[geos-commits] [SCM] GEOS branch main updated. 7f8bc49ce3afbdbd3d510e8e97be530c1206f45a
git at osgeo.org
git at osgeo.org
Mon Sep 20 15:21:23 PDT 2021
the project "GEOS".
The branch, main has been updated
via 7f8bc49ce3afbdbd3d510e8e97be530c1206f45a (commit)
via 5e536f4fa9b368c97ed35111a5bea29d9ca06d27 (commit)
from 128f6d9ffeb961b5b8c9baa6651521a88cfdfe35 (commit)
revisions in full, below.
commit 7f8bc49ce3afbdbd3d510e8e97be530c1206f45a
Merge: 5e536f4 128f6d9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Sep 20 15:21:19 2021 -0700
Merge branch 'main' of https://git.osgeo.org/gitea/geos/geos into main
commit 5e536f4fa9b368c97ed35111a5bea29d9ca06d27
Date: Mon Sep 20 15:21:13 2021 -0700
Quiet MSVC compilation warnings from CI
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index ee4beea..f95ca6f 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1430,14 +1430,16 @@ extern "C" {
Geometry*
GEOSUnionCascaded_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- // CascadedUnion is the same as UnaryUnion, except that
- // CascadedUnion only works on MultiPolygon, so we just delegate
- // now and retain a check on MultiPolygon type.
- const geos::geom::MultiPolygon *p = dynamic_cast<const geos::geom::MultiPolygon *>(g1);
- if (!p) {
- throw IllegalArgumentException("Invalid argument (must be a MultiPolygon)");
- return GEOSUnaryUnion_r(extHandle, g1);
+ return execute(extHandle, [&]() {
+ // CascadedUnion is the same as UnaryUnion, except that
+ // CascadedUnion only works on MultiPolygon, so we just delegate
+ // now and retain a check on MultiPolygon type.
+ const geos::geom::MultiPolygon *p = dynamic_cast<const geos::geom::MultiPolygon *>(g1);
+ if (!p) {
+ throw IllegalArgumentException("Invalid argument (must be a MultiPolygon)");
+ return GEOSUnaryUnion_r(extHandle, g1);
Geometry*
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index 3d03d03..9921887 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -563,8 +563,8 @@ void object::test<31>
try {
// Create non-empty LineString instance
auto lr(factory_->createLinearRing(pseq));
- fail("IllegalArgumentException expected.");
ensure(!lr->isEmpty());
+ fail("IllegalArgumentException expected.");
catch(geos::util::IllegalArgumentException const& e) {
const char* msg = e.what(); // OK
Summary of changes:
capi/geos_ts_c.cpp | 18 ++++++++++--------
tests/unit/geom/LineStringTest.cpp | 2 +-
2 files changed, 11 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
