[geos-commits] [SCM] GEOS branch main updated. ba10ba4508af887a1a78bbc632ab45d89ce3242c
git at osgeo.org
git at osgeo.org
Wed Sep 29 12:59:14 PDT 2021
the project "GEOS".
The branch, main has been updated
via ba10ba4508af887a1a78bbc632ab45d89ce3242c (commit)
from beb9207f650abeff96e9872903cf2a20b8011654 (commit)
revisions in full, below.
commit ba10ba4508af887a1a78bbc632ab45d89ce3242c
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Sep 29 21:57:13 2021 +0200
Add GEOSDistanceWithin and GEOSPreparedDistanceWithin
Closes #1124
The implementations are just a stubs, wrapping GEOSDistance, but
can be improved in the future.
diff --git a/NEWS b/NEWS
index f73de05..3612578 100644
--- a/NEWS
+++ b/NEWS
@@ -2,6 +2,9 @@ Changes in 3.10.0
2020-xx-xx
- New things:
+ - CAPI: GEOSDistanceWithin, GEOSPreparedDistanceWithin
+ (#1124, Sandro Santilli)
- Output WKT using positional precision with the ryu
library (#868, Paul Ramsey)
- geosop CLI for GEOS (Martin Davis)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 3c7c8bc..c3f80df 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -273,6 +273,12 @@ extern "C" {
return GEOSDistance_r(handle, g1, g2, dist);
+ char
+ GEOSDistanceWithin(const Geometry* g1, const Geometry* g2, double dist)
+ return GEOSDistanceWithin_r(handle, g1, g2, dist);
int
GEOSDistanceIndexed(const Geometry* g1, const Geometry* g2, double* dist)
@@ -1432,6 +1438,12 @@ extern "C" {
return GEOSPreparedDistance_r(handle, g1, g2, dist);
+ char
+ GEOSPreparedDistanceWithin(const geos::geom::prep::PreparedGeometry* g1, const Geometry* g2, double dist)
+ return GEOSPreparedDistanceWithin_r(handle, g1, g2, dist);
GEOSSTRtree*
GEOSSTRtree_create(std::size_t nodeCapacity)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index cdf8469..5fe5bda 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1116,6 +1116,12 @@ extern int GEOS_DLL GEOSPreparedDistance_r(
const GEOSPreparedGeometry* pg1,
const GEOSGeometry* g2, double *dist);
+/** \see GEOSPreparedDistanceWithin */
+extern char GEOS_DLL GEOSPreparedDistanceWithin_r(
+ GEOSContextHandle_t handle,
+ const GEOSPreparedGeometry* pg1,
+ const GEOSGeometry* g2, double dist);
/* ========== STRtree ========== */
/** \see GEOSSTRtree_create */
@@ -1515,6 +1521,13 @@ extern int GEOS_DLL GEOSDistance_r(
double *dist);
+/** \see GEOSDistanceWithin */
+extern char GEOS_DLL GEOSDistanceWithin_r(
+ const GEOSGeometry* g1,
+ double dist);
/** \see GEOSDistanceIndexed */
extern int GEOS_DLL GEOSDistanceIndexed_r(
@@ -3286,7 +3299,7 @@ extern GEOSCoordSequence GEOS_DLL *GEOSPreparedNearestPoints(
const GEOSGeometry* g2);
-* Using a \ref GEOSPreparedDisjoint do a high performance
+* Using a \ref GEOSPreparedDistance do a high performance
* calculation to find the distance points between the
* prepared and provided geometry. Useful for situations where
* one geometry is large and static and needs to be tested
@@ -3301,6 +3314,23 @@ extern int GEOS_DLL GEOSPreparedDistance(
double *dist);
+* Using a \ref GEOSPreparedDistanceWithin do a high performance
+* calculation to find whether the prepared and provided geometry
+* is within the given max distance.
+* Useful for situations where
+* one geometry is large and static and needs to be tested
+* against a large number of other geometries.
+* \param[in] pg1 The prepared geometry
+* \param[in] g2 The geometry to test
+* \param[in] dist The max distance
+* \return 1 on success
+extern char GEOS_DLL GEOSPreparedDistanceWithin(
+ double dist);
/* ========== STRtree functions ========== */
@@ -3957,6 +3987,18 @@ extern int GEOS_DLL GEOSDistance(
double *dist);
+* Calculate the distance between two geometries.
+* \param[in] g1 Input geometry
+* \param[in] g2 Input geometry
+* \param[in] dist max distance
+* \returns 1 on true, 0 on false, 2 on exception
+extern char GEOS_DLL GEOSDistanceWithin(
+ double dist);
* Calculate the distance between two geometries, using the
* indexed facet distance, which first indexes the geometries
* internally, then calculates the distance. Useful when one
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 56078eb..64d44bf 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -805,6 +805,15 @@ extern "C" {
+ char
+ GEOSDistanceWithin_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double dist)
+ // TODO: optimize this
+ return execute(extHandle, 2, [&]() {
+ return g1->distance(g2) <= dist;
int
GEOSDistanceIndexed_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
@@ -3273,6 +3282,17 @@ extern "C" {
+ char
+ GEOSPreparedDistanceWithin_r(GEOSContextHandle_t extHandle,
+ const geos::geom::prep::PreparedGeometry* pg,
+ const Geometry* g, double dist)
+ return pg->distance(g) <= dist;
// STRtree
diff --git a/tests/unit/capi/GEOSDistanceWithinTest.cpp b/tests/unit/capi/GEOSDistanceWithinTest.cpp
new file mode 100644
index 0000000..6d18b4e
--- /dev/null
+++ b/tests/unit/capi/GEOSDistanceWithinTest.cpp
@@ -0,0 +1,55 @@
+// Test Suite for C-API GEOSDistance
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+#include <geos/constants.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <memory>
+#include <math.h>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capigeosdistancewithin_data : public capitest::utility {
+ test_capigeosdistancewithin_data() {
+ GEOSWKTWriter_setTrim(wktw_, 1);
+typedef test_group<test_capigeosdistancewithin_data> group;
+typedef group::object object;
+group test_capigeosdistancewithin_group("capi::GEOSDistanceWithin");
+// Test Cases
+template<>
+template<>
+void object::test<1>
+ geom1_ = GEOSGeomFromWKT("POINT(10 10)");
+ geom2_ = GEOSGeomFromWKT("POINT(3 6)");
+ double dist = 8.1;
+ char ret = GEOSDistanceWithin(geom1_, geom2_, dist);
+ ensure_equals(ret, 1);
+ ret = GEOSDistanceWithin(geom1_, geom2_, dist-0.1);
+ ensure_equals(ret, 0);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp b/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
index 0000000..96a654c
--- /dev/null
+++ b/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
@@ -0,0 +1,166 @@
+// Test Suite for C-API GEOSPreparedDistance
+// geos
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut {
+// Test Group
+struct test_capigeosprepareddistancewithin_data : public capitest::utility {
+ const GEOSPreparedGeometry* pgeom1_;
+ test_capigeosprepareddistancewithin_data()
+ : pgeom1_(nullptr)
+ ~test_capigeosprepareddistancewithin_data()
+ GEOSPreparedGeom_destroy(pgeom1_);
+ void checkDistanceWithin(const char* wkt1, const char* wkt2,
+ double dist, char expectedResult)
+ geom1_ = GEOSGeomFromWKT(wkt1);
+ ensure(nullptr != geom1_);
+ pgeom1_ = GEOSPrepare(geom1_);
+ ensure(nullptr != pgeom1_);
+ geom2_ = GEOSGeomFromWKT(wkt2);
+ ensure(nullptr != geom2_);
+ int ret = GEOSPreparedDistanceWithin(pgeom1_, geom2_, dist);
+ ensure_equals("return code", (int)ret, (int)expectedResult);
+typedef test_group<test_capigeosprepareddistancewithin_data> group;
+group test_capigeosprepareddistancewithin_group("capi::GEOSPreparedDistanceWithin");
+// Test Cases
+template<>
+template<>
+ checkDistanceWithin(
+ "POLYGON EMPTY",
+ "POLYGON EMPTY",
+ std::numeric_limits<double>::infinity(),
+ 1
+template<>
+template<>
+void object::test<2>
+ "POLYGON((1 1,1 5,5 5,5 1,1 1))",
+ "POLYGON((8 8, 9 9, 9 10, 8 8))",
+ 4.25,
+ 1
+template<>
+template<>
+void object::test<3>
+ "POINT(2 2)",
+ 0,
+ 1
+template<>
+template<>
+void object::test<4>
+ "LINESTRING(1 5,5 5,5 1,1 1)",
+ "POINT(2 2)",
+ 1,
+ 1
+template<>
+template<>
+void object::test<5>
+ "LINESTRING(0 0,10 10)",
+ "LINESTRING(0 10,10 0)",
+ 0,
+ 1
+template<>
+template<>
+void object::test<6>
+ "POLYGON((0 0,10 0,10 10,0 10,0 0))",
+ "LINESTRING(8 5,12 5)",
+ 0,
+ 1
+template<>
+template<>
+void object::test<7>
+ "LINESTRING EMPTY",
+ "POINT EMPTY",
+ 1
+template<>
+template<>
+void object::test<8>
+ "POINT EMPTY",
+ 1
+} // namespace tut
Summary of changes:
NEWS | 3 ++
capi/geos_c.cpp | 12 +++++
capi/geos_c.h.in | 44 +++++++++++++++-
capi/geos_ts_c.cpp | 20 ++++++++
tests/unit/capi/GEOSDistanceWithinTest.cpp | 55 ++++++++++++++++++++
...Test.cpp => GEOSPreparedDistanceWithinTest.cpp} | 58 ++++++++++++----------
6 files changed, 165 insertions(+), 27 deletions(-)
create mode 100644 tests/unit/capi/GEOSDistanceWithinTest.cpp
copy tests/unit/capi/{GEOSPreparedDistanceTest.cpp => GEOSPreparedDistanceWithinTest.cpp} (61%)
hooks/post-receive
More information about the geos-commits
