[geos-commits] [SCM] GEOS branch main updated. bf18ba807b775f429bbbc62d5eed4fe24390cee7
git at osgeo.org
git at osgeo.org
Mon Jul 10 15:35:07 PDT 2023
the project "GEOS".
The branch, main has been updated
via bf18ba807b775f429bbbc62d5eed4fe24390cee7 (commit)
via 17fd3b0ffcb7dac8a79ca35b1938760f444629cd (commit)
via 4d8d694a888b6584a8c14c8107f25b035af37001 (commit)
from 6bc91ff0f985abb96e44f1c8ef9cf010d9d2006c (commit)
revisions in full, below.
commit bf18ba807b775f429bbbc62d5eed4fe24390cee7
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Jul 10 15:34:00 2023 -0700
Make line intersection computation more robust (#937)
diff --git a/src/algorithm/Intersection.cpp b/src/algorithm/Intersection.cpp
index 6a69596de..e23c33dcc 100644
--- a/src/algorithm/Intersection.cpp
+++ b/src/algorithm/Intersection.cpp
@@ -16,6 +16,7 @@
#include <vector>
#include <geos/algorithm/Intersection.h>
+#include <geos/algorithm/CGAlgorithmsDD.h>
namespace geos {
namespace algorithm { // geos.algorithm
@@ -26,59 +27,7 @@ geom::CoordinateXY
Intersection::intersection(const geom::CoordinateXY& p1, const geom::CoordinateXY& p2,
const geom::CoordinateXY& q1, const geom::CoordinateXY& q2)
- double minX0 = p1.x < p2.x ? p1.x : p2.x;
- double minY0 = p1.y < p2.y ? p1.y : p2.y;
- double maxX0 = p1.x > p2.x ? p1.x : p2.x;
- double maxY0 = p1.y > p2.y ? p1.y : p2.y;
- double minX1 = q1.x < q2.x ? q1.x : q2.x;
- double minY1 = q1.y < q2.y ? q1.y : q2.y;
- double maxX1 = q1.x > q2.x ? q1.x : q2.x;
- double maxY1 = q1.y > q2.y ? q1.y : q2.y;
- double intMinX = minX0 > minX1 ? minX0 : minX1;
- double intMaxX = maxX0 < maxX1 ? maxX0 : maxX1;
- double intMinY = minY0 > minY1 ? minY0 : minY1;
- double intMaxY = maxY0 < maxY1 ? maxY0 : maxY1;
- double midx = (intMinX + intMaxX) / 2.0;
- double midy = (intMinY + intMaxY) / 2.0;
- // condition ordinate values by subtracting midpoint
- double p1x = p1.x - midx;
- double p1y = p1.y - midy;
- double p2x = p2.x - midx;
- double p2y = p2.y - midy;
- double q1x = q1.x - midx;
- double q1y = q1.y - midy;
- double q2x = q2.x - midx;
- double q2y = q2.y - midy;
- // unrolled computation using homogeneous coordinates eqn
- double px = p1y - p2y;
- double py = p2x - p1x;
- double pw = p1x * p2y - p2x * p1y;
- double qx = q1y - q2y;
- double qy = q2x - q1x;
- double qw = q1x * q2y - q2x * q1y;
- double x = py * qw - qy * pw;
- double y = qx * pw - px * qw;
- double w = px * qy - qx * py;
- double xInt = x/w;
- double yInt = y/w;
- geom::CoordinateXY rv;
- // check for parallel lines
- if (!std::isfinite(xInt) || !std::isfinite(yInt)) {
- rv.setNull();
- return rv;
- // de-condition intersection point
- rv.x = xInt + midx;
- rv.y = yInt + midy;
- return rv;
+ return CGAlgorithmsDD::intersection(p1, p2, q1, q2);
diff --git a/tests/unit/algorithm/RobustLineIntersectionTest.cpp b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
index 8ee79e294..595dbd79f 100644
--- a/tests/unit/algorithm/RobustLineIntersectionTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
@@ -305,25 +305,21 @@ void object::test<2>
// but apparently works now.
// Possibly normalization has fixed this?
-#if 0 // fails: finds 1 intersection rather then two
template<>
template<>
void object::test<3>
std::vector<Coordinate> intPt;
- intPt.push_back(Coordinate(2089426.5233462777, 1180182.3877339689));
- intPt.push_back(Coordinate(2085646.6891757075, 1195618.7333999649));
+ intPt.push_back(Coordinate(2087600.4716727887, 1187639.7426241424));
checkIntersection(
"LINESTRING ( 2089426.5233462777 1180182.3877339689, 2085646.6891757075 1195618.7333999649 )",
"LINESTRING ( 1889281.8148903656 1997547.0560044837, 2259977.3672235999 483675.17050843034 )",
- 2,
+ 1,
intPt, 0);
-#endif // fails
-#if 0 // fails: the intersection point doesn't match
// 4 - Outside envelope using HCoordinate method (testCmp5CaseWKT)
template<>
template<>
@@ -331,7 +327,7 @@ void object::test<4>
- intPt.push_back(Coordinate(4348437.0557510145, 5552597.375203926));
+ intPt.push_back(Coordinate(4348440.8493873989, 5552599.2720221197));
checkIntersection(
"LINESTRING (4348433.262114629 5552595.478385733, 4348440.849387404 5552599.272022122 )",
@@ -339,9 +335,7 @@ void object::test<4>
1,
intPt, 0);
-#endif // fails
// 5 - Result of this test should be the same as the WKT one!
// (testCmp5CaseRaw)
template<>
@@ -356,11 +350,10 @@ void object::test<5>
pt.push_back(Coordinate(4348440.8493874, 5552599.27202212));
checkIntersection(pt, 1, intPt, 0);
-#endif // fails
* Test involving two non-almost-parallel lines.
@@ -453,7 +446,7 @@ void object::test<10>
"LINESTRING (-215.22279674875 -158.65425425385, -218.1208801283 -160.68343590235)",
1,
"POINT ( -215.22279674875 -158.65425425385 )",
- 0);
+ 1.0e-10);
diff --git a/tests/unit/operation/relate/RelateOpTest.cpp b/tests/unit/operation/relate/RelateOpTest.cpp
index f65cd9a6f..9c75fd33b 100644
--- a/tests/unit/operation/relate/RelateOpTest.cpp
+++ b/tests/unit/operation/relate/RelateOpTest.cpp
@@ -120,5 +120,28 @@ void object::test<3>()
+// see https://github.com/locationtech/jts/issues/396
+// testContainsNoding
+template<>
+template<>
+void object::test<4> ()
+ checkRelate(
+ "LINESTRING (1 0, 0 2, 0 0, 2 2)",
+ "LINESTRING (0 0, 2 2)",
+ "101F00FF2" );
+// see https://github.com/libgeos/geos/issues/933
+template<>
+template<>
+void object::test<5> ()
+ checkRelate(
+ "MULTILINESTRING ((0 0, 1 1), (0.5 0.5, 1 0.1, -1 0.1))",
+ "LINESTRING (0 0, 1 1)",
+ "1F1000FF2" );
} // namespace tut
diff --git a/tests/xmltester/tests/general/TestRelateLL.xml b/tests/xmltester/tests/general/TestRelateLL.xml
index 4c05b6664..4a4fb4289 100644
--- a/tests/xmltester/tests/general/TestRelateLL.xml
+++ b/tests/xmltester/tests/general/TestRelateLL.xml
@@ -1,5 +1,4 @@
<run>
- <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/>
<case>
<desc>LL - disjoint, non-overlapping envelopes</desc>
@@ -308,7 +307,7 @@
</case>
<case>
-<desc>LA - closed multiline / empty line</desc>
+<desc>LL - closed multiline / empty line</desc>
<a>
MULTILINESTRING ((0 0, 0 1), (0 1, 1 1, 1 0, 0 0))
</a>
@@ -320,4 +319,50 @@
</test>
</case>
+<case>
+<desc>LL - test intersection node computation (see https://github.com/locationtech/jts/issues/396)</desc>
+ <a>
+ LINESTRING (1 0, 0 2, 0 0, 2 2)
+ </a>
+ <b>
+ LINESTRING (0 0, 2 2)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="101F00FF2">true</op>
+ </test>
+ <test><op name="contains" arg1="A" arg2="B"> true </op></test>
+ <test><op name="coveredBy" arg1="A" arg2="B"> false </op></test>
+ <test><op name="covers" arg1="A" arg2="B"> true </op></test>
+ <test><op name="crosses" arg1="A" arg2="B"> false </op></test>
+ <test><op name="disjoint" arg1="A" arg2="B"> false </op></test>
+ <test><op name="equalsTopo" arg1="A" arg2="B"> false </op></test>
+ <test><op name="intersects" arg1="A" arg2="B"> true </op></test>
+ <test><op name="overlaps" arg1="A" arg2="B"> false </op></test>
+ <test><op name="touches" arg1="A" arg2="B"> false </op></test>
+ <test><op name="within" arg1="A" arg2="B"> false </op></test>
+</case>
+<case>
+<desc>LL - test intersection node computation (see https://github.com/libgeos/geos/issues/933)</desc>
+ <a>
+ MULTILINESTRING ((0 0, 1 1), (0.5 0.5, 1 0.1, -1 0.1))
+ </a>
+ <b>
+ LINESTRING (0 0, 1 1)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1F1000FF2">true</op>
+ </test>
+</case>
</run>
diff --git a/tests/xmltester/tests/issue/issue-geos-398.xml b/tests/xmltester/tests/issue/issue-geos-398.xml
index 3143f09e0..edb3984ef 100644
--- a/tests/xmltester/tests/issue/issue-geos-398.xml
+++ b/tests/xmltester/tests/issue/issue-geos-398.xml
@@ -32,9 +32,8 @@ POLYGON ((50.0044466166182886 0.0,
</b>
<test>
<op name="union" arg1="A" arg2="B">
-MULTIPOLYGON (((0 25.950779066386122, 0 26.860827855779647, 0 29.83879230192533, 0 35.73921397193218, 60 13.183894681853793, 60 10.39852836763784, 60 7.802134559422377, 60 6.657099879646016, 60 6.510515132098641, 60 0, 55.31611974965083 0, 50.00444661661829 0, 43.31611974965083 0, 0 0, 0 14.034613342373582, 0 17.92266612923108, 0 21.587486526024364, 0 25.950779066386122),
- (0 21.587486526024364, 34.025852439655786 6.898140262297274, 34.02585243965579 6.898140262297273, 0 21.587486526024364)),
- ((13.44557253233479 36, 60 36, 60 16.794451829809802, 60 16.36440115550932, 60 14.043996030454757, 2.9187843276549756 36, 11.8945390820011 36, 13.44557253233479 36)))
+MULTIPOLYGON (((0 26.860827855779647, 0 29.83879230192533, 0 35.73921397193218, 60 13.183894681853793, 60 10.39852836763784, 60 7.802134559422377, 60 6.657099879646016, 60 6.510515132098641, 60 0, 55.31611974965083 0, 50.00444661661829 0, 43.31611974965083 0, 0 0, 0 14.034613342373582, 0 17.92266612923108, 0 21.587486526024364, 0 25.950779066386122, 0 26.860827855779647)),
+ ((60 36, 60 16.794451829809802, 60 16.36440115550932, 60 14.043996030454757, 2.9187843276549756 36, 11.8945390820011 36, 13.44557253233479 36, 60 36)))
</op>
</test>
</case>
diff --git a/tests/xmltester/tests/robust/overlay/TestOverlay-pg-list.xml b/tests/xmltester/tests/robust/overlay/TestOverlay-pg-list.xml
index 66f488591..f5f9e69ee 100644
--- a/tests/xmltester/tests/robust/overlay/TestOverlay-pg-list.xml
+++ b/tests/xmltester/tests/robust/overlay/TestOverlay-pg-list.xml
@@ -47,7 +47,7 @@ MULTIPOLYGON (((742591.4178018438 5087769.04526206, 742591.417801844 5087769.045
<test>
<op name="intersection" arg1="A" arg2="B">
-MULTIPOLYGON (((434608.9999999999 2012571.9999999907, 434608.99999999977 2012571.9999999907, 434505.9999999997 2013031.9999999907, 434889.4374999999 2013081.8073453507, 434506 2013031.99999999, 434608.9999999999 2012571.9999999907)), ((434990.9999999999 2013094.99999999, 435264.9999999997 2013496.9999999898, 435311.2499999999 2013535.9783236892, 435265 2013496.99999999, 434991 2013094.99999999, 434990.9999999999 2013094.99999999)), ((436813.9999999997 2014014.99999999, 436802.9999999997 2014278.9999999893, 436803 2014278.9999999893, 436814 2014014.99999999, 436813.9999999997 2014014.99999999)), ((437427.6587183307 2014442.90461996, 437488.99999999977 2014458.99999999, 437372.9999999997 2016223.9999999898, 437686.7499999999 2016676.926282041, 437373 2016223.99999999, 437489 2014458.99999999, 437427.6587183307 2014442.90461996)))
+MULTIPOLYGON (((437372.9999999997 2016223.9999999898, 437686.7499999997 2016676.9262820408, 437373 2016223.99999999, 437489 2014458.99999999, 437427.6587183306 2014442.90461996, 437488.99999999977 2014458.99999999, 437372.9999999997 2016223.9999999898)), ((434990.9999999999 2013094.99999999, 435264.9999999997 2013496.9999999898, 435311.2499999997 2013535.9783236892, 435265 2013496.99999999, 434991 2013094.99999999, 434990.9999999999 2013094.99999999)), ((434505.9999999997 2013031.9999999907, 434889.4374999997 2013081.8073453507, 434506 2013031.99999999, 434608.9999999999 2012571.9999999907, 434608.99999999977 2012571.9999999907, 434505.9999999997 2013031.9999999907)), ((436802.9999999997 2014278.9999999893, 436803 2014278.9999999893, 436814 2014014.99999999, 436813.9999999997 2014014.99999999, 436802.9999999997 2014278.9999999893)))
</op>
</test>
commit 17fd3b0ffcb7dac8a79ca35b1938760f444629cd
Date: Mon Jul 3 09:54:55 2023 -0700
Update NEWS.md
diff --git a/NEWS.md b/NEWS.md
index b3b2d3fa3..d447cbf42 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -68,6 +68,7 @@
- GEOSIntersection: Fix FE_INVALID exception on intersection of disjoint geometries
(GH-791, Joris Van den Bossche & Dan Baston)
- Fix incorrect result from Envelope::disjoint (GH-791, Dan Baston)
+ - Fix handling of odd cases in PolygonHoleJoiner (JTS-946, Paul Ramsey, Martin Davis)
- Polygonizer: Fix duplicate lines return by getInvalidRingLines (GH-782, Martin Davis & Dan Baston)
- GEOSUnaryUnion: Fix crash on collection containing empty point (GH-830, Dan Baston)
- GEOSBuffer: Fix crash with Inf coordinates (GH-822, Dan Baston)
commit 4d8d694a888b6584a8c14c8107f25b035af37001
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sat Jul 1 10:42:51 2023 -0700
Fix final WKB test, GH-934
diff --git a/tests/unit/capi/GEOSWKBWriterTest.cpp b/tests/unit/capi/GEOSWKBWriterTest.cpp
index 9b49cba8f..2f3e041d6 100644
--- a/tests/unit/capi/GEOSWKBWriterTest.cpp
+++ b/tests/unit/capi/GEOSWKBWriterTest.cpp
@@ -38,8 +38,9 @@ template<>
template<>
void object::test<1>()
+ GEOSWKBWriter_setByteOrder(wkbwriter_, GEOS_WKB_XDR);
ensure_equals(GEOSWKBWriter_getIncludeSRID(wkbwriter_), 0);
- ensure_equals(GEOSWKBWriter_getByteOrder(wkbwriter_), getMachineByteOrder());
+ ensure_equals(GEOSWKBWriter_getByteOrder(wkbwriter_), GEOS_WKB_XDR);
ensure_equals(GEOSWKBWriter_getFlavor(wkbwriter_), GEOS_WKB_EXTENDED);
ensure_equals(GEOSWKBWriter_getOutputDimension(wkbwriter_), 4);
Summary of changes:
NEWS.md | 1 +
src/algorithm/Intersection.cpp | 55 +---------------------
.../unit/algorithm/RobustLineIntersectionTest.cpp | 17 ++-----
tests/unit/capi/GEOSWKBWriterTest.cpp | 3 +-
tests/unit/operation/relate/RelateOpTest.cpp | 23 +++++++++
tests/xmltester/tests/general/TestRelateLL.xml | 49 ++++++++++++++++++-
tests/xmltester/tests/issue/issue-geos-398.xml | 5 +-
.../tests/robust/overlay/TestOverlay-pg-list.xml | 2 +-
8 files changed, 83 insertions(+), 72 deletions(-)
hooks/post-receive
More information about the geos-commits
