[geos-commits] [SCM] GEOS branch main updated. 193dacad1128de3a9be032eaf13a0f4081fcae76
git at osgeo.org
git at osgeo.org
Mon Jul 31 16:55:32 PDT 2023
the project "GEOS".
The branch, main has been updated
via 193dacad1128de3a9be032eaf13a0f4081fcae76 (commit)
from 3d4870f7970dfac1b090e8a0d05d9b969a9d1180 (commit)
revisions in full, below.
commit 193dacad1128de3a9be032eaf13a0f4081fcae76
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Jul 31 14:55:51 2023 -0700
Fix PolygonNodeTopology unit tests
diff --git a/tests/unit/algorithm/PolygonNodeTopologyTest.cpp b/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
index 93b0f3b7d..720349164 100644
--- a/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
+++ b/tests/unit/algorithm/PolygonNodeTopologyTest.cpp
@@ -31,13 +31,19 @@ struct test_polygonnodetopology_data {
checkCrossing(wktA, wktB, true);
+ void
+ checkNonCrossing(const std::string& wktA, const std::string& wktB)
+ checkCrossing(wktA, wktB, false);
void
checkCrossing(const std::string& wktA, const std::string& wktB, bool isExpected)
std::unique_ptr<CoordinateSequence> a = readPts(wktA);
std::unique_ptr<CoordinateSequence> b = readPts(wktB);
// assert: a[1] = b[1]
- bool isCrossing = ! PolygonNodeTopology::isCrossing(
+ bool isCrossing = PolygonNodeTopology::isCrossing(
&a->getAt(1), &a->getAt(0), &a->getAt(2), &b->getAt(0), &b->getAt(2));
ensure(isCrossing == isExpected);
@@ -60,7 +66,7 @@ struct test_polygonnodetopology_data {
- bool isInterior = ! PolygonNodeTopology::isInteriorSegment(
+ bool isInterior = PolygonNodeTopology::isInteriorSegment(
&a->getAt(1), &a->getAt(0), &a->getAt(2), &b->getAt(1));
ensure(isInterior == isExpected);
@@ -94,30 +100,30 @@ void object::test<1> ()
checkCrossing(
"LINESTRING (500 1000, 1000 1000, 1000 1500)",
- "LINESTRING (1000 500, 1000 1000, 500 1500)", false);
+ "LINESTRING (1000 500, 1000 1000, 500 1500)");
-// testCrossingQuadrant2
+// testNonCrossingQuadrant2
template<>
template<>
void object::test<2> ()
- checkCrossing(
+ checkNonCrossing(
"LINESTRING (300 1200, 1000 1000, 500 1500)");
-// testCrossingQuadrant4
+// testNonCrossingQuadrant4
template<>
template<>
void object::test<3> ()
- checkCrossing(
+ checkNonCrossing(
"LINESTRING (1000 500, 1000 1000, 1500 1000)");
@@ -131,7 +137,7 @@ void object::test<4> ()
checkInterior(
"LINESTRING (5 9, 5 5, 9 5)",
- "LINESTRING (5 5, 9 9)");
+ "LINESTRING (5 5, 0 0)");
@@ -143,7 +149,7 @@ void object::test<5> ()
checkExterior(
- "LINESTRING (5 5, 0 0)");
+ "LINESTRING (5 5, 9 9)");
} // namespace tut
Summary of changes:
tests/unit/algorithm/PolygonNodeTopologyTest.cpp | 24 +++++++++++++++---------
1 file changed, 15 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
