[geos-commits] [SCM] GEOS branch 3.9 updated. 2d9cfd05594fdacc53a818f353f90c55b7b3ab9a
git at osgeo.org
git at osgeo.org
Wed Sep 8 14:24:38 PDT 2021
the project "GEOS".
The branch, 3.9 has been updated
via 2d9cfd05594fdacc53a818f353f90c55b7b3ab9a (commit)
from 0d3e09cc31101a7bd58051add7db0ce0aef6b6f5 (commit)
revisions in full, below.
commit 2d9cfd05594fdacc53a818f353f90c55b7b3ab9a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Sep 8 14:24:29 2021 -0700
Guard against some null inputs, references #1111
diff --git a/NEWS b/NEWS
index 46559bf..1e29d50 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,7 @@ Changes in 3.9.2
- Fix BufferOp to avoid artifacts in certain polygon buffers (#1101, Martin Davis)
- Declare parameterless functions in geos_c.h as func(void) (Paul Ramsey)
- Performance improvement in SegmentNodeList (Even Rouault)
+ - Catch memory leaks on createPolygon failure (#1111, Paul Ramsey)
Changes in 3.9.1
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 188d100..e43d6d8 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2408,31 +2408,46 @@ extern "C" {
//assert(0 != holes);
return execute(extHandle, [&]() {
+ GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ const GeometryFactory* gf = handle->geomFactory;
+ bool good_holes = true, good_shell = true;
- std::vector<LinearRing*> tmpholes(nholes);
- for (size_t i = 0; i < nholes; i++) {
- LinearRing* lr = dynamic_cast<LinearRing*>(holes[i]);
- if (! lr) {
- throw IllegalArgumentException("Hole is not a LinearRing");
+ // Validate input before taking ownership
+ for (std::size_t i = 0; i < nholes; i++) {
+ if ((!holes) || (!dynamic_cast<LinearRing*>(holes[i]))) {
+ good_holes = false;
+ break;
- tmpholes[i] = lr;
- LinearRing* nshell = dynamic_cast<LinearRing*>(shell);
- if(! nshell) {
- throw IllegalArgumentException("Shell is not a LinearRing");
+ if (!dynamic_cast<LinearRing*>(shell)) {
+ good_shell = false;
- GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
- const GeometryFactory* gf = handle->geomFactory;
- /* Create unique_ptr version for constructor */
- std::vector<std::unique_ptr<LinearRing>> vholes;
- vholes.reserve(nholes);
- for (LinearRing* lr: tmpholes) {
- vholes.emplace_back(lr);
+ // Contract for GEOSGeom_createPolygon is to take ownership of arguments
+ // which implies freeing them on exception,
+ // see https://trac.osgeo.org/geos/ticket/1111
+ if (!(good_holes && good_shell)) {
+ if (shell) delete shell;
+ if (holes && holes[i])
+ delete holes[i];
+ if (!good_shell)
+ throw IllegalArgumentException("Shell is not a LinearRing");
+ else
+ throw IllegalArgumentException("Hole is not a LinearRing");
+ std::unique_ptr<LinearRing> tmpshell(static_cast<LinearRing*>(shell));
+ if (nholes) {
+ std::vector<std::unique_ptr<LinearRing>> tmpholes(nholes);
+ for (size_t i = 0; i < nholes; i++) {
+ tmpholes[i].reset(static_cast<LinearRing*>(holes[i]));
+ return gf->createPolygon(std::move(tmpshell), std::move(tmpholes)).release();
- std::unique_ptr<LinearRing> shell(nshell);
+ return gf->createPolygon(std::move(tmpshell)).release();
- return gf->createPolygon(std::move(shell), std::move(vholes)).release();
diff --git a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
index b560975..56a4746 100644
--- a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
@@ -50,5 +50,31 @@ void object::test<1>
free(holes);
+template<>
+template<>
+void object::test<2>
+ GEOSCoordSequence* shell_seq = GEOSCoordSeq_create(5, 2);
+ double shell_coords[] = {0,0, 0,10, 10,10, 10,0, 0,0};
+ for (unsigned int i = 0; i < 5; i++) {
+ GEOSCoordSeq_setXY(shell_seq, i, shell_coords[2*i], shell_coords[2*i+1]);
+ GEOSGeometry* shell = GEOSGeom_createLineString(shell_seq);
+ GEOSGeometry** holes = nullptr;
+ unsigned int nholes = 1;
+ // Returns null on exception, wrong input type for shell
+ GEOSGeometry* polygon = GEOSGeom_createPolygon(shell, holes, nholes);
+ ensure(polygon == nullptr);
+ // Shouldn't need this
+ if (polygon)
+ GEOSGeom_destroy(polygon);
} // namespace tut
Summary of changes:
NEWS | 1 +
capi/geos_ts_c.cpp | 51 +++++++++++++++++---------
tests/unit/capi/GEOSGeom_createPolygonTest.cpp | 26 +++++++++++++
3 files changed, 60 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits
