[geos-commits] [SCM] GEOS branch 3.10 updated. eca8bc67e7767b30610b357f10a4fcd96480e655
git at osgeo.org
git at osgeo.org
Tue Jun 27 08:30:49 PDT 2023
the project "GEOS".
The branch, 3.10 has been updated
via eca8bc67e7767b30610b357f10a4fcd96480e655 (commit)
from aad507317fee68dbd85ae1c0c4f632a603ae67b8 (commit)
revisions in full, below.
commit eca8bc67e7767b30610b357f10a4fcd96480e655
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Jun 19 14:56:42 2023 -0700
Catch Mixed-Dimension case and handle (#926)
Catch mixed-dim exception and dump to old overlay code, add test for old mixed-dim behaviour
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index c5cbbff01..62064b497 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -424,6 +424,13 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
catch(const geos::util::TopologyException& ex) {
::geos::ignore_unused_variable_warning(ex);
+#if GEOS_DEBUG_HEURISTICOVERLAY
+ std::cerr << "OverlayNGRobust: " << ex.what() << std::endl;
+#endif
+ catch(const geos::util::IllegalArgumentException& ex) {
+ ::geos::ignore_unused_variable_warning(ex);
#endif
diff --git a/tests/unit/geom/Geometry/differenceTest.cpp b/tests/unit/geom/Geometry/differenceTest.cpp
index 51a834c82..0aee2f0bd 100644
--- a/tests/unit/geom/Geometry/differenceTest.cpp
+++ b/tests/unit/geom/Geometry/differenceTest.cpp
@@ -57,4 +57,25 @@ void object::test<1>
+// https://github.com/libgeos/geos/issues/924
+template<>
+template<>
+void object::test<2>
+ std::string wkt1("GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)), LINESTRING(20 20, 30 30))");
+ std::unique_ptr<geos::geom::Geometry> g1(wktreader.read(wkt1));
+ std::string wkt2("GEOMETRYCOLLECTION(POLYGON((9 9, 21 9, 21 21, 9 21, 9 9)), POINT(5 5))");
+ std::unique_ptr<geos::geom::Geometry> g2(wktreader.read(wkt2));
+ auto result = g1->difference(g2.get());
+ result->normalize();
+ std::string wktExpected("GEOMETRYCOLLECTION (LINESTRING (21 21, 30 30), POLYGON ((10 0, 0 0, 0 10, 9 10, 9 9, 10 9, 10 0)))");
+ std::unique_ptr<geos::geom::Geometry> expected(wktreader.read(wktExpected));
+ ensure_equals_geometry(expected.get(), result.get());
} // namespace tut
Summary of changes:
src/geom/HeuristicOverlay.cpp | 7 +++++++
tests/unit/geom/Geometry/differenceTest.cpp | 21 +++++++++++++++++++++
2 files changed, 28 insertions(+)
hooks/post-receive
More information about the geos-commits
