 80, 70 70, 60 70, 60 30, 70 30, 70 20, 80 20, 80 10, 50 10, 50 90, 80 90, 80 80, 70 80)))");
+template<>
+template<>
+void object::test<51>()
checkFixZ(
"POLYGON Z ((10 90 1, 60 90 6, 60 10 6, 10 10 1, 10 90 1), (20 80 2, 90 80 9, 90 20 9, 20 20 2, 20 80 2))",
"POLYGON Z((10 10 1, 10 90 1, 60 90 6, 60 80 6, 20 80 2, 20 20 2, 60 20 6, 60 10 6, 10 10 1))");
@@ -627,5 +632,4 @@ void object::test<52>()
} // namespace tut
Summary of changes:
NEWS | 4 +-
include/geos/geom/util/GeometryFixer.h | 53 +++++++++++----
src/geom/util/GeometryFixer.cpp | 100 ++++++++++++++++++++++-------
tests/unit/geom/util/GeometryFixerTest.cpp | 26 ++++----
4 files changed, 136 insertions(+), 47 deletions(-)
hooks/post-receive
More information about the geos-commits
