[geos-commits] [SCM] GEOS branch main updated. e4639e4d5be1f8199d2864622f53f43a58e62bb1
git at osgeo.org
git at osgeo.org
Wed Jun 7 08:45:18 PDT 2023
the project "GEOS".
The branch, main has been updated
via e4639e4d5be1f8199d2864622f53f43a58e62bb1 (commit)
from 335cf85d0a66540bcf4474a00f9f39c1084976b3 (commit)
revisions in full, below.
commit e4639e4d5be1f8199d2864622f53f43a58e62bb1
Author: Mike Taves <mwtoews at gmail.com>
Date: Thu Jun 8 03:44:47 2023 +1200
Change WKTWriter default output dimension to 4 and trim to 'on' (#915)
diff --git a/NEWS.md b/NEWS.md
index 7e3c57ba1..d3ad2efed 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -74,6 +74,7 @@ xxxx-xx-xx
- Remove Orientation.isCCW exception to simplify logic and align with JTS (GH-878, Martin Davis)
- Change MultiPoint WKT to use parentheses in sub-members (GH-903, Mike Taves)
- Change WKBWriter default output dimension to 4 (GH-908, Mike Taves)
+ - Change WKTWriter defaults output dimension to 4 and trim to 'on' (GH-915, Mike Taves)
## Changes in 3.11.0
2022-07-01
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 76e508e5a..385f744f5 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -5412,8 +5412,9 @@ extern char GEOS_DLL *GEOSWKTWriter_write(
* With trim set to 1, the writer will strip trailing 0's from
* the output coordinates. With 0, all coordinates will be
* padded with 0's out to the rounding precision.
+* Default since GEOS 3.12 is with trim set to 1 for 'on'.
* \param writer A \ref GEOSWKTWriter.
-* \param trim The trimming behaviour to set, 1 for 'on', 0 for 'off', default 'off'
+* \param trim The trimming behaviour to set, 1 for 'on', 0 for 'off'
* \since 3.3
@@ -5434,10 +5435,10 @@ extern void GEOS_DLL GEOSWKTWriter_setRoundingPrecision(
int precision);
-* Sets whether or not to write out XY or XYZ coordinates.
-* Legal values are 2 or 3.
+* Set the output dimensionality of the writer. Either
+* 2, 3, or 4 dimensions. Default since GEOS 3.12 is 4.
-* \param dim The desired dimension, default 2.
+* \param dim The dimensionality desired.
* \since 3.3
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 710004c4e..64df095e5 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -935,7 +935,11 @@ extern "C" {
GEOSGeomToWKT_r(GEOSContextHandle_t extHandle, const Geometry* g1)
return execute(extHandle, [&]() {
- char* result = gstrdup(g1->toString());
+ // Deprecated, show untrimmed 2D output
+ geos::io::WKTWriter writer;
+ writer.setTrim(false);
+ writer.setOutputDimension(2);
+ char* result = gstrdup(writer.write(g1));
return result;
diff --git a/include/geos/io/WKTWriter.h b/include/geos/io/WKTWriter.h
index 54463d790..09f6184ef 100644
--- a/include/geos/io/WKTWriter.h
+++ b/include/geos/io/WKTWriter.h
@@ -161,7 +161,7 @@ public:
* Enable old style 3D/4D WKT generation.
- * By default the WKBWriter produces new style 3D/4D WKT
+ * By default the WKTWriter produces new style 3D/4D WKT
* (ie. "POINT Z (10 20 30)") but if this method is used
* to turn on old style WKT production then the WKT will
* be formatted in the style "POINT (10 20 30)".
@@ -177,7 +177,7 @@ public:
* \brief
* Returns the output dimension used by the
- * <code>WKBWriter</code>.
+ * <code>WKTWriter</code>.
int
getOutputDimension() const
@@ -186,11 +186,12 @@ public:
- * Sets the output dimension used by the <code>WKBWriter</code>.
+ * Sets the output dimension used by the <code>WKTWriter</code>.
- * @param newOutputDimension Supported values are 2 or 3.
+ * @param newOutputDimension Supported values are 2, 3 or 4.
+ * Default since GEOS 3.12 is 4.
* Note that 3 indicates up to 3 dimensions will be
- * written but 2D WKB is still produced for 2D geometries.
+ * written but 2D WKT is still produced for 2D geometries.
void setOutputDimension(uint8_t newOutputDimension);
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index 50f1737e3..d514e4d36 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -454,6 +454,9 @@ std::string
Geometry::toText() const
+ // To enable "GEOS<3.12" outputs, uncomment the following:
+ // writer.setTrim(false);
+ // writer.setOutputDimension(2);
return writer.write(this);
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 90847c0d1..77d4b20dc 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -57,9 +57,9 @@ WKTWriter::WKTWriter():
decimalPlaces(6),
isFormatted(false),
roundingPrecision(-1),
- trim(false),
+ trim(true),
level(0),
- defaultOutputDimension(2),
+ defaultOutputDimension(4),
old3D(false)
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index e7de6f69d..bb2f17377 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -620,7 +620,6 @@ BufferBuilder::computeNodedEdges(SegmentString::NonConstVect& bufferSegStrList,
#if JTS_DEBUG
geos::io::WKTWriter wktWriter;
- wktWriter.setTrim(true);
std::cerr << "before noding: "
<< wktWriter.write(
convertSegStrings(geomFact, bufferSegStrList.begin(),
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index a2f7179ec..02cfb9311 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -184,8 +184,6 @@ OverlayNG::getResult()
#if GEOS_DEBUG
io::WKTWriter w;
- w.setOutputDimension(3);
- w.setTrim(true);
std::cerr << "Before populatingZ: " << w.write(result.get()) << std::endl;
#endif
diff --git a/tests/unit/capi/GEOSBufferTest.cpp b/tests/unit/capi/GEOSBufferTest.cpp
index 9c36cffc4..0c7cab962 100644
--- a/tests/unit/capi/GEOSBufferTest.cpp
+++ b/tests/unit/capi/GEOSBufferTest.cpp
@@ -25,7 +25,6 @@ struct test_capigeosbuffer_data : public capitest::utility {
test_capigeosbuffer_data()
: bp_(nullptr)
- GEOSWKTWriter_setTrim(wktw_, 1);
~test_capigeosbuffer_data()
diff --git a/tests/unit/capi/GEOSBuildAreaTest.cpp b/tests/unit/capi/GEOSBuildAreaTest.cpp
index 1ac7e3144..a06b7e72f 100644
--- a/tests/unit/capi/GEOSBuildAreaTest.cpp
+++ b/tests/unit/capi/GEOSBuildAreaTest.cpp
@@ -20,8 +20,6 @@ namespace tut {
struct test_capi_buildarea_data : public capitest::utility {
test_capi_buildarea_data()
- GEOSWKTWriter_setOutputDimension(wktw_, 3);
diff --git a/tests/unit/capi/GEOSClipByRectTest.cpp b/tests/unit/capi/GEOSClipByRectTest.cpp
index 1e6f4fe4c..27f27aa29 100644
--- a/tests/unit/capi/GEOSClipByRectTest.cpp
+++ b/tests/unit/capi/GEOSClipByRectTest.cpp
@@ -36,7 +36,6 @@ struct test_capigeosclipbyrect_data : public capitest::utility {
test_capigeosclipbyrect_data()
GEOSWKTWriter_setRoundingPrecision(wktw_, 8);
diff --git a/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp b/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
index e428134a4..81e3c7d90 100644
--- a/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
+++ b/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
@@ -20,7 +20,6 @@ namespace tut {
// Common data used in test cases.
struct test_capiconstrainedgeosdelaunaytriangulation_data : public capitest::utility {
test_capiconstrainedgeosdelaunaytriangulation_data() {
diff --git a/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp b/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
index 35c1e0502..c55f093fe 100644
--- a/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
+++ b/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
struct test_capigeosdelaunaytriangulation_data : public capitest::utility {
test_capigeosdelaunaytriangulation_data() {
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index 84f44e259..4c953c4bf 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -23,7 +23,6 @@ namespace tut {
struct test_capigeosdistance_data : public capitest::utility {
test_capigeosdistance_data() {
diff --git a/tests/unit/capi/GEOSFrechetDistanceTest.cpp b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
index db3c3cc8c..ab79a48ac 100644
--- a/tests/unit/capi/GEOSFrechetDistanceTest.cpp
+++ b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
@@ -21,7 +21,6 @@ namespace tut {
struct test_capigeosfrechetdistance_data : public capitest::utility {
test_capigeosfrechetdistance_data() {
diff --git a/tests/unit/capi/GEOSGeomToWKBTest.cpp b/tests/unit/capi/GEOSGeomToWKBTest.cpp
index e9679ad25..e445e47a5 100644
--- a/tests/unit/capi/GEOSGeomToWKBTest.cpp
+++ b/tests/unit/capi/GEOSGeomToWKBTest.cpp
@@ -41,7 +41,6 @@ struct test_capigeosgeomtowkb_data : public capitest::utility {
GEOSWKTWriter* wktwriter = GEOSWKTWriter_create();
GEOSWKTWriter_setRoundingPrecision(wktwriter, 3);
- GEOSWKTWriter_setTrim(wktwriter, 1);
GEOSWKTWriter_setOutputDimension(wktwriter, 3);
char* wkt_c = GEOSWKTWriter_write(wktwriter, geom2_);
GEOSWKTWriter_destroy(wktwriter);
diff --git a/tests/unit/capi/GEOSGeomToWKTTest.cpp b/tests/unit/capi/GEOSGeomToWKTTest.cpp
index 72f3941de..548da91ea 100644
--- a/tests/unit/capi/GEOSGeomToWKTTest.cpp
+++ b/tests/unit/capi/GEOSGeomToWKTTest.cpp
@@ -23,12 +23,13 @@ struct test_capigeosgeomtowkt_data : public capitest::utility {
void
test_wkt(std::string const& wkt)
- geom1_ = GEOSGeomFromWKT(wkt.c_str());
- ensure(nullptr != geom1_);
+ GEOSGeometry* geom1 = GEOSGeomFromWKT(wkt.c_str());
+ ensure(nullptr != geom1);
- char* wkt_c = GEOSGeomToWKT(geom1_);
+ char* wkt_c = GEOSGeomToWKT(geom1);
std::string out(wkt_c);
free(wkt_c);
+ GEOSGeom_destroy(geom1);
ensure_equals(out, wkt);
@@ -36,12 +37,13 @@ struct test_capigeosgeomtowkt_data : public capitest::utility {
void
test_wkt(std::string const& wkt, std::string::size_type n)
free(wkt_c);
ensure_equals(out.substr(0, n), wkt.substr(0, n));
@@ -105,14 +107,18 @@ void object::test<6>
// Comparing string based on float-point numbers does not make sense,
-// so make poor-man comparison of WKT type tag.
+// so make poor-man comparison of WKT type tag and first few numbers
template<>
template<>
void object::test<7>
- test_wkt("POINT (1.234 5.678)", 7);
+ test_wkt("POINT (1.234000 5.678)", 15);
+ // check default OutputDimension(2) with higher dimension points
+ test_wkt("POINT (1.234000 5.678 9)", 15); // POINT Z
+ test_wkt("POINT (1.234000 5.678 9 10)", 15); // POINT ZM
template<>
@@ -120,7 +126,7 @@ template<>
void object::test<8>
- test_wkt("LINESTRING (0 0, 5 5, 10 5, 10 10)", 13);
+ test_wkt("LINESTRING (0.000 0, 5 5, 10 5, 10 10)", 17);
template<>
@@ -128,7 +134,7 @@ template<>
void object::test<9>
- test_wkt("POLYGON ((0 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10))", 11);
+ test_wkt("POLYGON ((0.000 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10))", 15);
template<>
@@ -136,7 +142,7 @@ template<>
void object::test<10>
- test_wkt("MULTIPOINT ((0 0), (5 5), (10 10), (15 15), (20 20))", 13);
+ test_wkt("MULTIPOINT ((0.000 0), (5 5), (10 10), (15 15), (20 20))", 17);
template<>
@@ -144,7 +150,7 @@ template<>
void object::test<11>
- test_wkt("MULTILINESTRING ((0 0, 10 0, 10 10, 0 10, 10 20),(2 2, 2 6, 6 4, 20 2))", 19);
+ test_wkt("MULTILINESTRING ((0.000 0, 10 0, 10 10, 0 10, 10 20),(2 2, 2 6, 6 4, 20 2))", 23);
template<>
@@ -152,7 +158,7 @@ template<>
void object::test<12>
- test_wkt("MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0),(2 2, 2 6, 6 4, 2 2)),((60 60, 60 50, 70 40, 60 60)))", 17);
+ test_wkt("MULTIPOLYGON (((0.000 0, 10 0, 10 10, 0 10, 0 0),(2 2, 2 6, 6 4, 2 2)),((60 60, 60 50, 70 40, 60 60)))", 21);
} // namespace tut
diff --git a/tests/unit/capi/GEOSGetCentroidTest.cpp b/tests/unit/capi/GEOSGetCentroidTest.cpp
index 3ea672c4e..96b6334be 100644
--- a/tests/unit/capi/GEOSGetCentroidTest.cpp
+++ b/tests/unit/capi/GEOSGetCentroidTest.cpp
struct test_capicentroid_data : public capitest::utility {
test_capicentroid_data() {
GEOSWKTWriter_setRoundingPrecision(wktw_, 6);
diff --git a/tests/unit/capi/GEOSHausdorffDistanceTest.cpp b/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
index b56888c8a..3cddf2424 100644
--- a/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
+++ b/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
struct test_capigeoshausdorffdistance_data : public capitest::utility {
test_capigeoshausdorffdistance_data() {
diff --git a/tests/unit/capi/GEOSIntersectionPrecTest.cpp b/tests/unit/capi/GEOSIntersectionPrecTest.cpp
index 135bf448e..0d38e06ac 100644
--- a/tests/unit/capi/GEOSIntersectionPrecTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionPrecTest.cpp
struct test_capigeosintersectionprec_data : public capitest::utility {
test_capigeosintersectionprec_data() {
static int
diff --git a/tests/unit/capi/GEOSIntersectionTest.cpp b/tests/unit/capi/GEOSIntersectionTest.cpp
index 915510518..94d209e26 100644
--- a/tests/unit/capi/GEOSIntersectionTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionTest.cpp
@@ -13,8 +13,6 @@ namespace tut {
struct test_capigeosintersection_data : public capitest::utility
test_capigeosintersection_data() {
diff --git a/tests/unit/capi/GEOSMakeValidTest.cpp b/tests/unit/capi/GEOSMakeValidTest.cpp
index 7382fe7ca..c28d14606 100644
--- a/tests/unit/capi/GEOSMakeValidTest.cpp
+++ b/tests/unit/capi/GEOSMakeValidTest.cpp
@@ -21,8 +21,6 @@ namespace tut {
struct test_capimakevalid_data : public capitest::utility {
test_capimakevalid_data() {
diff --git a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
index f4f3e580c..556c9a993 100644
--- a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
+++ b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
@@ -25,7 +25,6 @@ struct test_capimaximuminscribedcircle_data : public capitest::utility {
test_capimaximuminscribedcircle_data()
: wkt_(nullptr)
diff --git a/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp b/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
index 61d02e348..3bfd6326a 100644
--- a/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
+++ b/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
@@ -22,7 +22,6 @@ namespace tut {
struct test_capiminimumboundingcircle_data : public capitest::utility {
test_capiminimumboundingcircle_data()
diff --git a/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp b/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
index e8251f466..a71462d86 100644
--- a/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
+++ b/tests/unit/capi/GEOSMinimumRotatedRectangleTest.cpp
@@ -19,7 +19,6 @@ namespace tut {
struct test_minimumrotatedrectangle_data : public capitest::utility {
test_minimumrotatedrectangle_data() {
diff --git a/tests/unit/capi/GEOSMinimumWidthTest.cpp b/tests/unit/capi/GEOSMinimumWidthTest.cpp
index 3d27c3b41..bad070c10 100644
--- a/tests/unit/capi/GEOSMinimumWidthTest.cpp
+++ b/tests/unit/capi/GEOSMinimumWidthTest.cpp
struct test_capigeosminimumwidth_data : public capitest::utility {
test_capigeosminimumwidth_data()
diff --git a/tests/unit/capi/GEOSNodeTest.cpp b/tests/unit/capi/GEOSNodeTest.cpp
index 96295b23f..abda612bb 100644
--- a/tests/unit/capi/GEOSNodeTest.cpp
+++ b/tests/unit/capi/GEOSNodeTest.cpp
struct test_capigeosnode_data : public capitest::utility {
test_capigeosnode_data()
@@ -140,7 +139,6 @@ void object::test<6>
GEOSNormalize(result_);
GEOSNormalize(expected_);
auto wkt_result = GEOSWKTWriter_write(wktw_, result_);
auto wkt_expected = GEOSWKTWriter_write(wktw_, expected_);
@@ -167,7 +165,6 @@ void object::test<7>
@@ -194,7 +191,6 @@ void object::test<8>
- GEOSWKTWriter_setOutputDimension(wktw_, 4);
diff --git a/tests/unit/capi/GEOSOffsetCurveTest.cpp b/tests/unit/capi/GEOSOffsetCurveTest.cpp
index 052a5f9df..d5ddfb8f6 100644
--- a/tests/unit/capi/GEOSOffsetCurveTest.cpp
+++ b/tests/unit/capi/GEOSOffsetCurveTest.cpp
struct test_capioffsetcurve_data : public capitest::utility {
test_capioffsetcurve_data() {
void debugOutput (const char* label, GEOSGeometry* geom)
diff --git a/tests/unit/capi/GEOSPointOnSurfaceTest.cpp b/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
index 14d834ee9..65f885e3d 100644
--- a/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
+++ b/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
struct test_capipointonsurface_data : public capitest::utility {
test_capipointonsurface_data()
GEOSWKTWriter_setRoundingPrecision(wktw_, 4);
diff --git a/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp b/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
index dcecc63c0..8d6c9c2c6 100644
--- a/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
+++ b/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
struct test_capiremoverepeatedpoints_data : public capitest::utility {
test_capiremoverepeatedpoints_data() {
diff --git a/tests/unit/capi/GEOSSharedPathsTest.cpp b/tests/unit/capi/GEOSSharedPathsTest.cpp
index 98f013b6a..0c16640bc 100644
--- a/tests/unit/capi/GEOSSharedPathsTest.cpp
+++ b/tests/unit/capi/GEOSSharedPathsTest.cpp
struct test_capigeossharedpaths_data : public capitest::utility {
test_capigeossharedpaths_data()
diff --git a/tests/unit/capi/GEOSSnapTest.cpp b/tests/unit/capi/GEOSSnapTest.cpp
index c3ccdf2fb..17d9da8f2 100644
--- a/tests/unit/capi/GEOSSnapTest.cpp
+++ b/tests/unit/capi/GEOSSnapTest.cpp
struct test_capigeossnap_data : public capitest::utility {
test_capigeossnap_data()
diff --git a/tests/unit/capi/GEOSUnaryUnionPrecTest.cpp b/tests/unit/capi/GEOSUnaryUnionPrecTest.cpp
index 21a33de25..0f873b9e3 100644
--- a/tests/unit/capi/GEOSUnaryUnionPrecTest.cpp
+++ b/tests/unit/capi/GEOSUnaryUnionPrecTest.cpp
struct test_capiunaryunionprec_data : public capitest::utility {
test_capiunaryunionprec_data() {
diff --git a/tests/unit/capi/GEOSUnaryUnionTest.cpp b/tests/unit/capi/GEOSUnaryUnionTest.cpp
index 095e16c3e..e164bbd39 100644
--- a/tests/unit/capi/GEOSUnaryUnionTest.cpp
+++ b/tests/unit/capi/GEOSUnaryUnionTest.cpp
struct test_capiunaryunion_data : public capitest::utility {
test_capiunaryunion_data() {
diff --git a/tests/unit/capi/GEOSVoronoiDiagramTest.cpp b/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
index f1c6b4e9e..c8843ac23 100644
--- a/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
+++ b/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
struct test_capigeosvoronoidiagram_data : public capitest::utility {
test_capigeosvoronoidiagram_data() {
diff --git a/tests/unit/capi/GEOSWKTWriterTest.cpp b/tests/unit/capi/GEOSWKTWriterTest.cpp
index 200a40ffb..54b570d8b 100644
--- a/tests/unit/capi/GEOSWKTWriterTest.cpp
+++ b/tests/unit/capi/GEOSWKTWriterTest.cpp
@@ -24,15 +24,31 @@ struct test_geoswktwriter_data : public capitest::utility {
void
test_writer_wkt(std::string const& wkt)
- wkt_ = GEOSWKTWriter_write(wktwriter_, geom1_);
- std::string out(wkt_);
+ char* wkt_c = GEOSWKTWriter_write(wktwriter_, geom1);
+ std::string out(wkt_c);
+ free(wkt_c);
+ void
+ test_writer_wkt(std::string const& wkt, std::string const& expected)
+ free(wkt_c);
+ ensure_equals(out, expected);
GEOSWKTWriter* wktwriter_;
char* wkt_;
@@ -42,33 +58,108 @@ typedef group::object object;
group test_geoswktwriter("capi::GEOSWKTWriter");
+// Check default output dimension 4
template<>
template<>
void object::test<1>()
- ensure_equals(GEOSWKTWriter_getOutputDimension(wktwriter_), 2);
+ ensure_equals(GEOSWKTWriter_getOutputDimension(wktwriter_), 4);
+ test_writer_wkt("POINT (10 13)");
+ test_writer_wkt("POINT Z (10 13 3)");
+ test_writer_wkt("POINT M (10 13 5)");
+ test_writer_wkt("POINT ZM (10 13 3 5)");
+// Check writer with output dimension 2
template<>
template<>
void object::test<2>()
- GEOSWKTWriter_setTrim(wktwriter_, 1);
+ GEOSWKTWriter_setOutputDimension(wktwriter_, 2);
+ ensure_equals("getOutputDimension_2", GEOSWKTWriter_getOutputDimension(wktwriter_), 2);
+ test_writer_wkt("POINT Z (10 13 3)", "POINT (10 13)");
+ test_writer_wkt("POINT M (10 13 5)", "POINT (10 13)");
+ test_writer_wkt("POINT ZM (10 13 3 5)", "POINT (10 13)");
+// Check writer with output dimension 3
+template<>
+template<>
+void object::test<3>()
+ GEOSWKTWriter_setTrim(wktwriter_, 1); // redundant, but keep to ensure it stays trim
GEOSWKTWriter_setOutputDimension(wktwriter_, 3);
- ensure_equals("getOutputDimension_2", GEOSWKTWriter_getOutputDimension(wktwriter_), 3);
+ ensure_equals("getOutputDimension_3", GEOSWKTWriter_getOutputDimension(wktwriter_), 3);
+ test_writer_wkt("POINT M (10 13 3)");
+ test_writer_wkt("POINT ZM (10 13 3 5)", "POINT Z (10 13 3)");
+// Check Old3D with output dimension 3
template<>
template<>
-void object::test<3>()
+void object::test<4>()
+ GEOSWKTWriter_setOld3D(wktwriter_, 1);
+ test_writer_wkt("POINT (10 13 3)");
+ test_writer_wkt("POINT ZM (10 13 3 5)", "POINT (10 13 3)");
+// Check Old3D with default output dimension 4
+template<>
+template<>
+void object::test<5>()
+ test_writer_wkt("POINT (10 13 3 5)");
+// Check to get legacy default output before GEOS 3.12, showing untrimmed 2D WKT
+template<>
+template<>
+void object::test<6>()
+ GEOSWKTWriter_setTrim(wktwriter_, 0);
+ std::string expected("POINT (10.0000000000000000 13.0000000000000000)");
+ test_writer_wkt("POINT (10 13)", expected);
+ test_writer_wkt("POINT Z (10 13 3)", expected);
+ test_writer_wkt("POINT M (10 13 5)", expected);
+ test_writer_wkt("POINT ZM (10 13 3 5)", expected);
+// Check untrimmed WKT with a fixed precision
+template<>
+template<>
+void object::test<7>()
+ GEOSWKTWriter_setRoundingPrecision(wktwriter_, 2);
+ test_writer_wkt("POINT (10 13)", "POINT (10.00 13.00)");
+ test_writer_wkt("POINT Z (10 13 3)", "POINT Z (10.00 13.00 3.00)");
+ test_writer_wkt("POINT M (10 13 5)", "POINT M (10.00 13.00 5.00)");
+ test_writer_wkt("POINT ZM (10 13 3 5)", "POINT ZM (10.00 13.00 3.00 5.00)");
} // namespace tut
diff --git a/tests/unit/capi/GEOSisValidDetailTest.cpp b/tests/unit/capi/GEOSisValidDetailTest.cpp
index 20092baa5..cafa342f6 100644
--- a/tests/unit/capi/GEOSisValidDetailTest.cpp
+++ b/tests/unit/capi/GEOSisValidDetailTest.cpp
@@ -25,8 +25,6 @@ struct test_capiisvaliddetail_data : public capitest::utility {
test_capiisvaliddetail_data() : loc_(nullptr), reason_(nullptr)
void
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 5851d679b..11305e956 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -28,7 +28,6 @@ namespace capitest {
initGEOS(notice, notice);
wktw_ = GEOSWKTWriter_create();
GEOSWKTWriter_setRoundingPrecision(wktw_, 10);
std::feclearexcept(FE_ALL_EXCEPT);
diff --git a/tests/unit/coverage/CoverageRingEdgesTest.cpp b/tests/unit/coverage/CoverageRingEdgesTest.cpp
index 43c25140e..bf0fdc610 100644
--- a/tests/unit/coverage/CoverageRingEdgesTest.cpp
+++ b/tests/unit/coverage/CoverageRingEdgesTest.cpp
@@ -25,7 +25,6 @@ struct test_coverageringedges_data
WKTWriter w;
test_coverageringedges_data() {
- w.setTrim(true);
void
diff --git a/tests/unit/coverage/CoverageSimplifierTest.cpp b/tests/unit/coverage/CoverageSimplifierTest.cpp
index 04bd69c33..61e79f54e 100644
--- a/tests/unit/coverage/CoverageSimplifierTest.cpp
+++ b/tests/unit/coverage/CoverageSimplifierTest.cpp
@@ -22,7 +22,6 @@ struct test_coveragesimplifier_data {
std::vector<std::unique_ptr<Geometry>> geomArray;
test_coveragesimplifier_data() {
- w.setTrim(true);
void checkNoop(
diff --git a/tests/unit/coverage/TPVWSimplifierTest.cpp b/tests/unit/coverage/TPVWSimplifierTest.cpp
index dbd2569ee..3c1143a6c 100644
--- a/tests/unit/coverage/TPVWSimplifierTest.cpp
+++ b/tests/unit/coverage/TPVWSimplifierTest.cpp
@@ -21,7 +21,6 @@ struct test_tpvwsimplifier_data {
WKTWriter w;
test_tpvwsimplifier_data() {
- w.setTrim(true);
void
diff --git a/tests/unit/geom/Geometry/normalizeTest.cpp b/tests/unit/geom/Geometry/normalizeTest.cpp
index cfe33c01f..9ad06928a 100644
--- a/tests/unit/geom/Geometry/normalizeTest.cpp
+++ b/tests/unit/geom/Geometry/normalizeTest.cpp
@@ -27,7 +27,6 @@ struct test_geometry_normalize_data {
test_geometry_normalize_data()
: reader(), writer()
- writer.setTrim(true);
void
diff --git a/tests/unit/geom/Geometry/toTextTest.cpp b/tests/unit/geom/Geometry/toTextTest.cpp
new file mode 100644
index 000000000..f1fd0c603
--- /dev/null
+++ b/tests/unit/geom/Geometry/toTextTest.cpp
@@ -0,0 +1,60 @@
+// Test Suite for Geometry's toText() function
+// tut
+#include <tut/tut.hpp>
+// geos
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <memory>
+#include <string>
+namespace tut {
+// Test Group
+struct test_totext_data {
+ typedef std::unique_ptr<geos::geom::Geometry> GeomPtr;
+ geos::io::WKTReader reader;
+ test_totext_data()
+ : reader()
+typedef test_group<test_totext_data> group;
+typedef group::object object;
+group test_totext_data("geos::geom::Geometry::toText");
+// Test Cases
+// Input WKT is the same as output from toText()
+template<> template<> void object::test<1>
+ std::vector<std::string> variants{
+ "POINT (1 2)",
+ "POINT Z (1 2 3)",
+ "POINT M (1 2 4)",
+ "POINT ZM (1 2 3 4)",
+ "POINT EMPTY",
+ "POINT Z EMPTY",
+ "GEOMETRYCOLLECTION EMPTY",
+ for (const auto& wkt : variants) {
+ GeomPtr g1(reader.read(wkt));
+ ensure_equals(g1->toText(), wkt);
+} // namespace tut
diff --git a/tests/unit/geom/util/GeometryFixerTest.cpp b/tests/unit/geom/util/GeometryFixerTest.cpp
index 1cececb8b..bc10f61d6 100644
--- a/tests/unit/geom/util/GeometryFixerTest.cpp
+++ b/tests/unit/geom/util/GeometryFixerTest.cpp
@@ -36,8 +36,6 @@ struct test_geometryfixer_data {
test_geometryfixer_data()
- wktwriter_.setTrim(true);
- wktwriter_.setOutputDimension(3);
void checkFix(const std::string& wkt, const std::string& wktExpected) {
diff --git a/tests/unit/io/GeoJSONFeatureTest.cpp b/tests/unit/io/GeoJSONFeatureTest.cpp
index 06f2f3820..0f9b4a8d9 100644
--- a/tests/unit/io/GeoJSONFeatureTest.cpp
+++ b/tests/unit/io/GeoJSONFeatureTest.cpp
@@ -51,12 +51,12 @@ void object::test<1>
{"id", geos::io::GeoJSONValue(1.0) },
{"name", geos::io::GeoJSONValue(std::string{"One"}) },
- ensure_equals(feature.getGeometry()->toText(), "POINT (-117.000 33.000)");
+ ensure_equals(feature.getGeometry()->toText(), "POINT (-117 33)");
ensure_equals(feature.getProperties().at("id").getNumber(), 1.0);
ensure_equals(feature.getProperties().at("name").getString(), "One");
const geos::io::GeoJSONFeature feature2 = feature;
- ensure_equals(feature2.getGeometry()->toText(), "POINT (-117.000 33.000)");
+ ensure_equals(feature2.getGeometry()->toText(), "POINT (-117 33)");
ensure_equals(feature2.getProperties().at("id").getNumber(), 1.0);
ensure_equals(feature2.getProperties().at("name").getString(), "One");
@@ -78,10 +78,10 @@ void object::test<2>
ensure_equals(static_cast<size_t>(2), features.getFeatures().size());
- ensure_equals(features.getFeatures()[0].getGeometry()->toText(), "POINT (-117.000 33.000)");
+ ensure_equals(features.getFeatures()[0].getGeometry()->toText(), "POINT (-117 33)");
ensure_equals(features.getFeatures()[0].getProperties().at("id").getNumber(), 1.0);
ensure_equals(features.getFeatures()[0].getProperties().at("name").getString(), "One");
- ensure_equals(features.getFeatures()[1].getGeometry()->toText(), "POINT (-127.000 53.000)");
+ ensure_equals(features.getFeatures()[1].getGeometry()->toText(), "POINT (-127 53)");
ensure_equals(features.getFeatures()[1].getProperties().at("id").getNumber(), 2.0);
ensure_equals(features.getFeatures()[1].getProperties().at("name").getString(), "Two");
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index 0f43b9e5b..3f36218d4 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -52,7 +52,7 @@ void object::test<1>
std::string geojson { "{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}" };
GeomPtr geom(geojsonreader.read(geojson));
- ensure_equals(geom->toText(), "POINT (-117.000 33.000)");
+ ensure_equals(geom->toText(), "POINT (-117 33)");
ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 2u);
@@ -64,7 +64,7 @@ void object::test<2>
std::string geojson { "{\"type\":\"LineString\",\"coordinates\":[[102.0,0.0],[103.0,1.0],[104.0,0.0],[105.0,1.0]]}" };
- ensure_equals(geom->toText(), "LINESTRING (102.000 0.000, 103.000 1.000, 104.000 0.000, 105.000 1.000)");
+ ensure_equals(geom->toText(), "LINESTRING (102 0, 103 1, 104 0, 105 1)");
@@ -76,7 +76,7 @@ void object::test<3>
std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[[30,10],[40,40],[20,40],[10,20],[30,10]]]}" };
- ensure_equals(geom->toText(), "POLYGON ((30.000 10.000, 40.000 40.000, 20.000 40.000, 10.000 20.000, 30.000 10.000))");
+ ensure_equals(geom->toText(), "POLYGON ((30 10, 40 40, 20 40, 10 20, 30 10))");
@@ -88,7 +88,7 @@ void object::test<4>
std::string geojson { "{\"type\":\"Polygon\",\"coordinates\":[[[35,10],[45,45],[15,40],[10,20],[35,10]],[[20,30],[35,35],[30,20],[20,30]]]}" };
- ensure_equals(geom->toText(), "POLYGON ((35.000 10.000, 45.000 45.000, 15.000 40.000, 10.000 20.000, 35.000 10.000), (20.000 30.000, 35.000 35.000, 30.000 20.000, 20.000 30.000))");
+ ensure_equals(geom->toText(), "POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))");
@@ -100,7 +100,7 @@ void object::test<5>
std::string geojson { "{\"type\":\"MultiPoint\",\"coordinates\":[[10, 40], [40, 30], [20, 20], [30, 10]]}" };
- ensure_equals(geom->toText(), "MULTIPOINT ((10.000 40.000), (40.000 30.000), (20.000 20.000), (30.000 10.000))");
+ ensure_equals(geom->toText(), "MULTIPOINT ((10 40), (40 30), (20 20), (30 10))");
@@ -112,7 +112,7 @@ void object::test<6>
std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[[[10, 10], [20, 20], [10, 40]],[[40, 40], [30, 30], [40, 20], [30, 10]]]}" };
- ensure_equals(geom->toText(), "MULTILINESTRING ((10.000 10.000, 20.000 20.000, 10.000 40.000), (40.000 40.000, 30.000 30.000, 40.000 20.000, 30.000 10.000))");
+ ensure_equals(geom->toText(), "MULTILINESTRING ((10 10, 20 20, 10 40), (40 40, 30 30, 40 20, 30 10))");
@@ -124,7 +124,7 @@ void object::test<7>
std::string geojson { "{\"type\": \"MultiPolygon\", \"coordinates\": [[[[40, 40], [20, 45], [45, 30], [40, 40]]], [[[20, 35], [10, 30], [10, 10], [30, 5], [45, 20], [20, 35]], [[30, 20], [20, 15], [20, 25], [30, 20]]]]}" };
- ensure_equals(geom->toText(), "MULTIPOLYGON (((40.000 40.000, 20.000 45.000, 45.000 30.000, 40.000 40.000)), ((20.000 35.000, 10.000 30.000, 10.000 10.000, 30.000 5.000, 45.000 20.000, 20.000 35.000), (30.000 20.000, 20.000 15.000, 20.000 25.000, 30.000 20.000)))");
+ ensure_equals(geom->toText(), "MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))");
@@ -136,7 +136,7 @@ void object::test<8>
std::string geojson { "{\"type\": \"GeometryCollection\",\"geometries\": [{\"type\": \"Point\",\"coordinates\": [40, 10]},{\"type\": \"LineString\",\"coordinates\": [[10, 10], [20, 20], [10, 40]]},{\"type\": \"Polygon\",\"coordinates\": [[[40, 40], [20, 45], [45, 30], [40, 40]]]}]}" };
- ensure_equals(geom->toText(), "GEOMETRYCOLLECTION (POINT (40.000 10.000), LINESTRING (10.000 10.000, 20.000 20.000, 10.000 40.000), POLYGON ((40.000 40.000, 20.000 45.000, 45.000 30.000, 40.000 40.000)))");
+ ensure_equals(geom->toText(), "GEOMETRYCOLLECTION (POINT (40 10), LINESTRING (10 10, 20 20, 10 40), POLYGON ((40 40, 20 45, 45 30, 40 40)))");
@@ -148,7 +148,7 @@ void object::test<9>
std::string geojson { "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}}" };
@@ -160,7 +160,7 @@ void object::test<10>
std::string geojson { "{\"type\":\"FeatureCollection\",\"features\":[{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}},{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-122.0,45.0]}}]}" };
- ensure_equals(geom->toText(), "GEOMETRYCOLLECTION (POINT (-117.000 33.000), POINT (-122.000 45.000))");
+ ensure_equals(geom->toText(), "GEOMETRYCOLLECTION (POINT (-117 33), POINT (-122 45))");
@@ -258,7 +258,7 @@ void object::test<18>
geos::io::GeoJSONFeatureCollection features(geojsonreader.readFeatures(geojson));
ensure_equals(features.getFeatures().size(), static_cast<size_t>(1));
ensure_equals(static_cast<size_t>(features.getFeatures()[0].getGeometry()->getCoordinateDimension()), 2u);
ensure_equals(features.getFeatures()[0].getProperties().at("name").getString(), "one");
ensure_equals(features.getFeatures()[0].getProperties().at("required").getBoolean(), true);
@@ -274,7 +274,7 @@ void object::test<19>
std::vector<geos::io::GeoJSONValue> values = features.getFeatures()[0].getProperties().at("items").getArray();
@@ -299,9 +299,9 @@ void object::test<20>
ensure_equals(features.getFeatures().size(), static_cast<size_t>(3));
- ensure_equals(features.getFeatures()[0].getGeometry()->toText(), "POLYGON ((87.890 64.923, 76.992 55.178, 102.656 46.558, 115.312 60.413, 94.570 58.447, 87.890 64.923))");
+ ensure_equals(features.getFeatures()[0].getGeometry()->toText(), "POLYGON ((87.89 64.923, 76.992 55.178, 102.656 46.558, 115.312 60.413, 94.57 58.447, 87.89 64.923))");
- ensure_equals(features.getFeatures()[1].getGeometry()->toText(), "LINESTRING (1.406 48.690, 41.835 34.016, 22.500 13.923)");
+ ensure_equals(features.getFeatures()[1].getGeometry()->toText(), "LINESTRING (1.406 48.69, 41.835 34.016, 22.5 13.923)");
ensure_equals(features.getFeatures()[2].getGeometry()->toText(), "POINT (-28.125 39.095)");
ensure_equals(features.getFeatures()[2].getProperties().at("id").getNumber(), 3.0);
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index 9374b81fd..09909f6bf 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -36,7 +36,6 @@ struct test_lengthindexedline_data {
test_lengthindexedline_data()
diff --git a/tests/unit/noding/snapround/SnapRoundingNoderTest.cpp b/tests/unit/noding/snapround/SnapRoundingNoderTest.cpp
index d19692dbf..fbd5e5564 100644
--- a/tests/unit/noding/snapround/SnapRoundingNoderTest.cpp
+++ b/tests/unit/noding/snapround/SnapRoundingNoderTest.cpp
@@ -53,7 +53,6 @@ struct test_snaproundingnoder_data {
std::unique_ptr<Geometry> expected = r.read(expected_wkt);
- // w.setOutputDimension(4);
// std::cout << std::endl << "result" << std::endl;
// std::cout << std::endl << w.write(result.get()) << std::endl;
// std::cout << std::endl << "expected" << std::endl;
diff --git a/tests/unit/operation/geounion/UnaryUnionOpTest.cpp b/tests/unit/operation/geounion/UnaryUnionOpTest.cpp
index 7cccff20f..780907382 100644
--- a/tests/unit/operation/geounion/UnaryUnionOpTest.cpp
+++ b/tests/unit/operation/geounion/UnaryUnionOpTest.cpp
@@ -37,7 +37,6 @@ struct test_unaryuniontest_data {
: gf(GeometryFactory::create()),
wktreader(gf.get())
- wktwriter.setTrim(true);
void
diff --git a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
index 8e126fcb9..568eb2a42 100644
--- a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
+++ b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
@@ -35,7 +35,6 @@ struct test_rectangleintersectiontest_data {
test_rectangleintersectiontest_data()
: wktreader()
// wktwriter.setRoundingPrecision(30);
diff --git a/tests/unit/operation/linemerge/LineMergerTest.cpp b/tests/unit/operation/linemerge/LineMergerTest.cpp
index 6864776d1..1fea1cd7b 100644
--- a/tests/unit/operation/linemerge/LineMergerTest.cpp
+++ b/tests/unit/operation/linemerge/LineMergerTest.cpp
@@ -40,7 +40,6 @@ struct test_linemerger_data {
test_linemerger_data()
: wktreader(), wktwriter()
~test_linemerger_data()
diff --git a/tests/unit/operation/linemerge/LineSequencerTest.cpp b/tests/unit/operation/linemerge/LineSequencerTest.cpp
index 2b9bd95bc..fc7415d26 100644
--- a/tests/unit/operation/linemerge/LineSequencerTest.cpp
+++ b/tests/unit/operation/linemerge/LineSequencerTest.cpp
@@ -39,7 +39,6 @@ struct test_linesequencer_data {
test_linesequencer_data()
~test_linesequencer_data()
diff --git a/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp b/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
index 6fb28d953..aec919b20 100644
--- a/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
+++ b/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
@@ -36,7 +36,6 @@ struct test_coverageunionng_data {
try {
ensure_equals_geometry_xyzm(result.get(), expected.get());
} catch (const std::exception& e) {
- w.setOutputDimension(4);
std::string wkt_result = w.write(result.get());
std::cerr << std::endl << wkt_result << std::endl;
throw;
diff --git a/tests/unit/operation/overlayng/ElevationModelTest.cpp b/tests/unit/operation/overlayng/ElevationModelTest.cpp
index e6626268b..0065fb439 100644
--- a/tests/unit/operation/overlayng/ElevationModelTest.cpp
+++ b/tests/unit/operation/overlayng/ElevationModelTest.cpp
@@ -37,8 +37,6 @@ struct test_overlayng_elevationmodel_data {
test_overlayng_elevationmodel_data()
- w.setTrim(true);
void checkElevation(const std::string& wkt1, const std::string& wkt2, std::initializer_list<double> ords)
diff --git a/tests/unit/operation/overlayng/OverlayNGZTest.cpp b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
index fd8247d04..9769a7be0 100644
--- a/tests/unit/operation/overlayng/OverlayNGZTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
@@ -36,8 +36,6 @@ struct test_overlayngz_data {
test_overlayngz_data()
- w.setTrim(true);
void checkOverlay(int opCode, const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
diff --git a/tests/unit/operation/polygonize/PolygonizeTest.cpp b/tests/unit/operation/polygonize/PolygonizeTest.cpp
index ea9c8c566..0a1a9e40e 100644
--- a/tests/unit/operation/polygonize/PolygonizeTest.cpp
+++ b/tests/unit/operation/polygonize/PolygonizeTest.cpp
@@ -47,7 +47,6 @@ struct test_polygonizetest_data {
test_polygonizetest_data()
: wktreader()
template <class T>
diff --git a/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp b/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
index d82bc0799..58d9ef046 100644
--- a/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
+++ b/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
@@ -37,7 +37,6 @@ struct test_shpathop_data {
test_shpathop_data()
private:
diff --git a/tests/unit/operation/valid/RepeatedPointRemoverTest.cpp b/tests/unit/operation/valid/RepeatedPointRemoverTest.cpp
index d6f75c4e9..205eefcc9 100644
--- a/tests/unit/operation/valid/RepeatedPointRemoverTest.cpp
+++ b/tests/unit/operation/valid/RepeatedPointRemoverTest.cpp
@@ -41,7 +41,6 @@ struct test_repeated_point_remover_test_data
std::string
wkt(const Geometry& geom)
return writer.write(&geom);
diff --git a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
index 3342f3417..b36ad12a3 100644
--- a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
+++ b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
@@ -33,7 +33,6 @@ struct test_tpsimp_data {
, wktreader(gf.get())
, wktwriter()
- //wktwriter.setTrim(1);
diff --git a/tests/unit/triangulate/VoronoiTest.cpp b/tests/unit/triangulate/VoronoiTest.cpp
index b5ce4104e..922060295 100644
--- a/tests/unit/triangulate/VoronoiTest.cpp
+++ b/tests/unit/triangulate/VoronoiTest.cpp
@@ -104,7 +104,6 @@ runVoronoi(const char* sitesWkt, const char* expectedWkt, const double tolerance
static_cast<std::size_t>(expected->getCoordinateDimension()));
bool eq = results->equalsExact(expected.get(), 1e-7);
if(! eq) {
std::cout << std::endl;
std::cout << " Expected: " << writer.write(expected.get()) << std::endl;
std::cout << " Obtained: " << writer.write(results.get()) << std::endl;
diff --git a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
index 66049d9b9..c6bd9ca1e 100644
--- a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
+++ b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
@@ -43,7 +43,6 @@ struct test_quadedgesub_data {
reader(),
writer()
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index 51c8a9bbf..fe6d7e9db 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -219,7 +219,6 @@ ensure_equals_geometry(T const* lhs_in, T const* rhs_in, double tolerance = 0.0)
if(! (areCoordsEqual && areaNumPointsEqual)) {
WKTWriter writer;
<< writer.write(*rhs) << std::endl
<< writer.write(*lhs) << std::endl;
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index bad3bb40d..45aefbc66 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -557,13 +557,9 @@ void GeosOp::outputGeometry(const Geometry * geom) {
else {
// output as text/WKT
WKTWriter writer;
- writer.setOutputDimension(4);
if (args.precision >= 0) {
- writer.setRoundingPrecision(args.precision);
- else {
- // turn off stoopid fixed precision
+ writer.setRoundingPrecision(args.precision);
std::cout << writer.write(geom) << std::endl;
diff --git a/web/content/specifications/geojson.md b/web/content/specifications/geojson.md
index fb3cee7de..a1b58a4cb 100644
--- a/web/content/specifications/geojson.md
+++ b/web/content/specifications/geojson.md
@@ -70,7 +70,7 @@ void main(void)
// Prepare WKT writer
WKTWriter writer;
+ writer.setTrim(true); // Only needed before GEOS 3.12
writer.setRoundingPrecision(2);
// Print out the features
diff --git a/web/content/specifications/wkt.md b/web/content/specifications/wkt.md
index 7eb49f334..6956d327e 100644
--- a/web/content/specifications/wkt.md
+++ b/web/content/specifications/wkt.md
@@ -107,10 +107,10 @@ const char* linestring = "LINESTRING(0 0 1, 1 1 1, 2 1 2)";
GEOSWKTReader* reader = GEOSWKTReader_create();
GEOSGeom* geom = GEOSWKTReader_read(reader, linestring);
-/* Get a WKT writer*/
+/* Get a WKT writer */
GEOSWKTWriter* writer = GEOSWKTWriter_create();
-/* Preserve the Z dimension. */
+/* Preserve the Z dimension -- only needed before GEOS 3.12 */
GEOSWKTWriter_setOutputDimension(writer, 3);
/* Sets the number places after the decimal to output in WKT. Default 16. */
@@ -121,6 +121,7 @@ GEOSWKTWriter_setRoundingPrecision(writer, 4);
+ * This is generally only needed before GEOS 3.12.
GEOSWKTWriter_setTrim(writer, 1);
diff --git a/web/content/usage/c_api.md b/web/content/usage/c_api.md
index 2e9d31aec..e6012f878 100644
--- a/web/content/usage/c_api.md
+++ b/web/content/usage/c_api.md
@@ -291,7 +291,7 @@ GEOSGeometry* geom = GEOSWKTReader_read(reader, wkt_in);
/* Convert geometry back to WKT */
-/* Trim trailing zeros off output */
+/* Trim trailing zeros off output; only needed before GEOS 3.12 */
char* wkt_out = GEOSWKTWriter_write(writer, geom);
diff --git a/web/content/usage/cpp_api.md b/web/content/usage/cpp_api.md
index 155c7a49b..9bb56839a 100644
--- a/web/content/usage/cpp_api.md
+++ b/web/content/usage/cpp_api.md
@@ -79,7 +79,7 @@ int main()
/* Convert Geometry to WKT */
WKTWriter writer;
+ writer.setTrim(true); /* Only needed before GEOS 3.12 */
std::string inter_wkt = writer.write(inter.get());
/* Print out results */
Summary of changes:
NEWS.md | 1 +
capi/geos_c.h.in | 9 +-
capi/geos_ts_c.cpp | 6 +-
include/geos/io/WKTWriter.h | 11 ++-
src/geom/Geometry.cpp | 3 +
src/io/WKTWriter.cpp | 4 +-
src/operation/buffer/BufferBuilder.cpp | 1 -
src/operation/overlayng/OverlayNG.cpp | 2 -
tests/unit/capi/GEOSBufferTest.cpp | 1 -
tests/unit/capi/GEOSBuildAreaTest.cpp | 2 -
tests/unit/capi/GEOSClipByRectTest.cpp | 1 -
.../GEOSConstrainedDelaunayTriangulationTest.cpp | 1 -
tests/unit/capi/GEOSDelaunayTriangulationTest.cpp | 1 -
tests/unit/capi/GEOSDistanceTest.cpp | 1 -
tests/unit/capi/GEOSFrechetDistanceTest.cpp | 1 -
tests/unit/capi/GEOSGeomToWKBTest.cpp | 1 -
tests/unit/capi/GEOSGeomToWKTTest.cpp | 32 +++---
tests/unit/capi/GEOSGetCentroidTest.cpp | 1 -
tests/unit/capi/GEOSHausdorffDistanceTest.cpp | 1 -
tests/unit/capi/GEOSIntersectionPrecTest.cpp | 2 -
tests/unit/capi/GEOSIntersectionTest.cpp | 2 -
tests/unit/capi/GEOSMakeValidTest.cpp | 2 -
tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp | 1 -
tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp | 1 -
.../unit/capi/GEOSMinimumRotatedRectangleTest.cpp | 1 -
tests/unit/capi/GEOSMinimumWidthTest.cpp | 1 -
tests/unit/capi/GEOSNodeTest.cpp | 4 -
tests/unit/capi/GEOSOffsetCurveTest.cpp | 1 -
tests/unit/capi/GEOSPointOnSurfaceTest.cpp | 1 -
tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp | 2 -
tests/unit/capi/GEOSSharedPathsTest.cpp | 1 -
tests/unit/capi/GEOSSnapTest.cpp | 1 -
tests/unit/capi/GEOSUnaryUnionPrecTest.cpp | 2 -
tests/unit/capi/GEOSUnaryUnionTest.cpp | 2 -
tests/unit/capi/GEOSVoronoiDiagramTest.cpp | 1 -
tests/unit/capi/GEOSWKTWriterTest.cpp | 109 +++++++++++++++++++--
tests/unit/capi/GEOSisValidDetailTest.cpp | 2 -
tests/unit/capi/capi_test_utils.h | 1 -
tests/unit/coverage/CoverageRingEdgesTest.cpp | 1 -
tests/unit/coverage/CoverageSimplifierTest.cpp | 1 -
tests/unit/coverage/TPVWSimplifierTest.cpp | 1 -
tests/unit/geom/Geometry/normalizeTest.cpp | 1 -
tests/unit/geom/Geometry/toTextTest.cpp | 60 ++++++++++++
tests/unit/geom/util/GeometryFixerTest.cpp | 2 -
tests/unit/io/GeoJSONFeatureTest.cpp | 8 +-
tests/unit/io/GeoJSONReaderTest.cpp | 28 +++---
tests/unit/linearref/LengthIndexedLineTest.cpp | 1 -
.../noding/snapround/SnapRoundingNoderTest.cpp | 1 -
tests/unit/operation/geounion/UnaryUnionOpTest.cpp | 1 -
.../intersection/RectangleIntersectionTest.cpp | 1 -
tests/unit/operation/linemerge/LineMergerTest.cpp | 1 -
.../unit/operation/linemerge/LineSequencerTest.cpp | 1 -
.../operation/overlayng/CoverageUnionNGTest.cpp | 1 -
.../operation/overlayng/ElevationModelTest.cpp | 2 -
tests/unit/operation/overlayng/OverlayNGZTest.cpp | 2 -
tests/unit/operation/polygonize/PolygonizeTest.cpp | 1 -
.../operation/sharedpaths/SharedPathsOpTest.cpp | 1 -
.../operation/valid/RepeatedPointRemoverTest.cpp | 1 -
.../simplify/TopologyPreservingSimplifierTest.cpp | 1 -
tests/unit/triangulate/VoronoiTest.cpp | 1 -
.../quadedge/QuadEdgeSubdivisionTest.cpp | 1 -
tests/unit/utility.h | 1 -
util/geosop/GeosOp.cpp | 8 +-
web/content/specifications/geojson.md | 2 +-
web/content/specifications/wkt.md | 5 +-
web/content/usage/c_api.md | 2 +-
web/content/usage/cpp_api.md | 2 +-
67 files changed, 227 insertions(+), 129 deletions(-)
create mode 100644 tests/unit/geom/Geometry/toTextTest.cpp
hooks/post-receive
More information about the geos-commits
