[geos-commits] [SCM] GEOS branch 3.9 updated. 1f727025ec8c19f2d540c902580862ef4c670b11
git at osgeo.org
git at osgeo.org
Thu Sep 23 17:33:12 PDT 2021
the project "GEOS".
The branch, 3.9 has been updated
via 1f727025ec8c19f2d540c902580862ef4c670b11 (commit)
from 4e0008c232831d95c909982b2981e3556111760b (commit)
revisions in full, below.
commit 1f727025ec8c19f2d540c902580862ef4c670b11
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Sep 23 17:32:57 2021 -0700
Avoid stack overflow in KdTree::queryNode (from Even Roualt)
diff --git a/NEWS b/NEWS
index 8a066d0..db42c61 100644
--- a/NEWS
+++ b/NEWS
@@ -11,6 +11,8 @@ Changes in 3.9.2
- Performance improvement in SegmentNodeList (Even Rouault)
- Catch memory leaks on createPolygon failure (#1111, Paul Ramsey)
- Fix DiscreteFrechetDistance to use initial points of input lines (#1128, Martin Davis)
+ - Avoid stack overflow in KdTree::queryNode (Even Roualt)
Changes in 3.9.1
2021-02-10
diff --git a/src/index/kdtree/KdTree.cpp b/src/index/kdtree/KdTree.cpp
index 1df6e48..75530fb 100644
--- a/src/index/kdtree/KdTree.cpp
+++ b/src/index/kdtree/KdTree.cpp
@@ -17,6 +17,7 @@
#include <vector>
#include <algorithm>
+#include <stack>
using namespace geos::geom;
@@ -152,34 +153,76 @@ KdTree::insertExact(const geom::Coordinate& p, void* data)
void
KdTree::queryNode(KdNode* currentNode, const geom::Envelope& queryEnv, bool odd, KdNodeVisitor& visitor)
- if (currentNode == nullptr)
- return;
- double min;
- double max;
- double discriminant;
- if (odd) {
- min = queryEnv.getMinX();
- max = queryEnv.getMaxX();
- discriminant = currentNode->getX();
- } else {
- min = queryEnv.getMinY();
- max = queryEnv.getMaxY();
- discriminant = currentNode->getY();
- bool searchLeft = min < discriminant;
- bool searchRight = discriminant <= max;
- // search is computed via in-order traversal
- if (searchLeft) {
- queryNode(currentNode->getLeft(), queryEnv, !odd, visitor);
- if (queryEnv.contains(currentNode->getCoordinate())) {
- visitor.visit(currentNode);
- if (searchRight) {
- queryNode(currentNode->getRight(), queryEnv, !odd, visitor);
+ // Non recursive formulation of in-order traversal from
+ // http://web.cs.wpi.edu/~cs2005/common/iterative.inorder
+ // Otherwise we may blow up the stack
+ // See https://github.com/qgis/QGIS/issues/45226
+ typedef std::pair<KdNode*, bool> Pair;
+ std::stack<Pair> activeNodes;
+ while(true)
+ if( currentNode != nullptr )
+ double min;
+ double discriminant;
+ if (odd) {
+ min = queryEnv.getMinX();
+ discriminant = currentNode->getX();
+ } else {
+ min = queryEnv.getMinY();
+ discriminant = currentNode->getY();
+ bool searchLeft = min < discriminant;
+ activeNodes.emplace(Pair(currentNode, odd));
+ // search is computed via in-order traversal
+ KdNode* leftNode = nullptr;
+ if (searchLeft ) {
+ leftNode = currentNode->getLeft();
+ if( leftNode ) {
+ currentNode = leftNode;
+ odd = !odd;
+ } else {
+ currentNode = nullptr;
+ else if( !activeNodes.empty() )
+ currentNode = activeNodes.top().first;
+ odd = activeNodes.top().second;
+ activeNodes.pop();
+ if (queryEnv.contains(currentNode->getCoordinate())) {
+ visitor.visit(currentNode);
+ double max;
+ if (odd) {
+ max = queryEnv.getMaxX();
+ } else {
+ max = queryEnv.getMaxY();
+ bool searchRight = discriminant <= max;
+ if (searchRight) {
+ currentNode = currentNode->getRight();
+ if( currentNode )
+ odd = !odd;
+ } else {
+ else
+ break;
@@ -187,29 +230,32 @@ KdTree::queryNode(KdNode* currentNode, const geom::Envelope& queryEnv, bool odd,
KdNode*
KdTree::queryNodePoint(KdNode* currentNode, const geom::Coordinate& queryPt, bool odd)
- return nullptr;
- if (currentNode->getCoordinate().equals2D(queryPt))
- return currentNode;
- double ord;
- if (odd) {
- ord = queryPt.x;
- else {
- ord = queryPt.y;
+ while (currentNode != nullptr)
+ if (currentNode->getCoordinate().equals2D(queryPt))
+ return currentNode;
- bool searchLeft = (ord < discriminant);
- if (searchLeft) {
- return queryNodePoint(currentNode->getLeft(), queryPt, !odd);
- else {
- return queryNodePoint(currentNode->getRight(), queryPt, !odd);
+ double ord;
+ if (odd) {
+ ord = queryPt.x;
+ else {
+ ord = queryPt.y;
+ bool searchLeft = (ord < discriminant);
+ odd = !odd;
+ if (searchLeft) {
+ currentNode = currentNode->getLeft();
+ else {
+ return nullptr;
Summary of changes:
NEWS | 2 +
src/index/kdtree/KdTree.cpp | 144 +++++++++++++++++++++++++++++---------------
2 files changed, 97 insertions(+), 49 deletions(-)
hooks/post-receive
More information about the geos-commits
